Üdvözlet az Acer notebook topikban! Mielőtt kérdeznél ajánlott elolvasni az alábbi összefoglalót!!
maximilian4
válasz brata1986 #31835 üzenetére
Driverek fent vannak az acer honlapján.
Jó drivert raktál fel? Nekem anno 2 driver volt.elérhető (Intel, qualcomm), így az volt az első hogy aida-ban megnéztem hogy melyik van a gépben (qualcomm) és a hozzá tartozó drivert raktam fel.A te esetedben 3 is van. Ez user error lesz. A megfelelőt telepítsd.
Maxi
maximilian4
maximilian4
maximilian4
válasz AlexiStukov #32384 üzenetére
Én 9 hónapig használtam vx15-öt. Ott nem volt ilyen hiba, pedig nagyon sokat hordtam ide oda.
Nem tudom mennyire tudsz angolul, ITT Matt Heck-es válasz elég hasznos és szakmai.
Maxi
maximilian4
válasz maximilian4 #32385 üzenetére
All of this is wrong, except for the preventative measures. You have damaged, at a minimum, the anti-glare/anti-reflective coating. For an LCD screen, there is a strong chance that you have also damaged the front polarizer as well. For an LED screen (e.g., OLED, *not* LED backlit LCD), there is a somewhat lower chance that you have damaged the front glass.
The scratches can indeed be buffed out. The problem is that doing so would remove the anti-glare coating from the affected area, which will sharply contrast with the rest of the screen. In practice, that means you will have to polish the coating off the entire screen. This is easier said than done, since the coatings normally also include a high-hardness abrasion-resistant (AR) coating.
If you remove the AR coating, then polish out the screen (done by starting with high-grit polishing compound, then going through about six different grades of grit until you finally do a dozen passes with a finishing compound), you will have a crystal-clear laptop screen— with no anti-glare or AR coating. This will look awful, as it will reflect even weak light very strongly, and scratch very easily, so you will need to protect it. This would ideally be done by adding, big surprise, the surface coatings that were on it in the first place. This cannot be done without a proper lab; you WILL trap dirt, dust, lint, pollen, smoke, failure, and broken dreams under the coatings.
The second choice would be to use a very thin piece of coated borosilicate glass, such as Gorilla Glass. It is a serious pain in the butt to get this this stuff in arbitrary shapes and sizes. It is also somewhat heavy, at these sizes. Finally, it will add enough thickness that it may be a problem. It will, however, be hard enough to resist damage— however, if coated, the coatings may not be.
One compromise MIGHT be to get Abrasion Resistant Acrylic (“AR Acrylic”) laser-cut by TAP Plastics or similar. This is inexpensive and has very good optical properties, but is fragile with respect to drops and bends. Lexan (polycarbonate sheet) is much tougher, but scratches more easily, and has to be cut mechanically instead of by laser; unless you use a waterjet cutter, the edges will not be very smooth.
Finally, you might luck out if you can find a 3M Laptop Privacy Screen that fits your unit well. These have some anti-glare side-effects since they strongly reduce off-axis light. If you like those okay, you can consider polishing the screen down and using one of these as a makeshift anti-glare solution. This will, however, reduce the viewing angle (since that’s the whole point of the product), and reduce maximum brightness.
So, if possible, your best bet is going to be to get a laptop with a dead motherboard and swap screens. Beware of dead laptops on eBay— sometimes they’re fine, but often they are “graveyard” units, composed solely of failed components.
Maxi
maximilian4
válasz Zsombor994 #32399 üzenetére
Witcher 3-hoz biztos nem lesz elég az mx150. Iszonyat magas a gépigénye. Szerintem GTA 5-höz is édeskevés. [link]
Maxi
maximilian4
válasz Zsombor994 #32402 üzenetére
Gta 5 elvileg natív medium mellett is simán játszható. Ha nem zavar hogy némely nagy gépigényű játéknál vissza kell venni a felbontást akkor jó.
Az Aspire a515-öt sokan ajánlják alternatívaként alacsony árszegmensben és a kinézete is visszafogott.
Mennyi pénzt szánnál rá?
Maxi
maximilian4
válasz Zsombor994 #32407 üzenetére
270-ért már van dell 7567 windows 10-zel pcx-nél vagy 7577 linux-szal mediamarkt-ban. Mindkettő 1050-nel, 4 magos 45w-os i5-tel. Izmos hűtéssel, minőségi anyaghasználattal és nem csilivili külsővel. Ha hosszabb távban gondolkodsz akkor szerintem ezek jobb választások lennének. Már csak azért is mert jóval tartósabb egy 1050 + 7300hq mint egy mx150 + valami 15w-os intel i proci.
Maxi
maximilian4
válasz kancsal #32448 üzenetére
Szerintem ennyiért korrekt kis laptop, jobbat nem nagyon fogsz találni. A "Milyen notebookot vegyek?" topikban is rendre szokták ajánlani ebben az ársávban mint multimédiás gép. Nyilván játékra nem az igazi, mert nem egy gaming laptop, de módjával, itt-ott vissza véve a részletességből el lehet vele játszogatni. [link]
Egy kis cs go, cod ww2, fortnite, gta 5 simán játszható mediumon akár natív felbontás mellett is.[ Szerkesztve ]
Maxi
maximilian4
válasz B-Clone #32451 üzenetére
Na igen. A színhelyes kijelző azért keményen megdobná az árat. Ebben az árkategóriában kb. ennyi az átlag. Esetleg megérné utána nézni hogy ennyiért van-e elfogadható színhelyességű kijelzővel rendelkező lapos.
Ezt a listát találtam. Itt van egy-kettő budget laptop elég szép eredménnyel. Pl. ideapad 320s 97%sRGB-vel és 62% aRGB-vel egész jó.
Maxi
maximilian4
válasz kancsal #32455 üzenetére
Még annyi hogy ha lájtos játékra akarod használni, akkor az a 4 giga ram mindeképp kevés lesz. Mivel (ha jól tudom) csak 1 slot van benne, így a régi helyére egy 8 gigásat kell beraknod. Én személy szerint itt aprón vennék memóriát 12k-ért már vannak 8 gigás 2400Mhz-es modulok, a régit meg elpasszolod. Így gyakorlatilag minimális ráfordítással meglesz a dolog. De ez már csak egy tipp.
(#32450) CHIPman
Találtam egy ilyencikket.
Jó pár dolog okozhatja.
Maxi
maximilian4
válasz maximilian4 #32456 üzenetére
Mondjuk én személy szerint biztos csinálnék vele valamit, mert sosem tudtam nyugodtan maradni ilyen helyzetben. Gyorsan lepattintanám a hátlapot lehúznám majd visszadugnám az akksi kábelt stb...hátha.
De rám ne hallgass. Én mikor megvettem a vx15-öt első nap szétszedtem és újrapasztáztam, az alienwerem úgyszint (ahhoz képest gyerek játék volt az acer).Maxi
maximilian4
válasz flegga92 #32467 üzenetére
M2 ssd-hez le kell szedni az egészet, a ram-nak és a 2,5"-ös hdd/ssd-nek van külön szerelőnyílása. Ilyen sztorikat én is hallottam hogy szépen kiszedték belőle a bővített cuccokat, nem szép dolog... Remélem a vx-et amit eladtam nem kerül szervizbe, mert abba 2 db ssd-t is raktam, és eredetileg hdd-vel vettem, vagy kiveszi belőle az új tulaj. Mert azért elég nagy érvágás lenne ha azokat lenyúlnák belőle.
Maxi
maximilian4
válasz flegga92 #32471 üzenetére
És ha azt mondom hogy a laptopszalonban rakták bele ahol vettem...na bumm. Amúgy világi hülyeség emiatt garanciavesztés. Ha meg szervizelés előtt kiveszem az életben nem jönnek rá. Nyilván ez is csak üzlet. Mezei felhasználó is meg tudja csinálni 2 perc alatt, de ők megcsinálják ugyanazt egy halom pénzért ( legalábbis az időráfordításhoz képest egy halom pénzért). Nekem ettől a politikától hánynom kell. Hála istennek a dell-alienware-nél akkor sem szólnak ha darabjaira szeded a gépet és minden lehetőt kiscserélsz...egyedül akkor ha megrongálsz valamit.
Maxi
maximilian4
Elég sok mindenre képes egy minimális kézügyességgel és értelmi képességgel rendelkező user. Számos videó áll rendelkezésre, részletes ifix-it leírás lépésről lépsére stb.. Nem kell ehhez műszerészek lenni. Totál egyszerű dolgok ezek. Ott van lehet követni egyes gyártók példáját. Ha szétcseszi akkor ugrik a garancia, de ez... Valaki belerak egy ssd-t meg egy memóriát és megvonják a garanciát, vagy éppen lenyúlják belőle a cuccot.
Maxi
- Háromféle processzor is része lesz a Core 200 sorozatnak
- Amazon Fire TV stick/box
- Az Apple megszerezné a klubvilágbajnokság közvetítési jogait
- Milyen monitort vegyek?
- Modern monitorokra köthető 3dfx Voodoo kártya a fészerből
- ÚJ Dell Vostro 3520 - 15.6" IPS 120Hz / i5-1235U / 8-16Gb DDR4 / 512Gb / HUN backlit / 3 ÉV GAR.
- BESZÁMÍTÁS! HP Omen 15 15 FHD Gamer notebook - i7 10750H 16GB RAM 1TB SSD RTX 2070 8GB WIN
- Lenovo Thinkpad T495 Ryzen 5 PRO 3500U/16GB RAM/256 SSD/14" FULL HD garanciás laptop eladó
- Üzletből, garanciával, legújabb Asus Vivobook 17" i7-1355U 10 mag 5GHz/16RAM/1TBSSD/17,3"FULLHD
- Üzletből, garanciával DeLL XPS 15 9500 i7-10750H 32GBRAM 1TBSSD/GTX1650Ti 15,6"4KTOUCH
