- HyperX Fury DDR4 - 3200 - CL16 - 16GB RAM (8GB x 2) RGB
- Új, bontatlan Corsair VENGEANCE 32GB (2x16GB) DDR5 6000MHz CL28 RGB KIT XMP - 2 év bolti garival! -
- MacBook Pro 13, 14, 15, 16, MacBook Air M1, M2 M3 M4 bill magyarosítás lézerrel / sapkacserével
- BESZÁMÍTÁS! MSI B550M R9 3900X 32GB DDR4 500GB SSD RX 7800XT 16GB Corsair 4000D Cooler Master 750W
- ÚJ Asus V16 V3607VM - 16" WUXGA 144Hz - Core 5 210H - 16GB - 1TB - Win11 - RTX 5050 - 3 év garancia
- Bomba ár! Lenovo ThinkPad T470s - i5-6GEN I 8GB I 256GB SSD I 14" FHD Touch I Cam I W11 I Gari!
