- Asus H110-PLUS/ i3 6100/ ingyen foxpost/ garancia
- KINGSTON FURY 32GB Beast DDR5 5200MHz CL40 KIT KF552C40BBK2-32
- Shure Podcast mikrofon
- BESZÁMÍTÁS! Asus ROG STRIX B360 i7 8700K 16GB DDR4 512GB SSD RTX 2070 SUPER 8GB Zalman N5 ADATA 600W
- BESZÁMÍTÁS! ASUS ROG Z690 i9 14900K 32GB DDR4 1TB SSD RTX 3090 OC 24GB be quiet Pure Base 500 850W
- Gamer szék ASUS ROG Destrier Ergo SL400
