Angel2014
Tényleg bosszantó 300 ezer ft ért vettem egy jónak ígérkező gépet és nem lehet használni .....lassan ott tartok földhöz verem vagy kidobom az ablakon.
Felteszem a wint ahogy muerte írta felteszem a drivereket abban sorrendben ahogy ráengedem az updatét szétzuzza és kék halál most tényleg ez egy olyan gép 300 ezer ft ért amire n nem lehet win 8 at sem rakni mert a vga driver miatt nem megy fel ha meg win 7 el haszálom akkor meg nem lehet updatelni
kezdek elfáradni vele idegileg....
Csak a Weider ad neked erőt és mindent lebíró akaratot!
Angel2014
És ebben a sorrendben:
1. Chipset Driver
2. USB 3.0 Driver (11xR3, 14x, 17xR3, 18x only)
3. Intel RST Driver / Intel Management Engine
4. Freefall Sensor Driver (Optional - many members choose not to install this. Also, as long as your drive supports it, the 'App' will work with aftermarket drivers)
5. Alienware On-Screen Display Driver
6. INTEL/AMD/NVIDIA Display Driver
Optimus systems require the Intel Driver be installed prior to the NV Driver. So if you have an M11xR2/R3, M14x or M17xR3, install the Intel Driver FIRST.
If you have a 17xR3 with 3D option, Optimus does not apply to you and the Intel driver is not needed
For M17xR3 with AMD, install the AMD Display Driver. AMD owners report the Intel HD Graphics driver is included with the AMD installer.
For M18x with AMD,
If you are unable to switch between the AMD GPUs and the iGPU (Intel HD 3000), try the following:
1. FN+F7 to initiate the GPU switch call.
You will be greeted by a dialog box:
Quote:
BinaryGFX Keypress Detected. Choose Yes to continue (a system reboot is required) or No to cancel.
2. Select 'Yes' and the system will shutdown.
3. Once the shutdown has completed, power up the system.
4. When you are back at the desktop, run the IntelHD driver installer (grab it from the M18x Driver Download page - linked earlier in this post).
5. Once the driver is installed, reboot and when you return to the desktop, hit FN+F7 again (dialog box will display).
6. Select 'Yes' to switch and the system will again shutdown.
7. Once you power back up you will again be in discrete mode (AMD GPUs active).
Done - iGPU driver has been installed.
7. LAN Driver
8. Wireless Network Driver
9. Audio Driver
10. Bluetooth Driver
11. Touchpad Driver
12. Media Card Reader Driver
13. Remote Control/Infrared Driver (Older systems - M15x, M17xR1/R2)
14. Alienware Command Center
NOTE: Command Center should always be installed last.
15. Log in over @ https://smartsource.dell.com to grab any apps which came bundled with your system that were not included on the Resource DVD. Webcam application is one of them.Túlmelegedésre gyanakodtam hogy folyton használja az nvidia kártyát felakartam tenni épp ezért a processor grafikusát de azt sem lehet sehogy sem.
Angel2014
sehogy nem tudom feltenni a grafikust...
kérdés ha veszek egy másik karit akkor már tudom telepíteni a win 8at ? vagy a bios nem fogja engedni?
Intel / AMD / NVIDIA Display Driver
Optimus rendszereknél az Intel illesztőprogram telepítése előtt az nv illesztőprogram. Tehát, ha van egy M11xR2 / R3, M14x vagy M17xR3, telepítse az Intel illesztőprogramot.
Ha van egy 17xR3 3D opcióval, Optimus nem vonatkoznak Önre és az Intel illesztőprogram nincs szükség
A M17xR3 AMD, telepítse az AMD Display Driver. AMD tulajdonosok jelentik az Intelitt azt irja nekem nvidiám van . nem lehet felrakni ill nincs szükség rá....
Angel2014
Fél órát megy utána kék halál. És ez ismétlődik.
Du megpróbálom megint....Lehet szét is szedem ...kiszedem a vgát megnézem a gpu pasztázását ill ventilátor nincs e tele porral.
Amúgy milyen vgá-t ajánlanál ebbe ha rossz ez?
Angel2014
A másik amit akartam kérdezni , ha kiveszem az nvidiát akkor szerinted felmenne a processzor grafikusa?
Mert lehet azért nem teszi fel , mert benne az nvidia? Bármit állítottam a biosban nem ismeri fel Peg stb...
Angel2014
válasz Ursache #2541 üzenetére
Kezdtek megijeszteni.....
Nálad is ez volt? Leírnád a hibajelenségedet pontosan és milyen procit tettél bele.
Hogy sikerült kiszűrni a hibát .
2630qm i7 szerinted ez gyár benne adtak ki r3-at ilyennel.
Angel2014
válasz Ursache #2547 üzenetére
Na és akkor amikor te vetted a gyári volt benne vagy elképzelhető cserélték ami benne volt, ezért kérdeztem az én r3 -somat adták ki a 2630qm -el.
A procinak semmi hibája nem volt csak nem szerette azt a lapot gondolom. Vagy hibás volt?
Angel2014
Sok mindentől függ:
Lemezkezelőben nézted? és ott előhozod de ott formázni kell hogy látszódjon azt hiszem.
Függ a legacy ill uefi bootol is
Függ a bios beállitástól is mert azt hiszem az allien raidra rakja a biosban alapból. azt kell ahci re állítani benne.
De ha raidról telepítetted kezdheted elölröl ahci re állítva a telepítést.
Angel2014
Nem tudnátok segíteni nekem amit muerte használ az melyik program?
Próbáltam feltenni a lenovomra is.....mert azt hittem az msi after Burner de nem az ....
Angel2014
Azért nem annyira érthető a videó.
PL. nállam a riva nem indult a win 8.1 en kézzel indítottam és videóban sincs benne hogy kell hozzáadni a programot ...
Gondolom a rivában baloldalt kiválasztom az msi -it beállitom a szint méretet hol helyezkedjen ek stb...de nem akar látszani.
Angel2014
válasz KillHates #2700 üzenetére
Nos leadtam a gépet egy szervizben , kipróbáltak másik procit ill az enyimet is átették egy másik gépbe tökéletes azt mondták vga-t is nézték arra is azt mondták jó , viszont teli volt porral és kosszal kifújták és kitakarították , azóta nem csinálja a kék halált , kérdés : ez okozhat olyat ha teli van porral a direkt x re utaló kék halált? vagy a túlmelegedés miatt amit a por okozott? Amúgy most 53 fokos terhelés nélkül.
Mivel csepeli vagyok és a kvassai híd tőlem kb: 10 perc , ha jelentkezik megint a próbléma akkor bevihetem hozzád?
Angel2014
válasz KillHates #2718 üzenetére
ÁÁÁÁÁÁ meglátnak általában nekem szoktak fizetni inkább csak távozzak már a taxisok se szokták elfogadni a fuvar végére a tarifát....
3000 ft volt....és meg is várhattam!
Proci ki be utána pasztázás és kifújta a port.
Csak arra adj választ szerinted okozhatott ez erre utaló kék halált ? vagy pl a melegedés miatt ha teli van porral ?
Angel2014
válasz solyom76 #2763 üzenetére
Én meg szeretném mert lehet ha azt használnám lehet a hőfokot csökkenteném rajta...
Bármit csinálok nem megy fel és a bios sem látja a HD 2000 et
Örökké erre a hibakódra dob kék halált ...[link] fél óránként
Kitakarítattam de megint elkezdte....megy a dell szervízbe azt hiszem vagy KillHates kezeibe adom....
Angel2014
Azért annyira nem vagyok kezdő én sem ,hiszen valamennyire evvel foglalkozom naponta...
Semmi különös nem történt azóta , vettem egy collermaster hűtőpadot alája , és amikor felrakom a windowst a gyerek a heroes 3 al játszik rajta .annak meg szerintem csak el kell futnia egy ilyen gépen...
Angel2014
válasz solyom76 #2766 üzenetére
Nem az fel sem megy sehogy, készen vagyok a telepítéssel , aktiválom a wint , felrakom a drivereket ebben a sorrendben [link]
A windows olyan 64 bites ultimate amiben már bele van integrálva szeptemberig a frissítések , szóval a driverek telepítését nem kell megszakítanom mert benne vannak a keretrendszerek is. És a win frissítését is kikapcsolom.
Amikor végeztem és fent van minden felrakok pár progit cc kleaner, utorrent , heroes3 , advanced system stb...és akkor indul a kék halál fél óránként.
Angel2014
Hogy miért ....mert az a hibakód igen csak a videókártya vagy a processorban lévő hd2000 kavar be muszáj valahogy kiszűrnöm.
Kérdés: ha kiszedném a videókártyát akkor lenne hd 2000 em? Akkor már felmenne?
Vagy ezt a procit beletenném egy másik alaplapba akkor megjelenne a hd2000?Vagy ahogy kretén javasolta tök mindegy hogy milyen de 2. generációs i5 . i7 el próbáljam meg egy másikkal?
Angel2014
válasz Mikulásbá #2770 üzenetére
Na az most jött el mivel ez egy olyan win amiben minden benne van Felraktam a home premiumut ugyan így de a legvégén az Alienware Command Centert nem bírtam feltenni sehogy ....elkezdtem a command centert telepíteni ismét egy kék halál nagy nehezen felállt a gép és utána nem engedte felrakni a command centert.
elindítottam a telepítést hibaüzenet és azt írja ki hogy tökéletesen fent van ...ultimatéra meg fel engedte tenni.Gondoltam rá lehet ezzel a winnel van a baj....
Angel2014
válasz solyom76 #2771 üzenetére
Igen kihagyom, meg sem próbálom már ...hiszen nem megy fel csak az nvidia és ugyan úgy jön a kékhalál.
Megpróbálok egy másik wint felrakni...ami tiszta...és ha akkor is jelentkezik megpróbálom a videót amit küldtél.
Angel2014
Na végre megértettem erre a panelra gondoltál. Én azt hittem a vga-ra.
Ha jól tudom ebben a gépben volt egyszer egy garis kijelző csere.
Olyat nem lehetne csinálni,hogy a 3d -ét ki tudnám kapcsolni? Vagy nem a herzet kellene állítgatnom az nvidia kezelőfelületében?
Angel2014
Angel2014
válasz kreten67 #2792 üzenetére
Akkor ezt azt jelenti ha egyszer rátettem a win 8at akkor már annak a command centere kell?
Mert lefelé nem kompatibilis? Márpedig egyszer rátettem és azt hiszem az r4 win 8 asát.De gondolkodjunk logikusan ami nálam van kék halál az a 0x00000116 os hibakód ami a directx re utal.
Ha máshová dugnám a csatit elhárulna ez a hiba?
Ha a command center rossz pl: elhárulna ez a hiba?[ Szerkesztve ]
Angel2014
válasz Angel2014 #2793 üzenetére
Szerintem ezek a lehetőségek nem érintik ezt a hibalehetőséget.
Lehet miatta kék halál de biztos nem ezzel a hibakóddal fog megjelenni.
Ez szerintem vagy a processor vga-ja kavar be , vagy a videó kártya , vagy az nvidia driver 3d stb..,..
Angel2014
Arra a hibajelenségre jöttem rá, ha a tápkábelt kihúzom lefut a 3DMARK teszt ....ahogy rádugom a tápkábelt egyből lefagy,megáll ill megint kék halál lesz ez miért van ill lehet.
Amúgy ez lett a 3D mark tesztem:
Lehet sok az áram , vagy a töltés miatt nagyobb a hőfelvétel? Ahogy kihúzom semmi baja....
Ez a pontszám jónak mondható ....szerintem egy core 2 es asus gép is többet kapna nem ?
Angel2014
válasz Angel2014 #2828 üzenetére
Na lehet megvan a próbléma ...ha tápkábel nélkül használom teljesen jó a gép...ahogy rádugom lefagy ill kék halál csak nehogy a command centerrel legyen a baj.
Vagy ez töltő hibára utalhat?
Kivettem az aksit is hátha az a baj de úgy is fagy....
Angel2014
● A topikban hirdetni TILOS!
- Lenovo T480 i5-8.gen laptop
- 2es gép - Lenovo ThinkPad T14 G3 (Gen3, Gen 3) - i5-1250P / 24GB / 256GB SSD / TOUCH / 3 év garancia
- 1es gép - Lenovo ThinkPad T14 G3 (Gen3, Gen 3) - i5-1250P / 24GB / 256GB SSD / TOUCH / 3 év garancia
- Kiváló ár! Fujitsu S751 laptop (i5/4GB/160GB) - 1 év garancia
- Kiváló ár! ASUS X551M laptop (Intel/8GB/256SSD) - 1 év garancia
- Dell XPS 13" 9360 - i5-7200U/8GB RAM/256GB SSD/100% Akkumulátor
- Dell XPS 15 9500,15.6",4K UHD,i7-10750H,32GB DDR4,1TB SSD,GTX 1650Ti,WIN11,TOUCH
- HP EliteBook 645 G9 (A1WY1E8) - ÚJ 14" üzleti notebook - Ryzen 5 PRO, 16GB, W11 pro
- Dell 130W laptop adapter, centerpines, újszerű/új
- Dell XPS 13 9370,13.3"UHD,i5-8350U,16GB,256GB SSD,WIN10,TOUCH
