Az előzmények:
zsolthee
Milyen tankokat érint a nerf és milyen mértékben?
Márciusban ez volt a hivatalos fórumon, nem tudom mennyire aktuális még:-Most arties got a major view range nerf between of 30 and 50 meters;
-Foch 155 aim time buffed from 3 to 2,8s, penetration nerfed from 293 to 272mm;
-Batchat got a stabilization buff (accuracy on the move improved by 12 percent), penetration nerfed from 259 to 249mm;
-Leopard Prototyp A and Leopard 1 penetration nerfed from 268mm to 257mm;
-Leopard Prototyp A got a stabilization buff (accuracy on the move improved by 9-10 percent), and reload time got buffed from 11,1s to 10,9s;
-Leopard 1 got stabilization buff (22 percent);
-E50M penetration got nerfed from 270 to 259mm;
-Jpz E-100 penetration got nerfed from 299 to 278mm;
-Type 61 top gun and STB-1 gun penetration got nerfed from 258mm to 248mm;
-STB-1 got stabilization buff (12 percent) and the gun aimtime was buffed from 2,3 to 2,2s;
-Charioteer, FV4202 and Centurion 7 top gun penetration nerfed from 268mm to 257mm;
-FV4005 and FV215b (183) AP shell penetration got nerfed from 310mm to 288mm;
-Firefly viewrange increased from 360 to 370m;
-M48A1, M60 gun penetration got nerfed from 268mm to 257mm;
-M48A1 Patton got accuracy loss from moving turret buff (you now lose 33 percent less accuracy);
-T110E3 and T110E4 penetration got nerfed from 295mm to 276mm;
-T110E4 got reduced dispersion when rotating the turret( by 17%), aim time was buffed from 2,9s to 2,8s;
-T-62A, Object 430, Object 907 and Object 140 penetration got nerfed from 264 to 253mm;
-Object 263 penetration got nerfed from 290mm to 270mm, stabilization got buffed by 12 percent and reload time got buffed from 10,7s to 10,5s;
-Object 268 penetration got nerfed from 303mm to 282mm;
-Object 704 and ISU-152 (top gun) penetration got nerfed from 286mm to 266mm;
-Chinese 121 tank penetration got nerfed from 258mm to 249mm, reload got buffed from 9,6 to 9,4s and there's also reduced dispersion during turret rotation (by 14%).Egyáltalán nem vészes, ráadásul több tanknál buff is párosul a megszorításokhoz.
Egyedül az ISU/O704 top lövegének a megnyírbálásával nem értek egyet. Én ahhoz nem nyúltam volna.[ Szerkesztve ]
zsolthee
válasz magyargyerek #95649 üzenetére
Megnyugtatlak: Tegnap 15-20 csatát mentem zsinórban a Cent7-tel és abból jó ha 2-t nyertem. Egy volt olyan, hogy mind2 csapat küzdött rendesen. A többiben vagy mi daráltunk le mindenkit vagy minket zúztak porrá. Folyton 15-2 meg hasonlók.Ez van.
Mondjuk pont aznap lett fullos a tank. Ennek ellenére azt mondom, nincs manipuláció. Hajamra kenhettem a tudásom, sebzek amennyit csak tudok és kész. Elismerem, ilyenkor jól jön az XVM mert ha látom, hogy a piroskák mennek hős halált halni, akkor inkább egyből visszavonulok.[ Szerkesztve ]
zsolthee
válasz Angel1981 #95663 üzenetére
Ezt a véleményt én is osztom. Vártam a X-es ágyút a Cent 7/1-en, de a 10mp-es reload lekanyarította a számat. Feláldoznám a 390-es alfát kisebbre ha 6-7 mp alatt betöltene.
Nem baj, most már kezdem megszokni vele a játék stílust.
Egyébként BIA+Venti mennyivel csökkenteni a lövedék betöltését.
Most rammer+optic+vert.stab van fent. Azon gondolkozom, hogy ha a 3. skill is felugrik 100%-ra, akkor újraosztom úgy, hogy legyen BIA. Megéri? -
zsolthee
T30, E3, és E4 miatt felesleges sírni. Mire nem elég a 280mm-es átütés?
De ez mégis mi a répa?
WZ-111 model 1-4:
Penetration of the Chuan bei-482 shell for the 130 mm 59-130T gun reduced from 244 to 232 mmST-I
Penetration of the BR-472 shell for the 122 mm M62-T2 gun reduced from 258 to 240 mm.Az IS-4-re is ugyan ezt a X-es löveget lehet feltenni Akkor az is 240 pen-nel fog szaladgálni top heavy létére?
zsolthee
válasz MinionFlasH #96407 üzenetére
A naggyal.
De a kisebbel is lehet meglepetéseket okozni a ~4mp-es újratöltés miatt.
Nagyon sokszor volt 2500-3000 között a sebzésem vele.
Ha mozgékonyabb lenne simán nyomnám a IX-essel. -
zsolthee
válasz adamgreen #96648 üzenetére
Ez gyakorlatilag egy tier8-as ELC AMX. Kezdek a kis franciával jóba lenni amúgy. Ha így folytatja, örök helyet kap a garázsban.
Szóval akinek fekszik a kis light annak az O416 még jobban fog. Leírás alapján teljesen ugyan azt a játékstílust követeli mint a "kis csigusz"-tól. Közel harcban viszot a ruszki jóval hatékonyabb.
Mondjuk én abban a hitben éltem, hogy körbe tud forogni a torony rajta, de azért így sem rossz. Most viszem az E50 /Leo1/Cent 7/1 vonalat és bele kezdtem a japánba is. Lehet még ötödiknek bele fér az orosz is -
zsolthee
Fél füllel kaptam el, hogy van most valami TOG akció vagy mi a nyavalya...a lényeg, hogy tegnap tier6 tele volt azokkal a dögökkel...és persze pipacsokkal.
ELC AMX-szel hibáztam egyet és megnéztem a csata végét, hogy mit csinál az utolsó játékosunk, egy TOG.
Addig jól csinálta, hogy elkezdte behúzni a bázis, viszont nem vonult fedezékbe. Mondom neki, hogy menj hátrébb a ház mögé, hogy legyél takarásba, így nem spotolnak fel olyan könnyen és nem bontanak le messziről. 3 ellen "küzdött" a csórikám, 2-t valahogy kilőtt, de a harmadik takarásból lecsipegette az összes HP-ját
Ha nem írtuk be vagy 10x neki, hogy hátra, a ház mögé...
És csak ment előre, hátra, forgatta a tornyot és nézett, hogy honnan a francból lövik.
Jó, ne értsen a játékhoz, de olvasson már chat-et ha nincs képbe. El is buktuk miatta természetesen.
Mi ez a TOG-tenger mostanában? -
zsolthee
Ugye hogy ugye? Csak meg kellett volna tartani azt a T34-et!
Most meg tudná durrantania kasszádat rendesen. Napi 5-6 jobb csatával simán összejön 300k nettó. 1 hét alatt - ha még a duplázós köröket is bele vesszük - simán meg van az RHM ára.
Az Emilt én is utáltam. Olyan helyzetekben ment mellé a lövés vagy pattant, hogy az már nevetséges volt. Papíron a nagy ágyú használhatónak bizonyult, de nem váltotta be a hozzá fűzött reményeket.
A borsó jó lesz, kitartás h1mpi![ Szerkesztve ]
zsolthee
Az IS3 front páncélján változtattak valamit?
Közelről oldalba vágtam a csőrét E75-tel majd egy másik csatában a Bélával is, de úgy pattintotta, hogy öröm volt nézni. -
zsolthee
válasz jozefgucci1 #97114 üzenetére
Heavy vonalra gondolsz? Azzal meg vagyok a 110-ig fullosan.
zsolthee
válasz jano_77 #97161 üzenetére
Én pl az M4-nél úgy csinálom: Első skill parancsnok 6.érzék a többieknek javítás, 100%-on. Most a 2skill végig BIA, kb 40%-on.
Azért van így, mert az előző garnitúra legénység (Ők mentek tovább a Pershing - Patton vonalon) is hasonló módon lett kiképezve és nagyon jól el voltam vele. Troll gun-nal használom, így álcának nem sok értelme van, se a sima utazásnak vagy más egyéni képességnek. Mire a 3. skill lesz soron, addigra meg átültetem őket egy másikba. Ott meg osztok nekik álcát, vagy amit az adott vas megkíván. Ezt a módszert akkor használom, amikor Tier 5-6 körül kezdek egy új ágat és nem akarok kopaszokkal kezdeni. PL: T37 - Mire a T49-hez érek, lesz már 4 skill-jük, T57 Heavy-nél meg már az 5.-et akarom súrolni.Mi van egyébként ezzel a "6. érzéket mindenkinek" ötlettel? Ez csak egy felvetés volt a WG oldaláról vagy szándékoznak is lépni valamit?
Új legénységnél nem győzöm kivárni amíg felugrik ez a képesség 100%-ra Főleg a könnyű tankoknál...[ Szerkesztve ]
zsolthee
válasz Viktoár #97291 üzenetére
Álcaháló, periszkóp, távcső.
Töltésgyorsítót feleslegesnek tartom. Lövés után el kell egyből spurizni, felvenni egy új pozíciót. Ehhez képest a tizenvalahány mp reload nem is sok.
Brutális álcája van, ezt kell kihasználni, szóval a festést se sajnáld róla.Skillek nálam így néznek ki:
Parancsnok: 6.érzék - álca
Vezető: Álca - Kuplung égetőEzután rágyúrok a látótávra majd BIA és akkor a távcső helyett teszek ventit.
Nem vagyok túl jó a light tankokkal, de ezzel bármikor szívesen nyomok néhány csatát.
Jó tanács: soha ne add el! -
zsolthee
válasz Viktoár #97340 üzenetére
Nem csak a szituációtól, hanem a tank egyéb karakterisztikájától is függ. (páncélozottság, dpm stb).
Mondjuk a Cent 7/1-nél nem tartom soknak a 268-as átütést, mert közelharcra - med létére - teljesen alkalmatlan. Ugyan így a német papír TD-ken sem kirívó az átlagosnál magasabb pen. -
zsolthee
válasz szbalogh #97351 üzenetére
Igazad van, a TD-vel kicsit alá lőttem. Inkább >=280
A brit ágon nem tudom mire lenne elég a 200.. Nem vagyok profi med-es, de a jelenlegi helyzetet elnézve még a IX-es szinten sem elég néha (T-54). Ha mindenki a típusnak megfelelően használná a vasat, akkor talán igen. -
zsolthee
A SIA képesség a női tagoknál 0. vagy 1. skill-nek számít?
zsolthee
Aki AMX 30 illetve 30B-vel aki nyomja aktívan, tudna véleményt mondani erről a két tankról?
A 1390-et nem nagyon csipázom, maximum az egyik 9-es med kifejlesztéséig vagyok hajlandó vele játszani, aztán megszabadulok tőle. -
zsolthee
3 észrevétel:
- elvették a SP I.C irányából az Indienre való áttérést. Ez mire volt jó?
- ez az SP I.C egy förtelem...számomra. Nagy (magas a sziluett), lomha és bitangul pontatlan mindkét top ágyú (a sima és a táras is)
- a RU viszont kellemes csalódás. Eddig legjobb light amivel játszottam. -
zsolthee
Én is gurulok azzal a rollerrel.
Azért vannak derűsebb pillanatok is.
Csípem amikor megy az okoskodás, csak nem tudom miért nem az öngyilkos csapattársak miatt pofázott a GW. T34 replay[ Szerkesztve ]
zsolthee
Mod nélküli játékhoz csak annyit, hogy a térképen megjelenített utolsó pozíció szerintem nagyon sokat számít. Elég sok mindenre kell figyelni, óriási segítség ha nem kell még egy tucat tank helyzetét memorizálni. (számomra lehetetlen )
Ha nem is az egész játék alatt, de a vége felé jó támpont.Nem sokan említették, de a nagyobb zoom - leginkább TD esetében - sem elhanyagolható.
Ha ezt a kettőt sikerül egy új patch alkalmával letölteni, már mehet is a móka.
Most láttam először OTM reload modot....hááát...ha egy ammo-rack sérüléssel is tud számolni, akkor szerintem mondhatjuk "csalásnak".Emlékeim szerint a parancsnok képessége lenne, hogy felismerje a sérült modulokat az ellenségnél. Na már most ez jó ha 4-5. skillnek beteszi az ember, szóval így van egy perk amit ki sem fejlesztesz mégis előnyhöz jutottál.
Az auto aim bot pedig valóban dobhat a játékos teljesítményén (valójában ügyesebb persze nem lesz). Kizárjuk az emberi hibát és a gép kiszámolja mennyivel lőjön a mozgó tank elé. Talán ez a legpofátlanabb mod az összes közül. A bal gomb nyomkodásához nem kell sok gógyi. Le merem fogadni, hogy a játékosok 80%-a azzal sincs tisztában, hogy a különböző lövedékeknek más a sebességük és a becsapódási szögük. Ha ezt kompenzáljuk egy ilyen csalással, akkor a "TomatoThomas" ki tudja csipegetni a száguldó light tankod utolsó HP-ját is 300m-ről.
zsolthee
Legyen fix tier, alap xp + spot dmg összege adja a végeredményt.
Hogy tényleg abszolút egyenlő eséllyel indulhasson mindenki, prémium tankok ne vehessenek részt.
( +10% xp bónusz jár nekik)(#98496) pajaci
Másolással[ Szerkesztve ]
zsolthee
válasz jozefgucci1 #98783 üzenetére
A Centivel távolról kell a csapatot támogatni. Nem sniperkedni egy bokorból természetesen, hanem a pálya adottságait kihasználva - lehetőség szerint a dombosabb részeken - kell vele operálni. Város, sidescrape felejtős,ammo rack-et rendszerint ellövik, ezért is kell folyamatosan rejteni az alját.
A dpm és a pen hiába jó, mozgékonyságban messze elmarad a szovjet társaitól, így a közelharcot felejtsd el vele. Max egy JT-re ronts rá ha egyedül van.
A 7/1 nekem tetszik, a kis ágyúval rengeteg jó köröm volt. Csak pislogtak amikor 4mp-ként szórtam a skulót a láncot meg nem tudták felpakolni. A nagy alfás top löveg az átütése miatt nagyon jó, de majdnem olyan lassan tölt mint egy HT. -
zsolthee
Nincs egyetlen egy artym sem 15k csata után. Melyik nemzettel érdemes most kezdeni?
Lényeg, hogy legyen esélyem megkedvelni ezáltal kicsit jobban megismerni a tüzérséget.
Köszi![ Szerkesztve ]
zsolthee
köszi a válaszokat.
Stug SPG-15-höz kéne igazából, tier 5-6-ig. Német ággal mi a gond?[ Szerkesztve ]
zsolthee
válasz Djuree #100436 üzenetére
Akkor nem is kérdezem, hogy a Stug LT-15-öt megcsináltad-e?
Én szívok vele egy ideje. Egyzer meg volt a 4k, de meghaltam.
A kitüntetéssel való teljesítés meg azért kéne, mert nincs artym így nem kapom meg a +1 tokent.
Nem akar esetleg valaki egy nap alatt 1000 aranyat keresni?[ Szerkesztve ]
zsolthee
válasz SoulReaver #100833 üzenetére
Ha Prokhorovka-ról indultok mondjuk E100-zal és van oldalanként 2-3 arty akkor merre veszitek az irányt?
Egy ügyesebb spotter 15-20 mp múlva már villant is, fedezék meg sehol. -
zsolthee
válasz Because #100970 üzenetére
Ha nem akarsz nagyon költeni a skill-resetre, akkor legalább az utolsó tagnál BIA-t vedd le, mert az így teljesen értelmetlen. A többi maradjon, majd másodiknak mehet végig az álca.
A legfontosabb a "láthatatlanság" és a nagy látótáv, főleg passzív felderítésnél. Ezért lett volna több értelme egyből a camot fejleszteni.Más:
ELC-vel indultunk Malinovka-n az északi - ahol a nincsenek épületek a bázis és a mező között - oldalról és gyönyörűen megmutatkozott a <800 WN8 játékosok tudása. Nem szoktam lenézni őket, mert amikor papír szerint tuti bukó lenne, akkor is sikerül valahogy összehozni a győzelmet.
Na de a lényeg, hogy nem hazudtolták meg magukat. Mondom nekik megyek középre villantani. Jön a sok "Értettem!". Felderítettem az ellenség 90%-át, de képtelenek voltak nyerés irányába fordítani az állást. A végén amikor már középen bejött egy Cromwell, kitörtem a bokorból és kapott egy ~200-as puszit. Végig szambáztam az ellenséges bázis előtt lévő épületeknél, majd egy Nashornba is beleszúrtam egyet. Visszamentem védekezni ahol egy TD-t ammorack sérüléssel robbantottam. De sajnos győzött a túlerő és lenyomtak.
Szóval tényleg nem kell sok ész az 1000Wn8-hoz és ezért sem tudom felfogni, hogyan lehet néhány százas értékeket produkálni több ezer csatából??? A száz alattiakra már csak legyintek.(#100972) xAttilax
És hogy ez mennyire igaz, még egy példa.
Egy Su85B és Achilles (én) védekezünk Prokhorovka-n, az idióta Chaffee meg reszkedve kucorog a sarokba. Volt még vagy 4-5 ellenséges tank, akiket ha csak öngyilkos módon is de megközelít, akkor mi simán ki tudtuk volna csipegetni és nyerünk. Persze nem ez történt, hanem mi voltunk a noob-ok, a 2 TD.
És mikor mozdult meg? amikor már csak egyedül maradt. Mondom gratulálok.
Kaptam is reportot mertméregből beírtam mindenkinek, hogy A1[ Szerkesztve ]
zsolthee
válasz Because #100974 üzenetére
Hogy egy kollégától idézzek: már a garázsban vesztésre játszol! ergo a játék közben sem nagyon érdekel, hogy mi a helyzet körülötted. Nehogy már az íratlan "szabályok" mondják meg, hogy én nem mehetek szembe egy nálam 2 szinttel nagyobb mednek. Megtehetem, nem?
De neked van igazad és Te "élvezed" igazán a játékot, mert a tudatlanság áldás! -
zsolthee
válasz Because #100985 üzenetére
Nem bántásból kaptad a kritikákat
A családi helyzet úgy hozta, hogy amikor kisebb voltam (ált.iskola) a sok testvér közül néggyel voltam közös házban, de leginkább mindig csak hozzám korban közelebb eső fiú testvérrel játszottam "komolyabb" játékokat. Komplett városrészeket építettünk mindenféle kacatokból és nagyon élveztük. Anyukánk megkérdezte, hogy a kicsiket miért nem engedjük a szőnyegnek arra a részére ahol mi vagyunk? Mert tönkreteszik amit csinálunk, nem tudnak szépen játszani.Nem tudják azokat a játékszabályokat elfogadni ami nekünk élményt nyújt. -
zsolthee
A replay visszajátszás működik nektek? Addig OK, hogy a Wot.exe-hez bemásolom a fájlt, elindul és rákérdez, hogy a verziókülönbség ellenére le akarom játszani? Igen. És kilép. A replay mindössze néhány napos...
Light téma:
Mivel kezdő vagy a könnyű tankok terén, szerintetek melyik az a LT amelyiket mindenképp érdemes kifejleszteni majd végleg megtartani?
Egyenlőre ELC AMX és a Bulldog nyert végleges helyet a garázsban. Utóbbi azzal vívta ki, hogy megcsináltam vele a Stug LT-15-öt. ELC just fun, brutál camo. RU-t a Leo-ig megtartom, 1390-et eladtam
T71 vagy esetleg MT-25? Mostanság randomban gyakori az LTTB is.
Eddig a kis 5-ös francia van a top lista élén az előbb említett magas álcaérték miatt. Emellett kis célpont és nagyon jó a pen a normál lőszeren. Egyetlen hátránya, hogy nem forog a tornya és ezt legalább 2 skill-es legénységgel illik kompenzálni.
Kíváncsi lennék, hogy kinek mi a favorit?[ Szerkesztve ]
zsolthee
válasz kchryss #101001 üzenetére
Tier6-ban tényleg nagyot üt a kis ELC, de butaság lenne TD módban lapulva üldögélni vele. (Ki sem lát egy apró bucka mögül)
2 skill-es legénységgel megy mint a mérgezett egér. Ha egy tier6-os heavy félig le van sebezve az ELC simán kivégzi. Menet közben kap egy taslit és mire észreveszi, hogy merre van arccal már a seggébe is vagy...és kampó.
Tier8-ban már kell a rutin, ott a gyorsaságodnak még nagyobb hasznát veszik a társaid a sok lomha dög között.
Amcsi T34-gyel voltam nem rég Live Oaks-on és a végjátékban egy ELC-vel maradtam a dombos részen a vasúti síneknél. Az ellenfél túlerőben volt, de a segítségével sikerült lehozni csatát. Nagyon jól forgatta a gépet a srác
Meg hát nem tudom hogy vagy vele, de én nem tudok ellenállni a sebességnek.[ Szerkesztve ]
zsolthee
Pár hete-hónapja találtam egy oldalt ahol egy olyan tech-tree volt, ami az adott ágon kiszámolta egy tanktól a másikig a szükséges XP és credit mennyiséget két kattintással. Égen-földön nem találom...
Ha ismeri netán valaki ezt az oldalt, tudna dobni egy linket?[ Szerkesztve ]
zsolthee
Úgy döntöttem, hogy el fogom adni a WTE100-at.
Egy tier 8 vagy 9 német TD-t vennék vissza helyette, csak nem tudom melyiket érdemes.
Borsignak jó az álcája viszont a JP2-nak legalább van némi páncélja és gyors is. Szóba jött még a WT PZ4 is mert azon a 128-as cső az 560-as alfával eléggé kecsegtető, viszont az szintén csak egy kartondoboz.Az eladást - azon kívül, hogy elsődleges cél vagyok spot után - az erősítette meg bennem, hogy gyengének érzem az álca értékét.Rákerestem, és megdöbbentő értéket láttam. Ez igaz lehet?
Nem létezik...!!!Ferdi és JT felejtős, utóbbit 2x adtam el.
Egy időben volt olyan info is, hogy lecserélik a WTE100-at. Ebből mikor realizálódik valami? Lehet tudni?[ Szerkesztve ]
zsolthee
nem tudok belépni a teszt szerverre. Korábban volt jelszócserém és próbáltam mindkettővel, de azt mondja, hogy "nem tud kapcsolódni a szerverekhez mert nem éri el vagy a hálózati probléma van". Nyilván egyik sem.
Nem lehet, hogy a korábban csak DEL gombbal letörölt teszt kliens (9.9) maradványa kavar be? User profile alatt mik azok a cache-elt dolgok amiket érdemes törölni ilyenkor? Ha egyáltalán az segít...
MODERÁTOR
(rögzített hozzászólás)
Figyelem!
- Naim Mu-So 2 Wood Edition - Makulátlan, akár beszámítással
- Apple Homepod (2. gen) - Csomagolás bontott, makulátlan, Apple garancia, akár beszámítással
- Samsung Galaxy Buds 2 Pro -Csomagolásbontott, makulátlan, jótállásal, akár beszámítással
- Apple Airpods 2 (2019) - Újszerű, Apple garancia, akár beszámítással
- Apple Airpods Pro 2 (2023) USB-C - Újszerű, Apple garancia, akár beszámítással
