- Corsair Vengeance 64GB (2x32GB) DDR5 6000MT/s CL40 XMP black kit - ÚJ, bontatlan, garis - ELADÓ!
- HyperX Fury DDR4 - 3200 - CL16 - 16GB RAM (8GB x 2) RGB
- Új, bontatlan Kingston FURY 32GB (2x16GB) DDR5 6000MHz CL36 Beast XMP/EXPO - 2 év bolti garival! -
- ROG STRIX B660-F GAMING WIFI
