Szeretettel köszöntünk a sztereó otthoni/szobai Hi-Fi világában !
Mezga Aladár
válasz krichd1 #56215 üzenetére
"also features a clock linked asynchronous USB input"
"ClockLink for USB
The Wadia 121 features a new implementation of Wadia’s traditional jitter reduction technology
in the form of a USB input featuring dedicated internal ClockLink.
As in previous versions, the function of ClockLink is to position a master oscillator as near as
possible to the D>A converter chip to reduce transmission-induced jitter. All upstream sources
are then synchronized to the DAC’s oscillator clock signal. With USB Internal ClockLink, instead
of using a clock embedded in the incoming data stream (isochronous audio), a high performance
fixed frequency oscillator located at the point of conversion to analog is used. In the case
of the 121 USB input, the receiver is Asynchronous in function. This means that the 121 is
controlling requests for audio data from your computer. The 121 is managing a buffer and
requesting data from the connected PC as needed to keep the buffer at an optimal level. Our
fixed oscillator located at the DAC is controlling the rate that data is depleted from this buffer
and in effect initiating the requests for additional audio data from the PC. The net result is
that the jitter laden source clock can be ignored and the high performance 121 DAC oscillator
is the only clock used in the conversion to analog process eliminating time related distortions."[ Szerkesztve ]
Accuphase E-306 integrált erősítő eladó.
Mezga Aladár
válasz bajnokpityu #56254 üzenetére
Elég elfogult vélemény.
Főleg úgy h., a streamer rendszereknél nincs probléma a kiolvasással.Accuphase E-306 integrált erősítő eladó.
Mezga Aladár
Adott egy jófajta integrál+tápszürő+dac+streamer linuxos mini pc.
Sajnos sem az integrált, sem a dac nem kikapcsolható távirányítóval(a dac sehogy nem kapcsolható).
Ha ezt a kütyüt a rendszerbe állítom, szerintetek, lesz a hangra valamilyen hatása?Accuphase E-306 integrált erősítő eladó.
Mezga Aladár
válasz simongab #56345 üzenetére
Nagyon átkellet építem, mert borzasztó sz@rok voltak.
Komolyabb terhelésre csak úgy pukkant el a hangszóró készlet h., öröm volt nézni.
A magas/közép az rendszeresen, de volt hogy a mély is tönkrement. Épített quad 405 végfokal mentek.Accuphase E-306 integrált erősítő eladó.
Mezga Aladár
válasz Colos1 #56408 üzenetére
"változik-e a magas hangok tisztasága a páratartalom növekedéséből adódó parciális légnyomáscsökkenés miatt,"
Haha.
Volt valaha a családban egy martin logan hangsugárzó, ha párás volt a levegő akkor hallgathatatlan volt,
Mintha egy nagy gombóc vattát nyomtak volna a fülembe. (Itt csak a páratartalom befolyásolt.)
Azért mert te még nem találkoztál ilyennel az nem azt jelenti nincs és főleg nem azt hogy értelmetlen.Accuphase E-306 integrált erősítő eladó.
Mezga Aladár
Új fórum, ajánlom mindenki figyelmébe.
Mezga Aladár
válasz #71562240 #56567 üzenetére
"Én a kísérleteim és a mindennapi működtetés során is számos észrevehető "bithibát" észrevettem már - ha elég sokáig csinálom a hibák egymásra rakását adott fájl USB-n való "sikeres", "bitperfect" oda-vissza másolgatásával, lejátszhatatlanná válik a fájl, először csak az egyik lejátszószoftverrel, aztán a másikkal, mindegyikkel, illetve előbb-utóbb másolhatatlanná is válik a fájl (amely sokszor másolt fájl esetleg az eredetileg másolni kezdett eredeti fájlhoz képest akár bitazonosnak mutatkozik, továbbra is. Horribile dictu: ugyanezt megtettem már egy-kétszer TCP/IP protokollon is - egyszer részlegesen beszéltem is erről itt."
Ááááááááá... ez nagyon fájt.
Bitperfect Talán nem vétózod meg őket.
Mezga Aladár
válasz krichd1 #56624 üzenetére
Hogy indult a digitális technika.
Nekem jónak tűnik, kár h., a cd-ről nem írnak.
Azt nem tudom h., a ma már nem használt technológiák leírása mennyire fogja érdekelni a topic olvasóit?
(Md, dat, atrac.)
Egy mérnök végzettségű fórumtag belenézhetne, az mindenképpen jó volna.Accuphase E-306 integrált erősítő eladó.
Mezga Aladár
válasz slick-adam #56626 üzenetére
Rated power 290 W (ref. 230V AC 50 Hz; 120V AC 60 Hz)
Standby power <1 W
Idle power <35WAccuphase E-306 integrált erősítő eladó.
Mezga Aladár
Mezga Aladár
Szaktársak.
Ugye jól tudom, az rca végfok bemenetnek a 2V a szabványos?
Mezga Aladár
Mi lenne ha befejeznétek egymás baszogatását!
Mezga Aladár
Talán itt lesz válasz.
Adott egy két szigetelt ér + árnyékolás, interconnect kábel.
A két szigetelt ér megy az rca csati két pontjára. Az árnyékolást szerintetek hogyan kössem be?
Induló, fogadó, vagy mind két oldal.Természetesen a hangminőséget figyelembe véve.
Mezga Aladár
Bocsánat pontatlan voltam.
Tehát a belső két ért kötöm be az rca csatiba(piros/fekete)
A külső sodrott árnyékolást pedig a védő földre.
Csak érdekesség h., az integrált phono bemenetének árnyékolása is egy potenciálon van a védő földel.Accuphase E-306 integrált erősítő eladó.
Mezga Aladár
Mezga Aladár
válasz Lompos48 #56857 üzenetére
Akkor ezek szerint, csak jobban járok ha a sima rca/rca utat választom?
Plusz elektronikát nem akarok belerakni.
A gondolat csak annyi volt, ha már az elő-fok valódi szimmetrikus akkor talán ki lehet használni.(#56858) simongab: Igen van otthon spec. kábel amit annak idején belső kábelezéshez vettem,
az árnyékolást rá kell még varázsolni. Az xlr kanóc miután gyári,(és nagyon drága volt) nem akarom megbontani.[ Szerkesztve ]
Mezga Aladár
válasz robi-k #56861 üzenetére
Az xlr kimenetet 1/2/4V lehet állítani.
"De az lenne a legjobb, ha használnál egy galvanikusan leválasztó audió transzformátort:"
Lehet ezzel ua ott lennék hangban, mint az rca-rca kapcsolaton.
(#56862) Lompos48
"akkor a kimenet kontrukciójától függően akár nagyobb bajt is okozhatsz a direkt kötéssel."Na ezt szeretném elkerülni, és ezért kérdezek butákat.
Mezga Aladár
Kicsit zavaros voltam.
Tehát van egy jófajta integrált ami egy kapcsolóval bontható elő/végfokra, és egy digitális elő-fok/dac.
A bekötés eddig, digitális elő-fok/dac hangerő max., integrált line-in xlr kábellel.
Hétvégén kipróbáltam h., integrált szétválaszt és rca-rca csatin keresztül a végfok bemenetre csatlakozott a
Megfülel, nagyon tetszik, csak egy/két nap után hallani a tyúkbél rca hangját.
És ekkor merültek fel a sokszor érthetetlen kérdések.
Bocs mindenkitől és köszönöm a segítségeket.[ Szerkesztve ]
Mezga Aladár
Mezga Aladár
Teljesen mindegy h., megérti vagy sem, ez megint egy tőle megszokott értelmetlen hsz.
(#57049) Generalhu: Ha valami tetszik, akkor keress egy kereskedőt ahol letét ellenében elvihető meghallgatható. Ha nem tettszik akkor visszaveszik.
- Bemutató Audio-gd Precision 2 erősítő teszt
- Asztrofotózás
- NVIDIA GeForce RTX 3080 / 3090 / Ti (GA102)
- bambano: Bambanő háza tája
- Óra topik
- Ukrajnai háború
- Megérkezett a legújabb és eddigi legátfogóbb 3DMark teszt
- Google Pixel 6/7/8 topik
- iPhone 14 PRO - Arany - Gyönyörű
- iPhone 14 PRO MAX - 2026.10ig Garancia - Független
- Microsoft Surface Book 2in1 Érintős Szétszedhető Laptop Tablet 13,5" -60% i5-7300U 8/256 QHD+ Win 10
- Lenovo Thinkpad T490, 14" FHD IPS, I5-8365U, 16GB DDR4, 256GB SSD, WIN 10/11, Számla, garancia
- Féláron! Új Dell XPS 13 9315 Prémium Érintős Profi Ultrabook 13,4" -50% i7-1250U 16/512 UHD+ Iris Xe
