fo_di
válasz amorpheus81 #9 üzenetére
a wikipedia szerint a fraunhofer aac-ben van egy agresszív aluláteresztő szűrő, melyet csak a legjobb vbr kapcsol ki
The FDK AAC encoder employs a more aggressive default low-pass filter than is used in other codecs. Higher frequencies are removed so that more bits are available to better describe sounds of lower frequencies, improving the overall quality for most combinations of recordings and listeners. In some, not completely rare, combinations the missing high frequencies are noticeable. The library allows overriding the low-pass filter setting, and in the highest VBR mode effectively applies no filter at all.
https://wiki.hydrogenaud.io/index.php?title=Fraunhofer_FDK_AAC#Bandwidth
The default bandwidth (or low-pass filter cutoff) for each bitrate mode will be the minimum of the appropriate value in the tables below or half the sample rate. This can be overridden, but the maximum value is 20000 Hz.[ Szerkesztve ]
- Ej-Ha! Lenovo ThinkPad P53s Szép Home & Business Laptop -70% 15,6" i7-8665U 16/512 Quadro P520 2GB
- Új Lenovo ideapad 5 Pro Prémium Ultrabook 14" -30% Bivaly Ryzen 5 5600U 8GB 512GB 2,2K RADEON 2GB!!
- iPhone 13, 128GB, starlight, kártyafüggetlen, 88% akku
- Tyű-ha Lenovo Thinkpad T15 "Golyóálló" Üzleti Laptop 15,6" -50% i7-10510U 4Mag 32GB/512GB FHD IPS
- Új 2K AM5 Gamer PC R5 7600/RTX 3070 8Gb/2X8Gb 6000Mhz DDR5/500Gb SSD M2/700W 2Év gari
