Minden ami kínai és óra, és minden ami olcsó és jó óra.
Bizonyítsuk be, hogy ami kínai és olcsó az is lehet jó óra. :-)
@mriya@
válasz schawo #11934 üzenetére
Előbb nézz utána, mielőtt állítasz valamit!
"BPC is the callsign of a time signal broadcasting from the BPC Shangqiu Low-Frequency Time-Code Radio Station, cooperatively constructed by the National Time Service Center of the Chinese Academy of Sciences and Xi’an Gaohua Technology Co., Ltd, since April 25, 2002.
BPC transmits a time signal on 68.5 kHz, which can be used for synchronizing radio controlled clocks. As opposed to other time signal transmitters, the signal format is not published openly; a special license is required. The transmission site is situated near Shangqiu, Henan Province at 34.457°N 115.837°ECoordinates: 34.457°N 115.837°E.
BPC broadcasts at 90 kW for 21 hours per day, with a 3-hour break from 05:00–08:00 (China Standard Time) daily (21:00–24:00 UTC). BPC includes both conventional amplitude modulated time code and additional spread-spectrum time code, about which little is known."
Bose, Philips hangcuccok a hardveraprón.
@mriya@
válasz han_lev #11933 üzenetére
TimeCenter-nél már egész olcsón találsz.
Ami nála kapható, az működik Magyarországon.
Amit kintről szerzel be, az nem biztos.
Németország, UK, USA, Japán, és Kína.
Itt vannak adók.
Azok az órák, melyekre MultiBand6 van írva, az összes frekvenciával kommunikálnak.
De vannak olyanok, amelyikek csak eggyel (régi dcf-esek például)."The receivers to which the watches can tune themselves vary by watch submodel. Casio mentions that in Europe, the watches will tune to the 77.5kHz low frequency time signal radio station DCF77 located at Mainflingen in Germany or 60kHz MSF at Anthorn (formerly transmitting from Rugby, Warwickshire) in the United Kingdom. In Europe the reception range is approximately 1500 kilometres. In the United States, they will tune to the 60kHz signal from WWVB at Fort Collins. In Japan, they will tune to the 40kHz signal from JJY at Mount Otakadoya, near Fukushima (Ohtakadoyayama) and the 60kHz signal from the Haganeyama Transmitter at Mount Hagane (Haganeyama). In China, they will tune to the 68kHz signal from BPC at Shangqiu. Some watches can register only some of these signals."
@mriya@
válasz gipsztigris #11965 üzenetére
Én kérek elnézést!
@mriya@
@mriya@
válasz gagyilovag #12044 üzenetére
Az óra felső részének (12) kell nyugati irányba néznie, és le kell rakni az órát.
@mriya@
válasz gagyilovag #12064 üzenetére
Ugye, hogy egy kvarcórának is van lelke?!
@mriya@
válasz Rodzser Mór #12147 üzenetére
Azt nem láttam, a rádiókontroll hol működik?!
@mriya@
válasz speedernet #12276 üzenetére
Hm, érdekes.
Casiora 3 év, Citizenre 5(!) év a garancia!Bose, Philips hangcuccok a hardveraprón.
@mriya@
válasz speedernet #12411 üzenetére
lehet, hogy nem kell ősszel az időt pörgetni, csak a dst-t kikapcsolni, és beáll a normál időre.
@mriya@
@mriya@
rugós stift.
bármelyik órás tud adni, ha ismered a méretét.[ Szerkesztve ]
@mriya@
@mriya@
válasz pulutodurumo #12429 üzenetére
Nem olvastam el, és most sem fogom.
@mriya@
válasz pulutodurumo #12466 üzenetére
erre a szerkezetre gondoltam.
@mriya@
válasz FERA88 #12600 üzenetére
Az első képen látható szerkezet jobb.
Az a "mutató" nem járástartalék kijelző, hanem a szabályzókucs egyfajta kialakítása.
A kínai bevonatok nem a legtartósabbak, a natúr tok acél, és nincs krómozva.
Én nem vinném vízbe ezeket az órákat, legyen bármi is rájuk írva, hacsak nem csináltatnék előbb egy nyomáspróbát. De mivel ezek kézihúzósak, kérdéses, hogy meddig bírja a tömítésük?
Járástartalékuk 36-40 óra, illik őket minden reggel "ütközésig" felhúzni!Bose, Philips hangcuccok a hardveraprón.
@mriya@
Hasonlítsd össze a két szerkezetet, nem hogy nem ugyanAZ, de még csak nem is ugyanOLYAN!
Az egyik 6497-es, a másik 6498-as.
Ez utóbbira pakolták rá azt az értelmetlen hosszú szabályzókart, ami egy ütődéstől akár el is mozdulhat.
Szerintem a 6497-es stabilabb szerkezet, legalábbis ebben a kivitelben.
Érdemes még az órák hátlapjának a felerősítésére is figyelni, mert a picinyke csavarok knnyen törnek, a picinyke menetek könnyen nyíródnak.Bose, Philips hangcuccok a hardveraprón.
@mriya@
válasz pulutodurumo #12607 üzenetére
Én pedig nem vitatkozom senkivel.
@mriya@
válasz pulutodurumo #12687 üzenetére
Ugyanolyan, csak egészen más.
- Eglo Torretta LED IP44 tükörvilágító lámpa 94617 - NEGYED ÁRON
- BRUTÁLIS ERŐ: Baseus A3 15000Pa vezeték nélküli autós porszívó - CSOMAGKÜLDÉSSEL IS
- TISZTA, MAKUÁTLAN: Tefal Ultra Compact 2000W - Konyhai grill bbq sütő - CSOMAGKÜLDÉSSEL IS
- Eladó vagy cserélhető sörös korsó és sörös pohár gyüjtemény!!!
- Google Home Mini CSOMAGKÜLDÉSSEL IS, PRÓBAGARANCIÁVAL
