- Trident Z5 RGB DDR5-7200 CL34-45-45-115 1.40V 32GB (2x16GB)
- BESZÁMÍTÁS! MSI B450M R5 5600X 32GB DDR4 512GB SSD RTX 3080 10GB ZALMAN Z1 Plus Cooler Master 750W
- Okosóra felvásárlás!! Samsung Galaxy Watch 6, Samsung Galaxy Watch 7, Samsung Galaxy Watch Ultra
- GYÖNYÖRŰ iPhone 13 Pro 128GB Sierra Blue -1 ÉV GARANCIA -Kártyafüggetlen, MS3965, 100% Akkumulátor
- Logitech G29 SE Driving Force PC/PS4/PS5
