Keksz
SubZero szedi nálatok a Mayans MC feliratokat? Nálam sajnos nem, gondolom vmi olyanon hasal el hogy Mayans M.C. (pontokkal) vs Mayans MC (simán)
Keksz
ahogy látom lesz itt egy kis para, a Plex arcok kinyírják a plugin támogatást...
Cserébe lesz egy jó szar “on the fly” Opensubtitles bővítmény... ;-(
“💀 Plugins: This was not a decision taken lightly, as they’ve been around for a long time, and we’ve had good times both writing and using them. But bluntly, hardly anyone uses them (less than 2% of users), the ancient protocol they use is a continued pain for clients to support, and if we were to build the feature again, we’d do it very differently in this day and age. For utility-type functionality, we love standalone apps like Tautulli and believe this is a better approach. But don’t panic—while the Plugin Directory will soon be gone, you can still manually install plugins for the foreseeable future.”
“When will these features get discontinued?The Plugin Directory will be removed from Plex Web App in an upcoming update. You will still be able to manually install plugins on the server itself, even after the Plugin Directory is removed.”
Keksz
Jack Ryan megy ezzel a trükkel. Köszi.
Mayans MC sajnos nem. Ott más lesz a gond:
2018-09-26 18:18:25,112 (7fb0537fe700) : INFO (logger:30) - subzero.video: Using filename: Mayans.MC.S01E03.720p.WEBRip.x264-TBS.mkv
2018-09-26 18:18:27,461 (7fb0537fe700) : INFO (logger:30) - subliminal_patch.score: <HosszupuskaSubtitle u'Mayans MC S01E03 [webrip-tbs, webrip-afg, webrip-rmteam]' [hu]>: Computed score 173 with final matches set(['episode', 'hearing_impaired', 'format', 'season', 'year', 'release_group'])Sajnos csak 173 pontot szed össze, és annyival nálam nem szedi még le.
A supersubtitles meg már itt elhasal:
2018-09-26 18:18:25,134 (7fb052ffd700) : INFO (logger:30) - subliminal_patch.providers.supersubtitles: Get series id from URL https://www.feliratok.info/index.php?term=Mayans M.C.&nyelv=0&action=autonameNincs találat :-(
Keksz
ja, nem tudom láttátok-e, de az Infuse 5 Pro már tud PLEX serverhez is csatlakozni és mindent direct play-ben játszik. Felirat sem zavarja, MKV sem zavarja IOS alatt.
Ez pl egy 1080p Fear of the Walking Dead rész, iphone SE-n, interneten keresztül lejátszva:
Kicsit drága az APP, de nativ visz mindent. Transcode nélkül. Nem harcolja le a szervert.
Keksz
szpeti40 #4369 üzenetére
Sonarrnak és Radarrnak is meg kell adni a "remote paths mapping" (settings/download client, show hidden) alatt a rendes elérési utat és az alkalmazáson belülit, párban:
dockert meg vhogy így indítod:
Sonarr:volumes:
- ${USERDIR}/docker/sonarr/config:/config
- ${USERDIR}/docker/downloads:/downloads #### $/docker/downloads egy symlink a downloads mappád-ra (ami bárhol lehet), de "TV" célkönyvtár nélkül
- ${USERDIR}/docker/TV:/tv ### $/docker/TV egy symlinke a MediaLibrary/TV mappádra, ahol a sorozatok vannak, ahol látja a sonarr hogy miből mi van már meg és vszínűleg ez a PLEX Library TV is. Itt az egész elérsi út kell, TV-vel együtt
- "/etc/localtime:/etc/localtime:ro"
- ${USERDIR}/docker/shared:/sharedA TV az én esetemben sorozatok nálad. ;-)
Keksz
morpheus133 #4368 üzenetére
Köszi a supportot, király vagy.
Mayans MC felirat megjött szépen hosszupuskáról a frissítés után. -
Keksz
Nekem így műkődik már a 3. setup, különböző gépeken, de mindig dockerrel:
Settings / Download clients alatt lehet megadni pl. Transmission-nak hogy mi a "Directory", ahová letöltsön. Nekem itt a teljes elérés van megadva, a Transmission így ismeri (az nem dockerből fut, ahogy a Plex sem)...
Akkor a default Transmission beállítást felülírja.
Plusz a /downloads/TV meg van adva local path-nak a Remote Path Mappings-ban. Ez a docker host-on mutat a jó remote path-ra.Azt hogy miből mi van meg, azt pedig onnan tudja Sonarr, hogy megadtad neki hol vannak a "mediafájlok" (szerintem, hiszen ez is mindig meg volt adva nálam, és megy Radarr alatt is).
- ${USERDIR}/media/tvshows:/tv
Itt van egyébként egy nagyon jó docker composer yml fájl, sok okosság van benne.
Keksz
sugarforce #4394 üzenetére
Opensubtitles-ről volt amikor nekem megjelent kliensben.
Keksz
bagaba1 #4406 üzenetére
Ha csak ennyi a gond, a DTS, akkor csinálj magából a filmből a Plex webes felületén egy optimalizált verziót. Itt van hogy hogyan kell:
https://support.plex.tv/articles/213095317-creating-optimized-versions/Optimized for TV – 8 Mbps 1080p – Video is limited to 1080p and 8 Mbps and audio streams will be preserved and transcoded to AAC or AC3 if needed. SRT subtitle streams will be copied as sidecar files and other subtitle formats will be burned into the video if selected (prior to optimization).
Így a PLEX átkódolja előre a hangot.
És a TV-n ezt a "minőséget" válaszd ki a lejátszásnál.
Keksz
maddionmax #4420 üzenetére
Én is kerestem.
Eddig sikertelenül.
Fórum posztot sem találtam róla. -
Keksz
ezt írta vissza a Plex support
“The downloaded subs are currently semi-temporary and aren't intended to be user-accessible.”
és egy oldalt is linkeltek
ott áll még pár érdekes adat:Where are subtitles saved?
Subtitles are temporarily saved in a blob database. Downloaded subtitles are not intended to be user-accessible.és szerintem ez a leghülyébb megoldás:
Why can’t shared users see the subtitle I selected?
Subtitles searches are saved for each user separately. If a friend of yours needs a subtitle in different language than you, it will not show in your list.nesze...
adatbázis
meg külön feliratakkor inkább a subzero
link:
https://support.plex.tv/articles/subtitle-search/[ Szerkesztve ]
Keksz
szpeti40 #4503 üzenetére
Nálam megy szépen, minden dockerben van, a jackett-re a sonarr, radarr a server teljes webcímén hivatkozik, https, api/v2.0
RSS Sync és search is megy.Korábban a docker belső/helyi IP címére csatlakoztam, de ott volt olyan hiba, hogyha a docker containerek nem bizonyos sorrendben indultak, akkor más "belső" IP címet kapott xy container. Ez most így már nincs.
Plusz most már mindent a Docker-compose kezel. Frissít&újraindít, stb.Azt írják ha localhost:port formában adod meg, akkor http:// kell elé
Keksz
milyen oprendszer alatt fut a Plex?
akár még olyat is el tudok képzelni hogy ha linux, akkor csinálsz egy ssh tunnelt egy másik VPS-re, aminek te menedzseled a tűzfal beállításait és azon keresztül éred el a filmeket/sorozatokat
mint amikor pl. nincs igazi külső ip címed, de egy másik gépen keresztül eléred a szolgáltatásokat
vagy 443-ra átrakhatod míg megnézed, :-)
Keksz
enginev3.0 #4554 üzenetére
rclone-nal vagy plexdrive-val be tudod olvasni a gdrive tartalmát egy linuxos serveren (rclone tuti van windows-ra is, cache-vel kb van olyan jó mint a plexdrive)
és akkor meg tudod adni Plex-nek mint 1 sima könyvtárat -
Keksz
maddionmax #4567 üzenetére
Nekem hozzá van adva, de jelenleg nem megy ahogy látom:
An error occured while testing this indexer
Found no results while trying to browse this tracker -
Keksz
maddionmax #4569 üzenetére
Sajnos nem működik vele a keresés és az rss sem, ahogy látom.
Azaz a search tuti nem. -
Keksz
Elméletileg 2016 óta van a PMP-ben ilyen funkció, https://forums.plex.tv/t/any-way-to-shut-down-pc-from-plex-media-player-interface/140564
Bár én még sosem találkoztam vele.
OXS alatt én nem találom. -
Keksz
enginev3.0 #4652 üzenetére
Ami ilyen "magyar" cucc, azt tvmaze agentre kapcsolva szoktam inkább megkeresni, jobbak az infók. Szerintem.
Keksz
interstate76 #4664 üzenetére
plex dance
- vedd ki az egész sorozatot (mozgasd ki a sorozat mappából a sorozat főkönyvtárat)
- nyomj egy plex library update-et/refresh-t (vagy könyvtárra, *lásd lent)
- rakd vissza a sorozatot (tmdb féle könyvtárnévbe, Season 01, Season 02 mappákba, s01e01 fájlnevekkel)
- nyomj egy plex refresh-t vagy az egész TV/Sorozat Library-re vagy parancssorból a könyvtárra[ Szerkesztve ]
Keksz
sugarforce #4717 üzenetére
Ugye van ez a fájl:
https://github.com/pannal/Sub-Zero.bundle/blob/master/Contents/Libraries/Shared/subliminal_patch/providers/hosszupuska.pyA Plex Media Server / Plug-ins / Sub-Zero.bundle / Contents / Libraries / Shared / sublimal_patch / providers könyvtárban...
És ebben van ez a rész:
return _fix_inconsistent_naming(title, {"DC's Legends of Tomorrow": "Legends of Tomorrow",
"Marvel's Jessica Jones": "Jessica Jones"})Ebbe fel lehet venni.
"Titans 2018": "Titans" formában
Aztán újratölteni a plugin-t.
De lehet ha @morpheus133 olvassa, akkor van rá vmi más ötlete is.
Keksz
szpeti40 #4764 üzenetére
Az én szerverem szolgáltatónál van, nem otthon és ha tesóm az androidos mediapad cuccával néz, akkor neki is néha 127.0.0.1 szokott írni a logba a plex. De kb úgy hogy 1 hónapig a rendes IP-je van a logban, aztán 1-2 napig a 127.0.0.1, aztán megint minden OK.
Nem csináltam nagy ügyes belőle. :-D
Keksz
batai15 #4809 üzenetére
Használatttól függően Plex servernek kb bármi jó, főleg ha van benne elég HDD a tartalomnak (vagy lehet rák kötni, ez már lehet nas is -- nem kell hogy egyben plex server is legyen (azok drágábbak)).
Lejátszó lehet tablet, telefon, pc (webes kliens vagy plex media player) és lehetnek külső média lejátszók is, vmi android box, vagy apple tv, vagy lehetnek tévé okosító eszközök is (fire stick, fire tv)... Mindegyiknek a saját korlátaival. Egy apple tv pl. mindent tud direct streamelni, nem fogja le a server eszközt. Egy fire stick mindent csak transzkódol, ami terheli a szervert. Itt függ a vastól hogy hányan nézhetnek akkor egyszerre sorozatot vagy filmet a plex serverről (ez függhet még a szerver feltöltési sebességétől is!).Minden használat és igény egyenlete. Mire akarod használni, milyen lehetőségeid vannak.
Ha pl 4K tartalommal kell elmennie a lejátszó kliensnek, akkor mondjuk más opciók vannak, mintha XVID vagy HDrip x264 cuccaid vannak.
Ahogy a net sebessége is függ attól, hogy mi van a plex server alatt és a kliens hol van.Van akinek elég a TV beépített kliens, de az mondjuk lehet mindent transzkódol majd. Van akit ez zavar.
És így tovább. -
Keksz
Érzésre nekem olyan mintha a Sub-Zero nem menne a feliratok.info -val. Pár napja... De még nem néztem logot. Egyszerűen csak a le nem töltött feliratok száma fura. :-(
Keksz
morpheus133 #4857 üzenetére
tudsz verziószámot mondani?
nálam ez van most: Sub-Zero 2.6.4.2859
köszi!
Keksz
morpheus133 #4859 üzenetére
Megnéztem, felraktam. Hosszupuska akkor OK lesz szerintem.
Már csak a feliratok.info -nak kellene megint mennie. :-)Van egyébként a 9-1-1 című sorozat, azt is beleírtam előre
"911": 9-1-1
formában
Keksz
Aszpirin #4876 üzenetére
Apple ügyben:
Atmos works for me in Netflix and Vudu. It doesn’t work outside of online streaming apps.
Itt van rá topik hogy legalább az Infuse app-ban elérjék a támogatást, de eddig az Apple nem reagált, nem tette be a tvOS-be.
Szerintem is egyébként MrMc vagy Infuse
Amik talán a képet nem tolnák át másik formátumba, stbDe a hang egy nagy kérdőjel.
Nvidia Shield talán, mint opció
Most éppen akciós az nvidia.de -n :-D 149 EUR
És az amazon.de -n is meg lehet így venni.
BlackFriday akció -
Keksz
morpheus133 #4894 üzenetére
Keksz
gyugyo79 #4917 üzenetére
Állítólag el fog tűnni, vagyis van már olyan akinek pl. a web kliensben már nem látszik a Plugin menü (ha jól olvastam éppen a napokban a Subzero wiki-n itt ("If you still have access to the Plugin Directory/Repository in Plex Web, look here")).
Ilyenkor manuálisan fel lehet rakni.
Kilövöd a szervert, a ZIP-ek tartalmát bemásolod a Plug-ins mappába, és elindítod a plex servert.
A kérdés később lesz inkább égető, amikor már nem lesz olyan felület hogy a telepített plugint konfiguráld.
Bár gondolom akkor meg a gui alapú konfig át fog állni vmi conf fájl verzióra. És az lesz az alapja.
Csak vmi olyan megkötéssel hogy nem a Plug-ins könyvtárban lesz tárolva, mert azt kb 1:1-ben bármikor felülírhatod. Most legalábbis úgy van és a beállítások vmi adatbázisban vannak(?). -
Keksz
sugarforce #4922 üzenetére
Így van, a kliensben nézd meg a minőséget. Tekerd fel a maxra.
Erre nem kell VPN. -
Keksz
gyugyo79 #4925 üzenetére
A sub-zero fejlesztő itt összefoglalja hogy WTF
https://www.reddit.com/r/PleX/comments/9n9qjl/subzero_the_future/
Úgy néz ki hogy beintegrálódik a cucc Sub-Zero esetében ide:
https://github.com/morpheus65535/bazarr
(radarr és sonarr alapú letöltés, ami nekem OK is lenne, bár az befejezetett/megszakított sorozatokat, vagy ami nincs fent "jól", magyar specifikusan tvdb-n azokat mással szoktam automatizálni, vagy már nem töltöm, de felirat még nem teljes - és akkor azokkal kellene vmit csinálni. Plusz egy meglévő rendszer megpiszkálni, sosem jó. FŐleg hogy ez az új cucc még nem tudja a magyar feliratos oldalakat)És inkább ezeké a standalone megoldásoké lesz a jövő.
Keksz
Ezt még sosem vettem észre, vagy most változott valami:
Van pár sorozat ami thetvdb-n elég rosszul van kitöltve, vagy nem volt még fent, amikor nekem már megvolt.
Így ezeknél a tvmaze agentet használom. Eddig(?) ment is minden szépen. Viszont most két sorozatnál (Legacies, Narcos: Mexico) azt vettem észre, hogy minden szép (poszter, leírás, epizód címek), de a feliratokat nem tölti be a sorozatokhoz. És ha refresh metadata-ra megyek, akkor is kb. 2-3 másodperc alatt végez és nem rakja be a feliratot. Ugye a settings/agents/shows/tvmaze csak 1 dolgot tartalmaz, nem úgy mint pl. a thetvdb fül. Ha átrakom a fix match alatt thetvdb-re, akkor megjön a felirat, viszont pl nincs poszter és hiányoznak az epizód címek (még... lehet h később azért pótolja).
Én ilyet korábban nem vettem észre. Nem is tudom mik vannak nekem tvmaze-re állítva, vszínűleg csak pár cucc, azok is főleg magyarok szerintem.Más is látott már ilyet?
Vagy rakjam át inkább "imdb"-re (a sorozatokat?)? Ott az agent fül alatt van pár további agent is amit használni fog... -
Keksz
Aszpirin #4943 üzenetére
"Ha audio kimenetnek az Infuse-ban passthrough-t állítok be, akkor az Atmos és bármely HD hangformátumú filmek vagy meg sem nyikkannak, vagy fülsértő kerregést produkálnak."
Nálam is ez van
MrMc-vel is, Infuse alatt is...Auto-n jó, az említett korlátozásokkal.
A Plugins (vagy régebben Channels) a kliensekben fog első körben eltünni.
Nem a servereknél.Sub-Zeroból érdemes mindig a legújabbat felrakni, azokkal most éppen fixen megy a feliratok.info és a hosszupuska is.
Régebbivel nem biztos.
Plusz érdemes átnézni a media score-t hogy filmet és sorozatot mennyitől fogadjon el, pl. nekem a sorozatnál 352 a pontszám (release group és formátum is egyezzen neki, akkor töltse le) -
Keksz
MasterMark #4965 üzenetére
Keksz
Olvastátok már?
We're introducing an amazing upgrade for video playback to our iOS and Apple TV apps! Until now, we’ve relied on Apple's built-in player for video playback. We’re happy to report that we've now added the same enhanced, higher-quality video player we have in Plex Media Player (our high-end home theater PC app). Get ready for broader playback support, sharper output, better performance, and improved subtitle support. The new player is available to Plex Pass holders as an early-access preview. Simple to turn it on and off at any time in Settings → Advanced.
Keksz
uuuuuu, évekig vártam erre...
megy a Direct Play iphone-on, Infuse nékül, a hivatalos iPhone App-ban....
PRODUCT Plex for iOS
PLAYER iPhone
QUALITY Original (2.5 Mbps)
STREAM Direct Play
CONTAINER Direct Play (MKV)
VIDEO Direct Play (H264 720p)
AUDIO Direct Play (EAC3 5.1)
SUBTITLE Direct Play (SRT)Pár infó az új kisérleti lejátszóról:
What’s changed?
With this new video player, the apps will be able to play many more video formats without transcoding. This also includes a new custom video player UI in the Apple TV app that adds support for seek thumbnails, proper audio & subtitle switching during playback, and some other things we’ll add in the near future. We also gained more control over our playback stack.Basically, with these changes, the apps will try to use the new video player based on mpv when possible, with a few exceptions:
LiveTV playback
News and Web Shows
HDR videos
Interlaced videos
Transcoded and Direct Streamed videos. This means that when a certain video cannot be Direct Played by mpv and needs any kind of conversion, it will be converted to a format compatible with AVPlayer and played with it.
In all these circumstances the app will use the old player. We’re working as we speak to reduce that list of exceptions.
There are two other exceptions where Apple’s AVPlayer is needed: when using AirPlay and Picture in Picture (on devices which support it). In those scenarios, when enabling those features the app will switch to the old player (meaning, it could require transcoding).
Finally, due to some performance and compatibility issues we found, for now the new player will be available only for devices with iOS 11 and newer.
It’s also worth mentioning that this doesn’t affect Sync right now. That means, your media will still be transcoded to the same format in order to be compatible with the old player.
What are those supported formats?
Right now, the new player can direct play the following formats:Supported containers: mkv, mov, mp4, mpegts, mpeg, mpegvideo, avi, flv, ogg
Supported audio codecs: aac, aac_latm, ac3, alac, flac, dca, vorbis, opus, eac3, mp1, mp2, mp3
Supported video codecs: h264, hevc, vp8, vp9, h263, mpeg1video, mpeg2video, mpeg4
Supported subtitle codecs: ass, dvb_subtitle, vobsub, eia_608, pgs, microdvd, movtext, ssa, srt
What’s in development?
We’re actively working on:Improving performance.
Adding support for HDR playback.
Adding support for tone mapping when playing HDR videos in SDR displays.
Improved controls/gestures in the Apple TV video player.
Increasing device compatibility.
Keksz
1080p is megy neki simán iPhone-on:
PLAYER iPhone
QUALITY Original (15.1 Mbps)
STREAM Direct Play
VIDEO Direct Play (H264 1080p)
AUDIO Direct Play (DCA 5.1)
SUBTITLE Direct Play (SRT)LOCATION WAN
BANDWIDTH 31.6 MbpsJelenleg még csak Plex Pass usereknek lehet aktiválni!
Keksz
BonFire #5066 üzenetére
Az IOS Appban az alján lehet változtatni hogy mi kerüljön ki a "home képernyőre".
Ezek vannak:
- On deck
- Recently added XY Library
Ez szerintem már nagyon régóta így van.A playlistek pedig a Show és Movies gombokon vannak. Lent. Ott látod az összes filmet és sorozatot is. Vagy music, ami még be van rakva.
Keksz
BonFire #5069 üzenetére
Igen és ott alul van hogy Shows és Movies (a Library típusa)
A playlistes dolgot én sem értem hogy miért is rakna bárki egy sorozatévadot még külön 1 playlistben, mikor szépen alapból is évadonként van rendezve?!
Én olyanokat szoktam playlistbe tenni, amit még nem nézek és ne felejtsem el, de csak 2 playlistem van, egy sorozatra és egy filmre.
Az egész évadot vagy sorozatot rakom playlistre, nekem azon belül a részek mindig részenkénti sorrendben vannak. Ahogy a tvdb-n is következnek egymás után.(Mondjuk az tényleg kicsit zavaró lehet, hogy ahány eszköz annyi féle "home screen" lehetőség és felosztás. Én főleg OSX, IOS alapú eszközökön használom. És főleg az "On deck" vagy az új filmeket nézem. A többi nálam az extra kategória. 1100+ film és 16.400+ sorozat epizód van nálam fent. Trakt.tv-re frissítem hogy mit néztem már meg, playlistet csak "emlékeztető" formájában használom. Kollekciókkal nem szöszöltem. Néha rányomok hogy stílus alapján adjon fel pl. horrort, és néha el szoktam kalandozni a plex pass-hoz járó funkcióban(?) a kapcsolódó filmek részeknél. Vagy a "újrafelfedezés" résznél a sorozatokban, pl. láttam 2-7 részt leszámítva valamiből az összeset és akkor azokat ott pörgeti míg nem fejezem be.)
Plex mellett ami még menő az az Emby.
Azt már nézted? -
Keksz
enginev3.0 #5081 üzenetére
Ja ja, remélem ez nem a PlexPy/Tautulli végét jelenti... Hogy majd azt nem támogatják. És hogy ezért több plex pass user legyen.
Persze még fapad. De csicsás. Főleg annak aki a másik megoldást nem ismeri.
Keksz
Én is hasonlóra gondolok:
Q18 FAQ Synology
For your Media Folder/s:
cd volume1
find ./Media_folder_name_here -type d -exec chmod 755 {} ;
find ./Media_folder_name_here -type f -exec chmod 644 {} ;
chown -R admin:users Media_folder_name_here
The commands above perform the following functions:
cd changes to the directory you wish to work in, in this case, volume1 (volume1 maybe volume2, volume3 etc.).
find searches for the folder you specify and changes it’s permissions to 755.
find again searches for the folder you specify and changes the permissions for all files in that folder to 644
chown sets the user and group owner of the folder and the files it contains to what you specify. In this case it sets the admin as user and the group to the users group.
