ƵøŁĭ
(ง'̀-'́)ง(ง'̀-'́)ง
ƵøŁĭ
PC/bővítmény verzió között mi a különbség ? Összehasonlító táblázatot nem találom most hirtelen .
(ง'̀-'́)ง(ง'̀-'́)ง
ƵøŁĭ
1PC+1Android ~2200Ft
(ง'̀-'́)ง(ง'̀-'́)ง
ƵøŁĭ
ƵøŁĭ
UPD: hotfix update. Version 6.2.356.1877 brings a fix for issue #1718, sometimes it was not possible to save new Assistant's size and location settings.After the last beta version, we have received a ton of remarks from our users, mostly about the new filtering log. It was somewhat expected, as the changes were many and it's hard to hit the nail on the head on the first try. So in this update, we address a lot of these problems (not all of them - it's a work in progress) and introduce the first iteration of the new Adguard Assistant.
(ง'̀-'́)ง(ง'̀-'́)ง
ƵøŁĭ
Azért vicces ,hogy android-on több termékfrissítés jön. Mostani RC verzió:
WHAT'S NEW
We are approaching the v2.10 release by creating this release candidate. Hopefully, it will be the last as well, but should any unnoticed bugs surface, another one will follow it. Anyway, here the major addition is the Battery usage stats screen. What it is, and why it was added is described right below. Aside from that, several minor UI changes and improvements to app's stability.
[Added] Battery usage stats screen
Historically, questions about AdGuard battery usage are among the most frequently asked ones. Sadly, Android distorts the battery consumption breakdown, attributing other apps' traffic and battery consumption to AdGuard. We've even written a detailed knowledgebase article that explains this issue.To mitigate the misconception, we added a new screen called 'Battery usage'. You can access it by tapping on the battery icon in the top right corner of the main screen.
Inside you will find a chart that shows the AdGuard battery resourse consumption within the last 24 hours, with an option to get more detailed hour-to-hour data by tapping on the dots on the chart. Besides that, there's also a numeric breakdown of the relevant data and a short technical explanation.Ad blocking
[Added] /deep/ and ::shadow selectors support #1403Networking
[Changed] AdGuard now can handle compressed responses when downloading filters #1412
[Fixed] Old certificates are not purged properly #1428
[Fixed] The Onion (theonion.com) does not work with AdGuard enabled #1379
[Fixed] Error while generating a domain certificate #1451
[Fixed] If IP address is blocked by ISP, it is impossible to connect to the site even via proxy #1449
[Fixed] No internet connection after disabling DNS settings #1456
[Improved] The iptables rules have been reworked #1249UI
[Added] Export/import of all profile's settings #133
[Added] An annotation to "Google Play services" app details #1106
[Added] Custom DNS ports support #1376
[Changed] Contents of state.txt file (the one attached to support messages) #1205
[Changed] French translation has been updated #1397
[Changed] 'Adguard' to 'AdGuard' in all translations #1413
[Changed] AdGuard notification text on Andoird 6.0+ #1241
[Changed] Some wording has been updated across the app #1430
[Changed] Minor UI changes #1445
[Fixed] Incorrect DNS is displayed when you set up a custom DNS #1416
[Fixed] AdGuard doesn't memorize the selected DNS server #1415
[Fixed] Proxy warning in apps management can be seen when changing tabs #1420
[Fixed] Scrolling on the DNS screen works incorrectly #1419
[Fixed] FAQ is displayed in the wrong language on Android N #1163
[Fixed] Side menu "Settings" button doesn't work as intended #1366
[Fixed] DNS requests blocking is not enabled by default when you toggle on the main DNS switch #1443
[Fixed] Main switch in HTTPS settings is not being toggled by tapping on the label #1455
[Fixed] Toast messages are shown in system language, not in app language #1454Other
[Added] AdGuard has been added to Google's apps backup #1396
[Fixed] Apps management section is not loaded in the background #1407
[Fixed] Сrashes on Android 6.0.1 #1421
[Fixed] Unnecessary exception in the log file #1176
[Fixed] App freezes and can't be restarted #1388
[Fixed] AdGuard crashes if you open ws:// or wss:// request in the Filtering log #1444
[Fixed] EV certificate filtering checkbox rarely works #1446
[Fixed] Advanced settings aren't applied on protection restart #1448
[FIxed] Crash on Android v4.x #1447
[Changed] .apk file has been removed from the app cache after the update #1414
[Changed] Compatibility fixes
[Changed] HTTPS exclusions have been updated(ง'̀-'́)ง(ง'̀-'́)ง
ƵøŁĭ
6.2.431.2165 RC
@vozersky vozersky released this 3 days agoPresumably, the last release candidate before the inevitable coming of AdGuard v6.2. The highlight of this version is integration with a reports web app. Read below to see what it is and why is it so cool. AdGuard default userscripts have been updated (Assistant, PopupBlocker), and other minor changes have been made too.
[Added] Integration with Reports Web App #1964
When it comes to keeping our filter lists updated, we owe our users a big one. Thanks to their timely reports of missed ads, false positives etc., AdGuard filters are always up-to-date. We want make the process of reporting a website easy for users and informative for filter developers, that’s why we decided to integrate AdGuard for Windows with a special web reporting tool.
When you see any problem like missed ad or annoyance, click on the Assistant icon and choose “Report this website”. You will be taken to a new page and asked to fill in some information about your AdGuard settings and the nature of the problem. Good thing is that AdGuard pre-fills most of the fields automatically, so most of the job is already done for you
We hope this change will strengthen the feedback from our users and allow AdGuard filters to stay at the cutting edge of ad blocking technology.
Ad blocking
[Fixed] Chromium is not filtered by default #1956
UI
[Fixed] Ctrl + Z does not work in any input field #1960
[Fixed] Filter editor bug #1969
[Fixed] User filter is always empty when "Filter editor" is opened for the first time #1970Other
[Changed] Localizations have been updated
[Fixed] Userscript is not injected #1958
[Fixed] Problematic userscript prevents others from working #1962(ง'̀-'́)ง(ง'̀-'́)ง
ƵøŁĭ
P8Lite készülékről eltávolításra került egy ideig.Annyira belassult a telefonom tőle ,hogy hihetetlen.
(ง'̀-'́)ง(ง'̀-'́)ง
ƵøŁĭ
(ง'̀-'́)ง(ง'̀-'́)ง
ƵøŁĭ
Nekem folyamatosan leáll a védelem.Újraindítást javasolt a support de....Ráadásul ilyenkor az internet se jön be .
(ง'̀-'́)ง(ง'̀-'́)ง
ƵøŁĭ
Új verzió elérhető.
(ง'̀-'́)ง(ง'̀-'́)ง
ƵøŁĭ
Finally, we're pretty sure we are done with eliminating bugs that were preventing us from sharing with you all the awesome new stuff that awaits you in the new version of AdGuard for Windows. So, welcome: AdGuard 7.0! From the very start you'll notice the difference, as you'll be greeted by renovated UI design. And the more you use the new version, the better you'll find it, hopefully: brand new CoreLibs filtering engine will make ad blocking better and faster. There are more goodies inside, so let's get to the gist.[Improved] UI and installer redesign
It is somewhat of a tradition by this point to have a UI redesign with each major AdGuard for Windows version upgrade. This time will not be an exception. AdGuard 7.0 for Windows will look very different from the current familiar version. Have a look for yourself:
- Light
- Dark
Yes, you saw it right: AG for Windows now has a dark theme too! Love it or hate it, it's there, it's optional and you are free to embrace it or ignore it altogether.
The installation wizard follows the trend and gets a redesign too. It only makes sense, because the installer is the first thing new users see when they start their acquaintance with AdGuard, and it better be good! Hope you'll find it an upgrade too:[Improved] Corelibs
Everybody knows what CoreLibs is by this point, but we'll remind anyway: it is a filtering engine that drives the whole process of ad blocking in most AdGuard products, AdGuard for Windows included. And with every new version of CL these products become better: the quality of ad blocking increases, they work faster and become more stable. This beta of AdGuard 7.0 for Windows features the most recent of CoreLibs version, which means this is as good as it gets. Well, at least until the next CoreLibs update ,In this beta we make an emphasis on UI changes but also fix several crashes. We also took this opportunity to introduce a new userscript — AdGuard Extra.,This is more of a hotfix than a beta. Some Firefox users reported problems with browser freezing. We determined that this behavior was a sequence of hanged connections, which in its turn was caused by a CoreLibs bug. It’s crucial to eliminate all such bugs before we release a stable version (which will be soon), so here we are.[Added] Automatic crash reports
Sometimes apps crash, and you can do nothing about it. Reasons can be very different, and so are solutions. To be able to investigate every crash individually and find a proper fix to it, we add integration with an automatic crash report system. If AdGuard crashes, upon the next launch you'll be asked if you want to send a crash report.
Nothing will ever be sent without your consent, and if you want to know what exactly is in the report, you can check out our Privacy Policy. We'll appreciate each and every report, as it will help us greatly in making AdGuard for Windows more stable.[Added] AdGuard Extra extension
In some complicated cases the usual approach with filtering rules just doesn’t work. In particular, in some cases of ad blocker circumvention/ad reinjection. So we came up with an alternative solution — a userscript. For those unfamiliar, userscripts are basically mini programs that modify web pages and augment browsing.
AdGuard Extra does it in a way that makes it harder for websites to employ the circumvention/reinjection techniques. AdGuard for Windows is the second AdGuard product to get this addition, we are thrilled to see it in action and read your feedback on it.Ad blocking
[Changed] Сustom filters do not support powerful modifiers anymore unless allowed explicitly by user
[Fixed] Custom filters are always displayed like they are up-to-date
[Fixed] Issues with Firefox certificate
[Fixed] Сustom apps with Cyrillic symbols in the path are not filtered
[Improved] The list of URL parameters to strip in the Stealth Mode module has been made customizableNetwork
[Fixed] Service connection issues after hibernate/sleep
UI
[Added] [Nightly] Filtering log - open url
[Added] An option to add/remove filters from the General settings screen
[Added] CoreLibs release version to the About section
[Changed] AdGuard Assistant extension name
[Changed] Notification text for the case when protection status is changed via the Assistant
[Changed] UI changes on Trial period & License screens
[Fixed] "BlockTypeRuleDescription" wrongly used as a rule in the filtering log
[Fixed] AdGuard splash screen appears even when `/nosplash` is specified
[Fixed] Date format for Arabic localization
[Fixed] Filter name is displayed in the Rule column in the filtering log
[Fixed] License activation window glitch
[Fixed] Notification's text is out of its bounds
[Fixed] Rule Editor suggest wrong exclusion for $$ rules
[Fixed] Rules from disabled filter lists are accounted for in the statistics
[Fixed] Scrollbar in the settings is too sensitive
[Fixed] The displayed rules in Filter editor are not refreshed after clicking on the "X" button in the search bar
[Fixed] The search in the "Settings" view doesn't work properly
[Fixed] UI window can only be dragged when the left mouse button is pressed
[Fixed] Update channel resets from "Nightly" to "Release" after settings get reset to defaults
[Improved] Chinese date format is now used for filters' update time in Chinese localization
[Improved] Descriptions for Stealth Mode options have been updated
[Improved] Filtering log now indicates what cookies were modified
[Improved] Filtering log search syntax has been extendedOther
[Added] Chromium-based Microsoft Edge to the filtered applications list
[Changed] Localizations has been updated
[Changed] Logging has been made less verbose where it's not necessary
[Changed] The list of apps filtered by default has been updated
[Changed] Translations have been updated
[Changed] Unicode marker (BOM) has been removed from the userscript content
[Fixed] AdGuard doesn't automatically detect system language
[Fixed] AdGuard hangs after exiting the sleep mode
[Fixed] An issue with userscripts updates
[Fixed] Application update resets Assistant settings
[Fixed] Compatibility problems
[Fixed] Empty lines in custom filters are imported as rules
[Fixed] Error deleting backup file
[Fixed] Error while doing the update check
[Fixed] Excluding an app from filtering also excludes all other apps with the same executable name
[Fixed] Greasy Fork userscripts display an error when checking for updates
[Fixed] Installer startup delay
[Fixed] The English language is set by default
[Fixed] User filter rule editing bug
[Improved] Additional userscript parameters are now stored when you export settings
[Improved] AdGuard now checks if the userscript is already installed before downloading it
[Improved] AdGuard-related system settings (e.g. UI window's size etc.) can now be imported along with the app settings
[Improved] CoreLibs has been updated
[Improved] The way to get userscripts' and filter subscriptions' content(ง'̀-'́)ง(ง'̀-'́)ง
ƵøŁĭ
Usually, new stable versions are preceded with a number of betas and take longer than a month to develop. But this one is a bit different, its purpose is mainly to fix some incompatibilities (such as Windscribe VPN), so it makes a lot of sense to release this version as soon as possible. It should also spark interest in Firefox users, as we addressed several certificate-related problems unique to that browser.Ad blocking
* [Fixed] Manual blocker options bug
Network
* [Fixed] AG certificate is not removed on the app uninstall or reinstall
* [Fixed] Certificate gets installed into the wrong system storage
* [Fixed] Compatibility issues with Sophos AV
* [Fixed] Cookies are getting removed even though self-destructing cookies options are disabledUI
* [Changed] Domain name is now shown in the filtering log in all cases when it's detected
* [Changed] Translations have been updated
* [Fixed] AdGuard settings respond slowly when Parental Control is enabled
* [Fixed] Release channel label is missingOther
* [Fixed] "Hide User-Agent" flag state is not passed properly to web reporter
* [Fixed] AdGuard crashes randomly when you open settings
* [Fixed] Userscripts' update channels don't match app's release channel(ง'̀-'́)ง(ง'̀-'́)ง
ƵøŁĭ
Adguard esetében ez miért nem működik?
##a[href*="hit.gemius.pl"]uBlock Origin egyből elfogadta.
(ง'̀-'́)ง(ง'̀-'́)ง
ƵøŁĭ
7.2 elérhető.
(ง'̀-'́)ง(ง'̀-'́)ง
ƵøŁĭ
Some users reported critical compatibility issues in AdGuard 7.2, mainly with Emsisoft software. This is a hotfix that will solve these problems, and we also seized the opportunity to update CoreLibs and make some other changes.You can help us make sure such incidents won't happen again by joining our beta testing program. Millions of AdGuard users will thank you (and you'll even get a beta tester's license key for free)!
[Fixed] WFP driver incompatibility with Emsisoft software #2957
[Fixed] E-mail text field issue in Support window #2951
[Fixed] Issue on the protection startup #2952
[Fixed] Window buttons tooltip localization #2953
[Fixed] Couldn't enable the proxy mode #2974
[Fixed] The port field is always highlighted #2976
[Fixed] Advanced settings translation #2944
[Improved] Additionally inform users about required reboot #2946
[Improved] Added a data limit to the length of sent logs in the installer crash reporter #2968(ง'̀-'́)ง(ง'̀-'́)ง
ƵøŁĭ
Lassan VPN szolgáltatás is érkezik.
(ง'̀-'́)ง(ง'̀-'́)ง
ƵøŁĭ
Egyáltalán nem éri meg. Ha több eszközre kell akkor itt a Family Plan ~9k.
(ง'̀-'́)ง(ง'̀-'́)ง
ƵøŁĭ
Én nem tudom megítélni a megbízhatóságát, mert csak arra tudok alapozni amit olvastam. A srác megvette a 9 eszközös kódot és sikeresen beaktiválta. Annyit javaslok, hogy írj az Adguardnak. Én a hivatalos oldalról vásároltam meg már egy jó pár éve.
(ง'̀-'́)ง(ง'̀-'́)ง
ƵøŁĭ
(ง'̀-'́)ง(ง'̀-'́)ง
ƵøŁĭ
There's a clear headliner for the new AdGuard for Windows update: AdGuard Browser Assistant. It's a browser extension to help manage filtering right from the web page that replaces the old Assistant. We also fixed a bunch of bugs and overall enhanced the app to work faster and better.
Browser AssistantBy developing this new product, we've resolved a couple of pretty important issues that the old Assistant had, without losing in functionality.
[Enhancement] Browser Assistant #2985
Meet our new AdGuard Browser Assistant! From a mere dependant userscript in AdGuard desktop apps it has evolved to become a full-fledged browser extension.
Obviously, new Assistant has the functions of the old one included but it’s far more cool and user-friendly. And it came in extremely handy, helping us solve three major problems at once:
- Former AdGuard Assistant was a dependent userscript able to communicate with the app only using a certain protocol. On the contrary, new Assistant is independent: it’s installed in a browser, and you don’t need to wait while the script would be injected into the filtered web page. Putting it simply, it is more autonomous. Technically the new Assistant can be used without the app, although the app is required for the full capacity.
- When AdGuard desktop app and our browser extension were used in so-called integration mode, the extension icon took over Assistant's functions. However, they could hamper each other’s work. Some websites would stop being protected by the desktop program and be backed up only by the extension which has less possibilities. With new Assistant being extension itself, there is no need to install our regular browser extension anymore, which means there is no risk of an incompatibility.
- Some people didn't like seeing the old Assistant’s presence at webpages, plain an simple. New Assistant's icon resides safely next to the browser's address bar – zero chance to stand in the way of website's content.
[Enhancement] Own settings tab #3118
From now on, you can open this tab and get the Assistant for your default browser in one click. And in case your browser is a rare one, you can always lay on the legacy non-extension version – it works everywhere.
[Enhancement] Onboarding process #3119
During the installation, AdGuard determines your default browser and prompts you with a download link for Assistant. If your browser is not compatible with AdGuard, the legacy version is automatically enabled.
Changelog- [Fixed] Advanced Editor clears user rules #2142
- [Fixed] Cannot report a website from Assistant when UI is not running #2138
- [Fixed] AdGuard not responding after resuming from sleep mode on laptop #2861
- [Fixed] Wrong date on statistics #3015
- [Fixed] Crash on viewing request details in filtering log #3074
- [Fixed] Wrong highlight for Stealth Mode exclusions in filtering log #3123
- [Fixed] Some processes are active after AdGuard update bug installer #3126
- [Fixed] Some windows are not centered #3127
- [Fixed] Scroll issue with touchpad in language combobox #3129
- [Fixed] Can't add apps from Blitz's subdirectory #3141
- [Fixed] License activation dialog design issues #3145
- [Fixed] Support button returns 400 Bad Request #3155
- [Fixed] No longer able to add filters that do not have a .txt extension #3165
- [Fixed] Unnecessary colon is displayed for Yandex-Turbo redirect userscript #3176
- [Fixed] Individual userscript incompatibility #3201
- [Fixed] Browsing security notifications don’t work #3203
- [Fixed] Using extension w/app allows user to bypass Parental Control #3219
- [Fixed] Screen is twitching after disabling the extension #3229
- [Fixed] Pale buttons' text while starting the AdGuard #3236
- [Fixed] Connection errors #3237
- [Fixed] After reinstalling the application does not work #3238
- [Fixed] "AdGuard Browser Assistant is not installed or configured incorrectly" error #3241
- [Fixed] Some requests’ names are cut and not displayed in the filtering log #3249
- [Fixed] Browser restart is required after AdGuard update #3250
- [Fixed] Disabled userscripts reenable automatically after an update #3258
- [Fixed] AdGuard starts in a windows instead of being minimized in the system tray #3276
- [Fixed] "AdGuard installed successfully" window pops up after a reboot #3278
- [Fixed] UI won't start after an update #3299
- [Fixed] Statistic isn't incremented #3311
- [Fixed] Native extension api GetOriginalCert returns wildcard cert if it is in cache #3315
- [Enhancement] Filtering log is on pause while import #1997
- [Enhancement] Update Advanced Uninstall Utility #2940
- [Enhancement] Using the current browser for the webpage opening #2099
- [Enhancement] AdGuard GUI unnecessarily raising Windows platform timer resolution #2734
- [Enhancement] Enabling HTTPS filtering for a portable FF is now easier #2735
- [Enhancement] An option to hide blocked QIUC records in the filtering log #2912
- [Enhancement] Description about opening AG main window at system start-up has been reformulated #3016
- [Enhancement] Description for the "Launch AdGuard at system start-up" option #3082
- [Enhancement] Some items have been renamed or added in the tray menu #3103
- [Enhancement] Get rid of double negative in "filter EV" section #3133
- [Enhancement] Wizard's provided filters to the pre-downloaded defaults #3162
- [Enhancement] Handling the well-known errors during installation is made more user-friendly #3163
- [Enhancement] "What's new" screen after the major app update #3169
- [Enhancement] Send Console and Host logs to the Sentry among with the Service logs #3172
- [Enhancement] Add new Edge browser support #3217
- [Enhancement] HTTP proxy mode's description is disabled #3227
- [Enhancement] Update CoreLibs to 1.5.238 #3246
- [Enhancement] Browser Assistant now supports Waterfox and Cliqz browsers #3264Corelibs updated to v1.5.267
- [Fixed] Rules with :style() are converted incorrectly #1149
- [Fixed] Cosmetic rules can be used as CSS rules #1293
- [Fixed] Basic rules with a wildcard in top-level domains aren't working #1298(ง'̀-'́)ง(ง'̀-'́)ง
ƵøŁĭ
Release rule №1 (or Murphy’s law, if you like): even when everything seems perfect, one or two hotfixes follow the new version.This is a minor post-release fix. We’ve slightly tweaked UI trial windows, so now ‘I have a license’ option is not hidden anymore in some cases. Also, fixed the issue when message can't be sent to support. And we also took our chance to polish a few other important things under the hood.
- [Fixed] The trial window localization issue #3333
- [Fixed] Unable to send a message to support #3337(ง'̀-'́)ง(ง'̀-'́)ง
ƵøŁĭ
Here we go - the Hotfix 2! A few more UI improvements, now it runs a lot smoother. Also, we paid special attention to the Firefox compatibility problem. Five quick stitches and AdGuard for Windows is patched up as good as new.- [Fixed] Date format view is invalid with some system language settings: #3136
- [Fixed] The latest windows nightly version cannot automatically update local rules: #3347
- [Fixed] Firefox policies page: #3336
- [Fixed] Slow Filter Update which leads to UI hang: #3348
- [Fixed] Disabling Adguard Assistant will remove HTTPS certificate in Firefox when Adguard is Closed into the background: #3352(ง'̀-'́)ง(ง'̀-'́)ง
ƵøŁĭ
Érdekes, hogy random időközönként a yt-n mintha megszűnne a funkcionalitása. Reklámok csak úgy özönlenek a videókban és a menüben.
(ง'̀-'́)ง(ง'̀-'́)ง
ƵøŁĭ
válasz Sweet Lou 6 #679 üzenetére
Eddig sose volta bajom vele. Mindig blokkolt mindent. Most meg néha olyan mintha fent se lenne.
(ง'̀-'́)ง(ง'̀-'́)ง
ƵøŁĭ
Vajon melyik szűrő blokkol minden képet ... Mozillában semmit nem látok, mert azonnal elrejti a képet, illetve egyéb funkciók sem működnek.
(ง'̀-'́)ง(ง'̀-'́)ง
ƵøŁĭ
(ง'̀-'́)ง(ง'̀-'́)ง
ƵøŁĭ
Jó szar lett az új frissítés. Kékhalál és lassan is tölt be.
(ง'̀-'́)ง(ง'̀-'́)ง
ƵøŁĭ
Facebook-ot blokkolja.
(ง'̀-'́)ง(ง'̀-'́)ง
- Vicces képek
- PlayStation Plus 2024 Essential - A májusi lista
- Tippmix
- Gaming notebook topik
- Renault, Dacia topik
- Jövő hónapban érkezik Apple eszközökre az Assassin's Creed: Mirage
- Bontatlan - BATTLEFIELD 1 Collectors Edition - Játékszoftver nélkül
- AKCIÓ! - STEAM kulcsok /Anuchard, Aragami, Children of Morta, stb. - 2024.04.17.
- Microsoft licencek KIVÉTELES ÁRON AZONNAL - UTALÁSSAL IS AUTOMATIKUS KÉZBESÍTÉS - Windows és Office
- Vírusirtó, Antivirus VPN kulcsok
- Windows, Office licencek a legolcsóbban, egyenesen a Microsoft-tól - 2990 Ft-tól!
