- Itt a Valve GŐZGÉP — Steam Machine, mi vagy te? 🧐
- OLED monitor topic
- OpenMediaVault
- ÚJSZERŰ MSI PRO Z790 A MAX WIFI 7 PCIe gen5
- G.SKILL Trident Z Neo 64GB (2x32GB) DDR4 3600MHz CL16 - 1 év garancia!
- G.SKILL Trident Z Neo RGB 32GB (2x16GB) DDR5 6000MHz F5-6000J3238F16GX2-TZ5NR
- Corsair VENGEANCE LPX 2x16GB DDR4 3200MHz CL16 - Új, bontatlan - Eladó!
- Telefon felvásárlás!! Samsung Galaxy A22/Samsung Galaxy A23/Samsung Galaxy A25/Samsung Galaxy A05s
- Bomba Ár! Lenovo ThinkPad L14 G1a - R5 4650U I 16GB I 256SSD I 14" FHD Touch I Cam I W11 I Gari!
- Bomba ár! Dell Latitude E5440 - i5-4GEN I 4GB I 320GB I 14" I HDMI I Cam I W10 I Gari!
- BESZÁMÍTÁS! Asus B150-Pro i5 6500 8GB DDR4 250GB SSD 1TB HDD GTX 1050Ti 4GB Rampage SHIVA 450W
