syberia
válasz syberia #16945 üzenetére
https://howbad.info/
syberia
válasz syberia #17370 üzenetére
FDA-approved drug Ivermectin inhibits replication of SARS-CoV-2
Nagyon kíváncsi vagyok-laikusként-hogy milyen eredményeket hozhat, ennek a jó ideje létező gyógyszernek a klinikai tesztelése.
syberia
It is an antibiotic which acts against a wide range of both Gram positive and Gram negative bacteria (in contrast to penicillin, which only acts against Gram-positive bacteria). It inhibits protein synthesis in the bacterium, binding to the rRNA in the ribosome, distorting the ribosomal decoding site and inhibiting binding of tRNA.
syberia
syberia
Az ivermektin egyre nagyobb figyelmet kap az orvosok körében, eddig biztató eredményeket értek el, sok COVID-19 betegen tudtak segíteni. Most még kísérleti jelleggel vetik be több kórházban, és még heteket kell várni, a szélesebb körű alkalmazhatóságot alátámasztó (vagy cáfoló) eredményekre.
"Although the coronavirus is not a parasite, experts suggest that ivermectin basically treats it like one, blocking the viral RNA — ribonucleic acid — from invading healthy cells and giving the immune system more time to fight off the illness."
"Another study conducted by researchers at the University of Utah found that “critically ill patients with lung injury requiring mechanical ventilation may benefit from administration of ivermectin,”
“We noted a lower mortality and reduced health care resource use in those treated with ivermectin,” wrote lead author Dr. Amit Patel.
And at Broward Health Medical Center in Florida, Dr. Jean-Jacques Rajter has already been using ivermectin in addition to hydroxychloroquine, azithromycin and zinc sulfate to treat his COVID-19 patients"“If we get to these people early, and what I mean by that is if their oxygen requirements are less than 50 percent, I’ve had nearly a 100 percent response rate, they all improve, if they’re on more oxygen than that, then it becomes a little more varied, some people, they don’t respond anymore because they are too far advanced,” Rajter told the outlet."
“More studies need to be conducted. We haven’t had any ill effects from it and it’s readily available, we have some patients who are pretty advanced, not yet intubated, and even those, in 12 hours, they showed a significant improvement.”
syberia
syberia
válasz CptAdamica #18072 üzenetére
Én csak azt szeretném kérdezni, ki írja neki a szöveget?
syberia
syberia
válasz Ringman #18777 üzenetére
Az új számítási módszer 42 százalékkal emelte a koronavírusos halottak számát Spanyolországban
Nálunk ez a veszély nem fenyeget, mert nem szabad rontani a fatörzs számait.
syberia
Coronavirus stats across Africa: 18,400+ cases, 966 deaths, 4,344 recoveries
Önmagában nem különleges adatok, már jó ideje terjed Afrikában a koronavírus. Ami számomra érdekesnek tűnik, az a folyami vakság elleni gyógyszerek hatékonysága. Az ominózus betegség ellen az ivermektint vetették be széles körben, és nagyon hatékonynak bizonyult a parazita ellen, komolyabb mellékhatásokról nem találtam feljegyzést. A programban résztvevő országokban alacsonyabb a COVID-19 esetszám, persze kérdéses a pontosság (mint itthon).
(#19196) bazger: Valóban annak tűnik, a fent említett folyami vakság ellen is hatékonynak bizonyult, és más paraziták ellen is bevethető hatóanyag.
syberia
syberia
syberia
válasz konzumpro #20296 üzenetére
Egyetértek, ő ebben a történetben egy "félretájékoztatási stróman". Persze ez nem menti fel a felelősség súlya alól, kétlem hogy kényszerből vállalta el ezt a szerepet.
(#20298): Szándékos züllesztették azzá, a saját szavazóikat is lenézik. Amúgy tisztában vannak-nagyságrendileg-a járvány méretével, nem véletlenül gáncsolják a szélesebb körű tesztelését a lakosságnak.
syberia
syberia
válasz t72killer #20869 üzenetére
Más betegségeknél is jobban állnak a nők, a gyengébbik nem valójában a férfiak.
(#20850): Az elmúlt évek halálozási statisztikájából kiindulva, nagyságrendileg meghatározható az új vírus okozta többlet. Ahol pedig lelkiismeretesen tesztelnek szinte minden elérhető korona-gyanús egyént-például a németeknél-ott a hivatalos számok is a valóság közelében járnak szvsz. .
syberia
Eddig 21 kórházi dolgozó kapta el a koronavírust a tatabányai kórházban
"Az országban mintegy 100(!) egészségügyi dolgozó vesztette életét a járvány miatt."
(#21816) Narxis: Nemzetközi példákból kiindulva, alacsonyabb kéne legyen nálunk a nők aránya. Sajnos az itthoni hivatalos COVID-19 statisztikáknak nem lehet hinni.
syberia
válasz fatal` #21849 üzenetére
Érdekes hogy nem említik azt a több mint 100 millió embert, akiket ezzel a gyógyszerrel tettek védetté a folyami vakságot okozó parazitával szemben:
The African Programme for Onchocerciasis Control (APOC) was launched in 1995 with the objective of controlling onchocerciasis in the remaining endemic countries in Africa and closed at the end of 2015 after beginning the transition to onchocerciasis elimination. Its main strategy has been the establishment of sustainable community-directed treatment with ivermectin (CDTI) and vector control with environmentally-safe methods where appropriate. In APOC’s final year, more than 119 million people were treated with ivermectin, and many countries had greatly decreased the morbidity associated with onchocerciasis.
[link](#21851): Pontosan. Orvosi felügyelet nélkül, nem szabad semmilyen szernek két pofával nekiesni. A tanulmány szerint befigyelhetnek mellékhatások, koszorúér-betegségben szenvedőknek ellenjavallt lehet.
syberia
Sajnos én is így látom, de ne legyen igazunk!
(#22702): Ebből az USA sem akar kimaradni. A világ legnagyobb emberkísérlete van készülőben? Az oltások fejlesztése nem véletlenül húzódik néha évekig, alsó hangon 1 évig. Persze valahol érthető India szándéka, ha náluk úgy berobbanna,mint ahogy Észak-Olaszországban láttuk, az százezres (ha nem milliós) nagyságrendű halálozással járhatna.
syberia
syberia
válasz FrezeR #22780 üzenetére
A gödény is professzorokra hivatkozott, amikor előadta a meséjét az ártatlan vírusról, ez a jóember sem számít egészségügyi szaktekintélynek:
Isaac Ben-Israel, who is not a medical expert... Kínában már rég megbukott ez a fantazmagória, és ott van a vírus radikálisabb mutációjának az eshetősége is.
syberia
Az államtitkár szerint már vannak betegek Kiskunhalason.
#laposgörbe
syberia
syberia
válasz Paxker315 #23944 üzenetére
Hát igen, de nekik van egészségügyi miniszterük! (Amíg ki nem rúgta borsika, mert az embereket egymás közti távolságtartása kötelezte volna)
As Brazil’s official death toll from the coronavirus surpassed China’s, where the virus first emerged, President Jair Bolsonaro did little more than shrug.
“So what?” he said to reporters who asked him about the day’s record number of deaths on Tuesday night. “What do you want me to do?”
Nagy különbség, nálunk a politikusoktól verbálisan svájci minőségű ellátást kapnak a betegek, de valójában brazil szinten van tartva a magyar egészségügy.
(#24029): Tehát ha szénné égetem magam a napon, akkor túlélem? Persze nem a véletlen műve, miért az árnyékos napok vége felé jön a legtöbb nyavalya. A természetes napfénnyel lehet a legtöbb D vitamint elraktározni a szervezetünkben, az egyéb formában bevitt nem rúg labdába mellette szvsz.
syberia
Coronavirus vaccine update: How far is the developement? | COVID-19 Special
(#24280): Egyszerűbb betiltani a cuccost.
syberia
válasz syberia #24411 üzenetére
Magyar járványgrafikon. Mikor is lesz a tetőzés, holnapután?
(#24414): Az orvosok ott sem hisznek a hivatalos statisztikáknak:
“Why should doctors keep a list of their own? Very simple: they don’t trust statistics,” the MBKh Media news website quoted neurosurgeon Alexei Kashcheyev as saying Sunday.
“They know what [Covid-19] looks like, so they won’t believe what the ministries tell them. They’ll maintain the list themselves,” Kashcheyev was quoted as saying.
[link][ Szerkesztve ]
syberia
Valaki tud itt portugálul, vagy jó barátságban van a Google fordítójával?
Nagyon érdekel ennek a jóembernek a mondanivalója, ha zöldség akkor is.
syberia
syberia
(#25421): Ez kismiska a Balatonon várható tumultushoz képest. Hallgattam tegnap egy riportot a vendéglátás újranyitásával kapcsolatban. Amikor azt kezdte magyarázni, hogy a higiénia miatt erősebb mosogatószert szereztek be, kikapcsoltam a tv-t. Ugyan lesz maszk az éttermi személyzeten, de a vendégeknek nem teszik kötelezővé. Mi baj lehet?
syberia
válasz gergo5991 #25497 üzenetére
" 1-2 hónap és visszatér minden a régi kerékvágásba"
Erre térjünk vissza 1-2 hónap múlva.
(#25488): A 60 fokos meleget viszont nem szereti. Hajszárítóval lehet legalább ilyen hőmérsékletű levegőt produkálni? Maszk fertőtlenítés miatt érdekel a kérdés.
syberia
válasz fatal` #25863 üzenetére
Ez annak fényében különösen érdekes, hogy ezeket a dolgozókat Dél-Koreában letesztelték a budapesti utazásuk előtt, és a negatív eredményük után el voltak elkülönítve. Pesten pedig csak a szálláshelyükön és a munkahelyükön tartózkodhattak, mégis elkapták a koronát.
syberia
ELHUNYT SZAKSZON IMRE A TV2 SZABOLCS-SZATMÁR-BEREG MEGYEI KÜLSŐS OPERATŐRE
"Ma reggel 6:30-kor hívott, panaszkodott. Hideg volt a kórházi szobában. Egyedül van az egész Covid-szárnyon – mondta, majd 7:30-kor megint beszéltünk. Köhögött, fázott, hangjában félelem: még mindig nem jött senki…
8:30-kor már nem vette fel a telefont. A teszt végül negatív lett."
syberia
syberia
syberia
válasz andor80 #27026 üzenetére
Már nem elérhető a tartalom.
(#27008): Az interjúban szereplő orvosok, egy nagyon hatékonynak tűnő gyógyszer (ivermectin) adagolási protokollját taglalták. A remdesivir esetében messze nem voltak ilyen jó eredmények, mégis attól volt hangos a világsajtó hetekig.
Információk, statisztikák:
● koronavirus.gov.hu
● vakcinainfo.gov.hu
● vakcina kisokos
● minden fontos információ a vakcinákról
● dunántúli kórházi oltópontok
● EU vaccine tracker oldal
● pandemia.hu - megyei statisztikával
● gisanddata.maps.arcgis.com
● worldometers.info
● ncov2019.live
● atlo.team
● google mobility reports
● euro momo
● covid-19 projections
Egyéb hasznos tanácsok:
● bevásárlólista házi karanténhoz
● karanténnal kapcsolatos tudnivalók
● AZ oltás időpont módosítás
- A Lian Li kompakt AIO-k mellé szánt tornya újragondolta a szellőzés módszertanát
- OLED TV topic
- Egy kabaré volt az Edge 50 család belgrádi bemutatója
- Androidos tablet topic
- BestBuy topik
- Milyen routert?
- Parfüm topik
