- GIGABYTE B760 GAMING X AX WIFI - Garancia 2027.09.06.
- Trident Z5 RGB DDR5-7200 CL34-45-45-115 1.40V 32GB (2x16GB)
- ROG STRIX B660-F GAMING WIFI
- KINGSTON FURY 32GB Beast DDR5 5200MHz CL40 KIT KF552C40BBK2-32
- Samsung Galaxy A23 5G 128GB, Kártyafüggetlen, 1 Év Garanciával
- HIBÁTLAN iPhone 14 Pro Max 512GB Silver -1 ÉV GARANCIA - Kártyafüggetlen, 100% Akkumulátor
- Bomba ár! Dell Latitude E5450 - i5-5GEN I 8GB I 128SSD I 14" FHD I HDMI I Cam I W10 I Gari!
- BESZÁMÍTÁS! MSI B650 R7 8700F 32GB DDR5 512GB SSD RX 6800 16GB Zalman Z1 Plus Cooler Master 750W
