Ebben a topicban tehetitek fel a videokártyákkal kapcsolatos azonnali, sürgős kérdéseiteket! Javasoljuk, hogy mielőtt kérdeztek töltsétek ki az adatlapotokon a konfigurációra vonatkozó részt!
BigDarkJoy
Sziasztok...
Szóval mint már néhányotokal beszéltem,kiderült hogy a Fujitsu Siemens D2151 alaplapom nembirja az Asus EAH 5450 DI DDR2 1Gb Silent videokarim..
Namármost vetem olcson 1 alaplapot amiGigabyte GA-G31M-S2L (rev. 1.0)
CPU
1.Support for an Intel® Core™ 2 Extreme processor/Intel® Core™ 2 Quad processor/Intel® Core™ 2 Duo processor/ Intel® Pentium® Dual-Core processor/Intel® Celeron® processor in the LGA 775 package
(Go to GIGABYTE's website for the latest CPU support list.)
2.L2 cache varies with CPUFront Side Bus
1.1600(O.C.)/1333/1066/800 MHz FSB
Chipset
1.North Bridge: Intel® G31 Express Chipset
2.South Bridge: Intel® ICH7Memory
1.2 x 1.8V DDR2 DIMM sockets supporting up to 4 GB of system memory
2.Dual channel memory architecture
3.Support for DDR2 1066(O.C.)/800/667 MHz memory modules
(Go to GIGABYTE's website for the latest memory support list.)Onboard Graphics
1.Integrated in the North Bridge
Audio
1.Realtek ALC662 codec
2.High Definition Audio
3.2/4/5.1-channel
4.Support for S/PDIF Out
5.Support for CD InLAN
1.RTL 8111C chip (10/100/1000 Mbit)
Expansion Slots
1.1 x PCI Express x16 slot
2.1 x PCI Express x1 slot
3.2 x PCI slotsStorage Interface
South Bridge: 1.1 x IDE connector supporting ATA-100/66/33 and up to 2 IDE devices
2.4 x SATA 3Gb/s connectors supporting up to 4 SATA 3Gb/s devices
iTE IT8718 chip: 1.1 x floppy disk drive connector supporting up to 1 floppy disk driveUSB
1.Integrated in the South Bridge
2.Up to 8 USB 2.0/1.1 ports (4 on the back panel, 4 via the USB brackets connected to the internal USB headers)Internal I/O Connectors
1.1 x 24-pin ATX main power connector
2.1 x 4-pin ATX 12V power connector
3.1 x floppy disk drive connector
4.1 x IDE connector
5.4 x SATA 3Gb/s connectors
6.1 x CPU fan header
7.1 x system fan header
8.1 x front panel header
9.1 x front panel audio header
10.1 x CD In connector
11.1 x S/PDIF Out header
12.2 x USB 2.0/1.1 headers
13.1 x chassis intrusion header
14.1 x power LED headerBack Panel Connectors
1.1 x PS/2 keyboard port
2.1 x PS/2 mouse port
3.1 x parallel port
4.1 x serial port
5.1 x D-Sub port
6.4 x USB 2.0/1.1 ports
7.1 x RJ-45 port
8.3 x audio jacks (Line In/Line Out/Microphone)I/O Controller
1.iTE IT8718 chip
H/W Monitoring
1.System voltage detection
2.CPU temperature detection
3.CPU/System fan speed detection
4.CPU overheating warning
5.CPU/System fan fail warning
6.CPU fan speed controlBIOS
1.1 x 4 Mbit flash
2.Use of licensed AWARD BIOS
3.PnP 1.0a, DMI 2.0, SM BIOS 2.3, ACPI 1.0bUnique Features
1.Support for @BIOS
2.Support for Download Center
3.Support for Q-Flash
4.Support for EasyTune
5.Support for Xpress Install
6.Support for Xpress Recovery2
7.Support for Virtual Dual BIOSVajon ezzel a lappal menni fog a videokarim??
Segitségeteket előreis köszönöm!!!
"megölni megtudnak....de megtörni soha.."
BigDarkJoy
Sziasztok, érdeklödnék hogy szerintetek eggy ASUS EAH 5450 1 GB ddr2 DX11 videokarin 2.4 dual procival,2gb rammal elmenne az NFS Shift 2?
föként a vidikari amiröl nemudom."megölni megtudnak....de megtörni soha.."
BigDarkJoy
válasz csucsbicep #7995 üzenetére
sajna anyagilag ennyire futja... ezzel kell beérnem.
BigDarkJoy
válasz csucsbicep #8000 üzenetére
E3400 asszem a proci, de lehet lessz E6600 ha mindenigaz
BigDarkJoy
válasz BigDarkJoy #8004 üzenetére
1066mhz a ram,és geil vagy micsoda
BigDarkJoy
válasz csucsbicep #8006 üzenetére
megvan,csak ha van olcson ami jó azt általában megveszem.
BigDarkJoy
Érdeklödni szeretnék hogy szerintetek a Geforce 8800GT videokarira mien hütést tegyek?
Most sikerült vennem olcson 1 jó 8800GT de modositott hütöje van.Egyébként ez a tipus mien kari?
Nemigazán ismerem,és pár vélemény azért jóljönne rola,mivel játszani szeretnék majd és nemtudom mennyire fogja birni.Szives válaszaitokat előre köszönöm!!!!!
BigDarkJoy
az asszonynak van 1 kemény hajszáritója...
hoztak pár GPU s fuji laptopot, na adtamnekik a hajszáritóval.. elindultak a gépek..segitett de ez kb pár órát bir...Othon nem lehet jól megoldani.. Kaposváron javitanak VGAt golyozás sőt ujra GPU is van.. nem vészes áron.
Fujitsu 2548 ra 13 ezret fizettem, ebböl 9ezer volt a chip a többi meg a munkadij."megölni megtudnak....de megtörni soha.."
BigDarkJoy
Segitséget szeretnék kérni hozzáértöbb emberektöl a következö karival kapcsolatban.
GeForce 8800GT PCIe 512mb 256bit
Alapon 45-50 fokon megy 2-3 óra játék után 55-57
a lényeg az hogy amiota ez a kari van gépben,töbször kék képernyő különbözö hivatkozásokkal előugrik,valamit számol...és ujraindul a gép.
Valaki megtudná mondani hogy mitől van ez?
BigDarkJoy
Megtudná nekem valaki mondani hogy kb mennyibe kerül 1 geforce 8800GT videokarin a mag "chip" csere?"megölni megtudnak....de megtörni soha.."
BigDarkJoy
Érdeklődni szeretnék hogy ha van 1 Galaxy9600Gt és 1 GeForce 8800Gt VGA m azt lehet SLI be kötni ? kompatibilisek?
Esetleg valamiféle leirás vagy rajz hogy kell csinálni az jólenne.
Szives válaszotokat előreis köszönöm!!!!
BigDarkJoy
válasz BigDarkJoy #12666 üzenetére
BigDarkJoy
válasz Dani_kp #12695 üzenetére
jó öreg wd40...
énsem tennék ujj ventit 1 5450 karira az tuti.. ha kell adok ingyen 1 bordát ventivel
AM WD40 et használok énis csak megelőzérs,havonta 1X szétkapom a vasat,kompresszor alá teszem kifujom a port mindenhonnan és a ventiket leápolom hogy simán mennyenek a csapágyak! Megelőzés a lelke a gépnek!
BigDarkJoy
válasz Dani_kp #12698 üzenetére
az a bajj hogy ezek a kis pi..a ventik már annyira anyaghiányosak hogy az szégyen!!Én ezért vettem EKL Gold hütést a CPU ra és az északi hidat is hütöm,de egy régi 370socetü proci hütöventi pörög rajta mert az anyagból van!
igy a hütés jó és enni lehetne a vas belsejének bármely pontjárol, a por bemászik a csapágyakhoz pláne az ujj kis ventiknél mert nyitottak alurol,vagy háturol.
Ezért sok takaritás és olaj kell nekik!"megölni megtudnak....de megtörni soha.."
BigDarkJoy
válasz Dani_kp #12700 üzenetére
a másik lapodon nézd át a kondikat alaposan!
ellem ki stb... és takaritsd is ki jól ( ha lehet kompresszoral fud át rendesen.
asus lapon lehet automata bios updatet csinálni,szerintem elkel neki mert valamiért biztos vagyok bene hogy a biosz szorakozik.asus lapon nemprobálkoztál bioszban tuningal? fsb álitás stb?
na de fürcsizem és jövök!
BigDarkJoy
válasz allein #12705 üzenetére
Én nemakarlak elkeseriteni de szerintem jobban járnál ha szereznél 1 775s lapot!
lent a kép nekem 2X3000mhz procim van és nézd meg hol fut!
ez az alap, és 4300 ig stabil.
szerintem váltsd le az amdt intelre
van PH-n aki megveszi jó áron a rossz pc lapokat meg vga kat,énis eladtam öket abbol vettem a lapomat
procit 775 laphoz adok neked olcson, pci-e s karit is kapni fillérekért.szerintem fontold meg. DE EZ CSAK VÉLEMÉNY AMI NEM RÁBESZÉLÉS AKÁRMIRE IS!
BigDarkJoy
BigDarkJoy
válasz allein #12739 üzenetére
ezt majd eldöntitek
én lekukáztam ezeket a lapokat és platform váltásal orvosoltam a nyügöket.
amiota a 775s lap van semmi felesleges gond nincs nem vacakol,olcsó a ddr2 ram olcso a 775 proci olcsó a pci-e vga. mikell még? tiszta habostorta vele az élet
BigDarkJoy
válasz blasko92 #12765 üzenetére
Óvatosan a huzogatással! de én személy szerint az afterburnere szavazok!
Csak a hőfokra is nagyon figyelj ugyanis hamar elkezd melegedni ha túlhajtod.
ha az afterrel eléred a az ujj bisos értéket stabilan azt akkor tedd csak fel[ Szerkesztve ]
BigDarkJoy
válasz blasko92 #12767 üzenetére
én csakis az aftert használom .
nekem az nagyon bevált! az asusal már pörköltem karit.
de jelenleg a DualCoreCenter fut nekem ezzel is lehet sokmindent álitani ( bár ez a procihoz jobb)
az afterel viszont ügyesen kilehet csikarni a maxot 1 vga ból."megölni megtudnak....de megtörni soha.."
- Alkoholista nevelde
- Projektor topic
- Robot fűnyírók
- Fűnyíró topik
- Microsoft Excel topic
- NVIDIA GeForce RTX 3080 / 3090 / Ti (GA102)
- BESZÁMÍTÁS! Gigabyte AORUS MASTER RX 6800XT 16GB GDDR6 videokártya garanciával hibátlan működéssel
- PCX Garancia! MSI RTX 3080 Ti 12GB GDDR6X Gaming X TRIO Videokártya! BeszámítOK
- ASRock Radeon RX 6800 XT Phantom Gaming
- Rog 4070 Ti //KERESEM!!//
- PowerColor RX 6800 XT Red Dragon 16GB GDDR6 256bit - Számla + Garancia, Ár alatt! BeszámítOK!
