- G.SKILL Trident Z Neo RGB 32GB (2x16GB) DDR5 6000MHz F5-6000J3238F16GX2-TZ5NR
- BESZÁMÍTÁS! ASRock B450 R5 5600X 16GB DDR4 512GB SSD RTX 3060 12GB Zalman Z1 Plus Cooler Master 750W
- 24 GB-os RTX 3090 OEM
- Telefon felváráslás!! Samsung Galaxy S22/Samsung Galaxy S22+/Samsung Galaxy S22 Ultra
- REFURBISHED és ÚJ - HP Thunderbolt Dock G2 230W with combo cable (3TR87AA)
- AKCIÓ! LG UltraFine 27" 5K IPS 99% DCI-P3 1 év garancia
