- KINGSTON FURY 32GB Beast DDR5 5200MHz CL40 KIT KF552C40BBK2-32
- GIGABYTE B760 GAMING X AX WIFI - Garancia 2027.09.06.
- Asus TUF Gaming F15 FX507 - 15,6"FHD 144Hz - i5-12500H - 8GB - 512GB SSD - RTX 3050 - 1 év garancia
- BESZÁMÍTÁS! MSI B450 R5 5600X 32GB DDR4 512GB SSD RTX 3080 10GB RAMPAGE Shiva Cooler Master 750W
- HIBÁTLAN iPhone 16 Pro 128GB Desert -1 ÉV GARANCIA - Kártyafüggetlen, MS3945, 92% Akkumulátor
- LG 49WQ95X-W - 49" NANO IPS - 5120x1440 Dual QHD - 144Hz - USB Type-C - HDR 400 - G-Sync - FreeSync
- Epson Workforce DS-530II dokumentumszkenner
