S_x96x_S
Petykemano #9005 üzenetére
> Az elmúlt napokban az Intel elég sok fejlesztést bemutatott.
az Inteles 3D V-Cache -ra kiváncsi leszek ..
Intel Adopting 3D-Stacked Cache for CPUs, Challenging AMD's 3D V-Cache
https://www.tomshardware.com/news/intel-will-adopt-3d-stacked-cache-for-cpus-says-ceo-pat-gelsinger""
"We feel very good that we have advanced capabilities for next-generation memory architectures, advantages for 3D stacking, for both little die, as well as for very big packages for AI and high-performance servers as well. So we have a full breadth of those technologies. We'll be using those for our products, as well as presenting it to the Foundry (IFS) customers as well," Gelsinger concluded.
It's logical that Intel could adopt this sort of technology; the hybrid bonding technology behind 3D V-Cache isn't proprietary to AMD -- it's enabled by TSMC's SoIC packaging technology. Additionally, this sort of chip architecture has been on the long-term horizon for chip makers for several years.
Stacked cache has proven to be a strategic advantage for AMD, as it powers the company's Ryzen X3D CPUs, which are the fastest gaming processors in the world. It's also a strong value add for its X-series EPYC processors, like Genoa-X. Now it appears that Intel will also throw its hat into the ring with this tech, too.
S_x96x_S
"AMD Posts Ryzen AI Software Platform Preview for Developers"
https://www.tomshardware.com/news/amd-posts-ryzen-ai-software-platform-preview-for-developers"""
AMD's Ryzen AI for Windows is a hardware unit built into the company's Ryzen 7040-series APUs based on the Zen 4 microarchitecture. AMD's Vitis AI offers a robust toolset for AI inference, seamlessly integrating with popular frameworks like TensorFlow, PyTorch, and ONNX....
AMD’s Ryzen XDNA AI engine is an on-die accelerator designed for lower-intensity AI inference workloads, such as audio, photo, and video processing. It aims to deliver faster response times than online services and is more power-efficient than CPU or GPU-based solutions. The engine can handle up to 4 concurrent AI streams and processes INT8 and bfloat16 instructions. AMD claims this engine is faster than Apple's M2 processor’s neural engine.
S_x96x_S
Hot Chips 2023: AMD’s Phoenix SoC
https://chipsandcheese.com/2023/09/16/hot-chips-2023-amds-phoenix-soc/
S_x96x_S
lesz egy kis verseny ..( 300 Watton )
Intel Core i9-14900KF 6 GHz CPU Benchmarks Leak Out: Up To 20% Faster Than 7950X, 15% Faster Than 13900K
https://wccftech.com/intel-core-i9-14900kf-6-ghz-cpu-benchmarks-leak-up-to-20-percent-faster-7950x/ -
S_x96x_S
Petykemano #8993 üzenetére
> Az M2-höz N4-en gyártott és és most
> az A17-ben debütált N3B-n gyártott lapkák egyszálas CPU teljesítménye
> szinte alig növekedett.lehet, hogy kezdenek átállni tik-tok -ra ..
( a GPU-ba jobban belenyultak )"Apple's A17 Pro SoC maintained the company's renowned six-core configuration and packs two high-performance cores functioning at up to 3.77 GHz and four energy-efficient cores operating at a lower frequency. When compared to the A16 Bionic (made on TSMC's N4), the A17 Pro boosts the maximum clock-speed of performance cores by 8.95% (from 3.46 GHz), which is in line with what TSMC's N3 (3nm-class) process technology offers compared to its 5nm-class counterparts (+10% ~ +15% compared to N5, about 10% compared to N4)."
Single-Core
2914 A17 Pro ( up to 3.77 GHz )
2641 A16 Bionic
3223 Core i9-13900K
3172 AMD Ryzen 9 7950X ( up to 5.70 GHz )
2050 Snapdragon 8 Gen 2"When Apple formally introduced its A17 Pro system-on-chip (SoC) earlier this week, it said that its high-performance cores deliver a 10% increase in single-thread workloads compared to its predecessor. Apparently, this was an accurate estimate and the new processor delivers single-thread performance that is competitive with some PC processors while working at a considerably lower frequency. Meanwhile, it looks like Apple has made little to no architectural changes to its A17 Pro CPU cores and only boosted clocks."
via:
Apple's A17 Pro Within 10% of Intel's i9-13900K, AMD's 7950X in Single-Core Performance
https://www.tomshardware.com/news/apples-a17-pro-challenges-core-i9-13900k-ryzen-7950x-in-single-core-performance -
S_x96x_S
Az új linux kernel optimalizációknak pár programnál eléggé látható hatása lesz a szervereknél (zen4 - bergamo)- hogyha nagy a magszám ...
"lower core count desktop systems " -nél nem annyira látható ..Linux 6.6 Delivers Some Impressive Gains For AMD EPYC 9754 "Bergamo" Server Performance
https://www.phoronix.com/review/linux-66-bergamo"Needless to say, I am very excited about the Linux 6.6 prospects after this round of testing on the AMD EPYC 9754 "Bergamo". As mentioned on lower core count desktop systems I haven't seen such dramatic gains, so presumably much of this work is in regards to large gains from scheduler enhancements. The workqueue optimizations benefiting multiple L3 caches like with modern AMD CPUs may also be a contributing factor. I'll be running more Linux 6.6 kernel benchmarks on AMD EPYC Genoa(X) and other platforms like Intel Xeon Max in exploring the Linux 6.6 performance. Exciting times ahead with all of the new Linux 6.6 features."
S_x96x_S
Petykemano #8989 üzenetére
> Arról szól a hír, hogy most találtak valami szoftveres megoldást,
> hogy az adatlokalitás optimalizálásával csökkentsék a késleltetést?csak egy még finomabb a hardveret jobban figyelembe vevő
szoftveres optimalizáció. -
S_x96x_S
többszörös ( chipletes ) L3 cache támogatás Linuxban
("multiple L3 caches like modern AMD chiplet-based systems." )Linux 6.6 WQ Change May Help Out AMD CPUs & Other Systems With Multiple L3 Caches
https://www.phoronix.com/news/Linux-6.6-Workqueue"Ryzen 9 3900x - 12 cores / 24 threads spread across 4 L3 caches. Core-to-core latencies across L3 caches are ~2.6x worse than within each L3 cache. ie. it's worse but not hugely so. This means that the impact of L3 cache locality is noticeable in these experiments but may be subdued compared to other setups."
S_x96x_S
AMD EPYC Venice SP7 12
AMD EPYC Venice SP7 16
https://twitter.com/yuuki_ans/status/1700146795899162699AMD Zen 6 Powered EPYC Venice CPUs To Feature Support On SP7 Platform With Up To 16-Channel Memory
https://wccftech.com/amd-zen-6-epyc-venice-cpus-feature-support-sp7-platform-16-channel-memory/ -
S_x96x_S
SP5
ASRock Rack GENOAD8X-2T/BCM Review An Uncomfortably Good Motherboard
https://www.servethehome.com/asrock-rack-genoad8x-2t-bcm-review-an-uncomfortably-good-motherboard-amd-epyc/ -
S_x96x_S
Hot Chips 2023: Characterizing Gaming Workloads on Zen 4
https://chipsandcheese.com/2023/09/06/hot-chips-2023-characterizing-gaming-workloads-on-zen-4/ -
S_x96x_S
UE 5.3 apró lépések az AVX-512 optimalizáció felé ..
"Updated support for minimum cpu arch for x64 platforms.
Replaces ModuleRules.bUseAVX.
MinimumCpuArchitectureX64, valid values are None, AVX, AVX2, & AVX512."
https://docs.unrealengine.com/5.3/en-US/unreal-engine-5.3-release-notes/ -
S_x96x_S
A Mindfactory heti cpu stat-ban a top3 proci
- 7800X3D 890 db
- 5700X 410 db
- 5800X3D 421 db -
S_x96x_S
TRX50 WS
ASRock preparing AMD TRX50 Workstation motherboard for next-gen Threadripper 7000
https://videocardz.com/newz/asrock-preparing-amd-trx50-workstation-motherboard-for-next-gen-threadripper-7000 -
S_x96x_S
egy újabb picuri gép.
ASRock Industrial's New 4X4 BOX 7040 Series Mini PC: Sprint Faster and Run Longer with AMD Ryzen™ 7040U Series APU
https://www.asrockind.com/en-gb/article/170
S_x96x_S
Petykemano #8969 üzenetére
> Azért az nem hangzik rosszul,
> hogy egy Veyron V1 mag még a Bergamonál is 30%-kal kisebb.Szerintem van 2 kulcs mondat, hogy miért is kisebb:
- "V1 has no vector capability, " és az AVX2/AVX-512 elég sok helyet foglal.
- "Ventana (B1) hasn’t included die to die interfaces in their images"https://chipsandcheese.com/2023/09/01/hot-chips-2023-ventanas-unconventional-veyron-v1/
SPECInt -ben viszont nem rossz .. , persze a zen4/zen5 -höz képest kell mérni majd, mert azok lesznek a versenytársai.
https://www.servethehome.com/ventana-veyron-v1-risc-v-data-center-processor-hot-chips-2023/
Az mindenesetre jó hír, hogy egyre nagyobb a verseny :-)
S_x96x_S
Petykemano #8964 üzenetére
> sávszélesség
talán az egyik ok .. a sok közül ..
a másik az általad is említett energia kérdése .. ( "hogy mennyi energia megy " )
és a link is jó, amit linkeltél ..
"Compared to an eight-channel DDR5 design, the NVIDIA Grace CPU LPDDR5X memory subsystem provides up to 53% more bandwidth at one-eighth the power per gigabyte per second while being similar in cost. An HBM2e memory subsystem would have provided substantial memory bandwidth and good energy efficiency but at more than 3x the cost-per-gigabyte and only one-eighth the maximum capacity available with LPDDR5X. "Tehát a DDR5 EPYC - kb 8x akkora energiát igényelhet ( Power / GBps )
mint a HBM és az LPDDR5x - GraceVagyis a [ sávszél * költség * energia ] alapján az Nvidiás mérnökök a DDR5-öt elvetették.
https://www.nextplatform.com/2022/08/29/details-emerge-on-nvidias-grace-arm-cpu/
----------------Amúgy az OpenFOAM -nak használ az AVX-512 ; vagyis a ZEN5 előrelépés lesz
https://www.phoronix.com/review/amd-epyc-avx512/9-------------------
Vagyis összefoglalva, ami számíthat az OpenFOAM szempontjából:
- Magok száma ( grace next : 144 )
- FPU hatákonyság ( itt gyengébb a grace , a zen5 meg ütős lesz .. )
- Memória sávszél , cache ( NVMe, 3Dvcache; 12 csatornás DDR5 )
- CPU Energia igény ( TSMC 4N ?? )
- Memória energia igény ( a DDR5 itt nem ideális )Amúgy nem tünik rossznak a Grace ..
S_x96x_S
Petykemano #8962 üzenetére
közben már megválaszoltam ott ( is )
De az Intel XEON MAX -os teszt alapján
a HBMe eléggé rásegíthet a feladatra
és az új grace HBME3e -s.vagyis a 3D-Cache segít, de a HBMe még jobban ..
az új MI300 -al kell majd összehasonlítani a Next Gen Grace-t. -
S_x96x_S
AMD Siena Shown at Hot Chips 2023 A Smaller EPYC for Telco and Edge
https://www.servethehome.com/amd-siena-shown-at-hot-chips-2023-a-smaller-epyc-for-telco-and-edge/érdekes frissitett slide-ok.
S_x96x_S
Busterftw #8957 üzenetére
> Pedig jönnie kell valaminek mert itt a nyakunkon
> a Raptor Lake Refresh +3%-os teljesítménnyel. :DDDaz új Intel 66 thread/core -os prociról nem is beszélve.
Érdekes új trend .. teljesen más architektúra ..
Bár kísérleti, néhány dolog biztos le fog csorogni a consumer szintre isIntel Shows 8 Core 528 Thread Processor with Silicon Photonics
Hot Chips 2023;
- RISC ISA és nem x86 ; ( mielőtt valaki pánikba esne )
- kísérleti DARPA kutatás ( Defense Advanced Research Projects Agency )
- TSMC 7nm
- 8-core 75W CPU ; silicon photonics.https://www.servethehome.com/intel-shows-8-core-528-thread-processor-with-silicon-photonics/
S_x96x_S
bővebb UCIe 1.1 leirás. - slideok
UCIe 1.1 Specs Announced for Chiplet Future
https://www.servethehome.com/ucie-1-1-specs-announced-for-chiplet-future/ -
S_x96x_S
AMD Ryzen 7 7840U Windows 11 vs. Linux CPU Performance
https://www.phoronix.com/review/amd-7840u-windows-linux" the AMD Inception mitigation lowered the performance by about 5% while the other Linux 6.2 to 6.5 kernel differences represented the rest."
S_x96x_S
"Amazon's New EC2 M7a AMD EPYC "Genoa" Instances Deliver Leading Performance In The AWS Cloud"
https://www.phoronix.com/review/aws-m7a-ec2-benchmarksperformance/cost -ban elég nagy végletek vannak ..
Azért a Graviton3 és a SPR -nak is vannak ideális tesztek, amelyeknél a zen4 eléggé le van maradva...viszont az Intel SPR erős AVX-512 / AMX teljesítménye látszik
pl. egy játék ...
És valamikor a Graviton3 is labdába rug ... a Zen4 meg a lista 2. felében ..
Persze az összesítésben jól áll az AMD zen 4
a verseny jó -
S_x96x_S
avx10 - újabb infók :
a cél
- az inkonzisztencia csökkentése
- és a több regiszterből valamaint a K-maszkokból eredő sebességnövekedés.
https://www.theregister.com/2023/08/15/avx10_intel_interviews/(intel) Van de Ven notes the new spec should address many of the frustrations raised by Torvalds back in 2020. "We listened very carefully to his feedback… part of his gripe was inconsistency," he said. "Inconsistency makes it harder for people to use it, and, if it's hard to use, it doesn't get used."
In terms of implementation, Van de Ven told The Register that once fully fleshed out, most applications should be able to take advantage of the new SIMD instructions with nothing more than a recompile. Though, of course, Intel says it will provide additional tools for the one percent that want to further optimize their code.
Another benefit of decoupling these features from AVX-512 is lower power overhead. "In terms of power and thermals, the extra registers and K-masks make the same code more efficient. That gives you a performance benefit, but the performance benefit is also a power benefit," Van de Ven said. "As an example, if your matrix multiply is suddenly 10 percent faster, you take 10 percent less time; your total power consumption is down by give or take 10 percent."
...Beyond a wider register width, AVX-512 has a couple of advantages over AVX2, SSE, and other SIMD instructions. Two of the biggest, according to Intel Fellow Arjan van de Ven, are its 32 registers, twice that of AVX2, and the introduction of K-masks. "A lot of the performance comes from those extra registers [and] from the K-masks; not so much the rest," he said.
Under the new spec, AVX10 compatible chips will, for the most part, share a common feature set
— including 32 registers, k-masks, FP16 support
— and minimally support 256 bit wide registers. -
S_x96x_S
Az Intel - eléggé kezd ráfeküdni a speciális hw-res gyorsításra
kíváncsi leszek, hogy mi lesz erre az AMD válasza ..pl. hw-res tömörítés támogatás:
- Intel® QuickAssist Technology Zstandard Plugin, an External Sequence Producer for Zstandard ( 08-16-2023 )
- https://github.com/intel/QAT-ZSTD-Plugin/releases/tag/v0.0.1 -
S_x96x_S
Az E-core + P-core ütemezés nem is olyan egyszerű ...
Future Intel CPUs May Dump Hyper-Threading For Partitioned Thread Scheduling
https://hothardware.com/news/future-intel-cpu-partition-threads"Basically, instead of scheduling on the application thread level, this new method analyzes the work required by a thread and then breaks application threads into segments using partitions. These partitioned threads are then scheduled onto processor cores based on their performance requirements. In other words, a program thread that is mostly simple ALU work but includes a crunchy AVX section may be scheduled onto an E-core, but have its AVX work thrown over to a P-core to make sure it gets completed within a certain time threshold."
S_x96x_S
Inception ... Ajajj ... rosszabb a helyezet, mint ahogy vártam
még emésztenem kell ...Benchmarking The Performance Impact To AMD Inception Mitigations
https://www.phoronix.com/review/amd-inception-benchmarks----- ZEN3-----------
One of the real-world areas where the AMD Inception mitigations did hurt the performance was in code compilation speed. The EPYC 7763 server was showing various open-source projects taking a few seconds longer to build now with the safe RET mitigations. Interestingly the new CPU microcode didn't provide much of a difference over the pure kernel-only mitigation run. The alternative IBPB mitigation showed the worst performance penalties.""The PostgreSQL database server also recorded some slowdowns as a result of the mitigated kernel."
----- ZEN4 ------
"Overall it comes down to what workloads you are engaged in whether you may notice any performance difference when upgrading your Linux kernel (or otherwise being patched for Inception on your given OS) on an AMD Zen desktop or server. For the most part users are unlikely to notice anything drastic, aside from some sizable database performance hits in a few cases. It's unfortunate seeing some of these regressions due to the Inception mitigation but ultimately is unlikely to really change the competitive standing of AMD's latest wares on Linux. Most of the prior AMD CPU security mitigations have also not resulted in any performance degradation, so this Inception mitigation difference is a bit rare. It also was announced on the same day as Intel Downfall where there was again a sizable hit to Intel CPU performance. For those wanting to avoid the new mitigation, there is always the "mitigations=off" route or the "spec_rstack_overflow=off" as used in this round of testing (the "off" metrics) for only disabling the Inception/SRSO and leaving all other CPU security mitigations at their respective defaults. I continue to run more AMD Inception and Intel Downfall benchmarks in looking to uncover any other performance differences worth mentioning." -
S_x96x_S
Petykemano #8939 üzenetére
> Nem tudom, hogy ezt hiányoltad-e.
érdekesnek érdekes ..
de ettől még nem leszek optimistább -
S_x96x_S
"Beelink GTR7 Pro Review a Faster AMD Ryzen 9 Mini PC"
https://www.servethehome.com/beelink-gtr7-pro-review-a-faster-amd-ryzen-9-mini-pc/-----------
az elmúlt pár hétben végignéztem jópár 7840HS, 7940HS Mini PC tesztet.
A hütés igencsak kényes pont, melegszik, throtlingol - mert a gyártók nem limitálták le a power-t, vagy mert az AMD driver is rossz, vagy eleve pici a házA tesztek szerint a Beelink a legjobb.
és a relative rangsor - hütés alapján:
1.) Beelink ( GTR7 ( PRO ))
2.) Minisforium ( UM780 Pro, UM790 Pro )
3.) Morefine ( M600 )Nehéz rendelni és általában 32GB RAM-ot adnak hozzá.
A Morefine M600 -asnál láttam 7840HS + 64GB verziót 2 TB SSD-bel - relative olcsón -
csak ennek a legrosszab a hűtése és az egyik usb4 -et kispórolták.
( 840 EUR-ért , németből rendeléssel - amúgy rebrandelt Morefine , KingnovyPC néven az amazon.de -ről. )A normál ASUS Expertcenteres 7840HS viszont még meg se jelent ..
lehet, hogy az ASUS - azt a kevés chipet amit kapott az AMD-től,
teljesen belenyomja a saját laptopjaiba.kezdem azt hinni, hogy a PhoenixAPU egy elátkozott széria ..
S_x96x_S
az X86 eredete ...
Tracing the roots of the 8086 instruction set to the Datapoint 2200 minicomputer
https://www.righto.com/2023/08/datapoint-to-8086.html"
The modern x86 architecture is descended from the Datapoint 2200's architecture. Because there is backward-compatibility at each step, you should theoretically be able to take a Datapoint 2200 binary, disassemble it to 8008 assembly, automatically translate it to 8080 assembly, automatically convert it to 8086 assembly, and then run it on a modern x86 processor. (The I/O devices would be different and cause trouble, of course.)" -
S_x96x_S
AMD Ryzen Threadripper 7995WX, 7985WX and 7945WX with 350W TDP spotted in transit
https://videocardz.com/newz/amd-ryzen-threadripper-7995wx-7985wx-and-7945wx-with-350w-tdp-spotted-in-transitSP6 -os foglalat.
S_x96x_S
Petykemano #8929 üzenetére
> A chiplet kommunikáció késleltetésén
érdekesség:
Az UCIe - 2ns alatti késleltetést céloz be .."Meanwhile, it’s interesting to note just what the promoters are expecting in terms of latency and energy efficiency. For all package types, latency is expected to be under 2ns, which is especially critical in chiplet designs that are splitting up what would previously have been a monolithic chip design. "
https://www.anandtech.com/show/17288/universal-chiplet-interconnect-express-ucie-announced-setting-standards-for-the-chiplet-ecosystem ( March 2, 2022 )
És a héten jelent meg az UCIe 1.1 - legalább valamit dolgoznak a háttérben ..
https://www.phoronix.com/news/UCIe-1.1-Specification
https://www.uciexpress.org/press-releasesA 3 nagy CPU gyártó ott van azok között - akik névvel is vállalták, hogy kiállnak mellette ..
Statements of Support for UCIe 1.1 Specification
AMD - Statement:
“The UCIe 1.1 specification, which adds new features to optimize silicon and packaging costs, additional protocol flexibility and automotive use cases, takes the first step towards establishing a chiplet ecosystem. We are proud of the UCIe Consortium’s progress so far and look forward to establishing a truly pervasive universal chiplet ecosystem.”
Nathan Kalyanasundharam, Corporate Fellow and AMD Infinity Fabric Lead Architect, AMDIntel - Statement:
“Intel is proud to be a founding member of the UCIe consortium. Chiplets are continuing to become a critical technology for the semiconductor industry. Intel Foundry Services (IFS) is focusing on UCIe to enable our foundry customers to build interoperable silicon solutions, based upon industry standards.”
Bob Brennan, Vice President of Customer Enablement, Intel Foundry ServicesArm - Statement:
“As compute requirements continue to grow and evolve across all industries, we must deliver scalable, cost-effective solutions and new approaches. Arm partners are already delivering chiplet-based solutions in infrastructure applications; in automotive, chiplets can reduce time to market, allow for new performance points and enable unique SoC designs in applications such as ADAS and infotainment, while still delivering the dedicated features tailored to the safety and real-time needs of the market. Arm will continue to work with industry leaders in the UCIe Consortium on standards and specifications like the UCIe 1.1 Specification as the Consortium expand to increase interoperability and address industry needs.”
Andy Rose, VP Technology Strategy and Fellow, Arm---------------------
és apró siker - az egyik cég már a 3nm-eren sikeresen tesztelte ..
"We are delighted to announce successful tapeouts on TSMC’s most advanced 3nm process including UCIe PHY IPs."
https://www.uciexpress.org/post/meet-ucie-consortium-member-alphawave-semi
(Board) UCIe Director -ok - van nVidiás és TSMC-s is.
https://www.uciexpress.org/board-representatives -
S_x96x_S
(mégegy Q2 ; néha nem árt újraolvasni egy másfajta tálalást .. )
"AMD FEELS THE SERVER RECESSION, TOO, BUT GROWTH IS LOOMING LARGE"
https://www.nextplatform.com/2023/08/11/amd-feels-the-server-recession-too-but-growth-is-looming-large/"
On a call with Wall Street analysts, chief executive officer Lisa Su said that AMD was on track to launch and deliver the MI300A hybrid GPU-GPU engines and the MI300X standalone GPUs in the fourth quarter and touted the fact that Amazon Web Services, Microsoft Azure, Oracle Cloud, and Alibaba Cloud had all launched instances based on the Genoa CPUs. There are over 30 instances based on Genoa worldwide, and all told, there are 670 instances worldwide powered by AMD CPUs and by the end of the year the company projects there will be nearly 900 – with the bulk of those new instances being powered by Genoa chips. Revenues from the Genoa CPUs doubled sequentially from Q1 to Q2, and the addition of “Bergamo” and “Genoa-X” variants will help drive sales further, and the “Sienna” Epyc CPU for hyperscalers will launch later this quarter and join the mix. Su added that AMD expects sequential growth in the double digits – which obviously can be anywhere from 10 percent to 99 percent growth, so that is a pretty wide bracket – in Q3.""AMD’s prognostications are for AI accelerators to drive over $150 billion
in revenues across the IT industry by 2027, and AMD is increasing its research, development, and go-to-market spending to try to capture a larger piece of this pie."
S_x96x_S
azért nem olyan egyszerű ez a chiplet dolog ...
"Sapphire Rapids Core-To-Core Latency // AUG 7, 2023
https://jprahman.substack.com/p/sapphire-rapids-core-to-core-latency"It’s interesting to note that with the upcoming Emerald Rapids die shrink on Sapphire Rapids, Intel is actually somewhat back-tracking from chiplets (at least temporarily for ER), scaling back from 4 → 2 chiplets. I’d expect with ER undergoing 2 → 4 die reduction from Sapphire Rapids, combined with improvements to the EMIB interconnect, to flatten the latency hierarchy just as AMD did going from Rome → Milan → Genoa (which I still need to benchmark)."
előzmény: AMD CPU Topology - Rome + Milan // JUN 3, 2023
https://jprahman.substack.com/p/amd-cpu-topology-rome-milanés még: "AWS is running a 96-core, 192-thread, custom Xeon server"
Amid all the Graviton chat, cloud colossus still has a soft spot for Chipzilla
https://www.theregister.com/2023/08/03/aws_custom_xeon_m7i_instances/
"A reader took the M7I instances for a spin, queried the machine to learn its CPU type, and told The Reg it is a two-socket machine packing a 48-core Xeon Platinum 8488C processor." -
S_x96x_S
Petykemano #8921 üzenetére
> Bennem ez azt erősíti, hogy a 2024Q1-es Zen5 rajt sínen van.
az is lehet, hogy a Zen5 -ös APU a gyorsító sávba került.
( valamiért nagy prioritást kapott Lisa Su-tól )És ha arra gondolok, hogy most az AI az AMD Number 1 prioritása
akkor tényleg az APU-nak több értelme van,
A STRIX Point lényegében egy ideális MI300/MI400-as dev kit ROCm kompatibilitással.
És ha lesz belőle mini PC/notebook/... akkor veszik mint a cukrot ..Az én spekulációm:
Vagyis ami az MI300/MI400 - szoftveres ellátottságát segíti - az magas prioritást kap.
a sima ZEN5 CPU - pedig alacsonyabbat.
Legalábbis ez az én spekulációm - az én szubjektív nézőpontombólAz is lehet, hogy a PhoenixAPU -val valami gond van
.. nagyon lassan megy a launch.
és az AM5 -ös desktop-os Phoenix verzióról kevesebb a pletyka mint a Strix Point -ról.
Nyugtassatok meg, hogy minden rendben vele -
S_x96x_S
Petykemano #8915 üzenetére
Valami olyasmi .. öngerjesztő spirál.
- szerintem most a kormányok és a cégek is több pénzt áldoznak erre, és az egyetemek + kutatók jobban kapnak erre forrásokat. ( ~ több benne a pénz )
- és egyre gyakorlottabbak a kutatók is. Ugyanazt a trükköt sokszor csak egy picit elég módosítani - és néha szerencséjük van, mert működik.
- És minél inkább felkapja a sajtó .. annál több pénzt adnak rá a politikusok és a cégek ..
amelyek újabb sebezhetőségeket generálnakA hosszú távú hatása, hogy a CPU-k egyre biztonságosabbak lesznek.
S_x96x_S
AMD "INCEPTION" CPU Vulnerability Disclosed
https://www.phoronix.com/news/AMD-INCEPTION
( elméletileg erre a javításra is lesz Phoronix-es benchmark, meglátjuk ... )AMD's statement to Phoronix on the matter is:
"AMD has received an external report titled ‘INCEPTION’, describing a new speculative side channel attack. AMD believes ‘Inception’ is only potentially exploitable locally, such as via downloaded malware, and recommends customers employ security best practices, including running up-to-date software and malware detection tools. AMD is not aware of any exploit of ‘Inception’ outside the research environment, at this time.
AMD recommends customers apply a µcode patch or BIOS update as applicable for products based on “Zen 3” and “Zen 4” CPU architectures. No µcode patch or BIOS update is necessary for products based on “Zen” or “Zen 2” CPU architectures because these architectures are already designed to flush branch type predictions from the branch predictor.
AMD plans to release updated AGESA™ versions to Original Equipment Manufacturers (OEMs), Original Design Manufacturers (ODMs) and motherboard manufacturers listed in the AMD security bulletin. Please refer to your OEM, ODM or motherboard manufacturer for a BIOS update specific to your product.
-- > https://www.amd.com/en/resources/product-security/bulletin/amd-sb-7005.html------------------
"Updated AMD Family 19h Microcode Published Following "Inception"
https://www.phoronix.com/news/AMD-Microcode-Inception
S_x96x_S
hokuszpk #8912 üzenetére
> ... AVX512 ...
// DOWNFALL //
pár napja ütött be a https://downfall.page/ az Intel oldalra, ami pont az AVX2/AVX-512 -es müveleteket érinti - és javítás ( a régebbi intel cpu-kon ) néha elég jelentős teljesítmény vesztéssel járhatdisclaimer: felhőben vegyesen használok AMD-t és Intelt - úgyhogy érint engem is. És van még egy inteles 8250-es Thinkpad-em is ..
( Which computing devices are affected? : Computing devices based on Intel Core processors from the 6th Skylake to (including) the 11th Tiger Lake generation are affected. )
pár link:
Hacker News: https://news.ycombinator.com/item?id=37052586"Intel DOWNFALL: New Vulnerability Affecting AVX2/AVX-512 With Big Performance Implications" https://www.phoronix.com/review/downfall
"Initial Benchmarks Of The Intel Downfall Mitigation Performance Impact"
https://www.phoronix.com/review/intel-downfall-benchmarks
"Intel has reported up to 50% performance penalties in extreme cases but from my testing over the past day it thankfully has tended to be less than that but still significant. "
S_x96x_S
Petykemano #8910 üzenetére
> Két dolog miatt hiszek a 2024Q1-es rajtban:
legyen igazad !
S_x96x_S
Petykemano #8908 üzenetére
> A 2024Q1-es rajt elég valószínű.
ki tudja ..
de a (May 15th 2023 -MLID-Videocardz alapján csak 2023Q1-ben kezdődik el a gyártása )
"More importantly, the slide shows when the product might enter production, which is between Q1 2024 and Q1 2025,"Az ábra alapján a "Turin Dense" és a "Turin Classic" kap nagyobb prioritást.
de amúgy én is örülnék, hogyha már januárban meg lehetne venni ..
S_x96x_S
Komplikato #8904 üzenetére
> Ezeket én is megtaláltam. Igazából engem az érkező alaplapok
>, azok felszreltsége és ára érdekelne.ha nem találod, akkor még nincs róla infó;
még korai ..> És mivel Am5 lapok is mocskos drágák,
> lehet az "olcsó" verzió a 64 PCIe lannel,
> meg a kevesebb memória csatornával megérnék.mire kell ?
- mert szerintem az AM5 átlagos árszintje felett lesz.- amúgy technikailag nincs akadálya - Gen4-es ( lebutított ) Threadripperes alaplapnak se
- vagy ránézhetsz az SP5 -ös lapokra és EPYC Gen4 -es CPU-t választasz.
https://geizhals.de/?cat=mbsp3&xf=644_SP5Supermicro H13SSL-NT retail - € 847,29 bis € 1011,50
- 12x DDR5 DIMM, 12-Channel PC5-38400R/DDR5-4800, max. 3TB (RDIMM), 3TB (LRDIMM)
- 3x PCIe 5.0 x16, 2x PCIe 5.0 x8, 2x M.2/M-Key (PCIe 4.0 x4/SATA, 22110/2280), 1x MCIO SFF-TA-1016 74-Pin (PCIe 5.0 x8), 2x MCIO SFF-TA-1016 74-Pin (PCIe 5.0 x8/SATA)Vagy Supermicro MBD-H13SSL-N-B : 352.034 Ft(277.192 Ft + ÁFA)
https://www.arukereso.hu/alaplap-c3128/supermicro/mbd-h13ssl-n-b-p977758878/És raksz bele egy olcsó EPYC procit ... $1200 EUR -tól.
https://geizhals.de/?cat=cpuamdam4&xf=12099_Server~16686_Epyc+9004 -
S_x96x_S
"Azure Provides Excellent HPC Cloud Performance With HBv4 Series Powered By AMD EPYC Genoa-X"
https://www.phoronix.com/review/azure-hbv4-genoaxteszt:
HBv4 - The 176 vCPUs with the EPYC 9V33X Genoa-X.
HBv3 - The 120 vCPUs for Milan-X with the EPYC 7V3X processors.
HBv2 - The 120 vCPUs with the EPYC 7V12 Rome processors.
HC - The original 44 vCPUs with the Xeon Platinum 8168 Skylake processors."When taking the geometric mean of all the benchmark results, the HBv4 with 176 vCPUs was 2.1x the performance of the 120 vCPU HBv3 VM. For classic high performance computing workloads and especially for areas like CFD, FEM, and other memory bandwidth intensive applications, the HBv4 performance uplift can be dramatic thanks to AVX-512 and the larger 3D V-Cache with Genoa-X. The price increase in the HBv4 line-up is justified and still the HBv4 top-end VM tended to deliver the best value."
S_x96x_S
AMD 2023Q2
egyedül az "Embedded Y/Y up 16%" .. a több csökkenés ..
https://ir.amd.com/news-events/press-releases/detail/1146/amd-reports-second-quarter-2023-financial-results"Data Center segment revenue was $1.3 billion, down 11% year-over-year primarily due to lower 3rd Gen EPYC processor sales as Enterprise demand was soft and Cloud inventory levels were elevated at some customers."
"Client segment revenue was $998 million, down 54% year-over-year due to reduced processor shipments resulting from a weaker PC market and a significant inventory correction across the PC supply chain."
"Gaming segment revenue was $1.6 billion, down 4% year-over-year. Semi-custom revenue grew year-over-year, which was more than offset by lower gaming graphics revenue."
"Embedded segment revenue was $1.5 billion, up 16% year-over-year primarily driven by strength in the Industrial, Vision and Healthcare, Automotive and Test and Emulation markets."
S_x96x_S
Komplikato #8897 üzenetére
> Az új Threadripper alaplapokról nincs pletyka, infó, lesifotó?
itt követheted: https://videocardz.com/?s=Threadripper
amúgy a "PRO" -n van a fókusz és az várhatóan SP6 + OEM -es .. ( Lenovo ? )
A kistestvére : az SP5- ös sima 4 memória csatornás TR talán egy picivel később várható:
( LGA-4844 based Threadripper variant, which would support quad-channel memory and 64 PCIe Gen5 lanes. )persze lehet, hogy az SP6-os is kijön októberben, mert a Noctua korábban ezt az infót kapta ..
"AMD Ryzen Threadripper PRO 7985WX with 64 cores appears in first benchmark"
https://videocardz.com/newz/amd-ryzen-threadripper-pro-7985wx-with-64-cores-appears-in-first-benchmark"AMD’s Zen4-based HEDT systems have faced delays, but it is evident the company has shifted its focus toward the workstation PRO market segment rather than the enthusiast desktop market (HEDT). Consequently, the demand for new Threadripper processors is influenced more by OEMs like Lenovo rather than everyday consumers and enthusiasts."
"Notably, the CPU is paired with eight DDR5-5600 memory modules, providing a total capacity of 256GB. This configuration implies the possibility of an LGA-6096-based Threadripper processor with support for 8-channel DDR5 memory and 128 PCIe Gen5 lanes. Additionally, AMD is reportedly working on an LGA-4844 based Threadripper variant, which would support quad-channel memory and 64 PCIe Gen5 lanes." -
S_x96x_S
nem hiszem, hogy megszívta az AMD ..
- egyrészt az AMD-nak sokkal könnyebb implementálni az AVX10/256 -t,
mint az Intelnek az "E" -ben az AVX-512 -t- másrészt az Intel szerveren az AVX-512 megmarad és a zen4 támogatás már most is megvan .. míg az AVX10/256 támogatáshoz kell +1-2 év ( gcc, llvm, ..) azután hogy megjelent az első Inteles chip. ; addigra már az AMD is tudja támogatni.
- az Intel eddig is rengeteg software-t optimalizált már az Intel AVX-512 -re, aminek a gyümölcsét az AMD aratja le.
S_x96x_S
Petykemano #8882 üzenetére
2.
> APX/AVX10 ...amúgy nem látok még tisztán ..
és minnél többet olvasok a témáról .. annál több kérdés merül fel bennem ..
S_x96x_S
> Szerinted az APX/AVX10 [link] már magábafoglalja/megvalósítja azt,
> amit az SVE-nél láttunk? Vagyis hogy az utasítás/vektorhossz
> és a végrehajtó szélessége nincs szorosan összekötve?(ahogy felületesen én látom)
bár messziről úgy tünk .. és egyes cikkek meg is emlitik [1]
csak "érzésre" van meg a hasonlóság ..
persze lehet, hogy egy következő AVX10.3/AVX10.4 már arrafelé vezet a kiegészítésekkel
de ezt még nem látjuk.[1] "However, the e-cores will be limited to the converged AVX10's maximum 256-bit vector length, while P-cores can use 512-bit vectors. This feels akin to Arm's support for variable vector widths with SVE. " ( tomshw )
Ami még érdekes olvasva a kommenteket (spekulációkat) ..
hogy egyesek szerint ez az Intel részleges válasza az AMD AVX-512 -es megvalósításra .."No, the E-cores will implement only a 256-bit subset of AVX-512, which halves the size of the vector registers to 256-bit and the size of the mask registers to 32-bit. The same subset will be implemented on the P-cores combined with E-cores.
This subset AVX10/256, is the reason for this new specification. It is the Intel response to AMD Zen 4.
When their competitor supports AVX-512 on all products, Intel had to do something to remain competitive. Because they believe that supporting the full AVX-512 on their E-cores is too expensive, they have created a subset of AVX-512, including only the instructions with an operand size up to 256 bits."
( via https://news.ycombinator.com/item?id=36854341 ) -
S_x96x_S
a zen4c ~érzékenyebb az AVX-512 -re mint a normál zen4;
"The AVX-512 Performance Advantage With AMD EPYC Bergamo"
https://www.phoronix.com/review/epyc-bergamo-avx512/5
"With the Bergamo AVX-512 testing we did see slightly higher power consumption compared to looking at the AVX-512 performance with the Ryzen 7000 series or EPYC 9004 Genoa(X) parts. Presumably some of that higher AVX-512 power difference is due to simply having more cores and any other alterations as part of the Zen 4C design. AVX-512 caused the CPU power consumption to increase by about 50 Watts or 20 Watts higher on the peak CPU power consumption observed. But for many tests the CPU power consumption was similar between runs. The power increase is also worthwhile when considering the much larger increases in performance observed for many workloads."
S_x96x_S
Busterftw #8879 üzenetére
> Teljesen mindegy, mert a Phoenixről van szó, ami késik
> és az ezt szolgáló szoftveres háttérrel lehet gond.igazából nem tudjuk pontosan, hogy mi lehet a probléma a háttérben ...
Lehet, hogy valamilyen gyártási probléma
vagy valami hw-re dolgot újra kellett tervezni .. -
S_x96x_S
Petykemano #8876 üzenetére
logikus:
"TSMC have the best nodes, but they are very expensive. Samsung can produce the mid range AMD products (like next console SoCs)."
https://twitter.com/BitsAndChipsEng/status/1684134578263404544 -
S_x96x_S
Intel árat emel ... hogy lesz ebből így akkor árverseny ?
Intel Planning Price Hike Across All “Core” CPUs As a Part of Restructuring Policy -
S_x96x_S
Busterftw #8872 üzenetére
> Amúgy Linus elsőként kapott a Framework laptopjába Phoenixet,
> de ott sem mutatták a rendszert élőben mert a Framework CEO nem nagyon engedte,erre egyszerű a magyarázat.
Mert akkor ( márciusban ) még be se volt jelentve hivatalosan a Ryzen 7840u,
és csak úgy volt megemlítve, hogy
- AMD Ryzen™ 7040 Series - Ryzen™ 5 / Ryzen™ 7Vagyis a Frame.work - hamarabb tett bejelentést ( ~ 23 Mar 2023 )
mint az AMD a Ryzen 7840u -t bejelentette ( ~ 03 May 2023 )Abu85 például - 2023-05-04 -én jelentette be a hírt ..
https://prohardver.hu/hir/amd_ryzen_7040u_meghozta_legujabb_ultramobil.htmlLinus videója meg előtte jó 1 hónappal ( ~ 2023-03-25 ) jelent meg
Persze az lehetséges, hogy januárban még azt az infót adta az AMD a frame.work-nek,
hogy márciusban majd bejelentjük a 7840u-t ..
viszont a frame.work - csak így - kompromisszummal tudta tartani a saját ütemtervét
és elkezdeni a megrendelések gyűjtését ...Vagyis azért nem muttaták élőben a rendszert,
mert a procit még nem jelentették be. -
S_x96x_S
remélem megéri a várakozást ..
mert amúgy ígéretes: ZEN4, RDNA3, AI> Anno sokat volt ez az indok hogy miert a "szarabb" intel architekturát
> preferaljak a gyartokvannak kivételek:
pl. az új "Framework Laptop 16" -nak egyenlőre csak az AMD-s változata van bejelentve.
Powered by AMD Ryzen™ 7040HS and Radeon™ RX 7700S
https://frame.work/at/en/products/laptop16-diy-amd-7040
ezen egy kicsit (pozitivan) meg is lepődtem.a másik érdekes ( és pozitiv) meglepetés nekem, hogy
A 8050-res "Strix Point" APU - ról már van "leak"
"A 12-core AMD Ryzen 8050 Zen5 “Strix Point” APU has been spotted"
és remélem ennek a rajtja sokkal simább lesz mint a mostani APU-é.<spekuláció on>
persze az is lehet, hogy a PhoenixAPU-val
valami mély architekturális probléma van
és emiatt van gyorsítósávon a "Strix Point" ..
Egy hónap múlva többet tudunk ..
<spekuláció off> -
S_x96x_S
extrém nagyot csúszik a Phoenix APU ...
( lehet, hogy az RDNA3 -al volt a probléma ?? )AMD Radeon 700M “RDNA 3” iGPU Driver For Phoenix APUs To Release By End of July
https://wccftech.com/amd-radeon-700m-rdna-3-igpu-driver-for-phoenix-apus-to-release-by-end-of-july/ -
S_x96x_S
"Zenbleed" - zen2 sérülékenység, ..
"Update 7/24/23 1:30pm PT: AMD has responded with key details and published a security advisory with the expected dates for new firmwares, many of which don't arrive until the end of the year. Google also sent us a statement. We have added that information to the original article below. "
https://www.tomshardware.com/news/zenbleed-bug-allows-data-theft-from-amds-zen-2-processors-patches-releasedhttps://lock.cmpxchg8b.com/zenbleed.html
- We reported this vulnerability to AMD on the 15th May 2023.
- AMD have released an microcode update for affected processors. Your BIOS or Operating System vendor may already have an update available that includes it.This technique is CVE-2023-20593 and it works on all Zen 2 class processors, which includes at least the following products:
- AMD Ryzen 3000 Series Processors
- AMD Ryzen PRO 3000 Series Processors
- AMD Ryzen Threadripper 3000 Series Processors
- AMD Ryzen 4000 Series Processors with Radeon Graphics
- AMD Ryzen PRO 4000 Series Processors
- AMD Ryzen 5000 Series Processors with Radeon Graphics
- AMD Ryzen 7020 Series Processors with Radeon Graphics
- AMD EPYC “Rome” Processorshacker news: https://news.ycombinator.com/item?id=36848680
S_x96x_S
az avx-512 jövője .. az Intel szerint
Intel AVX10: Taking AVX-512 With More Features & Supporting It Across P/E Cores
S_x96x_S
"The CEO also stated that due without TSMC, the upcoming Instinct Mi300 chips wouldn't have been possible due to their incredibly complex designs which include an assortment of various chips like the 3D SoIC, CoWoS packages, and various other vertically stacked chips. It's an engineering marvel and AMD has beaten both Intel and NVIDIA in the domain of chiplets. NVIDIA has yet to fully absorb the chiplet architecture for its chips whereas Intel's design has only just been adopted by Aurora, a supercomputer that had missed various launch schedules."
S_x96x_S
Petykemano #8856 üzenetére
> Különös, hogy ezúttal az APU változat (mérnöki példánya)
> látott előbb napvilágot és nem pedig az asztali.én ezt már nem tartom furcsának.
a 7840HS - is már elérhető .. de az asztali csak talán szeptember után várható> mindazonáltal számomra a 40CU-s változat sokkal izgalmasabban hangzik.
> Ugyanakkor én korlátozásként (kitolásként) élném meg,
> ha azt csupán valamilyen előregyártott kompakt egybegépként lehetne megvásárolni.a 40Cu-s -nak már 256 bites memória csatornája van .. és nem 128
És az is lehet, hogy csak konzol csip lesz
.. és nem is kerül kisker forgalomba még egy jó ideig. -
S_x96x_S
AMD EPYC 9754 Benchmarks For The 128-Core Bergamo
https://www.phoronix.com/review/amd-epyc-9754-bergamo
"Next year Intel will have Sierra Forest as their first E-core server solution providing up to 144 cores per socket. However, with being an E-core design will presumably lack HT (SMT) and AVX-512 support found with Bergamo. It should be an interesting battle next year as well as ultimately seeing how Bergamo competes with AmpereOne once those processors actually become available and there is independent performance analysis of those Arm server CPUs." -
S_x96x_S
AMD EPYC 9684X Genoa-X Provides Incredible HPC Performance
https://www.phoronix.com/review/amd-epyc-9684x-benchmarks
"For those looking to maximize their HPC performance right now, the AMD EPYC 9684X is easily one of the best processors I've looked at in the past 19 years of Phoronix.
The larger L3 cache paired with AVX-512, 12 channel DDR5 memory, and other Zen 4 benefits can really deliver phenomenal results in a wide range of high performance computing workloads."
megj: HBM-es Xeon is szerepel a tesztben, ami valamikor nagyon jól szerepel .. de ha nem fekszik neki a feladat, akkor nem igazán ..
pl. a korrektség miatt egy ilyet is belinkelek:ugyanezen bencsmark más tesztjében meg már nem annyira jó ..
"The Xeon Max 9480 2P in HBM-only mode did enjoy nice uplift over the HBM caching mode but at 56 cores wasn't enough -- with the exception of the MG test case -- to compete in these threaded benchmarks against the 96-core flagship EPYC Genoa(X) CPUs."
S_x96x_S
TPU Interviews AMD Vice President: Ryzen AI, X3D, Zen 4 Future Strategy and More
(Jul 12th, 2023)"""
Wouldn't it make sense to put an FPGA in a CPU then to be more future-proof?Honestly that's something we've looked at and considered. You know FPGAs have their own issues and limitations, I guess when it comes to capability per millimeter of die area, FPGAs are less efficient than a structure like the Ryzen AI engine. I think the reality is that in a consumer device where every dollar matters, that's a very hard investment to make in a significant enough way where you could implement enough capability to satisfy what a flexible engine might need to do in a system.
AM5 APU Delays ...
"You know a lot of it is the tuning of all those things together. With Phoenix one of the innovations that came into the platform is something that we call our power management framework or "PMF." It's beyond the SMU, which does processor-level control, but what we really worked on in the Phoenix generation is an extension of the concept of the SMU to the system-level. More OS interaction, more hints between the OS and the processor to make sure that we are running at the right power level. Many of these premium systems, what our customers are looking for is silent computing. If you are doing things like Office applications or Teams or web browsing, you don't want the fan to ever turn on. You want it to be absolutely silent. Many applications aren't written in way where the processor can easily understand what the real-time demand is for what the user is trying to do. So we built this framework in tying together operating system, user intent and SMU behavior to really achieve that vision of silent computing on many of these systems. That interaction has been one of those things that we have been working on most."Amúgy a napokban nézegettem pár 7840HS -es -es mini PC -s tesztet (beelink,minisforum,morefine..) .. és valamennyire a melegedés ott is tettem érhető volt..
S_x96x_S
What AMD Learned From Its Big Chiplet Push
Sam Naffziger was an early evangelist for breaking up silicon chips
27 JUN 2023
https://spectrum.ieee.org/chiplet -
S_x96x_S
(Microsoft Azur Cloud - benchmarkok is! )
Performance & Scalability of HBv4 and HX-Series VMs with Genoa-X CPUs
Published Jun 13 2023 11:03 AMA 780 GB/S -os DRAM sebességen csodálkozom ...
HBv4-series VMs
HX-series VMs
és sok sok benchmark pl.
S_x96x_S
[ ha már AI -nap .. ]
(piac: ~ avagy az AI sajtra - többen is pályáznak ;
szerintem az 5-10 év csak arra lesz elég, hogy megjelenjenek a RISC-V szerverek, de nem lesz itt még tömeges átállás.
A teljesen nyilt szoftveres ökoszisztéma, hasonló mint az Intelé , aki rengeteg energiát tett bele az X86 -ba; de ez önmagában nem biztos, hogy elég lesz.Jim Keller on AI, RISC-V, Tenstorrent’s Move to Edge IP
2023-06-09
https://www.eetimes.com/jim-keller-on-ai-risc-v-tenstorrents-move-to-edge-ip/“My belief is in the next 5 to 10 years, RISC-V will take over all the data centers,
” Keller told EE Times, adding that this is especially true for scientific computing and HPC. He said supercomputing could dominate even faster.
Keller is a big believer in open source for both hardware and software;
Tenstorrent intends to open-source its own AI software stack imminently.
"Amúgy én is nagy jövőt jósolok a RISC-V-nek;
de azért még nem tart ott, mint az X86-64 vagy az ARM
mivel nincs elég fejlesztőeszköz ..
és ez a debian port egyik problémája is.Debian 13 "Trixie" Aiming To Ship With RISC-V 64-Bit Support
10 June 2023
https://www.phoronix.com/news/Debian-13-RISC-V-64-Potential
"With today's release of Debian 12 the official ports are for AMD64, AArch64, ARMEL, ARMHF, i386, MIPS, 64-bit MIPS, POWER, and IBM System Z. There isn't RISC-V 64-bit as an official port but that is likely to change for Debian 13.
The release team update can be found on the Debian mailing list. It would have been nice to see RISC-V support with Debian 12 but understandable considering many community open-source developers lack access to performant RISC-V hardware, but by the time of Debian 13 hopefully the RISC-V 64-bit open-source ecosystem will be a lot more mature." -
S_x96x_S
"AMD launches Ryzen PRO 7000 65W desktop series, Ryzen 9 PRO 7945 features 12 Zen4 cores"
https://videocardz.com/newz/amd-launches-ryzen-pro-7000-65w-desktop-series-ryzen-9-pro-7945-features-12-zen4-coresRyzen 9 PRO 7945 12C/24T 3.7 GHz 5.4 GHz 65W Gen5/DDR5
Ryzen 7 PRO 7745 8C/16T 3.8 GHz 5.3 GHz 65W Gen5/DDR5
Ryzen 5 PRO 7645 6C/12T 3.8 GHz 5.1 GHz 65W Gen5/DDR5
S_x96x_S
ma jelentik be az AMD MI300 = Mesterséges Intelligencia 300 -at.
azért ide is beposztolom ..
"AMD MI300 – Taming The Hype – AI Performance, Volume Ramp, Customers, Cost, IO, Networking, Software"
https://www.semianalysis.com/p/amd-mi300-taming-the-hype-ai-performance- Banff XCD ( GPU , ~ CDNA3 )
- DG300 Durango CCD ( CPU )"
The other modular compute aspect of MI300 is the CPU side. AMD partially reuses their Zen 4 CCD chiplet albeit with some modifications. They changed a few of the metal layer masks to create bond pads for SoIC to the AID, necessitating a new tapeout with some metal masks redesigned. This modified Zen 4 CCD, GD300 Durango disables the GMI3 PHY. The bandwidth to the AID is significantly higher than GMI3. This CCD is on TSMC’s 5nm process technology and retains the same ~70.4mm2 die size as the Zen 4 CCD found on desktop and server.
Each AID can have 3 Zen 4 chiplets for a total of 24 cores. The max CCD/CPU configuration of MI300 could offer up to 96 cores."
"MI300A is packaged with an integrated heat spreader on a 72 x 75.4mm substrate, and fits into socket SH5 LGA mainboards, with 4 processors per board. It effectively paid for the development costs. It is already shipping, but really ramps in Q3. The standard server/node will be 4 MI300A’s. There is no need for host CPU as that is built in. This is by far the best HPC chip on the market and will remain so for a while.
MI300X is the AI hyperscaler variant that if successful would be the real volume mover. It is all GPU, for maximum performance in AI. The server level configuration that AMD is pushing here is 8 MI300X’s + 2 Genoa CPUs.MI300C would go the opposite direction and be CPU only with 96-core Zen4 + HBM answer to Intel's Sapphire Rapids HBM. However, the market for this may be too small and the product too expensive for AMD to productize this variant.
MI300P is like a half sized MI300X. It is one that can come in at a lower power in PCIe cards. This again requires host CPUs. This would be the easiest one to get to start developing with, although we think that’s more of a 2024 release.
S_x96x_S
S_x96x_S #8814 üzenetére
Az Intel szerint az ő procijuk a jobb ( SR vs. Genoa )
Intel Shares Real-World Xeon Sapphire Rapids vs EPYC Genoa Benchmarks Ahead of AMD’s Data Center Event
https://wccftech.com/intel-shares-real-world-xeon-sapphire-rapids-vs-epyc-genoa-benchmarks-ahead-of-amd-data-center-event/az árak:
XEON 8462Y ~ ab € 6939
AMD 9353 ~ ab € 3379
AMD 9354P ~ ab € 2799 -
S_x96x_S
"Intel Xeon Ice Lake vs. AMD EPYC Milan Server Performance, Efficiency & Value In 2023"
https://www.phoronix.com/review/milan-icelake-servers-2023tested:
Intel Xeon Gold 6338 SP - 32-Core, 2.00GHz, 48MB, 205W, $2,941 USD
Intel Xeon Gold 6342 SP - 24-Core, 2.80GHz, 36MB, 230W, $2,638 USD
Intel Xeon Gold 6346 SP - 16-Core, 3.10GHz, 36MB, 205W, $2,398 USD
AMD EPYC 7343 Milan DP/UP - 16-Core, 3.2GHz, 128MB, 190W, $1,508 USD
AMD EPYC 7413 Milan DP/UP - 24-Core, 2.65GHz, 128MB, 180W, $1,813 USD
AMD EPYC 7513 Milan DP/UP - 32-Core, 2.60GHz, 128MB, 200W, $2,955 USD
AMD EPYC 7543 Milan DP/UP - 32-Core, 2.80GHz, 256MB, 225W, $3,224 USD
AMD EPYC 7713P Milan UP - 64-Core, 2.00GHz, 256MB, 225W, $4,807 USD< .. sok sok teszt >
summary:
From this testing, AMD EPYC Milan easily led over Intel Ice Lake when it came to delivering the best performance-per-Watt. However, given all of my past testing of EPYC Milan(X) that should hardly be a surprise. AMD also generally "takes the cake" when it comes to the best value / performance-per-dollar. Intel meanwhile led in raw performance when it came to some workloads like single-threaded PHP processing and the PostgreSQL database server and then predominantly for software able to make effective use of AVX-512. Intel Ice Lake obviously came out ahead of AMD Milan in such cases of being able to leverage AVX-512, but thankfully AMD Zen 4 with 4th Gen EPYC brings a performant and power efficient AVX-512 implementation there, as I've already shown in several articles on Phoronix. Intel also ups the competition with Sapphire Rapids by introducing Advanced Matrix Extensions (AMX) that can be very beneficial in some AI workloads but so far the software adoption of AMX is still in its early stages.
In any case hopefully you found this AMD Milan vs. Intel Ice Lake server performance comparison look in 2023 interesting if you are considering these generation-old options for better availability and pricing. This will be complemented later by adding in the latest-generation Intel and AMD server offerings for showing the data center performance competition and generational uplift from each vendor.
S_x96x_S
Petykemano #8811 üzenetére
> lelkesítő, de sajnos szerintem valószínűbb,
azt már nem tudom, hogy mennyire igaz ..
de ha tényleg idén jön,
akkor augusztus végéig kell lennie valami ennél konkrétabb leak-nek is.
egyenlőre én még nem élem bele magamat ..A Threadripper Zen5c lehetőség - pedig túl jó lenne
annyira jó, hogy pont emiatt nagyon pici a valószínűsége. -
S_x96x_S
Petykemano #8809 üzenetére
> Mindenesetre ez akkor is előrevetíthet akár egy idén év végi Zen5 rajtot.
MLID ábráján - 2023 Q4 -re van téve a "TURIN Dense Zen5c" ( SP5 )
odatekerve -> https://youtu.be/3FsUTYnQNOA?t=632 -
S_x96x_S
RedGamingTech - szerint
a ZEN6 - már AM6 lesz. ( DDR6 + PCIe6 )
https://youtu.be/mKBreMVbFjs?t=429
( és a ZEN5 -nek átlagosan 19% IPC növekménye lesz ( + 5.8 -5.9 Ghz ) -
S_x96x_S
AMD confirms Ryzen 8000 AM5 desktop series will feature Zen5 CPU and Navi 3.5 GPU architectures
https://videocardz.com/newz/amd-confirms-ryzen-8000-am5-desktop-series-will-feature-zen5-cpu-and-navi-3-5-gpu-architectures -
S_x96x_S
"Zen 4c: AMD’s Response to Hyperscale ARM & Intel Atom"
https://www.semianalysis.com/p/zen-4c-amds-response-to-hyperscale
Core Area dropped by 35.4% for Zen 4c vs Zen4, which is remarkable as it is inclusive of the 1MB L2 cache on each. While this means the L2 SRAM Cells take up the same area, AMD were able to reduce the area of the L2 Region by making the L2 control logic more compact. Excluding the L2 and Chip Pervasive Logic (CPL) Regions, the core shrank by an incredible 44.1%, with the engine (Front End + Execution) area nearly being cut in half.This is what Papermaster is referring to, an amazing feat of engineering as Zen 4c is fundamentally the same design as Zen 4 with the same IPC, just implemented and laid out differently. The Floating Point Unit (FPU) did not shrink to quite the same degree, likely due to thermal hotspots, as the FPU is usually the hottest part of the core when heavily stressed. We also note that the SRAM Cells within the core itself also seem much more compact, with a 32.6% area reduction. You can see this clearly with the Page Table Walker on the bottom right."
As seen in our Zen 4 core annotations, there are numerous partitions for each logical block within the core, but this is drastically reduced in Zen 4c with just 4 partitions (L2, Front End, Execution, FPU). By merging those partitions from Zen 4, the regions can be packed closer together, adding another avenue of area saving by further boosting standard cell density. One can say that AMD’s Zen 4c ‘looks like an ARM Core’.
S_x96x_S
2 hír.
1.)
egy érdekes bug; avagy nem árt évente újrainditani a gépeket.
"AMD's EPYC Rome Chips Crash After 1,044 Days of Uptime"
https://www.tomshardware.com/news/amds-epyc-rome-chips-could-hang-after-1044-days-of-uptime
2.) "AMD Talks Hybrid Ryzen CPU Concepts, Avoiding Intel's AVX-512 Problem"
https://www.tomshardware.com/news/amd-talks-hybrid-ryzen-cpu-concepts-avoiding-intels-avx-512-problemha felületesen értelmezem,
akkor a ZEN5 -öt egyáltalán nem fogják a ZEN4C -vel összepárosítani,
- pedig régebben voltak ilyen pletykák is
- és mert az zen5-ben vannak újabb avx-512 -es utasítások, ami a zen4-ben nincs meg. -
S_x96x_S
Alogonomus #8783 üzenetére
> A 3 nm-en gyártott monolitikus gigachip esetén viszont biztosan jelentős haszonról
> kellene lemondani az Intelnek ahhoz, hogy reális opció legyen a Zen 5 ellenében.fontos a költség ..
de szerintem ez önmagában nem kizáró ok.
lehet, hogy a monolitikus résznél csak a cpu-s részre gondoltak és nem a teljes chipre.
de amúgy még az nVidia is monolitikus design-al hasít a GPU piacon és jól megvan.ezen kivül már eleve a költségeket és a várható árat is előre megtervezik a TSMC-s kontrakt árak alapján. Ha az Intel magas volument tud biztosítani, akkor ez kevésbé lesz gond, hasonlóan mint az Nvidiánál.
És mivel a notebook piacon az Intel dominál - a 3nm-es 8+32 -es CPU
a 16 colos notebook workstation-be ideális lesz.
És egy mobil RTX 4080 / RTX 4090 mellett nem fogják nézni, hogy az intel +50% -al árazza a prociját.
Ha valakinek a legjobb kell, akkor megfizeti a prémium árat.
( és most az AI developereknek kell az erős mobil vas és meg is tudják fizetni )
Amúgy is a TSMC csökkenti a 3nm-es árait, úghogy nehéz megbecsülni a jövőt.
( ... TSMC Might Cut 3nm Prices to Lure AMD, Nvidia ) -
S_x96x_S
Petykemano #8784 üzenetére
> 2024Q4-re simán megjelenhet desktopon egy 8P + 16E magos Zen5+Zen5c változat.
Ezzel egyetértek,
de azon spekulálok, hogy szerintem ez nem biztos, hogy elég lesz.
bár a Zen5c valószínűleg nem lesz lebutitva 1 szálra,.
de a sok lúd disznót győz .. ( mivel a másik oldalon: 8+32 )a korai tesztek alapján durván +15% Cinebench R23 MT várhatunk a zen5-től ( a zen4-hez képest ) és itt még az esetleges extra 3D-Vcache hozzáadása se segít, mert érzéketlen rá.
vagyis Cinebench R23 MT -ben
a papírforma alapján az Intelnek - van esélye +25% teljesítménnyel nyerni.viszont megvan az a remény,
hogy a Cinebench új verziója már támogatni fogja az AVX-512 -őt.Még lehet reménykedni a 3 chipletes AM5 -ben is (1x8 Zen5 + 2x 16 zen5c -vel) ami már 40 mag. De ehhez annyira át kellene tervezni az I/O die-t, hogy extrém kicsi esélyt adok rá, hogyha eddig nem kezdték el.
A pozitiv olvasata az egésznek: Lesz egy kis verseny és a verseny jó!
Mindenesetre kíváncsi leszek az AMD válaszára. -
S_x96x_S
Alogonomus #8776 üzenetére
A koronát szeretné újra megszerezni az Intel!
- Vagyis a "költség" itt nem annyira számít;
- és az ide elköltött többlet összeg a marketing hatékonyságát is megnöveli.
- És ahol számít majd az ár, ott majd az Intel 20A -al gyártott termékek lesznek terítve.vagyis jó stratégiának tűnik az Intel terve.
Az Intelnek valamit fel kell mutatnia,
hogy visszaszerezze az ügyfelek és a befektetők bizalmát.HA
- A sliden látható +30-40% ST ( a raptor-hoz képes ) - meglesz
- valamint az extrém 40 magos MT - is sikerül. ( a 3nm ideális a kis magoknak )
AKKOR
- az amd -nek nem lesz könnyű választ adnia.
- nem épthet arra, hogy az Intel majd megcsúszik a határidőkkel.míg az ST -re: a ZEN5 + 3DVcache ~ talán kiegyenlíti a versenyt.
de az extrém nagy MT -re mi lesz az AMD válasza?Talán lesz egy mini Threadripper ( ZEN5-el) ; de az se elég a desktop korona megtartásához. Ahhoz az AM5-be kellene egy ütős proci.
más:
Azt lehet tudni, hogy lesz-e AVX-512 + AMX az új intel hibrid desktop procikban? -
S_x96x_S
( konkurencia .. )
érdekesség:
a jövőben (2024 Q4) várható Intel proci TSMC 3nm -en;
Az Intel 8+32 ( Lion Cove + Skymont ) ellen - vajon a Zen5 + ZEN5c X.db mag elég lesz?
így darabszámra az AMD-nek 3 db chiplet-et kellene betokozni az AM5-be,
1db ZEN5 ( 8 core ? )
2db ZEN5c ( 16 core ? ) -
S_x96x_S
Petykemano #8773 üzenetére
> Mi300
izgi ...
abban reménykedek, hogy lesz Threadripperes verziója is az MI300A -nak. :-)friss tippelés mi várható:
https://www.theregister.com/2023/06/01/amd_june_event_preview/"Curiously, it appears AMD may not be using the same chiplet architecture found in last year's Epyc 4 Genoa series. The MI300A renderings appear to show two core-complex dies (CCDs) – what AMD calls its CPU chiplets. Judging from the picture, which could be obfuscated or just wrong, AMD may actually use two 16-core CCDs, like the ones we expect to find on Bergamo – more on that later – rather than two 12-core CCDs. Dual 16-core CCDs would be too many cores, but it's not uncommon for AMD to disable cores on its CCDs, bringing the working number down from 32 to 24."
"The MI300A is shaping up to be a proper APU with direct die-to-die communications and a shared pool of memory. Grace-Hopper differs in that it glues together a 72-core Arm-compatible CPU processor with a 96GB H100 GPU using Nvidia's NVLink-C2C interconnect."
S_x96x_S
versenytárs: új Arm magok.
Arm Unveils 2023 Mobile CPU Core Designs: Cortex-X4, A720, and A520 - the Armv9.2 Family
https://www.anandtech.com/print/18871/arm-unveils-armv92-mobile-architecture-cortex-x4-a720-and-a520-64bit-exclusive
"Cortex-X4: IPC Uplift, Scalable up to 14-Cores, Up to 32 MB L3 Cache"
" the Cortex-X4 will deliver a 15% IPC uplift at iso-frequency and iso-bandwidth versus the Cortex-X3 used in last year's flagship Android SoCs. There are a number of factors at play here in delivering that total performance improvement, including front-end optimizations and improvements, as well as a larger L2 per core cache of 2 MB and a larger L1D-TLB, which is a cache designed for recently accessed page transitions."
S_x96x_S
>> "Ark Invest believes that will
>Juj, csak nem szemelyesen Fa Katika?
Azért nem kell mindent "magyarosítani" vagy "honosítani" ( ~ Verne Gyula szindróma )
de ha mégis, akkor a "Z_A_P" -t hogyan lehetne magyarítani? "R_O_B_B" ??
Catherine D. Wood
https://ark-funds.com/about/ "As Chief Investment Officer (“CIO”) and Portfolio Manager, Cathie led the development of ARK’s philosophy and investment approach and has ultimate responsibility for investment decisions."
Van egy jelentős különbség egy fórumhuszár és egy befektetési alap között.
Az utóbbi saját és a befektetők pénzét is kockára teszi, vagyis saját bőrére megy - ez a "skin-in-the-game" koncepció. Tehát, ha a befektetés nem hozza a várt eredményt, ő is veszteséget szenved.Viszont itt a fórumban a vélemények és a tévedések nem járnak olyan nagy következményekkel.
S_x96x_S
jön a kibelezett ( ~ leegyszerűsített ) X86 ISA
X86-S ISA External Architectural Specification
Envisioning a Simplified Intel Architecture
https://www.intel.com/content/www/us/en/developer/articles/technical/envisioning-future-simplified-architecture.html"This whitepaper details the architectural enhancements and modifications that Intel is currently investigating for a 64-bit mode-only architecture referred to as x86S (for simplification). Intel is publishing this paper to solicit feedback from the ecosystem while exploring the benefits of extending the ISA transition to a 64-bit mode-only solution. "
What Would Be the Benefits of a 64-bit Mode-Only Architecture?
A 64-bit mode-only architecture removes some older appendages of the architecture, reducing the overall complexity of the software and hardware architecture. By exploring a 64-bit mode-only architecture, other changes that are aligned with modern software deployment could be made. These changes include:
- Using the simplified segmentation model of 64-bit for segmentation support for 32-bit applications, matching what modern operating systems already use.
- Removing ring 1 and 2 (which are unused by modern software) and obsolete segmentation features like gates.
- Removing 16-bit addressing support.
- Eliminating support for ring 3 I/O port accesses.
- Eliminating string port I/O, which supported an obsolete CPU-driven I/O model.
- Limiting local interrupt controller (APIC) use to X2APIC and remove legacy 8259 support.
S_x96x_S
Alogonomus #8764 üzenetére
> arm ...x86
vanak ám extrémebb vélemények is.
És a 27%-hoz képest már az 50% -is optimizmus .."Ark Invest believes that will change over the next 10 years, because ARM CPUs are becoming faster and cheaper. To that end, Ark estimates that ARM and RISC-V will hold 71% market share by 2030, while x86 chips will drop to 27%."
majd meglátjuk
.. egyenlőre minden végkifejlet lehetséges. -
S_x96x_S
Alogonomus #8762 üzenetére
> , így az ARM alapú termékek nem jelenthetnek komoly konkurenciát az évtizedek óta
> kialakult x86-os "nagygépes" területen,
> mert túl sokba kerülne újraalkotni a szoftvereket
> az ARM utasításkészlet lehetőségei menténA véleményem szerint a dolgok más irányba haladnak.
A cloud-alapú megoldásokhoz jelenleg a gyengébb ARM magok is megfelelő teljesítményt nyújtanak, és ha kijönnek az erősebb ARM magok, akkor még nagyobb lesz az AMD számára az ARM felőli nyomás.
Ez a tendencia már hosszú ideje folyamatban van:
- A GCC/Clang/LLVM programozási környezetek már most is jól támogatják az ARM architektúrát.
- Az amerikai fejlesztők többsége az Apple M1 és M2 chipjeivel felszerelt gépeken dolgozik, és sok alkalmazás kap extra ARM optimalizációt. Az ARM alapú Windows operációs rendszer pedig csak most kezd teret nyerni.
- Jelenleg az ARM szerverek a piac 6.8%-át birtokolják, de a várakozások szerint ez az arány az év végére 8%-ra fog növekedni.Az AMD piaci részesedése ezzel szemben várhatóan 20%-ra fog emelkedni. Az ARM felemelkedése, különösen a cloud szegmensben, egyre komolyabb versenyt jelent az AMD számára.
Nem kell pánikolni, de nem árt figyelni ..
S_x96x_S
Elemzés/Piac: ( Ian Cutress; Anton Shilov ; .. )
Experts Weigh Impact of Intel-Arm Collaboration ( 2023-05-15 )
https://www.eetimes.com/experts-weigh-impact-of-intel-arm-collaboration/
Egyenlőre egyesek nagyon optimisták az Intel GAA 18A irányába
"“I would expect Intel’s GAA to be higher-performance than other foundry options—in part because of the adoption of PowerVia [and also differences in transistor implementation]," -
S_x96x_S
az AVX-512 következménye .. ( Z1 APU )
"Asus Ally Emulates PS3, Nintendo Switch, Xbox 360 with Ease"
Who says you can’t fit an Xbox 360 in your pocket?
https://www.tomshardware.com/news/asus-rog-ally-emulation-performancevideo:
The ASUS ROG Ally Can Emulate It All! Past The Edge Of What Other Handhelds Can Do
https://www.youtube.com/watch?v=vTwyjArlsaI&t=5s
"The ASUS ROG Ally Is The Best Emulation Handheld we’ve ever seen! It Can Run the PS3 Version Of God Of War 3 at 60FPS using RPCS3, Emulate Nintendo Switch, PS2,PSP,3DS,Will U, Gamecube, Xbox, Xbox 360 and More!
The Z1 Extreme Rdna3 APU has taken handheld to the next level for sure." -
S_x96x_S
( Mercury Research - 2023Q1 )
"AMD and Intel CPU Market Share Report: Recovery on the Horizon (Updated)"
https://www.tomshardware.com/news/amd-and-intel-cpu-market-share-report-recovery-looms-on-the-horizonDesktop PC Market Share Q1 2023: AMD vs Intel :
AMD: 19.2% ( +0.6 Q / +0.9 Y )
"AMD gained a small amount of desktop client CPU share; both Intel and AMD experienced declines in shipments, but AMD's declines were slightly smaller than Intel's resulting in a small share gain," said McCarron.Notebook / Mobile Unit Market Share Q1 2023: AMD vs Intel
AMD: 16.2% ( -0.2 Q / -6.3 Y )Server Unit Market Share Q1 2023: AMD vs Intel
AMD: 18% ( +0.4 Q / +6.3 Y )Overall x86 Market Share Q1 2023: With IoT and Semi-Custom, AMD vs Intel
AMD Overall x86 : 34.6% ( +3.3 Q / +6.9 Y)
Arm vs x86 Consumer Market Share Q1 2023
- Arm Unit Share : 14.8% -
S_x96x_S
NYTimes: "U.S. Focuses on Invigorating ‘Chiplets’ to Stay Cutting-Edge in TechChiplets, a way to design chips for higher performance, has become a key prong of U.S. industrial policy. But pushing for more of this activity domestically is challenging."
paywall nélkül --> https://archive.md/pUgCO#selection-249.0-253.172"Sam Naffziger, an AMD senior vice president, said it wasn’t a slam-dunk for the company to bet its chip business for server computers on chiplets. Packaging complexities were a major hurdle, he said, which were eventually overcome with help from an undisclosed partner.
But chiplets have paid off for AMD. The company has sold more than 12 million chips based on the idea since 2017, according to Mercury Research, and has become a major player in microprocessors that power the web.....
Intel has been developing similar technology, as well as enhancing less-expensive conventional plastic substrates in an approach favored by some such as the Silicon Valley start-up Eliyan. Intel has also been developing new packaging prototypes under a Pentagon program and hopes to win CHIPs Act support for a new pilot packaging plant.
S_x96x_S
óvatosan a TPM-el ;
[Submitted on 28 Apr 2023]
faulTPM: Exposing AMD fTPMs' Deepest Secrets
https://arxiv.org/abs/2304.14717
HN comments: https://news.ycombinator.com/item?id=35787195
github: https://github.com/PSPReverse/ftpm_attackfőleg a Windows+Bitlocker-es tulajoknak kell vigyázni
"Furthermore, we lay out how any application relying solely on the security properties of the TPM - like Bitlocker's TPM- only protector - can be defeated by an attacker with 2-3 hours of physical access to the target device."extra password sose árt .. csak a TPM-ben bizni balgaság ..
S_x96x_S
holnap késő este ( May 2, 2023 ) vagy inkább máj3 hajnal -ban
teszi közzé az AMD a 2023 Q1-es eredményeket.Addig is lehet találgatni ..
"first quarter 2023 financial results on Tuesday, May 2, 2023, after the close of market. Management will conduct a conference call to discuss these results at 5:00 p.m. ET / 2:00 p.m. PT. "szerintem a szerver továbbra is erős ..
S_x96x_S
S_x96x_S #8731 üzenetére
egyesek szerint nagyobb a füst ..
AMD Ryzen 7000 series burn issues. Our Investigation, based on REAL data!
"From the moment the mainboard manufacturers started releasing BIOS to cope with this issue, it won’t be anything important if you ask me. I’ve already talked to some of my industry contacts, who told me that the RMA rates of the 7000 series are lower than those of the 5000 series, so don’t let these stories prevent you from getting a new AMD CPU."
https://hwbusters.com/cpu/amd-ryzen-7000-series-burn-issues-our-investigation-based-on-real-data/ -
S_x96x_S
CPU - Mindfactory (Német ) retail eladási stat :
( ~ német ízlés )furcsa
. nincs egyetlen egy AM5-ös eladás se ... ami nekem eléggé valószínütlen.
🔥 CPU Retail Sales Week 17AMD: 2140 units sold, 59.78%, ASP: 311.29 (Euro)
Intel: 1440, 40.22%, ASP: 282.58AMD revenue: 666'167.5, 62.08%
Intel: 406'918.4, 37.92%
https://twitter.com/TechEpiphany/status/1520514665079529472 -
S_x96x_S
Alaplapok - Mindfactory (Német ) retail eladási stat :
( ~ német ízlés )
Mainboard Retail Sales Week 17 2023 (mf)
AMD: 2095 units sold, 68.13%, ASP: 176
Intel: 980, 31.87%, ASP: 193
AMD revenue: 368766, 66.14%
Intel: 188781, 33.86%
ℹ️ By socket:
AM4: 1305
1700: 860
AM5: 790
1200: 120
ℹ️ Bestsellers:
AM5: MSI MAG B650 TOMAHAWK WiFi (=)
AM4: MSI MPG B550 Gaming Plus (=)
1700: Gigabyte B760 GAMING X DDR4 (=)
https://twitter.com/TechEpiphany/status/1652111290867785728 -
S_x96x_S
Petykemano #8730 üzenetére
> Wow Vajon mi készül majd ott?
Szerintem ez valamilyen deal része ... valamilyen viszonosság ...
de majd meglátjuk ...
2023-04-11: "Tovább licenceli az AMD Radeon IP-ket a Samsung"
https://prohardver.hu/hir/samsung_tovabb_licencel_amd_radeon_ip.html -
S_x96x_S
qwe8585 #8723 üzenetére
> Ez elégé szánalmas így cirka 7 hónap után
Mihez képest?
MF complaint rates:
7800X3D: 0.03%
5800X3D: 0.37%
13700K: 0.57%
https://twitter.com/TechEpiphany/status/1651473318615171074 -
S_x96x_S
AMD signed to use Samsung Foundry 4nm
https://twitter.com/OreXda/status/1652931486528716800
( via https://wccftech.com/amd-shifting-to-samsung-4nm-technology/ )
- BESZÁMÍTÁS! MSI B450M R5 5500 16GB DDR4 512GB SSD RTX 2060 Super 8GB Rampage SHIVA ADATA XPG 600W
- NEC MultiSync V421 monitor (42") 1920 x1080px
- LG 55G2 - 55" OLED evo - 4K 120Hz 1ms - 1100 Nits - NVIDIA G-Sync - FreeSync Premium - HDMI 2.1
- Kingmax 1x2GB DDR2 800 RAM eladó
- ÁRGARANCIA! Épített KomPhone i5 14400F 16/32/64GB RAM RX 9060 XT 16GB GAMER PC termékbeszámítással
