~ Kamaszkorunk legszebb focicsapatai ~
"The entire ground just died when the ball was played into him but instead of turning and going forward he played a soft pass back that a Fulham player intercepted. He mostly seems lost on the pitch at times. I think until he finds his feet at his “new club” (this is thrown around a lot as an excuse for him), he needs sit on the bench and come on in games when we need something different.
Arteta is literally changing the entire formation from something that almost won us the league last season to something that we are clearly struggling with on the pitch JUST to get Havertz in the team and it’s fucking annoying. Partey is one of the best DMs in the league, but has been stuffed into RB, and one of the best RBs in the league is now playing CB again, when we have Gabriel, one of the best left-footed CBs in the league, sat on the bench. Saka is starving on the RW now when he had a great partnership with White down the right last season.
We had a formula that worked last season. All we needed was good defensive cover and a replacement for Xhaka. We did that when we got Timber and Rice respectively. Havertz was a luxury addition to the squad but that’s no reason to completely break what almost won us the league just so that he can play him."
Tűpontos.
Go Gunners!
Buzibíró.
Go Gunners!
B*zd szájba vvD!
Go Gunners!
Más:
"This is the problem with xG becoming mainstream. So many people just mindlessly throw out the stat without any nuance, thinking it makes them look smart.
This stat is almost worthless, as Fulham had no intention of attacking once we gifted them the goal in the 1st minute. That inherently means that the game state heavily impacts this, and makes the xG stat favour us as we were playing against a team that had no reason to generate any xG for majority of the match. Not to mention that they went down to 10 men too.
Edit: same reason why we "lost" on xG to Forest, we scored 2 relatively low xG goals then shut up shop. Mind you that's an issue in itself, but again it shows how blindly using xG stats from a game to spin a narrative like this is pointless."Go Gunners!
Törppicúr az emberevők ellen?
Go Gunners!
NYUNYÓ!
Go Gunners!
Nesztek favágók!!!!!!!!!!
LolGo Gunners!
Gratula!
Mocskos favágók.
Go Gunners!
válasz Cs1csó #191048 üzenetére
Persze, a játéktérre se gurítsák vissza a labdát! Mit képzelt TAA? Nem is értem, ekkora gengsztert...
Az időhúzásos téma egy kreténség pláne a 9+ perces hosszabbításokkal. Tovább kell mutogatni a szponzorokat, meg bele kell lógni más sportokba vagy mi az arabok elvárása?Jelenleg nem lehet pozitív változásként tekinteni rá szerintem, mert össze-vissza szórják a lapokat.
Bedobásoknál különösen nevetséges. Akkor már határozzák meg, hogy hány másodpercen belül kell játékbahozni a labdát, nem pedig hasraütés szerűen.
Arsenal meccsen volt egy olyan jelenet, hogy lefújt egy szabálytalanságot a javunkra a bíró, de a Fulham csatár aki megszerezte a labdát úgy tett, mint aki nem hallotta, hogy vagy 4X fújt a bíró és elszaladt a labdával vagy 30 métert. Ez nem időhúzás?
Go Gunners!
Go Gunners!
Eladtuk Balogun-t. Egy újabb érthetetlen döntés. 21 gól a franciáknál és egy perc esélyt nem kapott Arteta-tól (holott igencsak adósak a gólokkal Jesus és Nketiah). ESR-ért állítólag bejelentkezett a chelsea... kiba dühös lennék, ha elküldenénk.
Go Gunners!
válasz grizlisandor #191191 üzenetére
Monaco 35m£ +17,5% a jövőbeni eladási árból. Az idei átig összegek tükrében nevetséges összeg.
Go Gunners!
Bl és Arsenal? Mi a szösz...
Go Gunners!
Holding-ot eladjuk 4m£-ért a CP-nak... Az eladásért felelős stáb (gondolom nem Edu egyszemélyben) komplett idióta.
Go Gunners!
Go Gunners!
Pontosították Holding eladási árát: 1m£ + 2,5m£ addonok. Lassan egy turbo rágó többe kerül.
A védelmünk sikerült rendesen szétbaxni.Go Gunners!
Csángó brékesek.... szevasztok!
Go Gunners!
Az igen!
Go Gunners!
Nyunyó next level... direkt rúgta így a kapufára.
Go Gunners!
Nah már a fater is előkerült...
Go Gunners!
Matip nagypapa...
Go Gunners!
Istenem...
Go Gunners!
Tetvesk*rvafaszát havec
Arteta meg menjen a pék f*szára![ Szerkesztve ]
Go Gunners!
Király Øde!
Go Gunners!
Ez nagyon szép volt, csak kár hogy Saka havercel edz.
Go Gunners!
Bántóan sima.
Go Gunners!
válasz LyonnaisFan1 #191555 üzenetére
Hát, ez a Havertz árt az egészségemnek az fix. Most is akkor pörögtek fel az események miután lement.
Emlékezetes lett Rice első gólja, Jesus meg tanár volt a végén. Hatalmas szurkolást rendeztünk itt feleségemmel.Go Gunners!
válasz atee_13 #191548 üzenetére
Teljesen adom az álláspontod.
De ha már a "ha" megengedett, nem biztos hogy jó lett volna a bunkerfoci, ha Havertz helyett valami focista lett volna a pályán (amikor full üreskapu szituban az 5-ösről az álló labdába luftot rúg). Utána még Saka is nyomott valami hasonlót, de nem ilyen látványosat. Szal könnyen megváltozhatott volna a meccs képe, ha nem balfaszkodjuk el.Hogy ne csak ekézzem volt egy szép blokkolt lövése, meg próbált fizikális lenni a szegény német, dolgozott becsülettel, de mintha elment volna benne valami. Előre tiszta Joelington (sír nála a labda, 0 közeli passzhatékonyság), védekezésben viszont nincs meg az a brutál testfelépítés.
Mindenesetre köszi a jinx-t! Ez is kellett a győzelmünkhöz.
Go Gunners!
válasz DeathAdder #191630 üzenetére
Pepe???? A megtestesült intelligencia.... Csak rá kell nézni....
Go Gunners!
Gabi XL:
Go Gunners!
válasz DeathAdder #191649 üzenetére
Lesz Liverpool tv a spillllleren, ha jól olvasom. El lesztek kényeztetve.
Go Gunners!
Pepe-ért belengettek egy igen komoly 2m£-os ajánlatot.
Go Gunners!
válasz atee_13 #191712 üzenetére
Neeem ez a már-már felfoghatatlan összeg a bónuszokkal felemelkedhet egészen 8m£-ig is.
Ha még fokozni akarom, akkor mondhatom azt is, hogy ez az összeg olyan hatalmas, hogy meghaladja Auba, Laca és Özil együttes eladási árát. (Mondjuk ez még a méltán híres 1m£-os Holdingra is igaz.) Döbbenet apám.
De, hogy ne csak agonizáljak, valami érdekes:
"Ødegaard has already scored as many goals against the traditional big -6 (PL) as Mesut Özil.
Ødegaard has already outscored Cazorla, Rosicky, Nasri and has as many goals as Aaron Ramsey against the big six. He needs 2 more to match Fabregas.
Big Game Player."[ Szerkesztve ]
Go Gunners!
Változott az ügy Pepe helyzetével, jelenleg állítólag a Besiktas akar pénzt, hogy leigazolják.
Go Gunners!
Ez mellé ment volna, mármint nem is a kapuba zartott a labda.
Go Gunners!
Wow.
Go Gunners!
Jólesett a meccs, bár a 2. félidőn bealudtam.
Go Gunners!
Go Gunners!
- Gyúrósok ide!
- Horgász topik
- EA Sports WRC '23
- Vallás
- RAM topik
- Pécs és környéke adok-veszek-beszélgetek
- Peugeot, Citroën topik
