A ZIDOO médialejátszó topik célja, hogy segítsük egymást
a minél jobb moziélmény elérésére
és a problémák megoldására.
Feltöltés folyamatban.
Ötleteket és segítséget Pü-ben várok.
Zidoo is not streaming player.
AZ új PRO boxok már
rendelkeznek
DRM L1
támogatással.
tomp
X9S-re elkészült a 2.1.25!
OTASystem
1. Optimized system stability;
Launcher
1. Fixed date display way of main interface when language setting in Chinese;
Home Theater
1. Added function that loading external devices automatically and automatic scanning switch;
2. Fixed the problem that the post wall will match failed when stopped scanning manually;
3. Added Focus looping function of left navigation list in setting interface;
4. Added Blu-ray navigation select box for match-failed movies;
5. Changed some UI of device interface;
6. Fixed the invalid automatic update of background;
7. Added function that importing previous setting after date cleared;
8. Optimized searching way that the post wall will continue matching by first letter, and will show the movie with high matching degree first;
9. Fixed virtual Key Layout of searching interface;
10. Fixed date no update when NFO matched films rematched to be TMDB films;
11. Fixed invalidation problem of INFO key and POP key in third layout of main interface;
12. Fixed the black line showed in the right part of the too long headline in second layout of main interface;
13. Optimized interface display of main interface’ left pane;
Music
1. Optimized accuracy of matching;
2. Optimized stability;
3. Optimized SACD matching and added matching of info files;
4. Added matching function of album;
6. Optimized analysis of album related information;
7. Optimized data analysis;
8. Optimized playback stability;
Quick settings
1. Added function of locking resolution;
2. Added 1080P23 and 4K23 resolution options;
3. Added play modes setting;
Player
1. Added function that when showing video information the movie will continue playing;
Blu-Ray Navigation
1. Optimized accuracy of Blu-Ray Navigation;
HDMI IN
1. Added sustaining record function when HDMI output turned off.Valaki meg tudja csinálni X8-ra? Anno volt aki az egyik bétánál megcsinálta, hogy az X9S fw felmenjen X8-ra. Mivel szinte ugyan az a kettő, gondolom csak a build.prop fájlban kell átírni a modellt de én nem tudom.
tomp
USB 2.0 1,3A-al van ellátva. De a 2db portnak 1betápja van. Azaz ha az egyiken már lóg egy vinyó akkor a másikra is bekötve már megránthatja annyira, hogy az első újra felpörög. Ha csak 1 vinyó megy akkor nem okozhat gondot az usb 2.0! USB 3.0-nak külön 1,5A-es betápja van.
Nálam az X8-on 2db vinyó van. 2TB+320GB. A 2TB-os közvetlenül a boxra van kötve egy sata-usb 3.0-s adapterrel de usb 2.0-ra a másik egy aktív usb hubon keresztül lóg szintén egy sata-usb 3.0-s adapterrel. A hub szintén a 2.0-s porton van. Így az usb 3.0-t nem használom mivel AC wifin megy a box és a wifi zavarná a 3.0-t. -
tomp
válasz univerzita #5767 üzenetére
Sajnos nem találtam.
tomp
válasz Beni2360 #5811 üzenetére
Na felraktam az új fw-t. Amit eddig észrevettem: sokkal gyorsabb film közben a menü. Eddig olykor hajlamos volt beszaggatni a menü(feliratok,hangsáv, stb menü). Most nagyon gyors lett. Hibával eddig nem találkoztam. Eddig 2 film ment az új fw verzióval. Nincsen hibás képarány.
tomp
válasz Beni2360 #5824 üzenetére
Ha 2.5" akkor mindképpen kell neki külső táp.
Ha usb 3.0-n használja akkor nem kell! Sőt a boxon még usb 2.0-ról is meg tudja hajtani mivel több mint 1A-rel lehet terhelni!
Ha kevés a táp neki akkor nem akadozik a film hanem leállítja a lejátszást és visszadob a Media Centerbe. -
tomp
tomp
válasz #48613632 #5852 üzenetére
apk mirroron fent van minden appnak az apk telepítője. Leszeded, boxon bekapcsolod az ismeretlen forrásból való telepítést és telepíted a fájlt. Vagy a Zidoo fórumon van Play Áruház app. Felrakod és megy.
Ha ezeknek nem néztél utána és a gyártóra köpködsz akkor jobb is ha visszaküldöd. Egyszerűen nem értesz hozzá... -
tomp
Ha nagyon jó a füled akkor hoaszabb távon zavarni fog a bluetooth kodek miatti minőség romlás mivel sajnos csak SBC kodeket támogat a box így egy Dolby vagy DTS hangsáv SBC-n eléggé "vizesen" szól. Jó lenne ha tudna a box legalább aptX kodekket mivel az már mérföldekkel szebben szól.
tomp
válasz Beni2360 #6119 üzenetére
Ott is SBC kodek van. Samsung prémium modelleknél lehet aac kodek de azt egy sima bt füles nem tudja.
SBC max zenehallgatásra jó de arra sem mindegyik fülessel. Nekem a fülesem SBC-t és aptX-et tud. Alapból aptX-el kapcsolódik a telefonra. Ha átváltom SBC-re érezhető a romlás.
Az SBC 328kbps-es az aptX 352kbps de teljesen más a tömörítés ezért szebben szól.
Van már aptX HD kodek is ami már a nagy felbontású(48kHz/24bit 576kbps) zenére való de az igaz nagyágyú az a Sony által fejlesztett LDAC kodek. 96kHz/24bit 990kbps-el. -
tomp
válasz Beni2360 #6255 üzenetére
Fórumon nincs fent de a box online frissítője jelez!
X8
X9S
X10
Changelog:
System
1. Optimize NFS connection strategy to avoid Player (Gallery) error caused by network fluctuations.
2. Optimize system stability.
3. Add mobile phone control function (mobile phone can control all functions of the player).
Device name can be changed in "All Apps" -> "Control Center".
The mobile control app is available on Google Play and will be updated to the Apple Store later.
Please search earch zidoo controller via google playVideo Player
1. Subtitle download supports two or more languages downloading at the same time.
2. Optimize DLNA mirror function.
3. Fix Player (Gallery) crash problem caused by ASS,SSA subtitle compatibility.Bluray Navigation
1. Subtitle download supports two or more languages downloading at the same time.Poster Wall
1. Optimize custom wallpaper loading to solve the problem of loading long images or high resolution images that are easy to crash.
2. Optimize search interface.
3. Optimize stability.Music Player
1. Completely rewrite the playback engine, upgrade to ZIDOO MUSIC V5.0
2. Optimize playback stability, fix SACD unexpected jump problem.
3. Add more audio format supporting, such as AIF.
4. In the folder page, support select the original directory structure to browse.
5. Optimize the accuracy of CUE file playbackQuick Settings
1. Subtitle download adds support for multiple languages
2. Modify the settings of the audio original sample rate output switch. -
tomp
válasz TanczosGabor #6290 üzenetére
Az Alita valóban HDR10+ de attól még sima HDR10-ben jónak kellett volna lennie.
Nekem SDR tv-m van de az összes HDR film gyönyörű! Az Alita is.
A HDR10+ egy ingyenes szabvány amit a Samsung talált ki a Dolby Vision ellen mivel az keményen licensz díjas. HDR10+ ugyan azt tudja mint a DV csak ingyen. Nyílt fejlesztés. Bárki belerakhatja az eszközébe.lassú (elvileg az összes Android lassú)
Gyakorlatilag viszont nem!
A boxon egészen jól megy az android. Nálam nem lassú. De ha villám androidot szeretnél akkor olyan telefont kell venni. -
tomp
válasz TanczosGabor #6297 üzenetére
Igen pontosan így van. Ha be van kapcsolva akkor SDR megjelenítőre is HDR képet küld. Ha kikapcsolod akkor viszont elvégzi a HDR-SDR konverziót.
tomp
Zidoo Controller
Hivatalos androidos app! -
tomp
A X8 USB áramellátását korábban már teszteltem.
"Az USB 2.0 1,3A-al van ellátva. De a 2db portnak 1betápja van. Azaz ha az egyiken már lóg egy vinyó akkor a másikra is bekötve már megránthatja annyira, hogy az első újra felpörög. Ha csak 1 vinyó megy akkor nem okozhat gondot az usb 2.0! USB 3.0-nak külön 1,5A-es betápja van."
Nekem van egy 7portos USB 3.0-s elosztóm aminek szintén 12V-os tápja van. 12V/2,5A.
Gondolom a nagyobb feszültségű táppal stabilabb az áramellátás.
2,5-ös merevlemezből nincs olyan amit nem bírna meghajtani a Zidoo! -
tomp
válasz TanczosGabor #6699 üzenetére
Na ez óriási hiba! A zip digitálisan alá van írva. Ha módosul akkor már nem felel meg. Esetleg töltsd le egy rendes böngészővel.
tomp
Bemutatták a Zidoo-X szörnyeteget!
6magos proci+DDR4!
HDR10, HDR10+, Dolby Vision, roon, MQA.
1-2 apróság. Gondolom az ára is horror lesz -
tomp
Másnál is eldobja néha az USB-re kötött merevlemezt a box? Megy a film, kilép és nem látszik a merevlemez. Kilépek a Media Centerből majd vissza és újra ott van. Lehet kellene egy gyári visszaállítás?
tomp
Már így is egy csere táp van rajta. 3A-es. Amúgy amelyik merevlemez a boxról kapja a tápot nem csinál semmit mikor kilép a lejátszás. Még a fejet sem rántja parkolóba egyszerűen csak megáll az olvasás. Parkolóba csak 10mp-es inaktív idő után megy.
10 lejátszásból max 1x csinálja ezt. -
tomp
válasz Monngoose #6812 üzenetére
Stressz teszten a magok dolgoznak igen. Na de film alatt nem mivel ezeket hardveresen végzi és nem szoftveresen.
Nekem az X8 egy UPC boxon van. Nyáron kapja arról a meleget de nem volt még soha emiatt film problémám. HEVC HDR-t gond nélkül vitte nyáron. Pedig az X8 is eléggé forró volt. -
tomp
válasz DroiDMester #6825 üzenetére
Nem a pc dobja el hanem bizonyos külső 2,5-ös rackek és aktív hubok.
Vagy elkezdi a windows folyamatosan újra csatolni vagy a sebesség lemegy fix USB 2.0 szintre.
Realtek chipes Ewent aktív hub szerette eldobni. A VIA chipes tp-Link hub már nem.
Amúgy még a windows ki is írta, hogy helyezzem távolabb az USB 3.0 eszköztől az 5GHz-es Wifit. 1x írta ki. Előtte és azóta se.
Tomp fórumlakókn összefoglalója miként készítsünk Dolby Vision videót a ZIDOO X szériás lejátszóhoz.
Egy cikk egyik fórumtársuntól a
ZIDOO UHD200 lejátszóról.
Hang rendszer
oldaláról.
- Aliexpress tapasztalatok
- Nintendo Switch
- Háztartási gépek
- Call of Duty: Mobile
- NVIDIA GeForce RTX 3080 / 3090 / Ti (GA102)
- Automata kávégépek
