HookR
Érdekesség:
Supermicro X10SDV-16C-TLN4F hivatalos oldal - [link]
- Broadwell-DE D-1587 (16C/32T / 24MB / 1.7GHz / 65W TDP)
- 4x DDR4 DIMM
- 6x SATA3 (6 Gbps)
- M.2 PCIe 3.0 x4 (2242/2280)
- 2x 10GbE LAN / 2x 1GbE LAN
- LG 50QNED85T3A / QNED / 50" - 127 cm / 4K UHD / 120Hz / HDR Dolby Vision / FreeSync Premium / VRR
- BESZÁMÍTÁS! MSI B450 R5 5600X 32GB DDR4 512GB SSD RTX 3080 10GB Zalman Z1 Plus Cooler Master 750W
- MacBook felvásárlás!! MacBook, MacBook Air, MacBook Pro
- GYÖNYÖRŰ iPhone 14 Pro Max 256GB Space Black -1 ÉV GARANCIA - Kártyafüggetlen, MS3766, 100% Akksi
