divan
válasz DroiDMester #58312 üzenetére
Magicsee N5 Max ügyben nincs újabb fejlemény? Nem sikerült helyrerakni a lan részét? Én is várok egy ilyet, kiváncsi leszek az milyen alkatrészekből összerakott lesz.
divan
Megjött a Magicsee N5MAX-om. Úgy tűnik szerencsés vagyok, Android alatt.
Letöltés:[ ID] Interval Transfer Bandwidth
[ 4] 0.00-1.00 sec 100 MBytes 839 Mbits/sec
[ 4] 1.00-2.00 sec 106 MBytes 890 Mbits/sec
[ 4] 2.00-3.00 sec 104 MBytes 874 Mbits/sec
[ 4] 3.00-4.00 sec 105 MBytes 883 Mbits/sec
[ 4] 4.00-5.00 sec 103 MBytes 867 Mbits/sec
[ 4] 5.00-6.00 sec 104 MBytes 877 Mbits/sec
[ 4] 6.00-7.00 sec 105 MBytes 883 Mbits/sec
[ 4] 7.00-8.00 sec 106 MBytes 885 Mbits/sec
[ 4] 8.00-9.00 sec 104 MBytes 872 Mbits/sec
[ 4] 9.00-10.00 sec 106 MBytes 886 Mbits/sec
[ 4] 0.00-10.00 sec 1.02 GBytes 876 Mbits/sec sender
[ 4] 0.00-10.00 sec 1.02 GBytes 876 Mbits/secFeltöltés:
[ 5] 0.00-1.00 sec 94.1 MBytes 789 Mbits/sec
[ 5] 1.00-2.00 sec 107 MBytes 897 Mbits/sec
[ 5] 2.00-3.00 sec 105 MBytes 883 Mbits/sec
[ 5] 3.00-4.00 sec 106 MBytes 893 Mbits/sec
[ 5] 4.00-5.00 sec 107 MBytes 899 Mbits/sec
[ 5] 5.00-6.00 sec 106 MBytes 889 Mbits/sec
[ 5] 6.00-7.00 sec 96.8 MBytes 812 Mbits/sec
[ 5] 7.00-8.00 sec 95.7 MBytes 803 Mbits/sec
[ 5] 8.00-9.00 sec 93.2 MBytes 782 Mbits/sec
[ 5] 9.00-10.00 sec 94.4 MBytes 792 Mbits/sec
[ 5] 10.00-10.04 sec 3.64 MBytes 832 Mbits/sec
[ 5] 0.00-10.04 sec 0.00 Bytes 0.00 bits/sec sender
[ 5] 0.00-10.04 sec 1010 MBytes 844 Mbits/secCoreelec alatt.
Letöltés:
[ 5] 0.00-1.00 sec 97.9 MBytes 821 Mbits/sec
[ 5] 1.00-2.00 sec 105 MBytes 880 Mbits/sec
[ 5] 2.00-3.00 sec 105 MBytes 880 Mbits/sec
[ 5] 3.00-4.00 sec 106 MBytes 888 Mbits/sec
[ 5] 4.00-5.00 sec 107 MBytes 901 Mbits/sec
[ 5] 5.00-6.00 sec 106 MBytes 885 Mbits/sec
[ 5] 6.00-7.00 sec 105 MBytes 883 Mbits/sec
[ 5] 7.00-8.00 sec 105 MBytes 884 Mbits/sec
[ 5] 8.00-9.00 sec 106 MBytes 887 Mbits/sec
[ 5] 9.00-10.00 sec 105 MBytes 879 Mbits/sec
[ 5] 10.00-10.04 sec 4.13 MBytes 884 Mbits/sec
[ 5] 0.00-10.04 sec 1.03 GBytes 879 Mbits/secFeltöltés:
[ 4] 0.00-1.00 sec 109 MBytes 913 Mbits/sec
[ 4] 1.00-2.00 sec 112 MBytes 938 Mbits/sec
[ 4] 2.00-3.00 sec 112 MBytes 939 Mbits/sec
[ 4] 3.00-4.00 sec 104 MBytes 876 Mbits/sec
[ 4] 4.00-5.00 sec 110 MBytes 926 Mbits/sec
[ 4] 5.00-6.00 sec 112 MBytes 941 Mbits/sec
[ 4] 6.00-7.00 sec 112 MBytes 939 Mbits/sec
[ 4] 7.00-8.00 sec 112 MBytes 938 Mbits/sec
[ 4] 8.00-9.00 sec 112 MBytes 940 Mbits/sec
[ 4] 9.00-10.00 sec 112 MBytes 938 Mbits/sec
[ 4] 0.00-10.00 sec 1.08 GBytes 929 Mbits/sec
[ 4] 0.00-10.00 sec 1.08 GBytes 929 Mbits/secLegújabb Nightly szépen felment rá, távirányító, kijelző még nincs, ma már nem is lesz. Holnpra marad.
divan
válasz junkpod #58648 üzenetére
A korábban DroiDMester által ajánlott linken, 38 dollárért, de a 32 G már kifogyott nála, csak 64-es van, így már 47 $ az ára. Én még a 32-eset vettem (és fizettem) de 64-eset küldtek.
Android verzióra annyit ír: 9. Ma valamikor, ha lesz időm szétszedem, és lefényképezem.Viszont betettem telepítés előtt az sd gyökerébe az általad linkelt rc_maps.cfg fájlt, de nem működik a távirányító. Mit kell még vele csinálni, hogy jó legyen?
divan
válasz Valkűr #58669 üzenetére
De hogy akartál felszín hangot letölteni, ha csak áll a Coreelec feliratnál?
Amúgy nekem is ezt csinálja most, szólt, hogy van újabb verzió, frissítem e, de a Coreelec boot képernyőnél, áll, és nem megy tovább. Lehet valamit félreírtak benne, vagy nem kompatibilis minden géppel?
Szerintem megcsinálom újra az sd kártyát az új nighly-val.[ Szerkesztve ]
divan
válasz meridaharcos #58694 üzenetére
Én augusztus 22-én.
Ahhoz, hogy menjen a bekapcsoló gomb is, akkor a BL301.BIN Injection-t kellene megcsinálnom?
divan
válasz junkpod #58015 üzenetére
Megcsináltam az injectiont, a .config mappában nekem nem volt config.ini fájl. Bemásoltam, de így sem működik. De már előtte is gyanús volt, hogy miért nincs ott. Elsőre az injection sem ment végig, ahogy lefutattam kiírta a hosszú szöveget, amit kell, kérdezte, hogy folytatom e, mondtam igen, erre visszadta a kurzort egy szó nélkül. Másodjára már megjött a visszaigazolás, hogy végrehajtotta feladatot. Lehet, hogy még mindíg nem volt teljes a folyamat, mert nem jött létre a config.ini fájl?
divan
Még mindig küzdök a bekapcsolással.
Az injection elvileg végigment rendesen, mert ha újra futtatom, akkorUpdate of BL301.bin on eMMC is not needed, exit
now... az üzenet.
Viszont nekem ott nem jött létre config.ini fájl, csak bemásoltam oda.
Csak hogy tisztázzuk, a .config mappában
kell ennek lennie, vagy esetleg nem jól értelmeztem valamit??[ Szerkesztve ]
divan
válasz DroiDMester #58910 üzenetére
Így már működik, köszönöm.
divan
válasz junkpod #59003 üzenetére
N5MAX:~ # ethtool eth0
Settings for eth0:
Supported ports: [ TP MII ]
Supported link modes: 10baseT/Half 10baseT/Full
100baseT/Half 100baseT/Full
1000baseT/Full
Supported pause frame use: No
Supports auto-negotiation: Yes
Supported FEC modes: Not reported
Advertised link modes: 10baseT/Half 10baseT/Full
1000baseT/Full
Advertised pause frame use: No
Advertised auto-negotiation: Yes
Advertised FEC modes: Not reported
Link partner advertised link modes: 10baseT/Half 10baseT/Full
1000baseT/Full
Link partner advertised pause frame use: No
Link partner advertised auto-negotiation: Yes
Link partner advertised FEC modes: Not reported
Speed: 1000Mb/s
Duplex: Full
Port: MII
PHYAD: 0
Transceiver: external
Auto-negotiation: on
Supports Wake-on: ug
Wake-on: d
Current message level: 0x0000003f (63)
drv probe link timer ifdown ifup
Link detected: yes -
divan
válasz junkpod #59153 üzenetére
Köszönöm szépen! Igazából a droidra semmi szükségem, bár valamiért mindegyik boxomon megtartottam, de sosem bootoltam át hozzá.
Amint időm lesz rá nekikezdek. Abból sajnos kevés van, még belakni sem tudtam, egyelőre nem látja a MySQL adatbázist, azt kell rendbetennem. Csak este érek haza, akkor a tv használatban van, ha tovább fenn bírok maradni mint a család, akkor tudom csinálni. A héten ez nem sikerült.
Köszönöm Csicsókának is. -
divan
divan
Na, rögtön az elején belefutottam egy kis gondba.
[1.039664@1] meson-mmc: [mmcblk0p20] data offset 0x0000ef600000,
size 0x000da0a00000
Tehát sem a legeleje, sem a legvége nem ugyanaz, csak a kivastagított rész, ha beírom a konverterbe, ugyanazt kapom:4016046080[ Szerkesztve ]
divan
válasz junkpod #59302 üzenetére
És ez most amremote, vagy meson-ir?
Nem lehet: Fullscreen video-->Windows--> Open Subtitle Search?Sikerült megcsinálnom a belső memóriából működő data-t. Végül a legegyszerűbb megoldást választottam, amit kovakovi77 is ajánlott, majd újrakezdtem az egészet, így már működik rendesen. Lehet, hogy data törléssel kellett volna kezdeni az egészet?
divan
válasz Valkűr #59537 üzenetére
Az iso az pont, hogy a millió egyezer fájlt tesz egybe egyetlen fájlba.
Szerintem is az lenne a megoldás, hogy csinálsz Film 1, 2, 3 mappákat, az 1-be belemásolod a filmek egyharmadát, a másodikba a 2. egyharmadát, stb. Utána ezeket próbálod beolvastatni. Ha megvan a hibás mappa, lehet szűkíteni, hogy hol a hiba. Biztos, hogy nem CE hiba, azért nem olvasol senkitől ilyet, mert ez a hiba csak nálad jön elő.
Szerintem majdnem mindenki használja a borítókat, így ha lenne ilyen általános hiba, biztosan előjött volna már másnál is.[ Szerkesztve ]
divan
Na akkor Magicsee N5MAX. Sd, a data eMMC.
N5MAX:~ # systemd-analyze
Startup finished in 20.849s (kernel) + 3.768s (userspace) = 24.618s
kodi.target reached after 3.763s in userspace
Ez nem túl acélos.A dmesg | grep mmcblk0:
N5MAX:~ # dmesg | grep mmcblk0
[ 4.004352@1] mmcblk0: emmc:0001 Biwin 58.3 GiB
[ 4.004490@1] mmcblk0boot0: emmc:0001 Biwin partition 1 4.00 MiB
[ 4.004620@1] mmcblk0boot1: emmc:0001 Biwin partition 2 4.00 MiB
[ 4.004763@1] mmcblk0rpmb: emmc:0001 Biwin partition 3 4.00 MiB
[ 4.006784@1] meson-mmc: [mmcblk0p01] bootloader offset 0x000000000000, size 0x000000400000
[ 4.006798@1] meson-mmc: [mmcblk0p02] reserved offset 0x000002400000, size 0x000004000000
[ 4.006807@1] meson-mmc: [mmcblk0p03] cache offset 0x000006c00000, size 0x000046000000
[ 4.006930@1] meson-mmc: [mmcblk0p04] env offset 0x00004d400000, size 0x000000800000
[ 4.006941@1] meson-mmc: [mmcblk0p05] logo offset 0x00004e400000, size 0x000000800000
[ 4.006950@1] meson-mmc: [mmcblk0p06] recovery offset 0x00004f400000, size 0x000001800000
[ 4.006959@1] meson-mmc: [mmcblk0p07] misc offset 0x000051400000, size 0x000000800000
[ 4.007054@1] meson-mmc: [mmcblk0p08] dtbo offset 0x000052400000, size 0x000000800000
[ 4.007065@1] meson-mmc: [mmcblk0p09] cri_data offset 0x000053400000, size 0x000000800000
[ 4.007074@1] meson-mmc: [mmcblk0p10] param offset 0x000054400000, size 0x000001000000
[ 4.007084@1] meson-mmc: [mmcblk0p11] boot offset 0x000055c00000, size 0x000001000000
[ 4.007094@1] meson-mmc: [mmcblk0p12] rsv offset 0x000057400000, size 0x000001000000
[ 4.007103@1] meson-mmc: [mmcblk0p13] metadata offset 0x000058c00000, size 0x000001000000
[ 4.007111@1] meson-mmc: [mmcblk0p14] vbmeta offset 0x00005a400000, size 0x000000200000
[ 4.007120@1] meson-mmc: [mmcblk0p15] tee offset 0x00005ae00000, size 0x000002000000
[ 4.007132@1] meson-mmc: [mmcblk0p16] vendor offset 0x00005d600000, size 0x000030000000
[ 4.007140@1] meson-mmc: [mmcblk0p17] odm offset 0x00008de00000, size 0x000008000000
[ 4.007150@1] meson-mmc: [mmcblk0p18] system offset 0x000096600000, size 0x000050000000
[ 4.007160@1] meson-mmc: [mmcblk0p19] product offset 0x0000e6e00000, size 0x000008000000
[ 4.007171@1] meson-mmc: [mmcblk0p20] data offset 0x0000ef600000, size 0x000da0a00000
Az enyémnek 64GB a belső tár, a junkpodé 32 GB. Nem tudom ez számít e?[ Szerkesztve ]
- OLED TV topic
- MIUI / HyperOS topik
- Az EU szerint kartelleztek az indítóakkumulátorok piacán
- Könyvajánló
- Google Pixel 8 Pro - mestersége(s) az intelligencia
- Xbox Series X|S
- AMD konfig (VGA nélkül), 16Gb RAM, 1TB HDD...
- Új 4K Gamer PC Ryzen 9 5900X/RTX 3070 Ti 8Gb/Asus Tuf lap/M2 500Gb NVME/2x16Gb DDR4/750W 2Év gari
- Új AMD Gamer PC R5 5500 vagy R5 5600/RTX 3060 12Gb/500Gb M2 SSD/16Gb DDR4 3200Mhz/700W 2-3Év gari
- Új Gamer PC R5 5500 vagy R5 5600/RTX 4060 vagy RTX 4060 ti 8G/500Gb M2 SSD/16Gb DDR4/700W 2-3Év gari
- Asztali PC , i5 6600 , GTX 980 4GB , 32GB DDR4 , 256GB SSD , 500GB HDD
