- KINGSTON FURY 32GB Beast DDR5 5200MHz CL40 KIT KF552C40BBK2-32
- Trident Z5 RGB DDR5-7200 CL34-45-45-115 1.40V 32GB (2x16GB)
- SK Hynix 16GB DDR5 4800Mhz laptop ram több db!
- HP Omen 80G8E9 - 27" IPS - UHD 4K - 144Hz 1ms - NVIDIA G-Sync - FreeSync - HDR 400 - USB Type-C
- Bomba ár! Dell Latitude E5550 - i5-5GEN I 8GB I 128SSD I 15,6" FHD Touch I HDMI I W10 I Cam I Gari!
- HP ZBook Fury G7 Intel Core i7-10850H Refurbished - Garancia
- ÁRGARANCIA!Épített KomPhone Ryzen 5 7500F 32/64GB RAM RTX 5060 Ti 8GB GAMER PC termékbeszámítással
