lacko6
Ez is érdekes MX Plus [link] aka Tronsmart Vega s95 Pro.
Érdemes megemlíteni hogy hálózaton (SMB) mennek a BDremuxok (sorozat 10GB/45 perc) akadás nélkül. Még tesztelés alatt...De média playerként elég az 1GB ram és csak 12000ft.
Openelec készülőben,kódnév CX A8
lacko6
válasz DoItYourself #81 üzenetére
Igy 40$ jol mutat, de a vege 30000ft minimum.
( lap tap haz posta afa) -
lacko6
New Firmware For Vega S95 Coming,Version 20160309
Here is the changelog:
1) Fix Random volume popup problem;
2) Fix “! “ in Wi-Fi icon;
3) Fix Apps being killed automatically when home button pressed
4) Fix Yomvi app playback issue (our engineer is working hard to fix other App problems reported);
5) Fix "10mb" error when connect to external HDD
6) Add automatic framerate function by request;
7) Add memory clear shortcut in status bar;
8 ) Fix DTS pass-through problem. (should use the official vidon 15.2.3 xbmc, not our last beta release, vidon will push ota update to official 15.2.3 for the old 14.2 users)
9) Fix OTA update problem, now system will inform you a new update , and you can choose to update or keep the current firmware.(apply for next update) -
lacko6
VidOn release 15.2.4 Compiled: Mar 16 2016 [link]
lacko6
válasz DoItYourself #247 üzenetére
Nem volt idom megnezni a vidont de akkor maradok a 3 nal.
lacko6
Mini mx eu raktár [link]
lacko6
New Firmware for Vega S95 released_2016.04.13
Dear Customers:
We are glad to release new firmware_20160413. Firstly, Thanks for the patience of our users to wait about one moth. Depends on the efforts of Amlogic’s engineers, Vidon’s engineers and Tronsmart’s engineers, we are happy to announced we do the following things.
1.Updated the H.265 drivers fix no sound issue with video switching.
2.Fixed streaming issue video, 4K H.265 and HD H.264.
3.Fixed boot issue Tronsmart Opening logo.
4.Fixed random drop out of AC3/DTS on Vidon player.
5.Fixed FF/RW black screen when playing videos
6.Fixed the pink screen on some old TV(Add option: Setting->more setting->force RGB Output, choose on)
7.Add auto frame rate function.
8.Add logs catch function(Settings-->More setting-->Developer option-->Save log)For S95 pro users, we are sorry to ask you wait a little longer, since we find a new bugs even we use the same amlogic sdk and vidon xbmc, we are working hard to check the problem, and once we fix that, we will release the firmware asap. Thanks for your patience.
The OTA update for Telos and Meta will come soon.
Please Note, In this firmware we include the newest vidon xbmc 15.2.3. So even with OTA update, your old kodi settings and adds-on should be reset. So we strongly recommend you back up your kodi adds-on before you do this update. Here is instruction for how to backup:
Na sikerült-e?
Nekem pro van,auto fps bd menü megy a vidonnal és a 2016.03.09 Fw el.
[link] Vidon 15.2.3
lacko6
lacko6
válasz DoItYourself #533 üzenetére
Tronsmarton mar megy az auto fps vidonon.Es a hd hang is elmeletileg.
lacko6
válasz DoItYourself #616 üzenetére
6.95.3 ?
lacko6
válasz DoItYourself #662 üzenetére
Csak masolni kell a dtb.img t a megitrt sdre?
lacko6
válasz DoItYourself #665 üzenetére
akkor nem en benaztam hanem bug
lacko6
válasz DoItYourself #4930 üzenetére
lacko6
válasz DroiDMester #5690 üzenetére
hulladék alkatrészekből vannak összerakva,s905 sem mind egyforma 20-60 usd-ig
lacko6
válasz paparazzi2 #6499 üzenetére
Usb tollal ragd ujra a rendszert.Visszakuldeses minimu 4-5 ezer.
lacko6
Helo.
Mecool KM8 P tv box 8.0-8.0.2a Libreelec.A 100 Lan-on akad minden usb-s lan (100) adapterrel megy.Mi lehet a gond? gyari dtb file kellene vagy csak gyenge a lan?
Jol ertelmezem hagy ez az androidbol kivett dtb.img [link]
Köszi hogyha valaki tudna segiteni.
lacko6
válasz DoItYourself #20236 üzenetére
lacko6
válasz DoItYourself #20239 üzenetére
meg 6.01 van rajta le. teszt megy
lacko6
válasz tibi970307 #21954 üzenetére
8.1.3 hoz a winbe kell fiok jelszot beallitani
lacko6
válasz tibi970307 #21958 üzenetére
neken igy ment,ip konyvtar nev(ami meg van osztva) jelszo
es a regi skin
- Óvodások homokozója
- Hobby rádiós topik
- Gyúrósok ide!
- Minecraft
- Háború Izraelben
- Havi kétszáz leégett tápcsatlakozó fut át egy Los Angeles-i szervizen
- Androidos tablet topic
- Be quiet! Pure Wings 2 140mm PWM High-Speed
- HP EliteDesk 800 G3 SFF / i5-7500 / NVME M.2 / USB Type-C / USB 3.1 / DDR4 / DVD-RW / 27% áfás
- Chia bánya - ELADÓ - 2000+ NFT plottal / 200+ TB
- INTEL MINI PC: Intel J4205 - 256GB SSD - 8GB RAM - BOLTI ÁR TÖREDÉKÉÉRT!
- i7 6700/ 32GB DDR4/ R5 430 2GB DDR5/ 256GB m.2/ Esprimo D756
