Crytek
Day 1 patch
ALL PLATFORM UPDATES:
Added more filters for Photo Mode
General bug fixes
General performance optimisations
General balance improvements
General polish improvements
Improved VO and subtitles timing in all languagesCONSOLE SPECIFIC UPDATES:
Further performance and memory optimisation
Tuned motion blur effects
Tuned horizontal rotation speed / acceleration on thumbsticksXBOX SPECIFIC UPDATES :
Added Dolby Atmos Support for Xbox One X
Added custom Xbox Adaptive Controller support and improved UI layoutPC SPECIFIC UPDATES:
Tuned HDR saturation
RTX Improvements / Bug Fixing
Added DLSS Support
Additional HUD removal options (coming soon to console) when playing in Ranger Mode
Added Motion Blur options (coming soon to console)ADDITIONAL PC FIXES SINCE REVIEW CODE WAS SENT:
Fixed Locking of player input after scene of rescuing Yermak
Removed v-sync option from benchmark launcher
Tuning and fixes for Atmos audio system
Fixed memory corruption in DX12
Fixed crash on launching game on old AMD CPUs
Fixed crash after changing of resolution and Shading Rate to 4k/4x on Video cards with 2Gb and less
Fixed blurred UI when DLSS is enabled
Fixed visual artifacts for RTX high mode
Fixed input lock in when patching gas mask during combat
Fixed forcing to V-Sync on after alt-tabbing the game running at maximal available resolution for the monitor
Fixed crash when pressing ALT + Tab during start videos
Fixed forcing of V-SYNC mode if the game resolution is different than the desktop
DLSS can be applied in the Benchmark
Tuned DLSS sharpness to improve image quality
Updated learned data for DLSS to improve image quality with DLSS onNext PC Upgrade: 2022
Crytek
válasz B.Á.L.!.N.T #503 üzenetére
Elsőre soha a büdös életbe nem maxolja ki senki sem egyik metrot sem. Szóval ne emészd magad emiatt. Alapból a befejezések miatt ez eleve lehetetlen hogy 1 kör alatt maxos legyen.
Crytek
válasz Fitzgerald #675 üzenetére
Ha csak végigmész mintha "cod" lenne 15 óránál nem több. A game time minden játékosnál más és más.
Crytek
válasz gainwardgs #678 üzenetére
A lényeget érti mindenki képzelj oda bármi mást akkor.. A lényeg ha nem tökölsz és nézel meg minden mm-rt 15 óra se lesz.. Ezért irtam minden ember máshogy játszik.
Crytek
válasz turbokappa #836 üzenetére
A lemezen nincs rajta a game szóval onnan nehéz lenne telepítened. CD kulcsot kell aktiválni az Epic Games Launcher programban és ott letöltened. Manapság már nagyon sok esetben csak az adott launcher exéje van a lemezen (nem is értem akkor már minek a lemez)
Crytek
Crytek
Nézd el neki. Metro témában szomorú de tényleg sok a tudatlan (most nem rád értem mert nálad valami bug lehet) de sokan szidják hogy szar mert nincs lőszer ,meg gázmaszk betét meg semmi ...Nos az ilyeneknek a tetrist ajánlom nem a Metro szériát
Érdekes én az előzőket legnehezebben vittem végig mégse volt semmi bajom,bár lehet én tudom is mit kell csinálni a játékban[ Szerkesztve ]
Crytek
Rajtam kívül valaki tolja még ezt a rakás szar MS Store-os verziót a játékból?
Ha igen sikerült megoldani a 7-8 perces töltési időt?
Crytek
Lepergett.
Jó volt, tetszett, hogy végre "nyílt" területeken lehetett kalandozni. Ezt a fegyverkraftolgatós dolgot én személy szerint az alapanyagok után kajtatás miatt DIREKT időhúzásnak tartom, mert gyakorlatilag egy deka jelentősége sincs. Az alap fegyokkal amit találsz röhögve végig lehet menni a játékon. A befejezés ügyileg sokkal "faékebb" mint az alap metrok mert ott kb walktrough alapján tolva se adta be a good endinget csak ha kb mákod volt vagy mi a rák, itt meg kb nem is tudom mit kéne csinálni a BADhez..(a jó befejezést kaptam)
A hangokat nem tudom hogyan sikerül immáron a 3. részben is elkúrni ,eszméletlen hulladék. Ezt nem tudom ,hogy ment át bármiféle ellenőrzésen. Kocsiba mellettem ül a társ beszél hozzám és mintha 500 méterre lenne olyan a feeling..gyötrelmes,de az egész játékban mindenhol.Szerintem ezt a Metro szériát halláskárosultak készíthették mert azok olyanok hogy ONLY szemből állva hallja amit mondasz meg akkor tud szájról is olvasni. Ha kicsit nem szembe vagy már a suttogok filmbe érzi magát az ember.
Sokszor inkább kikapcsoltam a hangot és toltam némán a játékot,mert kurva idegesítő
Várom steam-re. A game passos verzió a sátán műve a 8 perces töltéseivel.Next PC Upgrade: 2022
Crytek
válasz batman91 #1268 üzenetére
Bug nálam csak olyan volt hogy beragadtam sokszor "valamibe" és csak a quick load segített..+ volt hogy továbbengedett olyan pályarészre ahova nem szabadott volna "nem futott le a script" gondolom aminek kellett volna. Én hülye meg ott küzdöttem vagy 1.5 órát hogy probáljam magam visszaküzdeni ahova kellett volna de persze nem lehetett
Crytek
Van itt olyan aki acsimaxolta a játékot?
Ha igen tőlük kérdezem van valami értelme fullra felszedni minden cuccot? Tehát pl ha megtalálom a ruha fejlesztéseket gázmaszk fejlesztéseket stb, akkor fog érződni hogy na most nekem jobb van? Látni valamiben a hatásukat?
Crytek
Ez kb olyan mint az AC Origins előtti összes létező ACbe is minden fegyver köröket vert a hidden bladere mégse használtam soha mást.... MINEK ha van egy kb kifogyhatatlan valamid?
Soul Gem : Nincs szűkségem videóra én úgy játszom a játékokat ahogy én akarom... Pont ez benne a jó fog a tököm időt húzva mászkálgatni mindenféle szarárt amikor a zöld növény a "lötty" úgyis mindig küldetés utvonalba van és a tikharhoz csak az kell...
Majd ha egyszer nem lesz más és acsimaxolni akarnám biztos szedegetnék mindent... De ahogy nézem itt nem olyan könnyű a legnehezebb szint mint a korábbi metrokba így meg se fogom próbálni az acsimaxotNext PC Upgrade: 2022
Crytek
válasz batman91 #1288 üzenetére
Nem tudom mi a legnehezebb mod de a new game plusnál valamit bekapcsolva azt hiszem (ha jól olvastam) 1 halál azt az egész pályát a leges legelejéről kezded valami ilyesmi..
Nem mellesleg a többi Metró nem volt nehéz max nehézségen mert ott volt checkpoint hegyek úgy ami segít. Ezt a nem mentés nehezítést sosem értettem mire jó.. akkor legyen olyan mint a cod hogy másodpercenkét 5ösével dobálja az AI a gránátot de hogy nincs mentés az pure szopatás csak és extra időhúzásNext PC Upgrade: 2022
Crytek
válasz #75501312 #1293 üzenetére
Sajnos emiatt a new game plus kb halott ötlet. Lőszerek mindig fullon, filterek mindig fullon..gyakorlatilag eddig hozzám se tudott érni se szörny se ember.. Kb egy god mod így a game..így max az acsik gyűjtögetésének van értelme semmi másnak.
Ha ez a new game plus lepereg és még mindig nem szedik ki a game passból nekiállok legnehezebb szinten..akkor kreálok valami snipert azt 100 méterről szedek majd le mindent ugyis van ilyen acsi isMost ölöm azokat is akik megadják magukat mert a rossz endinget akarom
Crytek
válasz juliensorel #1328 üzenetére
Még nagyon drága, várunk tovább..Addig leülepszik legalább a 2 egymás utáni game passot végigjátszás. Bízom benne hogy 3 éven belül bundleba kerül.
- Autós kamerák
- Ukrajnai háború
- Videó stream letöltése
- Gaming notebook topik
- Motorola Moto G24 Power - hol van az erő?
- Milyen videókártyát?
- Helldivers 2 (PC, PS5)
