  • Archttila
    Az alabbi adatok alapjan mit gondoltok, ez az akksi toltesre szorul? Korulbelul ket honapja all a dobozaban mert sajnos még mindig nem erkezett meg az uj billentyuzethez egy foalkatresz.
    A kis (egyebkent olcso) muszer 3.86 voltot mutat ha ramerek
    Maga az akksi ezekkel a tulajdonsagokkal bir:
    Battery System: Li-Polymer Rechargeable Battery
    Standard Capacity: 12000 mah
    Standard Voltage: 3.7 V
    Weight: 195 G/ piece
    Model: 9068130 (90*68*130mm)
    High Energy Density
    The weight of a lithium ion battery is approximately one half compared to a nickel-cadmium or nickel-metal hydride battery of similar capacity. Moreover, the volume of the lithium ion battery is 40 to 50% smaller than that of a nickel-cadmium and 20 to 30% smaller than that of a nickel-metal hydride battery.
    High Voltage
    A single lithium ion cell has a voltage of 3.7V (mean value), which is equal to either three nickel-cadmium or nickel-metal hydride cells connected in series.
    Good safety performance
    As the aluminum bluster outer package is different from the metal shell of liquid lithium ion battery, and once safety problems arise, there is no explosion but only expansion.
    Pollution-free and friendly to environment
    The lithium ion battery does not contain any polluting substances such as cadmium, lead, mercury, etc.
    Non-metal Lithium
    The lithium ion battery does not employ any lithium metal. It is not governed by aircraft transportation rules relating to carrying lithium batteries in passenger airplanes.
    Long Cycle Life
    Under normal conditions, the lithium ion battery has a life of more than 500 charge/discharge cycles.
    No Memory Effect
    The lithium ion battery is free from the so-called memory effect, a phenomenon seen in nickel-cadmium in which the apparent battery capacity decreases when shallow charge and discharge cycles are repeated.
    Fast Charge Capacity
    The lithium ion battery can be fully charged in 1 to 2 hours, using a constant-current / constant-voltage (CC/CV) type dedicated charger with a rated voltage of 4.2V per cell.
