- Asus H110-PLUS/ i3 6100/ ingyen foxpost/ garancia
- BESZÁMÍTÁS! MSI B450 R5 5600X 32GB DDR4 512GB SSD RTX 3080 10GB Zalman Z1 Plus Cooler Master 750W
- Új Dell 5330 Latitude 13.3 FHD IPS Touch i5-1235U 4.4Ghz 16GB 512GB Intel Iris XE Win11 Pro Garancia
- REFURBISHED - DELL Universal Dock D6000 (452-BCYH) (DisplayLink)
- BESZÁMÍTÁS! MSI B450 R7 5700X 32GB DDR4 512GB SSD RTX 3070Ti 8GB Zalman Z1 Plus Cooler Master 750W
- LG 27MR400 - 27" IPS LED - 1920x1080 FHD - 100hz 5ms - AMD FreeSync - Villódzásmentes
. Bakker 2080ti 0.987V-on tudja a 2000Hz-et az szep.
