Battlefield 1
voodoo98
TSAR DLC FEGYVER UNLOCKOK
Assault
Model 1900 Factory
* Perform 40 kills with the M97 Trench Gun Backbored
* In a round, perform 5 kills with the AT Rocket GunModel 1900 Slug
* Perform 50 kills with the 12G Automatic Extended
*Perform 20 kills with the Gasser M1870 PistolSMG 08/18 Factory
* Perform 15 Kills with the MP18 Trench
* Perform 10 kills with the Anti-Tank GrenadeSMG 08/18 Optical
* Perform 50 kills with the Automatico M1918 Trench
* Destroy 5 tanks with the Anti-Tank MineMedic
Fedorov Avtomat Trench
* Perform 40 kills with the Cei-Rigotti Trench
* Perform 40 squad healsFedorov Avtomat Optical
* Perform 50 kills with the Selbstlader M1916 Optical
* Perform 20 kills with the C96 PistolGeneral Liu Rifle Factory
* Perform 40 kills with the Mondragon Storm
* Perform 30 squad revivesGeneral Liu Rifle Storm
* Perform 50 kills with the Autoloading 8 .35 Marksman
* Perform 30 kills with the Rifle Grenade FRGSupport
Parabellum MG14/17 Low Weight
*Destroy 2 airplanes with LMGs
* Perform 20 kills with the Mortar AirburstParabellum MG14/17 Suppressive
* Perform 40 kills with the Lewis Gun Low Weight
* Perform 50 vehicles repairsPerino Model 1908 Low Weight
* Perform 40 kills with the MG15 n.A Low Weight
* In a round, perform 10 squad resuppliesPerino Model 1908 Defensive
* Perform 50 kills with the BAR M1918 Storm
* Perform 20 kills with the Repetierpistole M1918 PistolScout
Mosin-Nagant M91 Infantry
* In a round perform 3 headshots with the SMLE MkIII Infantry
* Perform 20 kills with the Mars Automatic PistolMosin-Nagant M91 Marksman
* Perform 50 kills with the Gewehr 98 Marksman
* Perform 15 kills with the Tripwire Bomb HEVetterli-Vitali M1870/87 Infantry
* Perform 15 kills with the M1903 Experimental
* Perform 20 periscope spot assistsVetterli-Vitali M1870/87 Carbine
* Perform 50 kills with the SMLE MkIII Carbine
* Destroy 1 Vehicle with K BulletsPilot/Tanker
C93 Carbine
* Perform 40 kills with the FT Light TankPistols
Nagant Revolver
* Perform 20 kills with the Luger P08 PistolObrez Pistol
* In a round, perform 5 kills with the Mle 1903 Pistol[ Szerkesztve ]
Gangsters on the Boardwalk http://play.google.com/store/apps/details?id=com.hattedskull.gangsters
voodoo98
válasz blue01song #29181 üzenetére
Az a baj, h szar lesz sajnos...mondom ezt úgy, hogy cod világból jövök. 16k sok.
(#29183) blue01song
2. vh nekem is nagyon tetszik, de bf1 mellett ez visszaesés![ Szerkesztve ]
voodoo98
válasz prokxy #29187 üzenetére
Marha érdekes, hogy sokan "ittak, isznak" a lanos brigádban, de nagyon ritkán fordult elő, hogy ivott volna vki is. Csak a játék! Cod2-4-6. Pizza az persze alap!
BF1 közben sem szoktam. Nagyon ritka...vhogy nem érzem...Gangsters on the Boardwalk http://play.google.com/store/apps/details?id=com.hattedskull.gangsters
voodoo98
válasz deadwing #29200 üzenetére
Ne érts félre, nyáron majd mindennap ittam valamit (BF1 után). Hétvégén is vannak bulik, nem ezzel van a "gond", hanem azzal, hogy lanon ez vhogy nem volt jellemző. Talán 1 srác bontott egy sört anno.
voodoo98
válasz feco70 #29209 üzenetére
Kicsit változott a battlepack menüje, mást nem vettem észre.
Joker: közben lett magától még egy Nemesis kill-em, tehát meg lett volna, ha nem kapkodok!
Mindenesetre köszi!(#29207) A.C.E.
Bármibe lemerem fogadni, hogy a következő (2018) vagy azt következő BF mindenképpen 2. vh-s BF lesz.[ Szerkesztve ]
voodoo98
válasz Aventador91 #29213 üzenetére
Ment PÜ!
(#29223) Csaber
Cool! Nálunk évente 3-4 lan volt, de most már jó ideje...1 éve kb. nem volt semmi...
(Piálással nincs bajom, csak valahogy lanon sosem éreztem, hogy kéne...mondjuk kocsival mentem/megyek mindig, amiatt sem)Láttam már ezt a videót!
voodoo98
válasz sixpak #29247 üzenetére
Ezt irjak twitteren:
REPORT: With regard to the performance issues of the server machines, the parties in charge have been notified. It's being looked at #BF1.
Itt és itt is irják, hogy tudnak róla és dolgoznak rajta.Elvileg rajta vannak! Reméljük jön a fix asap.
Valszeg ez nem DICE issue, hanem szerver issue, tehát a bérelt szerókkal lehet valami gond...talán...Másik hir:
DICE wants operations in the serverbrowser and more improvements
Reddit linkorosz csaj:
(#29251) Gery9112
Bizony![ Szerkesztve ]
voodoo98
válasz FollowTheORI #29258 üzenetére
Ment is like a tweetekre !
voodoo98
Westie:
INCURSIONS MODE: SCORING EXPLAINED! - Battlefield 1 Incursions (Competitive Mode)Flakfire:
Battlefield 1 Incursions: Everything You Need to Know + Kit Details and Gameplay[ Szerkesztve ]
voodoo98
Korábban írtam sokat a BF1.exe crash-sel kapcsolatban! Úgy látszik kezd megoldódni a dolog:
Tünet:
5-10-20p játék után crashel a BF1.exe. "Battlefield™ 1 has stopped working..."Próbálkozások:
- Windows reinstall, NV driver cserék, stb. is meg volt, nem segített
- mindenféle tuning levétele, segített, de volt h 2 órát ment, volt h 50 perc után crashelt, instabil, hw hiba gyanu
- vga csere 970-re, azzal is jön!
- táp csere és az összes "áram" kábel csere, tápkábel is, de ugyanúgy jön a hiba
- ram teszt, memtest86-tal és windows beépített-tel (ami újraindíttja a gépet), lemegy a teszt rendesen! nem futtattam 5-10 órát, de kb. 1-et igen, lehet többet kellett volnaMegoldás:
Utoljára maradt a ram csere. Miért ne alapon! Hiszen lefutott a ramteszt, erre kiderül, hogy a 4-ből az egyik ram modul a hibás, cserélgetésekkel ki is sakkoztam, hogy melyik. holnap megy gariba!Tesztelés:
Több 10 óra nettó tesztelés és nem jött crash...kopp-kopp. 64-es CQ! Főleg orosz mapokon!
Ha berakom a hibás ram modult, akkor kb. 15 perc után jött.
Ha van is még valami, a ram biztosan szar!Konklúzió:
- Ram teszt nem feltétlen jelent bármit is. Small FFT és Blend Prime95-ös is lement 40 percet és nem bukott el.
- Nagyon fontos, h a fájdalommentesebb eseteket kell kipróbálni először. Pl.: egy ram csere egyszerűbb, mint egy proci, lap vagy tápcsere! Még egy windows reinstallálnál jobb.
- Ami nagyon érdekes volt számomra, hogy 8gb-tal is tök jól fut a játék, ilyenkor 6.5gb ramot eszik, ha 16gb ram van, akkor meg 10-11-et. Nyilván jobb a több, de 8-cal is elvan. 64-es CQ!Köszönöm a közösségnek a sok segítséget!
voodoo98
válasz Aventador91 #29371 üzenetére
Jaja!! Volt ilyen tegnap! El is buktam az egyik fegyver unlockot, újra meg kellett csinálnom 6 gasser kill!
voodoo98
válasz Aventador91 #29374 üzenetére
Engem a blur-os réteg is k-ra zavar, amit játékra tettek! Single-t is próbáltam tegnap egy pillanatra, ott nincs.
Régi mapokat még nem próbáltam.Gangsters on the Boardwalk http://play.google.com/store/apps/details?id=com.hattedskull.gangsters
voodoo98
válasz Aventador91 #29377 üzenetére
Fákon lehet látni elég jól!
Nekem korábban nagyon tesztettek az éles fák a távolban, mindig figyeltem.(#29378) prokxy
(#29381) Gery9112
Kipróbálom én is. Már terveztem.Viszont a TSAR-os mapokon nincs Frontlines!
Érdekesség:
gondolom más is észrevettem, de a Tsaritsyn az egyik a Volga River map a másik partja a Volga folyónak!
Poén.[ Szerkesztve ]
voodoo98
válasz Aventador91 #29384 üzenetére
Hát igen, ez ilyen "csalás" a fejlesztők részéről. Illetve általában performancia okai is vannak (így gyorsabban fut).
A legutolsó infó az, hogy a DICE keresi a módját, hogy belerakjon egy kapcsolót...jó lenne...Kicsit off:
Modder Gives Battlefield 1942 A HD Remake
First version: Nov 5, 2017
Final version: 2018[ Szerkesztve ]
voodoo98
válasz prokxy #29389 üzenetére
Fákon, a vékony ágak miatt még inkább látszik. De nem csak ott vehető észre, hanem az egész képen látszik, h valami nem stimmel.
Amikor először toltam TSAR mapon nem CTE-n, már rögtön feltűnt és kapcsolgattam a sweetfx-et ki-be, arra gondoltam, hogy nem működik!Forest!
voodoo98
voodoo98
válasz anubis6 #29399 üzenetére
Ezeket, hogyan kell apply-olni sweetfx/reshade-del? (mást én sem merek használni )
(#29401) prokxy
Ok, ha elég sokan lennénk, akkor benne vagyok, mert gondolom úgy nem jönne ki túl sokra![ Szerkesztve ]
voodoo98
válasz anubis6 #29407 üzenetére
Köszi! Én sweetfx-et használom, de ez a reshade-ben van benne...Mafia3-ra raktam össze egy ilyen reshade-s cuccot. Neked vannak konkrét beállításaid?
Nekem csak a TSAR mapon megjelenő blur-ral van bajom! Amit összeraktam elég minimalista, clear, nem performancia igényes beállítás-sereg (talán csak a lumashapren van benne átállítva, semmi más). Joker már előszeretetettel használja!Gangsters on the Boardwalk http://play.google.com/store/apps/details?id=com.hattedskull.gangsters
voodoo98
válasz prokxy #29416 üzenetére
Messzebbre jobban látsz, ad némi előnyt ezáltal...de nem sokat...viszont a szemnek sokkal kellemesebb!
★ Battlefield 1 Real Life Mode v2.4 ★
(ezt valszeg kipróbálom, kár, hogy a többi tsar mapról nincs screenshot, Galicia-ra nagyon kiváncsi lennék!)[ Szerkesztve ]
voodoo98
válasz Pro!Petya #29422 üzenetére
Ez így tényleg nagyon olcsó: € 38.99 = 11 954.7034 Hungarian forints!
(#29424) propetya85
Így van! Sokkal olcsóbb! Annyi, hogy origin-en nincs semmi kockázat, de szerintem cdkeys-en sem sok.
Aki most ruház be, annak érdemes ezt vennie.[ Szerkesztve ]
voodoo98
válasz adly77 #29431 üzenetére
Battlefield 1 Revolution Edition (PC) - MediaMarkt
(#29434) adly77
Nem fog! Illetve nem tudom, hogy a support tud-e abban segíteni, hogy átvinnéd egy másik acc-ra.
Próbáld meg az EA support-t hátha átviszik egy másik accra.[ Szerkesztve ]
voodoo98
válasz Aventador91 #29435 üzenetére
Ez k jó!
voodoo98
válasz Aventador91 #29438 üzenetére
Szerintem is. Nekem 2 db BF3-am van egy acc-on és csak egy stat van hozzá.
voodoo98
válasz anubis6 #29451 üzenetére
Kipróbáltam sok mindent! Nem sikerült túlságosan javítani rajta így hagytam az eredetit.
Viszont az alap mapok nem lett rosszabbak, ez jó.
Ami bevált:
- 120-125% rescale
- FXAA, vagy off
de így meg nem annyira szép, túl szemcsés, így maradtam az eredeti felállásnál...majd 4k-ban!Joker megpihent kicsit!
voodoo98
válasz prokxy #29458 üzenetére
Nem vesz le túl sok fps-t! Amit én használok (csak lumasharpen!), az kb. semmit! Az oldal 6-8 fps-t ír. De hogy teljesen jól kijöjjön a hatása, ahhoz fel kell húzni kicsit a scalet és TAA-t le kéne venni, ami viszont szemcsés lesz.
RECOMMENDED IN-GAME VIDEO SETTINGS
Render resolution: as high as possible
Anti-aliasing: TAA (FXAA for better performance)
Brightness: 50% or higher (depends on your monitor)
DirectX mode: DX11 (important)Konklúzió: elengedtem ezt a dolgot...egyelőre...majd 4k-val pár év múlva.
voodoo98
voodoo98
válasz Gery9112 #29476 üzenetére
Fegyverekről ne is beszéljünk. Obrez pisztoly pl nagyon op szerintem. Legalább 90-91-et sebez. 1 lövésre fekszenek tőle.
Fedorov Avtomat is kedvenc. Mindkét support is elég jó. Mosin-Nagant is tetszene, ha nem lehet nehezen kiütni a Marksman verziót, az még nincs meg.(#29472) prokxy
vagy a cpu vagy a ram nem bírja a kiképzést, nem biztos, h a 0.01v elég lesz, de majd kiderül. Általában 0.05v-ként szoktam első körben játszani, de utána még lehet finomítani, de arra már általában nincs idő/türelem.
Nálam is 4 hónapot ment ugyanúgy, aztán az egyik ram modul beszart, egyébként tegnap kaptam meg az új ramokat, garban cserélték.[ Szerkesztve ]
voodoo98
Van valami ilyesmi érzés bennem is, de a CTE-s emlékeim szerint a marksman egész jó.
De még mindig a SMLE és főleg a M1903-as marksman a kedvenc.[ Szerkesztve ]
voodoo98
Kiemelném a Chromatic abberation option-t, remélem belerakják!
Most már csak a laggot kéne, h megoldják és lehet is játszani!(#29488) Gery9112
Kb így van igen! Mosin-nak és az egyik új SMG-nek a kilockolás majdnem rage kategória (tripwire és tankmine killek), a többi nagyon egyszerű és gyorsan meg van! Indokolatlan szopatás.[ Szerkesztve ]
voodoo98
Kicsit off:
Tannenberg 1914-1918 I Release AnnouncementMagyarul beszélnek benne!!!
voodoo98
Tripwire HE 72-t sebez csak, "természetesen" a HC szerókon is csak 72%-ot, nem a dupláját!
voodoo98
Ezek szerint nem szerver issue, hanem kód:
Battlefield 1 Online Connectivity Issues[ Szerkesztve ]
voodoo98
válasz Németh Péter #29510 üzenetére
Én rárohantam az emberekre egy pisztollyal, lesebeztem őket utána leraktam a tripwire-t és viszonylag elég jól beleszaladtak. De egy pár órába beletelt ez.
voodoo98
Ma vmikor később igérnek egy CTE update-t.
voodoo98
válasz Aventador91 #29515 üzenetére
Nekem nem olyan szar! Szokni kell! Más távolságokra jó mint a többi! De valszeg az SMLE és M1903 jobb.
voodoo98
válasz prokxy #29525 üzenetére
Sajnos úgy, hogy a K/D-nek odab*sz!
Ahogy irtam is, hogy rá kell rohanni emberekre, de előtt egy pisztollyal lesebezni, mert csak 72-et sebez a tripwire HE, ami gáz! Sokszor volt 144-em (multi kell lett volna)! Nagy tömegben gyorsan lerakod és futás, vagy vársz!Gangsters on the Boardwalk http://play.google.com/store/apps/details?id=com.hattedskull.gangsters
(Nem csak) Prohardver!-es BF közösségi discord szerverünk:
[Battlefield Buddies]
- HUAWEI MATEBOOK 13 2020/2021
- DELL G15 5510 - 15,6"FHD IPS 120Hz - i5-10200H - 8GB - 512GB - GTX 1650 - Win11 - Garancia
- Ipad Pro 12.9" 3.Gen ( 2018 ) WIFI+ Cellular. 1 TB !!! , Üzletből, Garanciával, beszámitás
- Canon Powershot SX700 HS fényképező / kamera eladó! Választható tartozékok!
- Lenovo ThinkPad T490 14" FHD IPS i5-8365U 16GB DDR4 512GB NVMe ujjlolv., gar
