Qkackca
SilverStone Sugo 14
review a tpu-n
- Szép, dobozos MSI PRO Z790-S WIFI PCIe gen5 garival
- G.SKILL Trident Z Neo RGB 32GB (2x16GB) DDR5 6000MHz F5-6000J3238F16GX2-TZ5NR
- Corsair 32GB KIT DDR5 6000MHz CL30 Vengeance RGB Grey AMD EXPO / XMP
- G.SKILL Trident Z5 Royal NEO RGB 32GB (2x16GB) DDR5 6000MHz CL28
- Új, bontatlan ADATA XPG 32GB (2x16GB) KIT DDR5 6000MHz CL30 Lancer Blade Black XMP/EXPO - 10 év gari
- Katonai Rugged laptopok Panasonic Toughbook és Getac S410 6-11.gen gar.
- Xbox Series X 1 TB + kontroller 6 hó garancia, számlával!
- 159 - Lenovo LOQ (15APH8) - AMD Ryzen 7 7840HS, RTX 4060
- LG 55G4 - 55" OLED evo - 4K 144Hz & 0.1ms - MLA Plus - 3000 Nits - NVIDIA G-Sync - FreeSync Premium
