Router gondok
Encian
sajnos a probléma továbbra is fennáll. épp 10 perce telefonált egy srác, ugyanez a problémája a dir-655 össel mint nekem, lehet tipushibás
idemásolok egy router log-ot közvetlenül a leállás pillanatából, amikor még látszik a menü.
talán ez mond neked valamit.at Jan 31 14:38:55 2004 UPnP deleted entry 255.255.255.255 <-> 0.0.0.0:51858 TCP
[INFO] Sat Jan 31 14:38:41 2004 PPPoE session 0xFC40 terminated by access concentrator
[INFO] Sat Jan 31 14:38:41 2004 PPP network down
[INFO] Sat Jan 31 14:38:41 2004 WAN interface is down
[INFO] Sat Jan 31 14:38:41 2004 Stopping WAN Services
[INFO] Sat Jan 31 14:38:30 2004 Blocked incoming UDP packet from 98.160.153.99:33512 to 84.0.78.174:51858
[INFO] Sat Jan 31 14:38:17 2004 Blocked incoming UDP packet from 76.205.210.166:36361 to 84.0.78.174:51858
[INFO] Sat Jan 31 14:38:17 2004 Blocked incoming UDP packet from 85.72.140.174:18291 to 84.0.78.174:51858
[INFO] Sat Jan 31 14:37:58 2004 Blocked incoming UDP packet from 213.37.83.249:18896 to 84.0.78.174:51858
[INFO] Sat Jan 31 14:37:57 2004 Blocked incoming TCP connection request from 90.210.140.109:4318 to 84.0.78.174:12777
[INFO] Sat Jan 31 14:37:51 2004 Above message repeated 1 times
[INFO] Sat Jan 31 14:37:48 2004 Blocked incoming UDP packet from 71.232.143.198:38766 to 84.0.78.174:51858
[INFO] Sat Jan 31 14:37:48 2004 Blocked incoming TCP connection request from 90.210.140.109:4318 to 84.0.78.174:12777
[INFO] Sat Jan 31 14:37:42 2004 Blocked incoming UDP packet from 67.81.249.24:62453 to 84.0.78.174:51858
[INFO] Sat Jan 31 14:37:17 2004 Blocked incoming ICMP error message (ICMP type 3) from 68.190.125.108 to 84.0.78.174 as there is no UDP session active between 84.0.78.174:51858 and 192.168.1.100:31792
[INFO] Sat Jan 31 14:37:00 2004 Blocked incoming UDP packet from 189.140.98.106:10402 to 84.0.78.174:51858
[INFO] Sat Jan 31 14:36:51 2004 Blocked incoming UDP packet from 221.208.208.90:48737 to 84.0.78.174:1026
[INFO] Sat Jan 31 14:36:51 2004 Blocked incoming ICMP error message (ICMP type 3) from 82.5.99.254 to 84.0.78.174 as there is no TCP connection active between 84.0.78.174:1313 and 192.168.1.100:59990
[INFO] Sat Jan 31 14:36:48 2004 Above message repeated 1 times
[INFO] Sat Jan 31 14:36:45 2004 Blocked incoming UDP packet from 99.237.66.249:3105 to 84.0.78.174:51858
[INFO] Sat Jan 31 14:36:40 2004 Blocked incoming UDP packet from 80.98.1.90:32816 to 84.0.78.174:51858 -
Krystal_s
A feltöltési sebességen mindig "finomítottam"
Azt nem tudtam , hogy a letöltési sebességen is kellene...néha még a sávszél. kiosztást is masara állítom...
Az UPnP kikapcsolása tényleg szükséges ? mert olyankor nem kell külön portot nyitnom az adott programnak és akkor is aktív leszek.UPnP kikapolásnál szükséges ,ha nem akarok passzív lenni.
Szoftveres tűzfalnál természetesen engélyeztem a portokat...
Tényleg okozhat gondot az UPnP vagy a fagyás külön csak a p2p miatt van ?
Köszi előre is a választ ! -
TomBoy1986
Megvan a hiba. A Port Forwarding az jó volt, azzal volt a probléma, hogy az IP rovatba nem a külső Internetes IP-cím került, amikor automatikusan frissítette, hanem a LAN-on lévő
Viszont most, hogy manuálisan beírtam a netest, így működik. Most azt kell megtalálnom, hogy ennek az automatizálását hogyan tudom megoldani.
Köszönöm a segítséget!
Ha esetleg tudsz rá valami megoldást
Sajnos az autoupdate killőve[ Szerkesztve ]
AMD FX-6300 ; MSI 970A-G46 ; XFX RX-460 4GB ; CSX DDR3-1600 2x8GB ; WD 1TB ; CoolerMaster RealPower RS-520W
nova001
tüzfalon enm találom vistába csak h kiengedi de nem irja a portot amit nyitnom kéne a routeren :S
Akkor ha jol értem a következöt kell csinálni....megnézem milyen porton megy ki a játék azt kinyitom a routeren és kiengedem a tüzfalon amit felajánl magátol?
kérdés: honna tom h tcp vagy udp a port? -
miauut
Nincs felhasználónevem, sem pedig jelszavam, a szolgáltató meg a dunaweb, vezetéknélküli 768/128 internet.. Az adatokat manuálisan kell beírni. A TCP/IP fülön.
Nokia7710>HtcUniversal>HtcKaiser>Samsungi900>Htcx7510>SExperiax10>Galaxy Note>PF2>Honor6>Honor9>Honor 20>Xiaomi 11 Note
pepe1970
Köszi a választ. Eljutottam odáig, hogy a notin látom az asztalival megosztott mappákat, és tudok a notiról nyomtatni is. Az asztalin viszont nem látom a notin megosztott dolgokat, de az nem is olyan fontos. A lényeg a nyomtató megosztás volt. Még annyit kérdeznék, hogy most az asztalin a utorrent azt irja hogy valami baja van a portal, nincs beállítva, de ennek ellenére 300kbps-el tudok tölteni. A notin wirelessel teljes sávszéllel megy a torrent, az nagyon jó. Lehet hívnom kéne egy nálam okosabbat.(az nem lesz nehéz)
hugoo
Nyilván nem ez a mérvadó, de képeken is azt látja mindig az ember, h függőlegesen, ill ferdén állnak ezek az antennák. Más ismerősöm is meglepőnek találta, de engem végül is nem nagyon zavar, ha megy és nincs gond a nettel. Márpedig úgy tűnik tökéletesen működik, uh még egy szavazat a TP-LINK-re
Ilyen áron, 5 év garival jó választás. Remélhetőleg később sem lesz vele gond.
üdv
Sensei
Ha azt írja ki,hogy egy hálózati kábel nincs bedugva, akkor jelen kell lennie.
Találkoztam már olyan lappal is villámcsapás után (az utp-n keresztül szedett fel valamit, nem pedig az erősáramú hálózatból), ami nem csak hogy elindult, de a hálókártya is működött, viszont baromi rossz pingek voltak és csak egy új kártya segített.Nem vagyok hülye, csak van a fejemben néhány hibás szektor.
● Olvasd el az összefoglalót!
- Acer Nitro Gaming XV322QKKV 31,5" 4K monitor, újszerű, bontott, új, 21 vagy 36 hó gar, Áfá-s számla
- Asus TUF VG34VQL1B 34" ívelt monitor, 36 hó gar, Áfá-s számla
- Új GAMER félgép - ASUS TUF GAMING B760-PLUS WIFI + Intel I9 13900KF + Kingston 2x16GB DDR5 6000MHz
- AOC CU34G2 34 100Hz Freesync VA, Extra garival
- Eladó X1 Carbon 6th QHD IPS i7-8650U 16GB 256GB NVMe ujjlenyomat olvasó, 1 hét gar
