Puma K
"Cuccok: csattogós lepke és tiki-taki" └[ʘヘʘ]┘
Puma K
válasz TTomax #61748 üzenetére
Jól van sietek!
De előtte még ezt ide elhelyezem mert lehet szükségem lesz rá máshol
Relax, NVIDIA’s Telemetry Didn’t Just Start Spying on You
People Are Reading the Wrong Privacy Policy
People on Reddit found the Privacy Policy on NVIDIA’s website and summarized it as such: “NVIDIA may collect your name, address, email, phone number, IP address, and non traditional identifiers and share this information with business partners, resellers, affiliates, service providers, consulting partners, and others. This information is combined with typical browsing and cookie data and used by NVIDIA itself or advertising networks.”
It sends:
- Your GPU’s specification, vendor, clock speed, and overclock information.
- Your monitor information and display resolution.
- Driver settings for some specific games, such as whether you’ve disabled G-Sync or chosen a type of antialiasing for a game in the NVIDIA Control Panel.
- The resolution and quality settings you’ve chosen for some specific games.
- A list of games and applications installed, so NVIDIA can see how many people have Origin, Steam, Counter-Strike: GO, Overwatch, and other games installed.
- How much RAM you have.
- Information about your CPU, motherboard, and BIOS version.This is the type of data we’d expect to see, given what GeForce Experience does. NVIDIA can use much of this data to suggest optimal settings for your hardware.
To Disable Telemetry, You’d Have to Break GeForce Experience
You’re free to disable those telemetry services, but that won’t do anything for the time being. To truly stop NVIDIA’s software from phoning home, you’d have to break GeForce Experience by blocking its connections at the firewall level.
But if you do this, GeForce Experience won’t automatically check for and provide you with graphics driver updates anymore. The game-optimization features would stop working. Other Internet-connected features would also break.
In fact, if you block connections from GeForce Experience and it can’t connect to NVIDIA’s servers, it just kicks you back top a sign-in screen saying “We are unable to log you in at this time. Try again later.”
This is a bad idea. Those graphics driver updates are important!
Puma K
Na ez hogy lehet:
GTX 1060 3GB + GTX 1050 2GB + Intel IGP teljesítménye összeadódik(?) Windows 10 alatt:
Logout bejegyzés: [link]
+ pár mérési eredménye a fórumtagnak innen-onnan összegereblyézve a fentiekhez még:
Ja és:
BF1 Single fhd-ban 180-200 fps? dx11 alatt: [link]
A hardverinfóknál 3D Mark-ban az 1050-et 3GB-osnak mutatja és a GPU-Z is annak érzékeli. De az a vicces, hogy egyik kártya sem támogatja az SLI-t elvileg
Mindjárt felrakom én is a Win 10-zet és bedobok valami tápcsati nélküli VGA-t "mérgemben" az 1070 mellé plusz aktiválom az IGP-t
Puma K
Visítok:
Bárcsak tudnék tenni egy ilyen monoblock-ot a mostani lapomra...
... és bárcsak lenne egy épített vizes rendszerem
Puma K
válasz Devid_81 #62027 üzenetére
"... majd meglatom a Majus vegen hogy zarom a sajat tozsdemet "
Ismerős
Amit tervezek beszerezni egyszerre:
- 1db Fractal Design Define S
- 9-12db NB-eLoop Series 120mm
- 2-3db Y PWM ventikábelek
- 1db EK AIO... 360-asat céloztam meg... (az előző széria eléggé tetszetős volt számomra)
- 1db Corsair RM750i vagy EVGA 750 G3A Corsair szimpatikusabb, mert lehet Windows alól monitorozni a gép fogyasztását, terhelését és lehet ventilátorprofilt csinálni a tápnak. Viszont az EVGA méretét tekintve kompaktabb ami lehet jól jön ha esetleg a Define S ellenére is neki állnék egy saját ház építésének ami szintén kompakt lenne amennyire lehet
Puma K
válasz Devid_81 #62031 üzenetére
OC3D-nél elég jól kitesztelték és mérték az RM1000i és RM750i-t.
A szoftver nem tökéletesen pontos, de azért elég közel van a valós értékekhez: Corsair RMi RM1000i & RM750i PSU Review & Load Testing - youtube videó
Ezen videó alapján meg lehet látni mennyivel mér többet a szoftver, amit meg a gyakorlatban rá lehet számolni és meg is van az aktuális érték.
Csak ezen videó után jutottam oda, hogy ez a Corsair lehetséges befutó lenne ha cserélnék tápot.
Puma K
Komoly kérdést tett fel: [link]
Puma K
TTomax ezen szakadok
Puma K
Képrejtvény: Milyen PC van a képen?
Azt hittem a "Kínai popsztár dolgozta fel a Skyrim leghíresebb dalát - kár volt" cikk után nem lesz lejjebb... de lett
Puma K
Használ valaki közületek RAMDisk-et?
Puma K
Játékoknál próbáltad?
Egyik komának 32GB RAM van a gépében és a Cemu nevű emulátort használva játszik az új Zeldával ami mellé még fel van dobva a 4k textúra pakk.
A gépében van SSD az OS-nek és erről a meghajtóról fut az emulátor meg a játék is, de RAMDisk-el a játék töltési ideje eléggé durván lecsökken továbbá a játék is olyan vaj sima lesz hogy öröm nézni és játszani is.Megragadta a fantáziámat az a lehetőség, hogy i7 6800K + apránként bővítve (32->64->128GB) a RAM-ot 128GB-ig telepakoljam... és pl a GTA-t betoljam RAMDisk-be
De lehet egyszerűbb lenne RAID0-ban 2db SSD-vel?
Puma K
válasz proci985 #62229 üzenetére
Akkor a kesleltetest is eszre lehet venni ezekszerint? Pl mint a 60FPS vs 120FPS?
Mint irtam nem egybol dobalnek a gepbe 128GB RAM-ot hanem fokozatosan bovitenem 32->64->128.
Bar... az idozites nem a legjobb ilyen RAM arak mellett... 😧"Cuccok: csattogós lepke és tiki-taki" └[ʘヘʘ]┘
Puma K
válasz #Morcosmedve #62400 üzenetére
Javítottak rajta, viszont a korábbi 2 slot-os hűtés 2.5 lett
Puma K
válasz Devid_81 #62458 üzenetére
A GTX 1060 és GTX 1070/1080 topikokban lehetett olvasni, hogy akinek anno a kártyák megjelenésének idejében nem volt fent Windows 10-nél az 1607-es build és rendelkeztek adott VGA-val, azoknál nem lehetett telepíteni Nvidia driver-t. A Windows-t kellett frissíteni Anniversary Update-el azaz 1607-es build-re és megoldódott a probléma.
Rákeresve a témára pontosabban 1511-nél régebbi build-el rendelkező Windows 10 tulajok ütköztek az említett problémába:
This NVIDIA graphics driver is not compatible with this version of Windows
Az Anniversary Update (1607) ahogy olvasom a fórumot és adott topikokat a leghasználhatóbb állapotú Windows 10 jelenleg...
Puma K
Nahát-nahát [link]
Puma K
Puma K
válasz TTomax #62759 üzenetére
Jó kis
pop... populáris zenékTessék ebben az izraeli gitározgat is
Honfitársa: Yahel - Live Set PsyProg 2013
Puma K
Szerintetek ez a kocka megéri a 42ezres árát?
Puma K
Kevés a mostani hardverekhez a jelenlegi házam... vagy csak a ventilátorok nem a legmegfelelőbbek... lehet előbb azokat kéne cserélnem... vagy egyszerre a házat és a ventiket... Corsair 750D AirFlow-ért vagyok oda-vissza de az már nagy ahhoz képest mint amibe akarnám pakolni a gépet.
Ezért nézek valami kuckót. Ez a fektetett elrendezés tetszetős lenne, mert legalább a VGA által termelt meleget nem a felette lévő részek kapnák... hanem szépen rögtön szívnák kifelé a gépház tetején lévő ventik.
Puma K
válasz Habugi #63509 üzenetére
Ha nálad is a regidődből indulok ki akkor sejthetően nem olvastad a régebbi cikkírók munkásságait úgy mint fLeSs.
Nála nem emlékszem anno olyan Nvidia-Intel-t lehúzó és rossz színben feltüntető cikkekre-tesztekre-hírekre mint amit AMD85 tol ki magából...
Olvasd végig ezt a topikot: [link]
Ja és arról nem is beszélve, hogy 2007-2008-tól kezdve megy az AMD-t dicsőítő propaganda. Amiből megint csak kimaradhattál és csak azt látod 2011-től kezdve, hogy egy oldalakat írni tudó embert kritizál jó pár régi motoros teljesen jogosan, mert hiányolják az objektivitást ami addig meg volt míg ő el nem kezdett írni akár fórumra akár híreket-teszteket-cikkeket.
Valamint az is vicces, hogy olyan régi motorosokat fanoznak meg ilyen-olyan színű szemüvegesnek kiáltanak ki az újabb tagok akik amúgy a felső-csúcs kategóriában vásárolnak GPU gyártótól függetlenül és nem ritkán 2 kártyás rendszereket hajtanak-hajtottak így van tapasztalatuk és rálátásuk az adott hardverekre... de ez már senkit nem érdekel...
Puma K
Ilyen belső infókat mint:
"De egyébként hosszú távon jobban járna az Intel, ha most hozna egy csomó hibás döntést, mert elmúlna a befektetői bizalom Krzanich felé, akit a mérnökök jó része eleve utál, így jöhetne a helyére Renduchintala, akit viszont nagyon szeretnek a mérnökök, mert ő kardoskodott a legjobban a fejlesztések lassítása és a leépítések/részlegbezárások ellen."
hol olvasol, honnan tudod?
Puma K
Srácok!
Hüllőt nagyon szétkaptátok BF-ben, hogy ráment a GTA-ra?
Le merem fogadni GTA-n belül is valahogy megoldja, hogy tudjon PH!-ra írni egy újabb reggel
Puma K
válasz hszilard666 #63833 üzenetére
"...annyira gagyibés scriptelt. Usless shit. ..."
+1
kiakadtam rajta
Puma K
válasz cyberkind #63979 üzenetére
Anno eléggé tetszett a Dying Light, de nem játszottam vele túl sokat.
Viszont a közeli jövőben beszerzem Season Pass-al együtt.A GTA Online-hoz most jött egy 2.2 GB-os -szokás szerint ingyenes- DLC
GTA Online: Gunrunning Now Available
GTA Online: Gunrunning Trailer
Rockstar-ék sem csinálják rosszul, de ez a szerencsétlenkedés amit leművelnek hihetetlen egy ekkora cégtől.
A csalókkal nem tudnak mit kezdeni.Aki pénzt kap akaratán kívül (pl heist után bedobja az embert public-ba és már kapja a pénzt ha akarja ha nem...) annak az online bankszámláját lenullázzák... de az is valamikor történik meg szóval nem lehet rá számítani.
Puma K
válasz Erdei88 #64196 üzenetére
"Kínlódás már nekem ez a számítógép..."
Nekem is kezd az lenni... csak és kizárólag a GTA miatt építettem a nulláról majd fejlesztettem eddig a gépet, de azt most a legújabb DLC-vel elkúrták (számomra legalábbis) és most mivel többet autózom így az fog inkább prioritást élvezni... bár egy P38A-t még el tudnék viselni:
Ezek voltak... vannak(?)... tervbe véve nagyjából ebben a sorrendben:
- CPU delid
- jelenlegi ház ventik cseréje (NB-eLoop B12-PS vagy Noctua NF S12A PWM)
- CPU hűtő terén EKWB-re vártam téltől kezdve mostanáig... de még mindig nincs új AIO megoldásuk... télen még tavaszt jelölték meg időpontnak, hogy akkora fognak érkezni az újdonságok. Mostanra már a szöveget is átírták... és semmi egyéb infó lehet az Intel-AMD duóra várnak a szörnyeteg méretű CPU-ik miatt, hogy tudjanak AIO megoldást kínálni hozzájuk
- a házat cserélném Core X5-re, de ezt a lehetőséget sem vetettem el:
Corsair 200R Review & 360mm Radiator Modding Guide Watercooling
a Strix 1070 még pont elférne így push-pull ventikkel a radin vagy ha nem, akkor azon a részen kihagyok 1db ventit vagy csak a radiátor egyik oldalára mennének ventilátorok
- a mostani XFX Pro 450 táp helyett jönne egy EVGA G3 650 vagy 750 vagy még a monitorozás miatt tetszik a Corsair RM650i vagy 750
- minimum 1-2db 480-512GB-os SSD-t is pakolnék a masinába
Kb ezek voltak a tervek... de az autó fejlesztése mellett lehet veszek egy PS-t az exkluzív címek miatt és hozzá egy ilyet Tac Pro-t.
Puma K
A vs-be amit hami-nyami tol az valami kegyetlen
Puma K
AMD vs Nvidia hardvertémánál maradva milyen "szépen" átment személyeskedésbe....
Igazi AMD propeller...?
- Gigabyte GA-H81M-DS2 rev:2.1 LGA 1150 alaplap
- IPhone SE2 2020 64GB megkímélt akku 86%
- Asus P8H67 LGA 1155 alaplap
- Bomba ár! Fujitsu LifeBook E754 - i7-4712MQ I 8GB I 128SSD I 15,6" I HDMI I Cam I W10 I Garancia!
- Bomba ár! Fujitsu LifeBook E754 - i5-4GEN I 8GB I 128SSD I 15,6" FHD I HDMI I Cam I W10 I Garancia!
