- GYÖNYÖRŰ iPhone 12 Pro Max 128GB Pacific Blue -1 ÉV GARANCIA - Kártyafüggetlen, MS3940, 100% Akku
- Új MSI GF63 Thin 15 FHD IPS 144Hz i7-12650H 10mag 16GB 512GB SSD Nvidia RTX 4060 8GB Win11 Garancia
- BESZÁMÍTÁS! ASUS TUF A17 FA707NV notebook - R7 7735HS 16GB DDR5 1TB SSD nVidia RTX 4060 8GB WIN11
- Bomba ár! Lenovo ThinkPad X390: i5-G8 I 8GB I 256SSD I 13,3" HD I HDMI I Cam I W11 I Gari!
- Új Asus 15 Expertbook FHD Nano i5-13420H 4.6Ghz 16GB DDR5 512GB SSD UHD Graphics XE Win11 Garancia
