Huawei P9-P9 Lite OFF topik
petya220
Hát jóóó. akkor popcorn time
"Neked is pörög az agyad a szarokon, amíg a mosoly a szádra kanyarodik."
petya220
petya220
Szép ._. Ezekre nem tudok mit mondani.. aki nem tud olvasni, az ne is tegye..
Egy kis segítség kellene...
Rom forgatás hiba -->host SharedLib: libbacktrace (/media/petya230/3e1413b7-d2dc-46e6-8c44-2c8f28150c60/noug/out/host/linux-x86/obj/lib/libbacktrace.so)
libsepol.report_failure: neverallow on line 349 of system/sepolicy/domain.te (or line 9163 of policy.conf) violated by allow tee default_prop:property_service { set };
libsepol.report_failure: neverallow on line 345 of system/sepolicy/domain.te (or line 9159 of policy.conf) violated by allow hwcamcfgsvr default_android_service:service_manager { add };
libsepol.report_failure: neverallow on line 345 of system/sepolicy/domain.te (or line 9159 of policy.conf) violated by allow perfhub default_android_service:service_manager { add };
Install: /media/petya230/3e1413b7-d2dc-46e6-8c44-2c8f28150c60/noug/out/host/linux-x86/lib64/libunwind.so
libsepol.report_failure: neverallow on line 162 of system/sepolicy/domain.te (or line 8978 of policy.conf) violated by allow tee tee:capability { sys_ptrace };
Install: /media/petya230/3e1413b7-d2dc-46e6-8c44-2c8f28150c60/noug/out/host/linux-x86/lib64/libnativeloader.so
libsepol.check_assertions: 4 neverallow failures occurred
Error while expanding policy
system/sepolicy/Android.mk:144: recipe for target '/media/petya230/3e1413b7-d2dc-46e6-8c44-2c8f28150c60/noug/out/target/product/hi6250/obj/ETC/sepolicy.recovery_intermediates/sepolicy.recovery' failed
make: *** [/media/petya230/3e1413b7-d2dc-46e6-8c44-2c8f28150c60/noug/out/target/product/hi6250/obj/ETC/sepolicy.recovery_intermediates/sepolicy.recovery] Error 1
make: *** Waiting for unfinished jobs....
Aidl: framework <= frameworks/base/core/java/android/accessibilityservice/IAccessibilityServiceConnection.aidl
nothing matches overlay file default_wallpaper.png, for flavor hdpi-v4
nothing matches overlay file default_wallpaper.png, for flavor xhdpi-v4
nothing matches overlay file default_wallpaper.png, for flavor xxhdpi-v4
nothing matches overlay file default_wallpaper.png, for flavor xxxhdpi-v4
warning: string 'candidates_style' has no default translation.
warning: string 'gsm_alphabet_default_charset' has no default translation.
warning: string 'wfcSpnFormat' has no default translation.
#### make failed to build some targets (02:51:42 (hh:mm:ss)) ####"Neked is pörög az agyad a szarokon, amíg a mosoly a szádra kanyarodik."
petya220
Köszönöm!
Bááár, lehet, hogy az ablakon repül az egész... vagy odab@szok neki egyet.. Nem igen akar menni.. sebaj!Nem adom fel, míg egy darabban látsz
Nem adom fel, míg életben találsz
Nem adom fel, míg nem robbanok szét
Míg akad egy kerék
Mit tovább vihetnék
Mi tovább forog mégNeked jó munkát!
petya220
Aaaaaaaaaaaz egy durva buli lehetett...
Csoda, hogy itt vagy velünk
Én csak közel voltam az alkoholmérgezéshez Az első ivászat... van mérték? NINCS
és hát az egyik ős szabály --> Ne keverj! óó, dehogynem kevertünk, mindent is.
Szörnyű volt
De én még mindig szeretem az alkoholt, persze most már, csak mértékkelÁprilisban volt egy kis sütögetésünk, és hát volt alkohol is
Pár sör után, haverom is megérkezett a jó kis erdélyi pálinkájával is, na ki volt az első, aki megkóstolta? persze, hogy én...
emelem fel az üveg, innék belőle, aztán az egyik hülye, véletlen meglökött... a fele az orromba ment --> nyálkahártya --> gyors alkohol felszívódás --> Peti 2 óra pihi a hintaágyon és 2 percenként kérdeztem,hogy miért megy a hinta, mikor a lábammal löktem magam..
De a 2 óra leteltével, olyan józan lettem,hogy az valami hihetlen(amúúgy... megint sokat írtam )
petya220
Lehet, hogy megvan a gond,hogy miért nem fordult le a rom...
Na most majd kiderül, kb 1 óra múlva...[ Szerkesztve ]
petya220
RAW mentés, 4K videó, Távolról kezelhető legyen távirányítóval, illetve telefonnal.
Nagy látószöge legyen és külső akkuról tölthető legyen.DSLR
- RAW pipa
- 4k félpipa drága dslr ami 4k-ban tud felvenni..
- Távolról kezelhető pipa
- telefonnal pipa
- Nagy látószöge félpipa jó objektívval megvan a nagy látószög
- külső akkuról tölthető pipa powerbank + usbFényképezésre dslr-t vegyl! Videózásra... gopro
petya220
félpipa --> Nikon D500 2000 dollár ami 550ezer forint kb.. (és ehhez kell objektívet is venned) hát igen, ez drága.. de 4k! Amúúgy, miért kell neked 4k?
most görgettem le az oldalon... és ezt találtam --> The Nikon D500 is available for pre-order and costs $2,000 (LINK)
szóóval vakvágány. bocsánat[ Szerkesztve ]
petya220
Hát... google. Rákerestem,hogy van-e valami értesítő logout-ra (pl: privát üzi, stb.. ) és a google kidobta ezt --> itt <--
és a hsz-eket nézve Szoszo94 aláírásában bukkantam ráAmúgy.. jó messze laksz tőlem..
Bubus te meg még messzebb...
petya220
oh, értem, nála nincsenek ilyen gondok
help
Olyan php-t szeretnék írni, ami egy adatbázisből grafikont készít...
jelenlegi felállás szerint, van egy homerseklet.db adatbázis
és benne ido | fok mező
egy python script ezt folyton feltölti adatokkal amiket a raspberry nyer ki egy érzékelőből.
Kérdés,hogyan csináljam? xDD valaki tud valami php kódot? mysql-hez találtam, de sqlite3-at használok"Neked is pörög az agyad a szarokon, amíg a mosoly a szádra kanyarodik."
petya220
válasz sebijani1982 #2451 üzenetére
p9l-re nincs ilyen
Pedig szeretnék egyet... nem érdekel,hogy mennyivel nagyobb csak legyen éppségben"Neked is pörög az agyad a szarokon, amíg a mosoly a szádra kanyarodik."
petya220
petya220
válasz bubus66 #2466 üzenetére
Köszi
félreértelmezte a rollback-et.. nem nagy dolog, csak a megoldását még nem tudom..
Szétnyitottam a rollback update.app-ját, és ha csak a recovery-t flasheli vissza, annak is jónak kellene lennie nem? És aztán bejön a 3 gombos"Neked is pörög az agyad a szarokon, amíg a mosoly a szádra kanyarodik."
petya220
Cunaja, media_profiles.xml-t elkérhetem? vagy valakitől akinek p9-e van.
petya220
válasz szemesi69 #2489 üzenetére
örihari.
őőőőő
Az is világos, hogy olyanok írnak le tanácsokat nekem, akik életben nem próbálták ki a FirmwareFinderrel telepített ROM-okat, ha így lenne, már rég oeminfo-t kellene cserélniük. ez vicces, mert én használtam, de nem gond[ Szerkesztve ]
petya220
válasz tolnaisrac28 #2490 üzenetére
Honor 6x-et nem vágom, ne haragudj
petya220
Skacok, egy isten király vagyok
Sikerült olyan bitrátát varázsolni a videóknak, hogy tyűűű.. xDD
csak legyen sd ami bírja ezt..Holnap ha Cunaja oda tudja adni a másik fájlt, akkor boldog leszek és egy rendes script-et összedobok
petya220
Annyira, hogy a p9 topicban is elkértem.. xDDD köszönöm
maxBitRate="40000000" ez p9 lite-nál is ekkora miafene? vagy ez a codec-re tartozik? hm... yap, ez arra, én marha!
viszont ez is ugyanaz --> bitRate="17000000" pedig többet bír a telefont...
petya220
