Az előzmények:
notika77
Szó szerint nekem sem küldtek ilyet, de eredményét sem láttam. Legutóbb 2 hónapja küldtem be replay-t. Küldetést riggeltek és buktuk el a csatát, mert az ellenfélnek kellett pattintania és nyernie (nem spotolva lőtték az is-7 tornyát a bokorban, majd megfordulva kapták tőle a lövéseket a seggükbe). 2-en jelentettük őket replay-jel, utána 3-4 hétig nézegettem a 3 delikvenst, minden nap játszottak és még a cset-en is aktívak voltak (a levélben 1 nap chat bantól 7 nap felfüggesztésig hitegettek retorzióval).
jano_77
gyanítom vmi hasonló mint, amit én is kaptam:
"Hello farkasjano_,Thank you for reaching out to Wargaming Player Support.
We understand your concern and we are sorry that you have encountered such behaviour from Alcatraz_1007. We thank you for reporting this matter to our attention.
Because it can be the difference between an enjoyable game and a frustrating game for you we have in place an in-game system that takes into account situations like this. To use this system simply press ctrl right click on the person's name and select complaint and then "unfair behaviour" for example. Rest assured that the system always takes the appropriate measures against them so that they don't do it again. Also, this tool takes into account if somebody is doing this all the time and the measures taken will become more and more severe.
We will investigate your report and take all necessary actions to the player once found guilty but please understand that we are unable to provide any information regarding the investigation process.
In the effort to keep a friendly game environment, our teams are taking measures against the non-respect of our game rules with sanctions between 1 day chat ban and 7 days game suspension. In unique situations, our team will sanction with a permanent chat or game ban depending on the player’s history. Due to our Privacy Policies, we cannot disclose the nature of the exact actions taken against other player’s accounts. However, I can assure you that the right actions were taken based on the report you sent us
We hope we could give you some peace of mind by explaining what happens with this kind of player.
We hope that you'll still continue to enjoy the game for all of its positive aspects, regardless of any negative experiences you have had.
Should you require more assistance, keep in mind that we remain at your disposal. And lots of helpful articles can be found here Player Support Page. You may also find useful information and tank attributes to use as an advantage here: Tankopedia.
May the odds of war, be in your favour!
Kind Regards,"
Nesze semmi, fogd meg jól!
"egyenlőek között is mindig vannak és lesznek egyenlőbbek"
Argh!
Na ez jó, akkor igy mégis lehet hogy idén is odaadják ha már tavaly is ki volt irva mégis meglett ujra
Engem hiába gyözködsz hogy nem adják oda kétszer mikor tudom hogy alapból eladom az ilyen ajándék tankokat és tavaly megint ott lettek a garázsomba.Ugyanilyen vita volt tavaly is másik forumon. Egyesek szerint gusztustalan dolog hogy adnak ajándékéba tankot és valaki eladja.
Kolter
junior tag
Nem tudom mit nyavajogtok a kerekes tankokon .Tisztázzuk nekem nincs egyik se (kerekes ,arty) . Szerintem szar osztály , nekem nincs is. A wg rákfenéje az arty. Isten modban játszanak, soha nem volt (a valoságban), még ma sincs arty ami mindent lát a területen . Arty nerf amit a wg csalo banda bejelentett az buff. A kerekes szarok legalább a játék része ki lehet lőni a fosokat . Az arty meg egy szar csaló parasita banda.
EQMontoya
Igazabol azokban a csatakban low tier, mert nincs alacsonyabb szintu tank. Vagy tevednek? Azok a leginkabb fair csatak, nem sorolnam se low, se top kategoriaba.
Ne erveljunk mar egy atlag fideszes politikus szintjen, legyszi, mert 5 forumozonak egyutt van 40 altalanosa, szoval hamar lebukunk vele.
Same rules apply!
EQMontoya
Nem ez, hanem ennek az inverze. Tul sok az olyan meccs, amikor engem farmolnak.
Alapvetoen azt szeretnem, ha egyik iranyba sem lenne ilyen meccs (nem akarok en sem 2 szinttel gyengebbeket farmolni, de akkor lehetoleg engem se farmoljon senki igy), de ha mar letezik ez a jelenseg, legalabb ugyanannyi jusson mindkettobol.Leginkabb azert szar, mert van egy csomo olyan napi mission, hogy "sebezz meg egy csataban 5 jarmuvet", vagy "semmisits meg 3 jarmuvet", na ezt good luck 2-vel erosebbek ellen.
De nem akarom tovabb magyarazni, akinek ennyibol nem ertheto, hogy miert baj az aranytalanul sok low tier meccs, annak kesobb sem lesz.
Same rules apply!
phoenix1989
Pug
attól a sebzésed mértéke véletlen maradna ha figyelembe venné az előző sebzésed. hiszen elég nagy a mozgástere. ettől még véletlen lenne. csak annyiban változna hogy egy csatán belül közelebb járnál az átlag sebzéshez. számokkal ha 560 (420-700) átlagom van és lövök 540 et akkor a következőnél ne a 420 és 700 közé varázsoljon hanem 560-700 közé legalább megközelítőleg. én erről beszélek és ez ettől még véletlen. és kösz de ne nevezz butusnak.notika77
nem kell hogy tudja most sem tudja. a lövés pillanatában generálja a sebzésed és ennyi.duaface
ezeket még szóra sem méltatom mert ennek értelme sincs -
Djuree
jah, még jó hogy már ott minden ki van húzva, csak a light ág nincs ami nem is érdekel mondjuk.
valami más nemzet jó lett volna helyette...a britből majd kihúzom a kukáskocsit, bár az se vonz....LEGO gyűjtő és moc építő (munkát is keresek, bármit ami LEGOval kapcsolatos!), tankász, bringás, WH40k fan, MacGyver
e-newsee
Miért, mennyi gold jött, mennyi credit, és mennyi prémium nap? És mi egyéb?
Az biztos, hogy mindent átordítva valós pénzre kaptál annyi értéket, amennyibe kerültek. Nem véletlen vannak a garantált cuccok. Azoknak átszámolva ki kell adnia."Csak egy olyan töltött édesség van, ami megoldja az élet problémáit, és az az Oreo." /Sheldon Cooper/
e-newsee
Ez nekem is telejsen tiszta, hogy nem kaphatsz kétszer, mert felesleges, ezt írtam is.
De akkor, ha mondjuk azt látja, hogy nekem már az összes skin megvan, akkor nyilván nem fogok értékben kevesebbet kapni, tehát gondolom dob helyette mást. Goldot, creditet, prém napot, valamit. A kérdésem az lett volna, hogy mit, és mennyit. De ezt nem írták le.
Pedig ugyanúgy illett volna azt mondani, hogy egy 3D skin megfelel mondjuk 1500 goldnak (a Progettora pl annyiba került a shopban)."Csak egy olyan töltött édesség van, ami megoldja az élet problémáit, és az az Oreo." /Sheldon Cooper/
e-newsee
Az utolsó mondatban egyetértünk, bár nem tudom, milyenek azok a 6-os tankok. Lehet, hogy nem rosszak.
Persze, hogy akciós csomagban vennéd (én is), de elszámolni pénzügyileg listaáron számolják.
A WG-nek, mint cég pedig az a lényeg, hogy pénzügyileg legalább annyi in-game értéket kapj, amennyit valós pénzben ráköltöttél, hogy ne raklamálhass. A könyvelésükben pedig biztos, hogy a legutolsó 1-es dísznek is van valamekkora valós értéke, amin elszámolják.[ Szerkesztve ]
3
Szerintem maximum egy perc dropos csatornát találni. A Twitchen rákattintasz a World of Tanks kategóriára, és a legelső ismerős - de nem hírhedt - streamer nevére. Ahogy hallom, már a ZS kategóriás streamereknél is van drop.
Szerk.: nézőcsalogató okokból a gyengébbek a címbe is bele szokták írni, hogy van náluk drop.
Ha a moderátor indokolja a döntését, korrektül tegye. Vicc.
EQMontoya
Nem tartom magam jo játékosnak, vannak tankok, amiket érzek (pl T1-gyel nem az első ász volt a mai, és meg a legények sem különösebben képzettek benne), a Barackot egyelőre nagyon nem.
De nyilvan nem véletlenül magas vele az ász, meglesek majd par videót, hogy hogy érdemes játszani vele.
Same rules apply!
popey37
te nagyon okos vagy
érdekes modon a fejleszthető tasnkoknál nincs ilyen gondom.de hát te vagy az észkombájn, biztosan jobban látod.
amugy 37 eladott prémtankom van amit végtelenül vissza lehet álítani. ugyhogy ez a beszólás most nem jött be.
Teló: +36302105384 SW 100/900 ED strehl 0.986
popey37
szálj már le rólam légyszíves. ha értelmeset nem tudsz hozzászólni, kár koptatnod a billentyűket. ráadásul még olvasni sem tudsz rendesen: pont azt irtam, hogy a prém tankoknál hatványozottan előjön a kevés sebző találat a fejleszthető tankokhoz képest.
más téma, valaki biztosan tud rá magyarázatot:
a Jpanter II hogyan lőtt belém 600 feletti sebzést:280 alfával nem igazán jön ki a 613hp sebzés.
köpet
Viccnek szántam, játszottam és játszom szerepjátékokkal, tudom mi az.
Ez nyilván nem lesz olyan szerteágazó, nem ezen lesz a fókusz, de mint elem - számomra - érdekes és vonzó színt hozhat a játékba.
Lövöldében hasonló nekem a borderlands, ott van leegyszerűsített skill pontos fejlesztési lehetőség, ahol a karaktert nem túl tág keretek között ki lehet gyúrni valamire, kinek mi a fontos. Az sem RPG, de ebben az elemében hasonló.Ha felkel a nap, kezdődnek a gondok...
MODERÁTOR
(rögzített hozzászólás)
Figyelem!
- SSD kibeszélő
- Okos Otthon / Smart Home
- Konteó topic
- Linux kezdőknek
- sto1911: Pinball FX3 PH! verseny
- Pécs és környéke adok-veszek-beszélgetek
