Diablo 3 topik
MegalodonS
MegalodonS
PTR testing period for the 2.7.1 update begins June 17
New Season Theme: Season 24 introduces Ethereals, a new weapon-type that players will be able to acquire and hunt for in their upcoming seasonal journey. Ethereals will roll a powerful set of affixes, a random Class Weapon Legendary Power and a random Class Passive Power. Ethereals will have unique icons, names, item types, and sounds originally found in Diablo II. For additional details on Ethereals, check out the list below:
Season Rewards: Two unique new rewards, a portrait frame, and a pet will be granted to players who complete the Season 24 Guardian Journey. Please note that the reward content will not be available during PTR 2.7.1.
MegalodonS
válasz mephi666 #114097 üzenetére
Igen, Ethereal,en nem ismerem mivel nekem a D2 kimaradt Rumkola valaszolt A panci az 1:400 drop,irjak hogy a ketto kozott lesz!! Ethereal rarity drop rate is set between Ancient and Primal items.
Igen durva lesz minden karival kifarmolni,egy szezon alatt,bar lesz ido ra boven!!!Remelem valahol kovetheto ,hogy melyik esett mar ki??
Erdekes, a szezon vegen torlodik az osszes Ethereal fegyverEthereals only drop in Seasonal play, and will not transfer to your non-seasonal character when the season ends
Nerfeltek?Rax azt mondja a foldig nerfeltek a nekrot!!Viszont,nem nerfeltek a Wizz-t eleg erdekes!
MegalodonS
válasz reelc #114103 üzenetére
Igen,de ha kifarmolod az osszeset kozmetikaban megmarad Szerintem, D4 miatt nem teszik bele, de lehet majd egy par ev mulva!!
Egy main + off hand + set + kocka, mar 3 nap mulva G150 lenne a T6
Each Ethereal has fixed affixes and rolls one random Legendary Weapon power and one random Class Passive Skill.
Ami erdekes lesz,
Legendary Powers and Class Passive Skills rolled on Ethereals do not stack with the same power equipped through Kanai's Cube, Items or Skills.
Remelem, nem nagyon fog laggolandot csinalni -
MegalodonS
válasz Daelion #114116 üzenetére
En a szokasos szolo WD, mert az gyors leveling es meg gyorsabb kb GR100-ig.Utana FB Wizz marad,ha nem nerfelik GR110+ ez a paros most is jo bevalt nekem!!A harmadik,UE DH mert azzal szerintem gyorsan meg lesz,torles az utolsok Monk v Necro es Barb vagy Crusi azokkal soha nem jatszok, tehat utoljara maradnak. Akkor mar, ugy is kb P800-1000 korul leszek.Aki az Ethereals-t farmolja az ugy is,Bounty meg Rifteket fog tolni.
Ethereals are account bound and can only be dropped by monsters, chests, and destructibles
Ne aggodj meg senki sem, csak talalgatas van,de jovo heten csutortokon mar jobb lesz
MegalodonS
MegalodonS
válasz Daelion #114130 üzenetére
Nem is figyeltem,azt hittem csak a Pre CE valtozathoz van
Nekem ennyi siman belefer,igaz az Overwatch szarnyak,meg mindig hianyzonak,majd ha olcson adjak megveszem
En a D2 alfaban el sem jutottam az Act 2 reszere, mert azt sem tudtam, hol vagyok A D3 sokkal egyszerubb
MegalodonS
ALL ETHEREAL ITEMS GUIDE - Itt az osszes videjoban
Erdekesen neznek ki
Mindegy, hogy leirtak mar tobbX is, hogy auto gold pick up van,meg shared stash meg nagyobb lada meg mindig nem hiszik el
MegalodonS
PTR News
Wizz FB, 2 hand weapon es LB 1 (P1956 es GR142) WOW,nem tul megszokott Nem csodalom,ezeket a cuccokat, csak 1 szezonra dobjak be,mert tul OPOPWD Mundu, P1000+ es GR127
MegalodonS
PTR Ethereal modositasok, avagy hasznalhatatlan itemek hasznositasa affixel [link]
MegalodonS
MegalodonS
válasz Pszicho #114223 üzenetére
Azt hiszem 18db, kulonbozo szarny van,vannak amik mar nem megszerezhetoek, vagy draga megszerezni,pl a Diablo 3 Collector Edition - Glowing Angel Wings.
MegalodonS
válasz Janusz001 #114397 üzenetére
Mundu a The Barber es Gazing Demise nelkul gyenge,ha nincs captain recept menjel a full setben.A masik lehetoseges ha nincs Barber, Voo's Juicer es Sacred Harvester kombo mindegy melyik van a kockaban.
En wd szezont kezdtem es Zunimassa set nagyon eros ,szerintem, ha meg van minden akkor erosebb mint a Mundu igaz meg attol is papirabb build,tehat csak eros idegzetueknek valo!!!
GL HF
MegalodonS
Kedves SQX_Barto kollega,
Legyszi magyarazd mar el kicsit a LoD Bombarment Crusit azt tolom,tudom te nagy szakertoje vagy a kezdetek ota Mire figyeljek mert anno, te mondtad a chd nem szamit,mennyi CDR kell,mit tekerjek mire???Vagy melyik a leggyorsabb Crusi farm kari, GR 100 alatt??Kosziiii
Itt a karim tegnap ejszaka lett meg
Az elso LoD karim a D3 torteneteben,LoN meg nem is volt
MegalodonS
Nekem be jon
Itt ??
MegalodonS
válasz savior #114417 üzenetére
Set lehet rajtad,mivel es LoD??
Milyen fejes kell, de csak ez volt raktaron ??
Abbol a gatyabol mar sokat betortem, azt hittem mar nem fog kelleni Unity van a kockaban is,de valamiert nem mutatja a kozepsot pedig ott Leoric van a CDR miatt.Tudom hogy keves a geaR, de csak ez volt,azt nem tudtam feher kavicsok kellenek hiaba, elso LoD karim KosziiMivel semmi Crusi cuccom, nem volt a LoD volt az egyetlen opcio,most esnek a dolgok,mar es GR80 most 5perc ebben a gearben.Teljes set viszont meg nem esett ki egyikbol sem!!Egy Kiprobalom ezt az AoV buildet!!Koszii
MegalodonS
GR120 - 12:12 (P965 no augment es csak 6 anchient a tobbi normal a fegyo Ethereal!!)
37 Ethereal esett osszesen.A legjobban a LoD Crusi es a Barbi tetszett,mivel soha sem jatszom veluk!Ami nem jott be a Monk, haaat azzal nyuglodtem rendesen!
Jobb is van, mint a Yang
MegalodonS
válasz D3W1L3 #114487 üzenetére
Nem rossz , be vagy augmenmtalva, hanyas gemekkel mentel?? ??? Az en gearem nagyon hulladek, de azert megyek meg 1-2 kort!!Igen ugy tunik eleg eros, meg csak most lett meg az osszes ether, a wizzt szandekosan hagytam utoljara, mult szezonba is tetszett!!
MegalodonS
válasz HellGreg #114534 üzenetére
Diablo 3 Rank 1, '' HC '' Demon Hunter GR141 (P2275 , 21k Dex ,10 milla dmg)
Szerintem ebbol tanulhatsz
MegalodonS
válasz Pszicho #114550 üzenetére
Nem ertelek, T1 - T14 Ha meg van a barmelyik '' Set'' es a hozza valo fegyver+off hand, azzal siman megy a T16, itt kb mindenki T16 jatszik, tehat neked is ott kellene jatszani!!A GR100+ az mas, ott mar lehetnek kulonbsegek!!
Jo eros a cucc, egy sima geraben, augment nelkul,siman lejon a ,GR120+ az azert nem rossz!!
Lesz az hamarosan 135+ is
MegalodonS
válasz Pszicho #114554 üzenetére
Ertelek en,de ez ''NEM'' a POE,GD vagy sakk, mert ott lehet kezdeni az ''F'' gyaloggal csak nem tul jo,nem azt mondom vesziteni fogsz, hanem hogy szenvedni, kb ugyan ez itt is a jatekban.Itt buildek vannak es eleg sok van belole,amihez set es fegyver es off hand jar.Jo geart kifarmolni + paragon+augment nem kis ido!!Azert ha magasabb szintekre mesz, ott van rendesen kihivas.Eleg,1 szint emeles es mar anyit jelenthet, hogy meg sem tudod csinalni!!
GR100 felett kezdodik a jatek!
GR120-nal mar orulsz majd minden +1 szintnek!
GR130+ na ott mar izzadas van,augment es magas paragon nelkul,meg belatod meg nem is jartal a pokolbanHa ugy erzed konnyu a jatek, kezdjel ''HC'' karaktert,ott van kihivas es nem csak a mobok miatt,dc+lag es ha vege ott vege!!!
Itt is van ''Kemenymag'' ok segitenek a jelszavuk ''NE halj meg''En javaslom probald ki a szezonba gyujteni az Etherealt ugye 21db van.En szoloban csinaltam,garantaltan, nem fogsz unatkozni hosszu ideig es kiprobalhatsz sok buildet.En is jatszottam.Barb,Crusival amivel en normal esetben,soha nem jatszom de mind ketto erdekes volt!!
MegalodonS
válasz proci985 #114585 üzenetére
Remelem es sokan masok is, a W11 TMP 2.0 meghozza majd a megvaltast a sok csalotol!!Amikor eljon a hardver alapu ban,na az egy mas vilag lesz!!!
A drasztikus újítás elhozhatja a csalók számára a hardver alapú kitiltás korszakát
''mi lesz azokkal, akik majd olyan használt hardvereket vásárolnak, melyekről kiderül, hogy korábban szinte minden online játékból kitiltottak már. A legjobb megoldás valószínűleg egyfajta névtelen adatbázis lehetne, melyben az eladásra felkínált komponensek előélete leellenőrizhető''[ Szerkesztve ]
MegalodonS
SEASON 29: VISIONS OF ENMITY
DIABLO III PTR 2.7.6 PREVIEW jo lesz ez
Solo Self Found mode. In this mode, you’ll have only yourself to rely on to overcome the hordes from Hell. That’s right, it’s a single player experience.Vegre egyedul
MegalodonS
MegalodonS
válasz BitRider #116176 üzenetére
Igazabol minden jateknak a vege lelassul es mar a kerdes mit is csinalsz??
D3 GR150,D4 Uber Bossok,WoW M+ ami ugyan az ,csak emelkedik a minden, a gear szinted meg csokkenoben es ha nem esik ki,akkor jon a vegtelen farmolas, amig ki nem esik a megfelelo item!Aztan beleraknak egy meg magassabb itemet,meg egy mountot es ujra megy a vegtelen farmolas!Azert ha ennyire unalmasnak talalod,probald ki mindennel lehozni, a GR150-et es akkor azt mondom ugyes vagy,elore megmondom nem fogsz unatkozni,viszont nagyon sokat fogsz jatszani!Akkor meg ott van a solo-mode, abban is megcsinalhatod ugyan ezt!
- Milyen asztali médialejátszót?
- Skoda, VW, Audi, Seat topik
- btz: Internet fejlesztés országosan!
- Filmvilág
- I5 13600k rtx 4070 ti 32gb ram
- ASUS ROG STRIX RTX 3060 Ti OC LHR - eladó!
- iMac 2019 27" Retina 5K / i5 3 GHz / 32 GB DDR4 / 1 TB SSD / Radeon Pro 570X 4 GB
- AKCIÓZVA! HP EliteBook 850 G7 Fémházas Szuper Strapabíró Laptop 15,6" -65% i7-10610U 32/512 FHD HUN
- AKCIÓZVA! HP EliteBook 850 G7 Fémházas Szuper Strapabíró Laptop 15,6" -65% i7-10610U 16/512 FHD HUN
