Pár hasznos infó érhető el az összefoglalót megnyitvaˇ
****CS:GO OFF TOPIC****
[PH!] Steam Group | Facebook
Ha szeretnél jönni 10-es mixre,discordon jelezd
|PH CSGO Discord | Discord beállítási útmutató |
Láda Drop útmutató| Major infó
OPERATION VANGUARD
- Six community maps added to the Operation Vanguard map group, available for free to ALL CS:GO players.
de_marquis, de_facade, de_season, de_bazaar, cs_workout, and cs_backalley
- The Operation Vanguard Pass is now available. With an operation pass, you'll receive:
- A personal Operation Vanguard Journal
- Exclusive access to the new Operation Vanguard weapon case as a separate timed drop.
- TWO all-new Campaigns: Weapon Specialist and Vanguard. Choose your own path through a series of missions that span the globe, and receive extra weapons or Operation Vanguard weapon cases as a reward.
- Access to two optional campaigns: Maghreb and Eurasia.
- An Operation Vanguard Challenge Coin, which can be upgraded by completing branches of a campaign.
- Active Duty and Vanguard Scorecards, and Friends Leaderboards to track and compare your Competitive --- Matchmaking performance throughout the Operation.
- Operation runs until February 10th, 2015.ARMS RACE
- Friendly Fire has been turned off.
de_stmarc, de_lake and de_safehouse are now available in Arms Race mode.
- Fixed game reporting the wrong name of the player who got to knife level in Arms Race.Major update to Arms Race mode:
- Leaders (players with the highest weapon index) from each team now glow for a short time after attacking.
- The weapon progression list now picks a weapon randomly from 5 fixed weapon categories.
- The number of levels to reach Golden Knife have been reduced to 16.
- Two kills are needed to upgrade with each weapon (unless you get a knife kill or kill the enemy leader).
- Added some new sounds to AR mode.
- To see more of the Arms Race rules changes, see this guide: http://steamcommunity.com/sharedfiles/filedetails/?id=336510139[3]DEMOLITION
- de_shortdust added to Demolition modeDEATHMATCH
- Changed Deathmatch bonus weapon to support all guns.
GAMEPLAY
- When FF is off, bullets no longer penetrate teammates
UI
- Fixed grenades icons in weapon panel obeying the user's HUD color setting
- Fixed Mini-Scoreboard panel not properly hiding a few avatars slots on a full server in casual when you had the Mini-Scoreboard Style set to "Just Show Player Count"
- Fixed the freeze panel overlapping with the info panel.
MISC
- Halloween has come to a grisly end. (sv_holiday_mode set back to 0)
- Fixed rebuy not rebuying nades, defuse kit, or taser correctly.
- Volume of ambient and 1st person sounds have been slightly reduced in "headphones" setting.
- Death Camera music no longer plays while spectating.
- Half-time / Game-end music no longer plays in overwatch mode.
- Fixed bug where 10 second countdown music(s) would play after round end when round end music volume was set to 0.
- Addressed hitches that were caused by synchronous file i/o.Rumor has it:
New missions are rate limited to 4 days
Size is close to 500 MB
Az új fegyverek: [link]
#65313280
válasz shaddy1027 #24019 üzenetére
"- Operation runs until February 10th, 2015."
#65313280
válasz Skilly #24051 üzenetére
Ráadásul semmi érdemleges változtatás/javítás nem volt az update-ben. Az UI ugyanúgy szar, scoreboardnál esik az fps ugyanúgy, a füstöt már meg sem említem... 1 éve stabilan volt 200-250 fps-em natív felbontáson, most örülök ha a fele megvan 1024-en.
De legalább most fizethetünk azért hogy csirkékre vadásszunk deathmatch-en.A mapok kivételesen jók lettek (már amelyikhez volt szerencsém), az új season nagyon bejön.
#65313280
válasz #97716736 #24285 üzenetére
Engem is betalált tegnap valami csutás paraszt hogy szerinte nem fair a trade amit kiraktam, ezért nyom rám egy -repet. Kifejtettem neki hogy hova tegye azt a -repét. Pár gyereknek hihetetlen nagy pofája van csak azért mert sikerült anyuci bankkártyájáról lerántani egy késre valót...
#65313280
Trade ablakban nem lehet megnézni milyen állapotú a skin? WTF Volvo?
#65313280
válasz vorosmarti #24439 üzenetére
Drága egy VACációért.
#65313280
válasz vzsryl #24478 üzenetére
Az úgy lehet hogy a saját játékukat sem győzik javítani/fejleszteni mert összesen 7-en dolgoznak a CSGO-n, nemhogy még cheateket gyártsanak hozzá. Ahhoz még több erőforrás kellene hogy állandóan átnézzék az összes cheat oldalt a legújabb szarságok miatt és azt elemezgessék. Banwave után az ingyenes cuccok 99%-a úgyis megy a levesbe.
Persze abban hiszel amiben akarsz. Illuminati420yoloswag
#65313280
válasz vzsryl #24485 üzenetére
Igen, sajnos az update-k sűrűségéből és minőségéből is érezhető hogy tényleg nem egy 100 fős fejlesztőgárda áll a játék mögött.
Az a baj hogy a Valve úgy működik hogy náluk mindenki azon dolgozik amire jelentkezik. Így 7 ember jutott a CSGO-ra, 30+ a Dotára, többi a Half-Life3-ra ja arra nem -
#65313280
válasz Sziszifeca #24502 üzenetére
sv_cheats 1 nélkül sajnos sehogy. Offline szerveren sv_cheats 1 után pedig ezzel: snd_setmixer Ambient vol 0.0
#65313280
válasz Coccolino_O #24599 üzenetére
Cologne óta semmit nem mutattak. Ha GTR meg f0rest nem teszik oda magukat akkor megint groupstage-n esnek ki. De remélem sikerül összeszedniük magukat.
Fnatic, LDLC, VP lesz így sorrendben. Kivéve ha közben más is kap egy piros pecsétet.
#65313280
válasz Coccolino_O #24602 üzenetére
Amióta odakerült olof és krimz azóta tarolnak mindent, Cologne is csak a NiP szerencséjén múlt. Nagyon jót tett nekik a csere.
#65313280
Kioshima már kiürítette a raktárát és a twitterét is "feltörték". Titan és az Epsilon diszkvalifikálva a DHW-ről.
#65313280
válasz Coccolino_O #24611 üzenetére
Állítólag a steam couldon/workshopon tárolták a cheat-et, így automatikusan letöltődtek amikor LAN-on bejelentkeztek a gépen. ESEA ezt észrevette, szólt a volvonak és gondolom most mindent átnéznek.
Itt van a gyanúsított lista: [link]
#65313280
válasz #97716736 #24666 üzenetére
Én is akartam Titan matricát
(#24676) Coccolino_O: Redditen többször is volt poszt hogy sírnak az x22 fórumon hogy megint elkapta őket a banhammer. Meg írták hogy minden publikusan elérhető cheat előbb-utóbb belekerül a VAC adatbázisába és onnantól már egyre sűrűbben fognak lebukni ezek az oldalak. Tökmindegy mennyire csalnak okosan, azzal csak az overwatch-ot kerülik ki.
#65313280
Valószínűleg Flusha is elkezdhet csomagolni a VACációra. [link]
#65313280
válasz #97716736 #24770 üzenetére
Faruk 'pita' Pita @farukpita (törölt tweet)
It's a fking disgrace to the community and every hardworking player if @csgo_dev put flusha thru to play Dreamhack. Its obvious as it can beSteel
RT if flusha is a cheater
favourite if flusha is a cheaterTaz
Watching more and more strange videos of pro-players, this is just sick, and I'm truly scared of future events. @csgo_dev @DreamHackSeanGares
#justflushathingsPita 2
https://www.youtube.com/watch?v=1LcOiLipzoA
hahahahah..... no commentsNBK
Can't check any video atm but maaaaan.. That clip on mirage was already dodgy..... Where is this going !?Pita
Alot of rumours these days regarding players using cheats. smn first, kqly next, and sadly for the scene there will be more - alot more :/ -
#65313280
"1 new item in your inventory"
Anarchist CS:GO Trading Card
#65313280
válasz pr1mzejEE #25117 üzenetére
Az én DA 3G-m 7 éves, kb 2 éve cseréltem benne mikrokapcsolót, 3 hónapja pedig megkapta egy HA-n vett rossz 2013-as burkolatát, így teljesen patika állapotú. Nekem nagyon bejött ez az egér.
(Akár itt találsz új kapcsolót 500ft-ért, kicserélni meg tényleg nem egy agysebészet.)Get Right nagyon darálta a HR-t, remélem a többi meccsen is így nyomják majd.
#65313280
Kicsit lemaradtam a tegnapi meccsről, de már meg se lep hogy fnatic csalás nélkül nem tud nyerni. Vicc, remélem a szponzorjaik kidobják őket. Undorító egy csapat.
#65313280
válasz wannnabeees #25307 üzenetére
Kb az első CSGO meccs volt amit láttam a Verygames-NiP nuke-on. 14-1re zárta VG az első félidőt, onnantól pedig NiP simán hozta 16-14re. Epic meccs volt.
Most viszont alap köröket buknak apró hülyeségek miatt.
#65313280
Aztaqva mekkora meccs volt ez.
#65313280
Na hajrá NAVI.
#65313280
LDLC semmi nem lenne a buta CZ nélkül. Remélem szarrá lesz nerfelve DHW után.
#65313280
válasz Scrake^;DD #25434 üzenetére
Mert nem pisztoly. Az armor penetration és a firerate közel azonos az AK47-el, és automata fegyverként nincs helye a pisztolyok közt. Ez egy pro-nak annyit jelent hogy van egy AWP-je meg egy AK47-e, vagy 2 rifle-je ahogy pl GTR-tól is láttuk ma párszor.
(#25439) ZeroDK: Kiszedni már csak a skinek miatt sem fogják, de nagyon sok pro reklamált már miatta hogy valamit kezdeni kell vele.
#65313280
Valaki cserélne 10 NiP matricát egy kulcsra?
#65313280
válasz Coccolino_O #25680 üzenetére
Csak drágítva lett meg a firerate csökkent AK szintre.
Head:
CZ75-Auto - Unarmored 138 - Armored 107
M4A4 - Unarmored 131 - Armored 92
AK-47 - Unarmored 143 - Armored 111Chest:
CZ75-Auto - Unarmored 34 - Armored 26
M4A4 - Unarmored 32 - Armored 23
AK-47 - Unarmored 35 - Armored 27 -
#65313280
Ez az m4a1 árnövelés minek kellett?
Napi olof
#65313280
Volvo elvileg patch-elte a nospread/rage trigger és aimbotokat. [link]
- Tudástár Counter-Strike: Global Offensive
