S_x96x_S
"Introducing the Framework Laptop 16 and both Intel and AMD-powered Framework Laptop" 23 Mar 2023
https://frame.work/at/en/blog/introducing-the-framework-laptop-16-and-both-intel-and-amd-powered-framework-laptop-13új alalapok:
- AMD Ryzen™ 7040 Series ( a "Batch 1" már kifogyott.. és aki lemarad a "Batch 2"-ről, annl már csak a "Batch 3" 2023 Q4 - marad )
- 13th Gen Intel Core ( ez nem annyira kapós .. )Fontos infó:
Aki majd a 16 colra szeretne upgradelni a 13-as alaplapját, az óvatosan, mert valószínüleg nem lehetséges.
Q: Do the 13 and 16 use different mainboards? Can I buy an AMD 13 and move it to a 16 chassis?
A: They do use different mainboards in order to enable all of the functionality that exists in the Framework Laptop 16 (6x Expansion Cards, the Expansion Bay, and the Input Module system).
https://news.ycombinator.com/item?id=35279291
megj: persze azt azért furcsállom, hogy valami adapter ne tudjanak erre csinálni ..Amúgy lehet, hogy ősszel lesz már magyar billentyűzet is.
https://community.frame.work/t/request-review-of-norwegian-portuguese-swedish-swiss-slovenian-thai-hungarian-and-danish-keyboards/26949
ha valaki észrevesz valami problémát, jelezze ..
Mottó: "A verseny jó!"
S_x96x_S
A Phoronix-os linuxos tesztre még várni kell ( BIOS probléma )
Vagyis akinek Linux ot tenne alá, az nézzen alaposan utána ..
https://community.frame.work/t/announcement-linux-on-your-framework-laptop-13-amd-ryzen-7040-series/37367
official: "Unfortunately, the last firmware release provided by AMD to fix critical issues also introduced a regression on Linux. Specifically, certain kernel versions have amdgpu drivers that result in the system hanging. AMD has created the firmware fix for this and is currently completing validation on it. We’ll put this through an accelerated test and release process to get it out to you as quickly as possible. We anticipate this being available in mid October (roughly), and we’ll share it via LVFS. In the meantime, we’ve updated our Linux installation guides to call out which recipes will give you the best results with the 03.02 BIOS version that will come on your laptop:"--------------------
(2023-Október-03)
AMD Ryzen Powered Framework Laptop Linux Testing Held Up By BIOS Issue
https://www.phoronix.com/news/AMD-Framework-Linux-Hold"After installing an Ubuntu 23.10 snapshot to the device, there was no working desktop and when connecting via a VT, there were AMDGPU issues. Long story short there was a BIOS regression introduced... After working with AMD and Framework, a new BIOS revision should be available in the coming days to fix the issue. But that means no Linux benchmark results for today's review embargo lift. But as a notice to those that pre-ordered an AMD Framework Laptop, it means you'll also want to make sure you update to the latest BIOS (or stay on BIOS v3.00 as the known good version prior to regressing) so you won't run into any Linux show-stopper. A pre-6.5 kernel can be booted with the regressed BIOS to a working desktop but will be producing AMDGPU errors. This also isn't apparently a Framework-specific issue but other Phoenix laptop model(s) have had the same or similar issue -- at least the likes of the Lenovo ThinkPad P14s Gen 4 AMD with Ryzen 7 PRO 7840U have been unaffected by the problem."
- Sorozatok
- Yettel topik
- Redmi Note 13 Pro 5G - nem százas, kétszázas!
- Mesterportrékkal érkezett a Honor 200 Pro
- T Phone 2 5G - kétszer olyan jó
- Fotók, videók mobillal
- HP EliteBook 850 G7 Intel Core i7-10610U, 32GB RAM, 512GB NVMe SSD
- AKCIÓ ! Macbook Air 13" - 2019, i5, 16/256GB, garancia, doboz, szürke (01)
- Macbook Pro 14 (Late 2021) A2442 27% 14" Liquid XDR M1 Pro 32GB 512GB ujjlolv., gar
- EliteBook 850 G8 15.6" FHD IPS i5-1135G7 16GB 512GB NVMe ujjlolv., gar
- Dell Latitude 7300 27% 13.3" FHD IPS i5-8265U 16GB DDR4, 256GB NVMe gar
- Sony Vaio F15 Multi-Flip - SVF15N1C5E
- Dell Inspiron 15 laptop
- Lenovo ThinkPad X1 Yoga 2nd i7-7600u/16GB/512GB SSD/14"FHD 2in1 UltraBook garancia
- Acer Aspire 5732Z Pentium Dualcore 2.2GHz 2Gbram Radeon HD 4570 hibás de használható
- Lenovo Ideapad S145 - 15,6", i5-1035G4, 4 GB RAM, 128 GB SSD, 1 TB HDD, Intel Iris.
