- G.SKILL Trident Z Neo RGB 32GB (2x16GB) DDR5 6000MHz F5-6000J3238F16GX2-TZ5NR
- Corsair Vengeance 64GB (2x32GB) DDR5 6000MT/s CL40 XMP black kit - ÚJ, bontatlan, garis - ELADÓ!
- HyperX Fury DDR4 - 3200 - CL16 - 16GB RAM (8GB x 2) RGB
- BESZÁMÍTÁS! MSI ThinA15 B7VF-449XHU Gamer notebook - R7 7735HS 16GB DDR5 1TB SSD nVidia RTX 4060 8GB
- LG 55QNED86T3A / QNED / 55" - 139 cm / 4K UHD / 120Hz / HDR Dolby Vision / FreeSync Premium / VRR
- Macbook Air M2 15" 8GB 256GB 100%
- BESZÁMÍTÁS! Dell Precision 5540 notebook - i9 9880H 64GB DDR4 2TB SSD nVidia Quadro T2000 4GB W11
- GYÖNYÖRŰ iPhone 12 mini 64GB Fehér -1 ÉV GARANCIA - Kártyafüggetlen, 100% Akkumulátor
