OLVASD VÉGIG ALAPOSAN MIELŐTT ÚJ HOZZÁSZÓLÁST ÍRNÁL!!!
FireGL
[Szerkesztve]Az embert a gondolkodás tette állattá...
FireGL
FireGL
AMD Phenom, Phenom-X2, Phenom-X4, Phenom-FX
[link]Az embert a gondolkodás tette állattá...
FireGL
AMD 45nm-en: [link]Az embert a gondolkodás tette állattá...
FireGL
válasz VaniliásRönk #521 üzenetére
Itt olvashatsz róla angolul: [link]
FireGL
AMD K10 party mindenki részeg: [link] kb ~30MB wmv
FireGL
Barcelona: AMD's Next Generation [link]
FireGL
AMD to launch Barcelona quad-core on September 10
AMD today sent out emails inviting analysts, media and industry representatives to what the company calls ''the most anticipated premiere of 2007''.
Barcelona will not arrive one day too early: While the company does not explicitly mention the new quad-core as the proponent of its announcement, there is little doubt what will be announced on this day. Matching a report published by the Inquirer published in June, AMD will unveil its new quad-core architecture, which the company so desperately needs to restore its competitiveness in the 2P server market and prepare itself for the arrival of Intel's Tigerton processor in the 4P segment.
If the Inquirer is right, then Barcelona will arrive with clock speeds of up to 2.0 GHz, while faster versions with up to 2.4 GHz are expected to be available during the fourth quarter of the year. If AMD keeps its promise of avoiding a paper launch, then Barcelona-based systems should be available for purchase beginning at launch or the day right after it, September 11.
The question now is when AMD will be able to follow up and bring the Barcelona architecture to the desktop. We were told by AMD representatives that Phenom will follow 60 to 90 days after Barcelona, which puts the introduction of the chip into the mid-November to mid-December time frame.
The Barcelona launch event will be held in San Francisco's Presidio, beginning at 6:30 PM on September 10.
FireGL
AMD Phenom FX91
2.4 - 2.6GHz, 2MB L2 , 2MB Shared L3, HT 3.0, Socket 1207+ /2008Q1
AMD Phenom FX90
2.2 - 2.4GHz, 2MB L2 , 2MB Shared L3, HT 3.0, Socket 1207+ /2008Q1
AMD Phenom FX80
2.2 - 2.4GHz, 2MB L2 , 2MB Shared L3, HT 3.0, Socket AM2+ /2007Q4
AMD Phenom X4 GP-7100
2.0 - 2.2GHz, 2MB L2 , 2MB Shared L3, HT 3.0, Socket AM2+ /2007Q4
AMD Phenom X2 GP-6800
2.4 - 2.8GHz, 1MB L2 , 2MB Shared L3, HT 3.0, Socket AM2+ /2008Q1
AMD Phenom X2 GP-6650
2.2 - 2.6GHz, 1MB L2 , 2MB Shared L3, HT 3.0, Socket AM2+ /2008Q1
AMD Phenom X2 GP-6550
2.0 - 2.4GHz, 1MB L2 , 2MB Shared L3, HT 3.0, Socket AM2+ /2007Q4
2007-8-14 04:45 [link]
FireGL
válasz Mackósajt #1401 üzenetére
''Ami konkrétan azóta történt, az a drezdai gyár fejlesztésének halasztása, mivel nincs rá pénzük''
Akkor ide is belinkelem mert erről a PH nem ír és így hajlamsoak vagytok hülyeségeket kitalálni. Már nem először linkelem be.
Az Europai Bizottság 262 millio euroval támogatja a Drezdai gyár bővítését: [link]
Próbáljunk meg inkább a K10-ről írni, mert így elég gáz hogy miden második-harmadik oldalon ez a flame megy.Az embert a gondolkodás tette állattá...
FireGL
válasz #95904256 #1404 üzenetére
''Az Z-RAM technológia első licencelője az AMD volt, még 2006 elején, de konkrét elképzelésekről azóta sem hallani a vállalat felől. Legkorábban az évtized vége felé jelenhetnek meg a SRAM-ot legalább részben (például a harmadszintű gyorsítótárnál) felváltó Z-RAM gyorsítótárral tervezett processzorok. A cache sűrűségének növelésére az IBM saját eDRAM (beágyazott DRAM) technológiát fejleszt, mely lehetővé tenné a logikával egy szilíciumlapkára integrálást, és hatalmas, a SRAM-hoz képest háromszor nagyobb tárak integrálását -- a vállalat 24-48 megabájtról beszélt 45 nanométeres csíkszélességű eljáráson.''
Majd kiderül, hogy ténylegesen van benne Z-RAM vagy sem.
Tripla gyorsítótár, dupla teljesítmény - jön az IBM processzorba ágyazott DRAM-ja [link]
''A vállalat az új eDRAM kereskedelmi alkalmazását a 45 nanométeres csíkszélességű gyártástechnológiára tervezi. Az IBM termékei mellett a közös félvezetőgyártási eljárás következtében az AMD, a Sony és a Toshiba processzoraiban is megjelenhet eDRAM.''
FireGL
''(mert ebben a cikkben szó nincs arról, hogy változott volna a kettő közti busz órajele)''
Több helyen szó volt róla, hogy a K10 a DDR2 1066MHz memóriákat is szabványosan fogja kezelni. Ezt pedig 200MHz-es órajel miatt nem stimmel. Mivel írták, hogy az AM2-vel is visszafelé kompatibilis lesz, lehet itt fog 200-on menni. Ha az 1066MHz-es memória sebességből következtetek akkor az AM2+ az órajelben is lehet hogy hoz változást.Az embert a gondolkodás tette állattá...
FireGL
FireGL
"Azt nem találom sehol, hogy eddig C'n'Q által levett magórajel mellett K8 esetében a memória órajele is leesett-e"
K8 esetén változik a memória órajele is a C'n'Q miatt.
Saját konfigom:
X2 4000+ alap 2100MHz mag / 700MHz ram - dual ch.
C'n'Q 1000MHz / 400MHz - single ch.Az embert a gondolkodás tette állattá...
FireGL
Új részletek az AMD következő CPU-generációjáról - Szerző: janpotocki
"Azt is jelezte korábban az AMD, hogy újabb SSE utasításokkal gyarapítja processzorai kódkészletét. A friss információk szerint az Intel által kidolgozott SSE4 készlet 50 utasításának nagy része megjelenik az AMD lapkáiban is. Az SSE4A jelű kiterjesztésből csupán az Intel speciális 64 bites funkciói fognak hiányozni, az ígéret szerint a grafikai, videofeldolgozási, 3D-s és multimédiás feladatokhoz használt rész teljes egészében kompatibilis lesz a vetélytárs chipjeivel."
FireGL
válasz Hakuoro #3436 üzenetére
X3 előnyéről már volt szó korábban is. (vagy törölték a hozzászólásaimat ?)
Most csak nagy vázlatokban lassan próbálom megírni neked, hogy értsd. Adott az AMD-nél 4 mag (natív), ha hibás 1 akkor le lesz tiltva, másik 3 működik. Intel: adott 4 mag (2x2), ha hibás az egyik dualcore egyik magja akkor a hibás dualcore rész másik magja is kuka, ergo megint másik dualcore-t kell felhasználni majd a tokozáshoz.Az hogy a hibásokat is eladják az nem értem miért bosszant ennyire. Csak egy gyenge példa: 8800GTS kártyákon is hibás a G80 mag, mégis el lett adva.
"Kiadtak egy bugos architectúrát"
Ha a TLB hibára gondolsz akkor ugyanez a hiba a Core2-nél is előfordul, és ugyanúgy javítják/javították mint amit a phenomra ígérnek. Olvasd el: >>katt<<
FireGL
Az alaplap gyártók az otthoni "virtualizáló" userek miatt adnak ki kikapcsolhatatlan patchet ? Látom elsőkézből informálódsz, hogy mi lesz a késöbbi bios-okban mert nyilvánvalóan mindenki virtualizálni fog otthon a mostanság megvett B2-es reviziós Phenomján. Főleg hogy a B3 revzióra igérik ennek a TLB bugnak a javítását és így értelmét veszti a "késöbb lassul a bug miatt".
No comment: Inkább ne írj cikket és had legyen tévhit itt a PH-n a dologgal kapcsolatban.
FireGL
Mégegyszer de már unom.
Ha kiadnak a késöbbiekben is bios-t amiben be van kapcsolva ez a patch a mostani B2-es Phenomokhoz, akkor ez mit fog számítani egy B3-as és a többi... javított revíziós Phenom prociknál ?
Vagy úgygondolod mindenki B2-vel fog nyomulni végig ?
FireGL
A Sony-ba is belefektettek az arabok és mégse fikázza őket egy iskolás gyerek se ez miatt itt a fórumon. Vagy az amd-t muszály ?
FireGL
válasz Gyuri27 #3494 üzenetére
"Az egyes árucikkekhez való "kóros tapadás" azonban a pszichológus szerint magatartás-, személyiség- és értékrendzavarokat jelez. Szerinte a márkaimádat mögött is valamilyen hiánypótlás áll..."
De még mielött valaki beleköt, én megtudom indolkolni, hogy miért raktam össze amd-s gépet.
FireGL
Zambezi stock clock
FireGL
AMD has released their AMD Family 15h Software Optimization Guide
This guide provides optimization information and recommendations for AMD Family 15h processors. These optimizations are designed to yield software code that is fast, compact, and efficient. Toward this end, the optimizations in each of the following chapters are listed in order of importance.
http://support.amd.com/us/Processor_TechDocs/47414.pdfAz embert a gondolkodás tette állattá...
FireGL
FireGL
Akkor ez a Turbos táblázat is hiteles lehet mert az alapórajeleknak ugyanazok vannak feltüntetve mint ami Gigabyte oldalán.
http://www.hardware.fr/news/11726/60-90-jours-amd-fx.htmlalap:
- AMD FX-8150 : 3.6 GHz
- AMD FX-8120 : 3.1 GHz
- AMD FX-8100 : 2.8 GHz
- AMD FX-6100 : 3.3 GHz
- AMD FX-4100 : 3.6 GHzturbo:
- AMD FX-8150 : 4.2 GHz (+600 MHz)
- AMD FX-8120 : 4.0 GHz (+900 MHz)
- AMD FX-8100 : 3.7 GHz (+900 MHz)
- AMD FX-6100 : 3.9 GHz (+600 MHz)
- AMD FX-4100 : 3.8 GHz (+200 MHz)Az embert a gondolkodás tette állattá...
FireGL
FX-8150 vs X6 1100T
http://news.mydrivers.com/picture/204512/204512_1.html
http://news.mydrivers.com/picture/204512/204512_2.html
http://news.mydrivers.com/picture/204512/204512_3.html
http://news.mydrivers.com/picture/204512/204512_4.html
http://news.mydrivers.com/picture/204512/204512_5.html
http://news.mydrivers.com/picture/204512/204512_6.html
FireGL
Amazing live demonstration of AMD FX prior to launch at #IPL3. 7GHz Gaming - Battlefield 3 and Starcraft 2 - on LN2!
FireGL
A googleban nem fogod ám megtalálni az összes külföldi webáruházat. A hazai forgalmazásról pedig érdeklődj a nagykereknél.
FireGL
A júniusi Computex bemutatón ott voltak az ECS mellett az ASUS, MSI, Sapphire és Asrock alaplapok is.
http://us.hardware.info/news/35453/mini-itx-motherboards-with-amd-kabini-soc
FireGL
Az ide nem illő hozzászólások topikja:[link]
A topik témája:
Az AMD éppen érkező, vagy jövőbeni új processzorainak kivesézése, lehetőleg minél inkább szakmai keretek között maradva.
- Ryzen 9 5950X
- Beszámítás! Intel Core i5 6500 4 mag 4 szál processzor garanciával hibátlan működéssel
- Hibátlan - AMD Ryzen 5 2600 - 6 mag 12 szál 3.4GHz + gyári hűtő
- Beszámítás! Intel Core i3 10105 4 mag 8 szál processzor garanciával hibátlan működéssel
- Beszámítás! Intel Core i3 9100 4 mag 4 szál processzor garanciával hibátlan működéssel
