Gorneck
Már vártam a topik nyitását...
Kíváncsi vok milyen létjogosultsága lesz ennek a chipsetnek illetve az X48nak...melyik mikor is érkezik?! Melyik is lesz a fejlettebb? Vajon ez lesz a York és Wolf procik igazi tuning lapja?
Gorneck#1239
Gorneck
válasz i are robot #56 üzenetére
Virtuális csak a +6...szal igazából tökéletes a DS4 6 fázisa.
Gorneck#1239
Gorneck
Gigabyte, now Gigabyte United, is apparently here to contend in the High End motherboard arena, and they are doing so loud and clear. Gigabyte sports twin 6 phase voltage regulators (12 phases in all) using Solid State Capacitors instead of Electrolyte (as seen in many other manufacturers).
Quad-Triple Phase
An exclusive feature found only on GIGABYTE motherboards, this unique design incorporates Virtual 12 Power Phases to deliver steadier power and immediate current to the CPU and memory during heavy system workloads or overclocking. Additionally, Quad Triple Phase helps decrease the working temperatures, enhancing system stability and increasing component lifespan.A good case in point: the "Quad triple phase"... the board uses an Intersil ISL6327 PWM controller when I last had a look. This is a 6-phase device, which means that the board doesn't use a true 12-phase design as the marketing might cause the average Joe to believe (how many average Joes read the fine print and pay attention to the word "virtual" in "Virtual 12 Power Phases"?) but instead uses a 6-phase power design with twice the number of MOSFETs.... why not just call it 6-phase power, which is already impressive (and accurate)? If the purpose of having a whole 24 MOSFETs in the design was to lower the current flow through each MOSFET to lower power dissipation, why not just use uprated MOSFETs? 120A MOSFETs cost only about 35% more than the 56A ones used on the DQ6; so it'd be cheaper AND you get to save valuable PCB real-estate for other uses like better ground around the power islands, better-optimised routing, more fan headers and so on. But you see, staying at "6-phase" and calling it that isn't strong enough marketing: you need hyperbole, and by having '12' phases you get to add one more to the silly list of "Quads" as a "Quad Triple Phase". And since 12 is way way bigger than 6, you have an excuse to charge way way more for the board than you otherwise could.
Gorneck#1239
Gorneck
Gorneck
Gorneck#1239
Gorneck
válasz Laraxior #149 üzenetére
To support the Deeper Sleep State the platform must use a VRD 11.1 compliant
solution. The Deeper Sleep State also requires additional platform support. Refer to the
Voltage Regulator-Down (VRD) 11.1 Processor Power Delivery Design Guidelines for
further details.Gorneck#1239
Gorneck
Igazából Én inkább azon töröm az agyam, hogy...
P45+DDR3+Wolf/York.
P45+DDR2+Wolf/York.
XY+DDR3+Nehalem.Szal jó lenne tudni mit tud az a nehalem...mert ha olyan jól sikerül, mint a fenom, akkor maradnék az első két lehetőségnél...egy P45-DS3P-vel...
Laraxior: Jómagam/Sztaki...hajrá... Én meg oroszul, németül és magyarul...angol folyamatban van...
Gorneck#1239
Gorneck
Arról nem is beszélve, hogy új tokozás új hűtő új lapok...ki tudja nem e lesz olyan effekt mint a Fenomnál...alig mennek vmit...
P45 DS3P lesz ebből, ha megmarad, hogy DS4-HP=DS3P. A többibe nem látok annyit, hogy megérjék a többlet pénzt...
Bár, ha a DS3 biosa is jó lesz akkor marad az a vonal...Laraxior: De belemegy nagyobb is...
Gorneck#1239
Gorneck
Gorneck#1239
Gorneck
Gorneck#1239
Gorneck
Tehát emelt fesz mellett is visszavesz a tempóból...nem csak órajel szinten, hanem fesz szinten is csökkennek az értékek?!
DS3P:
1. Olcsó. DS3 és DS4 között.
2. Tuning opciók megegyeznek a nagyokéval (DS4/DS5/DQ6).
3. Tuning szint, mint a nagyoké (DS4/DS5/DQ6).bim: Ezzel nagyon egyetértek...
Gorneck#1239
- World of Tanks - MMO
- 2025-ben jöhet az Intel Panther Lake processzora
- Elkaszálhatja az Apple az iPhone Plust
- Videó stream letöltése
- Honor 90 - modellalkat
- Kecskemét és környéke adok-veszek-beszélgetek
