donmackó
válasz maszibmw #10447 üzenetére
Nálam így néz ki:
2013-09-23 21:13:29: [Info] Map Reject - Downstream Traffic Flow Not Mapped to BPI+ SAID ...
2013-09-23 21:13:29: [Info] SA Map State Machine Started;CM-MAC=44:32:c8:45:f6:6c;CMTS-MA...
2013-09-23 21:13:16: [Minor] SW upgrade Failed after download - Incompatible SW file
2013-09-23 21:13:16: [Info] SW dload: Invalid image signature!
2013-09-23 21:13:14: [Info] SW Download INIT - Via Config file fiberpower60_sip.cfg
2013-09-23 21:13:09: [Info] Authorized;CM-MAC=44:32:c8:45:f6:6c;CMTS-MAC=00:01:5c:49:28:4...
2013-09-23 21:13:04: [Info] TLV-11 - unrecognized OID;CM-MAC=44:32:c8:45:f6:6c;CMTS-MAC=0...
2013-09-23 21:13:03: [Minor] Missing BP Configuration Setting TLV Type: 17.9;CM-MAC=44:32:...
2013-09-23 21:13:03: [Minor] Missing BP Configuration Setting TLV Type: 17.8;CM-MAC=44:32:...
--- -- --:--:--: [Warn] DHCP WARNING - Non-critical field invalid in response ;CM-MAC...
--- -- --:--:--: [Info] Honoring MDD; IP provisioning mode = IPv4
--- -- --:--:--: [Info] WiFi Interface [wl0] set to Channel 11 (Side-Band Channel/A...
2013-09-23 13:55:58: [Major] SYNC Timing Synchronization failure - Failed to acquire QAM/Q...
2013-09-23 13:49:36: [Major] Received Response to Broadcast Maintenance Request, But no Un...
2013-09-23 13:49:36: [Major] SYNC Timing Synchronization failure - Failed to acquire QAM/Q...
2013-09-23 13:40:45: [Major] DHCP FAILED - Request sent, No response;CM-MAC=44:32:c8:45:f6...
2013-09-23 13:40:24: [Major] SYNC Timing Synchronization failure - Failed to acquire QAM/Q...
2013-09-23 13:40:14: [Major] SYNC Timing Synchronization failure - Failed to acquire FEC f...
2013-09-23 13:40:12: [Major] SYNC Timing Synchronization failure - Failed to acquire QAM/Q...
2013-09-23 13:39:54: [Major] Received Response to Broadcast Maintenance Request, But no Un...
2013-09-23 13:39:54: [Major] SYNC Timing Synchronization failure - Failed to acquire QAM/Q...
--- -- --:--:--: [Major] DHCP FAILED - Request sent, No response;CM-MAC=44:32:c8:45:f6...
2013-09-23 13:30:56: [Major] Resetting the cable modem due to docsDevResetNow
--- -- --:--:--: [Major] No Ranging Response received - T3 time-out;CM-MAC=44:32:c8:45...
--- -- --:--:--: [Major] SYNC Timing Synchronization failure - Failed to acquire QAM/Q...
--- -- --:--:--: [Major] SYNC Timing Synchronization failure - Failed to acquire FEC f...
--- -- --:--:--: [Major] SYNC Timing Synchronization failure - Failed to acquire QAM/Q...Release the cable hounds!
donmackó
válasz Intruder2k5 #10792 üzenetére
Ha már rendel az ember akkor vagy 8 csatit + toldót és 50 méter kábelt rendelek hogy legyen későbbre is. Hátha esetleg javítani kell vagy változtatni megint a rendszeren. Így azért már a szállítást is megéri szerintem.
donmackó
válasz Intruder2k5 #10796 üzenetére
Nálunk például 1 hd és1 digitális +1 net és teló előfizú van. A koax a padláson megy mindenhol és a kedves egérkék előszeretettel csócsálják meg a koaxot (nem tudom miért ízlik nekik) és a 20 méteres utp kábelt (ezen megy anyósékhoz a net a ház másik végébe). Ezt a kettőt évente cserélni kell legalább egyszer mert szétrágják és még arról nem is beszéltem hogy após a barkácsmester hányszor metéli el véletlenűl. Úgyhogy én mindenre fel vagyok készülve.
donmackó
donmackó
válasz TheHardOne #10800 üzenetére
Van.De csak konzerven él, meg galambokon.
donmackó
válasz Intruder2k5 #10817 üzenetére
UPnP + port továbbítás kombó tökéletesen műxik. Így csináld, a kettő közül valamelyiket csak használja. Open port check-kel teszteld.
Bocs Intruder nem neked válaszoltam.
donmackó
válasz Intruder2k5 #10825 üzenetére
Nem elég, nem fogadja el. Minimum 2 port az amit meg kell nyitni mert csak így akarja elfogadni.Ha 2 azonos számot írsz be akkor hibát dob ki.Én is csak azért nyitottam 3-at mert azt is használom másra.
donmackó
válasz Mr_Rob #10892 üzenetére
Rajta van az USB-n az 5 volt mert, a tablettát neki állt tölteni.Sőt a pendrive is villog ha bedugom és valami történik mert 2 másodpercre befagy a box csak valószínű nem tud vele mit kezdeni.Mondjuk nekem Cisco HD boxom van de valószínű a többi is egy kutya.
donmackó
Upc + Google DNS ex-Rubicom terület
donmackó
válasz Intruder2k5 #12731 üzenetére
Csak vicceltem. Nem is szedheti szét, mert a box a UPC tulajdona (ÁSZF megsértése).
donmackó
válasz Intruder2k5 #14709 üzenetére
Features
(Euro)DOCSIS 3.0 certified with 8 downstream & 4 upstream channels
Full band capture
4 Gigabit Ethernet LAN ports
Dual band concurrent Wi-Fi 802.11n 2.4GHz & 5GHz
Dedicated applications core with DLNA & hard disk sharing over Linux
Voice (Euro)PacketCable 1.5 (2.0 upgradable) or SIP
Multiple SSIDs and Wi-Fi hotspot roaming services
MPEG2 over IP encapsulation solution for advanced media streaming & IPTV
IPv4 & IPv6 support for more IP based servicesRelease the cable hounds!
donmackó
válasz jerry311 #14939 üzenetére
Véleményem szerint ahol xar a hálózat, ott olyan a sávszélesség is. Itt vidéken (legalább is ebben a faluban) van jó pár torrent és letöltésvezérlő huszár, még sincs semmi baj a sávszélemmel. Stabil 120/10 , néha több is.
Volt rubicomos területről írok. Ahol nincs meg ott a UPC-nek kellene talán csinálni egy eszköz bővítést, és nem több előfizetőt rákötni hátha még inkább terheltebb lesz a környék.Release the cable hounds!
donmackó
válasz jerry311 #14941 üzenetére
Lehet hogy sűrűsödött a környéketeken a előfizetés. Itt felénk az összes ismerős 120/10 ill. 240/20-as előfizetésekkel rendelkezik (nyilván nem "csak facebookoznak"). Mégsem terhelt a környék, pedig elvileg itt is ugyanaz a hálózat van. Nem ismerem a városi környezetet (faluban lakok).
donmackó
Hogy lehet a Cisco HD DVR-en megnézni a jelszinteket? Sajna már elfelejtettem. Xaraxanak a csatornák, vagy márnál is rosszak az adások?
donmackó
válasz kabelmania27 #15430 üzenetére
Ilyenek. A modem szinte nem is változott mióta át lett vezetékelve (amit még írtam a upc fiber power topikban) , de a box egyre többször xaraxik.
donmackó
válasz kabelmania27 #15438 üzenetére
Először elkezd bekockásodni/szétesni a kép, majd nincs jelre vált a kép. Elkapcsolom a csatornát, majd vissza és jó minden egy darabig. És ez nem a HD csatornáknál van hanem a sima digitálon. Ma például Nickelodeon, Spektrum, Jimjam, Baby tv, Viasat explorer volt idáig a rossz.
donmackó
donmackó
válasz kabelmania27 #15445 üzenetére
Újra indítottam. Elsőre nem akarta bevenni a központ számát, majd végül elfogadta. Most várok/nézem.
donmackó
Hétvégén kijön házhoz a upc? Azt hiszem megvan a probléma. Kijött a működtető füst a boxból (mert jó tanárom tanította hogy minden jó készülék füsttel műxik, ha kijön akkor már nem jó) Hívom a 1221-et. Rohadt büdös lett az egész házban.
donmackó
válasz kabelmania27 #15450 üzenetére
Na elvileg holnap du. 2-6 között jön szerelő. Mondtam hogy addig ne számítsák a HDR funkciót mert nem tudom használni (nem hajlottak rá). De felajánlották hogy addig ingyen nézhetem az analógot. Mintha nem tudnám hogy azt "lopni" is lehet.
donmackó
válasz Intruder2k5 #15455 üzenetére
Felénk akkor ezek szerint nem szokták. Tudok pár emberről aki így használja. De nem vagyok spicli.
donmackó
válasz seederking #16261 üzenetére
A samu galaxy tab 3 2x1.2 GHz-es (2 magos) 1gb ramos. Telefonálni nem lehet vele. A wifi only-s csak wifin tud kapcsolódni a netre, a 3G-s meg sim kártyával is. NEM LEHET VELE TELEFONÁLNI (max skype meg ilyesmi).
donmackó
válasz kabelmania27 #16483 üzenetére
Hát nem. Szó szerint füstölt. 2 órát kellet télvíz idején szellőztetni a házat.
De legalább díjmentesen cserélik.
Kungzi: Tegyél valamit a tetejére, akkor kellőképp felmelegszik, és nyílván tönkre is megy.Release the cable hounds!
● Olvasd el az összefoglalót!
● Jelszinteket ide írhatsz!
● Díjnet téma ITT!
● Mobil szolgáltatások ITT!
- lenovo DU9033S1 Onelink Pro Dock TÖBB DARAB Töltő nincs benne az árban
- Új Gyári Lenovo 65W Notebook adapter USB-C csatlakozóval
- iPhone 14 PRO - Arany - Gyönyörű
- iPhone 14 PRO MAX - 2026.10ig Garancia - Független
- Microsoft Surface Book 2in1 Érintős Szétszedhető Laptop Tablet 13,5" -60% i5-7300U 8/256 QHD+ Win 10
