Igen ez is egy opció, azért gondolkodtam az update-ben, mert naponta legalább 2x kapom a következő mail-t, ami zavar:
CRON-APT RUN [/etc/cron-apt/config]: Sat Mar 5 04:00:01 CET 2022
CRON-APT SLEEP: 3590, Sat Mar 5 04:59:51 CET 2022
CRON-APT ACTION: 0-update
CRON-APT LINE: /usr/bin/apt-get -o Acquire::http::Dl-Limit=25 update -o quiet=2
Exception ignored in: <function WeakValueDictionary.__init__.<locals>.remove at 0x7f67686b2400>
Traceback (most recent call last):
File "/usr/lib/python3.5/weakref.py", line 117, in remove
TypeError: 'NoneType' object is not callable
W: The repository 'https://dl.bintray.com/openmediavault-plugin-developers/arrakis stretch Release' does not have a Release file.
W: The repository 'https://dl.bintray.com/openmediavault-plugin-developers/arrakis-plex stretch Release' does not have a Release file.
E: Failed to fetch https://dl.bintray.com/openmediavault-plugin-developers/arrakis/dists/stretch/main/binary-amd64/Packages gnutls_handshake() failed: The TLS connection was non-properly terminated.
E: Failed to fetch https://dl.bintray.com/openmediavault-plugin-developers/arrakis-plex/dists/stretch/main/binary-amd64/Packages gnutls_handshake() failed: The TLS connection was non-properly terminated.
E: Some index files failed to download. They have been ignored, or old ones used instead.Volt egy "megoldás" rá, de nem hozott sikert:
For OMV 4.x only
cd /etc/apt/sources.list.d
sudo mv omv-extras-org.list omv-extras-org.bak
echo "deb https://openmediavault-plugin-developers.github.io/packages/debian arrakis main" | sudo tee omv-extras-org.list
cd /etc/apt/trusted.gpg.d/
sudo wget https://openmediavault-plugin-developers.github.io/packages/debian/omvextras2026.asc
sudo apt-key add omvextras2026.asc
sudo apt-get updateMint kiderült már semmi frissítést nem is fogunk kapni a jövőben erre és már 6-osnál tartunk, lassan az lesz a stabil verzió.
Hát a nagy verzió frissítések nem szoktak jók lenni. Legalábbis mobilokból, Win-ből kiindulva jobb ha tiszta telepítést csinál az ember. Ha backup-restore modszerrel megy a config nekem az is jó, de gondolom ott is mivel nagy verzió váltás van nem az igazi. 5-be nincsen már omv-extras, ott már container van, azt is ki kéne próbálni, hogy azt hogy is kell beállítani, használni. Max egyesével print screenelnem kell a beállításokat és újra beállítani az újba. Sehogy sem egyszerű, mindenféleképp melós
Üdv. Srácok azt meg lehet valahogy csinálni, hogy VirtualBox-ba felteszek egy OMV5-t, beállítok mindent, majd abból valahogy csinálok egy ISO-t és simán csak átrakom a mostani OMV4-et futtató SSD-re(persze azt előtte legyalulom)?
Üdv. Kollégák "kicsit" le vagyok maradva jelenleg OMV4-em van és dobálgatja már egy jóideje az anacron hibákat, ezeket most kilőttem(OMV fórumon találtam parancsokat omv-extrasra), de gondolom már igencsak kéne váltanom. Szóval ahogy olvastam mástól(meg IT-sként is azt gondolom) nem upgrade-lni kéne, hanem frissen telepíteni. Na igen, csak le kéne backupolni rendesen mindent úgy, hogy vissza is állítható legyen OMV5 telepítés után is. Futtatott torrentfájlok, megosztások, userek stb. Kézzel kéne kalapálni az összeset? Illetve anno nem volt OMV5-re extras(pl Plex), az most már van esetleg? Jónéhány plugin is van, pl SSD miatt: flashmemory. Plex, usbbackup. Ezek mind vannak 5-re is? Illetve ezt a Dockert szerintem már megkérdeztem anno is és 1. hsz-be is le van írva, de még mindig nem áll össze a fejembe, hogy ez nekem miért is jó.
Köszönöm a segítséget!
lovi27
#12313
Plex jó, csak szar, hogy kell neki net, nem lehet csak belső hálózaton tolni, illetve túl sok a menüpont. TV-n hiába van van LG-nél magic mouse, nem úgy működik, ami tökre kézreálló lenne sajnos. Keresem az alternatíváját, de nemtom mi lenne jó.
Más: Mostanság mindenki Docker-t használ? Jól értelmezem, hogy ez == VirtualBox?
Üdv. Srácok valamiért leállt a NAS-om valamikor. Log-ból hol tudom megnézni, hogy miért is? Deamon log érdekes, hogy Aug 5 és a mai nap között nincs semmi bejegyzés. Syslog-ról meg csak onnantól, hogy most bekapcsoltam. Pedig múlt héten végén biztosan ment a NAS. Áramszünet nem volt, mert alatta az UPS, akkor a router is szállt volna. Lehet aug 5.-én rajtam fel a Flash memory addont és akkor nem csinál bejegyzést?
DonThomasino
#10526
Bármilyen cuccból lehet még egy RPi B+ -ból is. Mivel linux nem kell nagy erőforrás. Lényegtelen, hogy 32 vagy 64 bit. OMV4-t tegyél fel, mert az 5-nél még lehetnek problémák.
Srácok, rohadtul kezd dühíteni, help me pls! OMV4 + TM2.92-nél semmilyen korlátozás nincs beállítva, mégis akármit töltök le 14-17MB/s között ugrál. 800Mbit-es netem van, semmi nem okolja, hogy itt megálljon, még a seederek sem, mert minden trnt-nél ez a jellemző. Köszi
lovi27
#10354
Köszi az érdeklődést, azóta nem volt időm foglalkozni vele, mert internetgondjaim voltak és azok prioritást élveztek
Most összedobtam, nyomtam egy shutdown-t webgui-ból és terminálból is simán leállt mindkét alkalommal. Lehet semmi baj nincs, csak a haltparancshoz kellene még egy kapcsoló is
Üdv. Srácok valakinek van ötlete mi a franc történhetett? Tegnap visított a gépem alatt levő szünetmentes, kikapcsoltam, de a NAS-t nem szépen állítottam le. Aztán UPS-be akkucsere, majd gép vissza és már LAN-on nem volt többet elérhető. Ma ránéztem, rádugtam monitort, bill.-t, hogy lássak is valamit, már az indulásnál furcsa, mert kiválaszthatom, hogy indítom simán a deb-et, vagy recovery mode-ot választok, vagy még másik 2 volt alatta(nem jegyeztem meg). Hagytam simán menjen, elérhető azóta LAN-ról ezzel már nincs gond, csak ha nyomok neki egy halt-ot, akkor kiírja, hogy halted, aztán ott szépen meg is áll, a gép meg pörög tovább, csak 10mp-es kézi kinyomással akar kikapcsolni.
lovi27
#10285
Köszi szépen, így érthető.
Van más nyűgöm: Plex-et beüzemeltem, állítgattam pár dolgot, kiírta, hogy valami ismeretlen hibát tapasztalt, menjen a fórumra, majd rá 2 percre, egyszerűen csak eltűnt. Azóta OMV reboot is volt és a plex-et is újrahúztam, de sehogy nem érem el. Amit tuti állítottam, hogy titkosítás required lett, és akkor ugye 32443-as porton kéne már elérjem, de ott sem. Hogy tudnám visszahozni?
Van itt log.
Srácok tulajdonképpen mi a különbség a permission és az ACL között? Merthogy van olyan, hogy beállítok egyikbe jogosultságot és a másikba nem látom(apply volt előtte).
No meg is oldottam, de nem indul túl jól a barátságunk, amikor próbálnék beállítani egy időt vagy épp újraindítani:
Ötlet?
Update: SSH-s restart megoldotta. Más kérdés: Update Manager-be látok egy rakat frissítést. Ti mindent rá szoktatok engedni? Csakmert van pl AMD procira vonatkozó, nekem meg Intel van benne.
Hali. Mindenki 4.1.22-t használ? Csakmert láttam van már 4.1.3-as telepítő. Mostmár muszáj átállnom 2-esről.
Srácok helpre lenne szükségem. Át akarok állni 4-es OMV-re, de ahhoz másik vasat is tennék alá. Virtual-ba szeretném futtatni, mert egy 8 magos gépet vétek lenne csak OMV-re elpazarolni. ESXi lenne a host, ez menne egy SSD-re, majd az OMV-t is erre az SSD-re szállásolnám el. Továbbá 2db 4TB-os HDD-t szeretnék RAID-be rakni. A lap tud HW-est. Az úgy működőképes gondolat, hogy már a bios után összerakom RAID1-be a 2 HDD-t, majd SSD-re ESXi, mint host, majd virtualba az OMV?
Mert ha OMV alatt rakok össze RAID-et az ugye csak szoftveres, így meg akkor 1 volume-ként kell lássa, ha már előtte HW-esen össze van lőve.
vasszarvas
#10098
Hát ezt csak úgy tudod, hogy külön lemented a torrenteket(meg a trnt fájlokat is ha megvannak) más adattárolóra, leformázod a HDD-t(ha ugyan arra akarod) ext4-re majd létrehozod ott a mappát, visszamásolsz mindent és betallózod a TM-be a .torrent fájlokat majd visszaellenőrzi.
Srácok. Van innen valakinek U-NAS NSC-401 vagy hasonló háza?
vasszarvas
#10064
Egyrészt nem ismerem a Dune-t(most gyorsba rákerestem, hát nem az esetem
), másrészt a TV-n pl a legfrissebb van belőle? Lehet valami apphiba, hogy nem fogadja el?! -
vasszarvas
#10062
Én a username milyen formában van beírva? Mert lehet kéri a "domain" nevet, ami a nas neve ez esetben.
Srácok helpet kérnék. Napi 2 ilyen mail-t kapok, már kezd zavaró lenni:
CRON-APT RUN [/etc/cron-apt/config]: Mon Apr 22 04:00:02 CEST 2019
CRON-APT SLEEP: 1918, Mon Apr 22 04:32:00 CEST 2019
W: Failed to fetch http://ftp.hu.debian.org/debian/dists/wheezy/main/source/Sources 404 Not Found
W: Failed to fetch http://ftp.hu.debian.org/debian/dists/wheezy/main/binary-amd64/Packages 404 Not Found
W: Failed to fetch http://ftp.hu.debian.org/debian/dists/wheezy-updates/main/source/Sources 404 Not Found
W: Failed to fetch http://ftp.hu.debian.org/debian/dists/wheezy-updates/contrib/source/Sources 404 Not Found
W: Failed to fetch http://ftp.hu.debian.org/debian/dists/wheezy-updates/non-free/source/Sources 404 Not Found
W: Failed to fetch http://ftp.hu.debian.org/debian/dists/wheezy-updates/main/binary-amd64/Packages 404 Not Found
W: Failed to fetch http://ftp.hu.debian.org/debian/dists/wheezy-updates/contrib/binary-amd64/Packages 404 Not Found
W: Failed to fetch http://ftp.hu.debian.org/debian/dists/wheezy-updates/non-free/binary-amd64/Packages 404 Not Found
W: Failed to fetch http://security.debian.org/dists/wheezy/updates/main/source/Sources 404 Not Found
W: Failed to fetch http://security.debian.org/dists/wheezy/updates/contrib/source/Sources 404 Not Found
W: Failed to fetch http://security.debian.org/dists/wheezy/updates/non-free/source/Sources 404 Not Found
W: Failed to fetch http://security.debian.org/dists/wheezy/updates/main/binary-amd64/Packages 404 Not Found
W: Failed to fetch http://security.debian.org/dists/wheezy/updates/contrib/binary-amd64/Packages 404 Not Found
W: Failed to fetch http://security.debian.org/dists/wheezy/updates/non-free/binary-amd64/Packages 404 Not Found
E: Some index files failed to download. They have been ignored, or old ones used instead.Egy
apt-get updateparancsot már futtattam, az kiszedett párat, de nem javította meg. OMV2 még. Valakinek ötlete? Köszi
Flowtation
#9775
Ez engem is érdekelne, baromi zavaró, hogy olyan hosszú a neve.
Srácok OMV4-ben van már beépített temperature modul?
Kollégák. Még a 2.1.4-nél vagyok(még nem sikerült időt fordítani rá, hogy átálljak a 4-re) és már sokadszorra esek ilyen gondba. Most pl mentem egy másik HDD-re a cuccokat, hogy át tudjak állni raid-re, és már 2 napja megy a mentés, és most melóból hazaérve tapasztalom, hogy egyszerűen nem elérhető a NAS. Megy a gép, de nincs IP-je. Ki tudom deríteni log-okból esetleg, hogy mi a frász történhetett? Olyan helyen van a gép, hogy nem tudok rátolni monitort, hogy azon egyáltalán látok-e valamit. Esetleg másnál is volt ilyen?
Mintha az ez előtti alkalom is úgy nézett volna ki, hogy meghajtottam rendesen a gépet másolással.
Core2duo6600
#9710
Miért baj az, ha jelszót kér? 1x megjegyezteted vele és nem kéri többet. Én úgy vagyok vele inkább kérjen jelszót, mi van ha valaki beférkőzik a belső hálódra? Legalább nem éri csak úgy el.
Core2duo6600
#9654
Hali.
dpkg --configure -a-t amit írt a végén lefuttattad? -
Srácok az új OMV4-et az új gépemre raknám rá, igenám, de egy i7-4860EQ-t csak simán OMV-nek elhasználni overkill. Mit javasoltok, mibe futtassam HyperV, vagy más? W10-et a sok telemetriás szarság miatt nem raknék fel host rendszernek.
Üdv. Kollégák még mindig 2-es OMV-t használok így most már úgy érzem ideje frissíteni 4-esre viszont ezt új telepítéssel tenném meg. Meg lehet valahogy oldani, hogy a beállításokat export-import módszerrel átvigyem? Gondolok itt megosztásokra, jogosultságok, userekre.
KaiotEch
#8086
Gyerekek itt valami kurvaérdekes a jogosultságkezeléssel kapcsolatosan. Megváltoztattam a userem jelszavát, de a W7 a régivel simán bemegy az újjal nem. 2: Most hányféle jogosultságkezelő felület van? Vagy egyszer a Shared Folderba mappára adható Privileges és ACL na most mi a különbség a 2 között, mert nemigazán értem. Aztán lehet a users-ba adni Privileges-nél, aminél rohadt érdekes, hogy pl itt az egyik mappára nincs adva jog mégis bármit csinálok benne, mert mappa szinten meg meg van adva. Nem kéne ez a 2 összefüggjön akkor?
Üdv. Kollégák permission helpet szeretnék kérni. Beszereztem egy kamerát, ami tud hálózatra menteni. Namost csináltam egy shared folder-t, guest joggal, meg SMB-be is beállítottam, hogy only guest, és megnyitom gépről, de ez még mindig kér jelszót. Valszeg ezért nem akar a kamera sem menteni oda, mert ott nem is lehet megadni user/pass-t. Valakinek 5lete?
Gyerekek ahogy nézem ez az OMV4 semmivel nem tud többet, mint az OMV2, ugyan az csak W10-esebb design, meg gondolom 1-2 progi frissebb. De azért csak kellene váltanom valamikor.
sad_Vamp
#7939
Egyrészt ma már nem olyan drága beszerezni egy SSD-t, másrészt a fentiben leírtam, nekem pl nagyon pici a hely, fontos mennyire melegszik. Nálam 4TB-s folyamatosan fut a p2p. De meghallgatom, ha valaki máshogy csinálná, javítani mindig lehet
Rendszervinyónak nekem most egy 500-as HDD van benne, de már van rajta pár hibás cella, így cserélném. A nagy gépen meg kinőttem a 120-as SSD-t, ezért valszeg azt raknám ennek a helyére. Házat még mindig keresek kicsit(2-4 bay-est), de nem találok értelmes áron.
SwissAirplan
#7810
Videókra jó a Plex. A többire nemtudom sajnos.
Srácok nektek működik a recycle bin? Hiába van nálam bekapcsolva, semmilyen törölt cucc nem kerül oda
Illetve lehet itt is(biztos lehet) olyat csinálni mint a piacvezető Syno-nál, hogy van fájlfeltöltő szolgáltatás link alapján?
doberman
#7796
Elolvastam nagyjából köszi. De newbie kérdés: Ha én kiállíttatok egy certit - mondjuk az ajánlott letsencrypt-el - akkor "ő lesz a közvetítő közted és az általad nem ismert, nem elérhető látogatók, felhasználók között.". Tehát a gyakorlatban ha én a belső hálón https-en keresztül nyitom meg mondjuk a nas-t, akkor a hozzám letelepített centi tesz egy kérést hozzájuk, és ha stimmel a kulcs, akkor átengedi?
Sziasztok! Abban tud valaki segédkezni, hogy hogyan tudok kiállítani saját tanusítványt? HTTPS-re bekapcsoltam az elérést és szeretném is, ha valósan az is lenne.
Köszi, közben ebben a pillanatban sikerült is helyrehozni egy full törléssel, reboot, install-al. Bár ugyan azt a plex verziót húzta le mint régen, mégis más volt a beállítása. Most úgy néz ki működik megint, de már látom sokáig nem lehet toligálni az OMV3-t, mert már itt a 4.
Figyelem!
Megjelent a Debian 10-re épülő OMV 5 stabil kiadása.
Új telepítésre ez a verzió ajánlott.
- HP EliteBook 840 G9 i7-1265U 16GB 512GB 14" FHD+ 1 év teljeskörű garancia
- GYÖNYÖRŰ iPhone 13 256GB Pink -1 ÉV GARANCIA - Kártyafüggetlen, MS3209, 94% Akkumulátor
- Számlás!Windows 10 Pro 11 Pro,Windows 10 Home 11 Home, Office 2016,2019,2021 ,Vírusirtok,Mac
- ÁRGARANCIA!Épített KomPhone i5 14600KF 32/64GB RAM RX 7800 XT 16GB GAMER PC termékbeszámítással
tradeelek11
