yodamastah
2015ös. Pár apró esztétikai hiba ami picit lefele húzza az árát. Pl tokfüleken volt 1-1 olyan mély sérülés ami polírral már nem jön ki (így vettm én is). Meg persze voltak a sima használatból eredő karcok amik polírral javíthatók.
AR rétegen voltak mikro karcok valóban. Nagyon picik, alig láthatóak. Normál használat közben soha nem venni észre.
yodamastah
Smp-n látni
yodamastah
válasz vadászcsiga #7491 üzenetére
A fene hirtelen azt hittem erre cserélted a 2254et Szép darab amúgy
yodamastah
válasz phranxinatra #7612 üzenetére
A co-axial még így sem lett teljesen problémamentes. A szerkezet egyes részeinek olajozása igen kifinomult művelet, ha nem jól van végrehajtva megfelelő eszközökkel, akkor továbbra is tud problémákat okozni.
Omega forumból a co-axial problémáról (a szerző omega minősített órás) :
Omega spent a ton of time trying to figure out ways around this problem, but it stems from the geometry of the teeth. They have found changes and procedures that help mitigate the problem, but the ultimate solution was going to the 3 level escapement that eliminated the problem geometry in the teeth.
For the co-axial wheel, although the marketing material talks about reduced friction in the co-axial, reduced doesn't mean zero. In addition the design of the co-axial wheel teeth results in pointed and very fine teeth right where they take the impact and wear, so it doesn't take much friction to cause them to wear when they contact the pallet fork stones. A microscopic amount of oil is placed on these teeth, but the amount is so small and it is subject to impact forces that mean it doesn't last forever, and when it goes away or dries out the wear starts. Note that it can also disappear through improper application - the amount of oil used is smaller than any drop of oil you would use in any other watch, so to be frank it's not an easy thing to do properly. If done improperly (too little or too much oil) the oil will soon be gone, and the wheel will suffer.Eredetileg az egész cirkusz a co-axial-al arról szólt volna, hogy csökken az óra szerviz igénye. Az eredmény meg az lett, hogy ha nem az omega szervizeli, akkor lehetnek bajok. Persze az Omega szemszögéből ez tökéletes. Egy 1120as omegát simán rá lehet bízni a "sarki" órásra, de a co-axial modelleket jobb márkaszervizbe vinni.
yodamastah
válasz vadászcsiga #7624 üzenetére
Végül megtartottad?
GTS300?
yodamastah
válasz FIREBLADE78 #7845 üzenetére
Moonwatch szokott lenni a butikban. Szép ára van már annak is.
yodamastah
Mága a plakátokon rendszereen kirakott órával pózol. Eddig csak az AP-t ismertem fel, vélhetően jó drága a többi is.
yodamastah
válasz FIREBLADE78 #7865 üzenetére
Ha vagyonos ember vagy és órabuzi, akkor megfordulna pár komoly óra a kezeden. Mikor a házad már megvan, van pár lakásod kiadva, 100 milliók befektetve, a garázsban állnak az autók, 2-3 vállakozás pörgeti a lét. Akkor lenne pár 10 millió órában.
Ha autóbuzi vagy akkor meg lenne pár veterán projekted lehet.. Amikor van hülyeségekre elkölthető lé, akkor az el is lesz költve hülyeségekre.
yodamastah
Ha már az árak szóbakerültek, beugrottam Omega butikba minap. A szendvics speedy 1790e ft már. És a pletyka az hogy nemsokára standard lesz a 3861 szerkezet. 2milla felett lesz a speedy is hipp hopp.
yodamastah
válasz Macyke82 #8084 üzenetére
Igen a méret nálam is határeset. Próbáltam a 38.5öst azt meg kicsit kicsinek éreztem. 40es lenne az igazi Meglátjuk még hordanom kell hogy érezzem ez milyen.
A középső szemek polírozottak voltak (rommá karcolva). A tükörre polírozott center link nekem nagyon nem tetszik és mivel ennek a szíjnak van teljesen szálcsiszolt változata, úgy gondoltam legyen ilyen. 100x jobban tetszik így. Persze megoldás lett volna az is ha skyfall modellt veszek csak azt kb lehetetlen találni és mocsok drága
yodamastah
Köszönöm mindenkinek. Régóta agyaltam ezen a verzión, és nagyon ritkán van eladó. Most volt egy, és belevágtam.
Squir!
13mm magas az óra, az üveg domború, még kicsit hozzáad. A fotó kicsit csalóka, 55mm obival készült, ami kicsit már nyomja össze a teret. Valamivel nagyobb a kezemen élőben. Ha mobillal fotóztam volna ami 28mm-nek felel meg kb, akkor meg óriásinak nézne ki
Djeperto!
Elegásnak 38.5öst. Mondjuk a feketéből sincs sok eladó.
yodamastah
válasz K.Andras.Vfx #8209 üzenetére
A 4 gombos 7 zenélős kvarcórám, amit általánosban hordtam a 80as évek elején, az az óra is jócskán meghaladta technikailag azt amit pl egy speedmaster tud. De ez a topic nem erről szól
yodamastah
Jelen pillanatban sem azért vesznek az emberek 3+ millióért sub-ot mert az egy praktikus használati tárgy. Hanem mert menő, és tartja az árát. Okosóra ebből a szempontból értéktelen. Apple watch nem luxustermék, ezért nem menő és nem is tartja az árát. 20 év múlva egy mai apple watch teljesen értéktelen kacat lesz.
Tag heuer is úgy árul okosórát hogy lehet upgradelni, vagy be lehet cserélni egy idő után egy "igazi" órára (nem ingyen).
yodamastah
válasz K.Andras.Vfx #8234 üzenetére
Attól menő mert drága és sokan felismerik. Az említett sub a legszélesebb körben ismert óramodell.
yodamastah
Az Aqua Terra-k meglehetősen nagynak hatnak. 43-ast próbáld fel mindenképp mielőtt emellett döntenél. Olyan érzés lesz mint egy 44-45ös búvár
A co-axial gátszerkezetes órákat olyan helyre értemes vinni, ahol fel vannak készülve ezeknek a szerkezeteknek a szervizelésére. A gátszerkezet olajozása igen kifinomult folyamat. Mikroszkópikus mennyiségű olajat kell felvinni több helyre. Ehhez megfelelő eszközök és tudás kell. Ezt nyilván a márkaszerviz meg tudja oldani, de az Omega szerviz árak igen magasak. Jelenleg egy 3 mutatós szerviz 170e, chrono pedig 230e ft az Omega Butikban. (Igen egy "mezitlábas" kézihúzós speedmaster szervize is 230e. )
Aqua Terra-t amúgy ajánlom, nekem régi kedvencem ez a sorozat. De a 43ashoz tényleg vastag csukló kell
yodamastah
gshock
yodamastah
válasz phranxinatra #8396 üzenetére
511
yodamastah
válasz vadászcsiga #8474 üzenetére
Szép darab
yodamastah
válasz whatnot #8907 üzenetére
Kb 99% hogy nem tudsz megfelelő órát venni másnak amit nem ő választott ki. Legutóbb apámnak vettem órát 70. szülinapjára. Megbeszéltem vele egy napot amit erre szántunk. Végig jártunk 4-5 órás boltot, ahol kiválasztotta a neki megfelelőt. Direkt próbáltattam vele nagyon olcsó és nagyon drága órákat is, ha már időt szántunk erre. Érezze mi a különbség
A választás egyáltalán nem volt könnyű. Még neki is, aki egyáltalán nem órabuzi, konkrét elképzelései voltak milyen órát szeretne vagy nem szeretne hordani. Én biztos mellélőttem volna.
yodamastah
válasz pikkubee #9534 üzenetére
Ha broad arrow speedmastert szeretnél, akkor sokkal olcsóban nem fog menni. Mondjuk én inkább a kézi húzóst venném 1861 szerkezettel (pl 3594.50.00)
Ebben az ársávban inkább speedy pro. De megy szépen fel annak is az ára. Omega most fog árat emelni szeptemberben (6% körül), és később lesz új modell új szerkezettel. Sztem simán 2M+ lesz egy új professional nemsokára.
yodamastah
válasz pikkubee #9539 üzenetére
Ezzel annyival vagy beljebb hogy nem 3303 van benne hanem 3313. Ugyanaz a szerkezet csak co-axial gátszerkezet. Ha korrektül akarod szervizeltetni, drágább lesz a szerviz. Arról nem is beszélve hogy 3313ból is van A,B,C.
A számlap nekem is jobban tetszik a 1957 felirattal
yodamastah
yodamastah
válasz Bling95 #10270 üzenetére
Ami bejön:
Step dial, új fémszíj, csepp másodperc mutató, applied logo.Ami nem:
- 3861. Még távolabb kerültünk az eredeti moonwatch-tól. Maradhatott volna 1861 vagy lehetett volna 321. Az egész óra arról szól, hogy 50+ éves modell pici változtatásokkal. De persze szuper az új szerkezet, csak én vagyok ilyen ódivatú
- Zafír milky ring
- Plexisen festett logó
- Az ára (igaz legalább tartalom is fejlődött)
- úgy néz ki továbbra sincs gyors mikro állítás a csaton.Összességében szerintem jó irányba mentek.
yodamastah
válasz vadászcsiga #10282 üzenetére
Mi lesz a holddal?
yodamastah
válasz vadászcsiga #10395 üzenetére
Az nem a tokfül, hanem a végszem. A tokfül alja a speedyn tükör polírozott.
Nbukta77 mit kell nézni? Nincs fókuszban a hibás rész. Bár mindegy is. Bármi reklamációd van, irány a butik.
Exkluzív órák topikja, elsősorban mechanikus svájci órák számára, de szívesen látunk német/japán/egyéb közép- és felsőkategóriás órákat is.
Az ide nem illő órák a következő topikok valamelyikébe tartoznak:
Óra topik
- Audiokultúra - Hi-Fi-ről hifisen
- Mobil flották
- Fogyjunk le!
- Redmi Note 13 Pro 5G - nem százas, kétszázas!
- Broken Roads teszt
