Csokilama
AxBattler
#37833
Akad ott h87 is.
Chipsethez még ennyit:
"Z87 is to top end chipset. Great for overclocking and SLI and other chipset features.
H87 basically the same as Z87 minus the overclocking abilities, and doesn't support triple SLI
H81 budget level, no overclocking, no sli, limited sata 6gb/s, limited usb 3.0The B85 you mention is a business focused chipset, and it is the budget level with limited options of the other business chipsets." - [link]
- Lenovo P500 - 1650-2690 v3 akár 12 mag/24 szál, 32GB DDR4 RAM, 490W 80+gold táp, számla, 6 hó gar
- BESZÁMÍTÁS! Asus ROG G531GV Gamer notebook - i7 9750H 16GB DDR4 512GB SSD RTX 2060 6GB WIN11
- HIBÁTLAN iPhone 15 Pro Max 256GB Blue Titanium -1 ÉV GARANCIA -Kártyafüggetlen, 100% Akkumulátor
- Bomba ár! Dell Latitude E5550 - i3-4GEN I 4GB I 500GB I 15,6" HD I HDMI I W10 I Cam I Gari!
