Terminus_
Ez Perlben van, de elég jól kommentezett.
#!/usr/local/bin/perl
# A test array
@sort_array = (4,7,12,3,15,28,1,3,44,13,18);
# Get the ball rolling
&do_merge_sort(@sort_array, $#sort_array);
#print out the results.
$end_result = join('', '',@sort_array);
print $end_result.'' '';
exit;
sub do_merge_sort {
&merge_sort(shift, 0, shift);
# Merge sort expects 3 parameters
# A reference to an array
# A start index of where to start sorting
# An end index of where to stop sorting
sub merge_sort {
my ($array_ref, $start_index, $end_index) = @_;
# Only do merge sort if there's a 1 element or greater sized array. No use for empty arrays.
if ($start_index <; $end_index) {
# Calculate the middle of the array
my $mid_index = int(($start_index + $end_index) / 2);
# Call the merge sort on the left half of the array
&merge_sort($array_ref, $start_index, $mid_index);
# Call merge sort on the right half of the array
&merge_sort($array_ref, $mid_index+1, $end_index);
# Merge these two arrays together since they will be in order by now
&merge($array_ref, $start_index, $end_index);
sub merge {
# calculate the middle of the array
my $right_index = int(($start_index + $end_index) / 2) + 1;
my $max_val = $end_index;
my $left_index = $start_index;
# While we don't exceed the bounds of the merge keep going.
while ($right_index <;= $max_val && $left_index <;= $max_val) {
# If the current item in the right array is bigger than the current
# item in the left array, we need to move the right item to the current
# position in the left array and shift the left array to the right by
# one.
if ($array_ref->;[$right_index] <; $array_ref->;[$left_index]) {
# Store the right index value that needs to be brought to the front
my $tmp = $array_ref->;[$right_index];
# Shift the left array over by 1 to the right to make room for the
# smaller value
for ($i = $right_index; $i >;= $left_index; $i--) {
$array_ref->;[$i] = $array_ref->;[$i-1];
# Swap in the value and change where the array indexes are located
$array_ref->;[$left_index] = $tmp;
$left_index++;
$right_index++;
} else {
# If the left item is greater than the right item you don't need to
# do any swapping since it's already keeping the sort order correct
# just make sure that the left index doesn't catch up to the right
# index or you're already done sorting this level!
$left_index++;
if ($left_index >;= $right_index) { return; }
Kár, hogy a struktúráltságát elvesztette :(
[Szerkesztve]-
- ÚJszerű Samsung Galaxy S20 Plus 5G (83e-től)
- Eladó Cablemod kábelszettek tápokhoz, moddinghoz a bolti ár töredékéért!
- Beszámítás! ASUS Prime B450M-A R5 5600 16GB DDR4 500GB SSD RTX 3070Ti 8GB CM MasterBox MB530P 650W
- Macbook pro 13 i7, 4gb ram, 512gbHdd
- Beszámítás! GIGABYTE B760 Aorus i7 13700F 32GB DDR4 1TB SSD RTX 3080 10GB CM MasterCase Maker 5 750W
