- BESZÁMÍTÁS! MSI B450M R5 3600X 16GB DDR4 512GB SSD RTX 2060 Super 8GB GameMax STORM Black 600W
- AKCIÓ! Lenovo Legion Slim 5 Gamer notebook - R7 7435HS 16GB RAM 1TB SSD RTX 4070 8GB GDDR6 WIN11
- BESZÁMÍTÁS! ASRock B450 R5 5600X 16GB DDR4 512GB SSD RTX 3060 12GB Zalman Z1 Plus Cooler Master 750W
- CTO Bontott 0perces TÜZES EZÜST MacBook Air 13.6" M4 10C/1G 16GB 512GB Gar.: 1 év APPLE világgar
- BESZÁMÍTÁS! MSI B450 R5 5600X 32GB DDR4 512GB SSD RTX 3080 10GB RAMPAGE Shiva Cooler Master 750W
