Okos Otthon összefoglaló
Vodike
válasz layerke #2992 üzenetére
Ez majdnem így van, viszont a Kolléga szerintem debian STRETCH alapú raspbiant használ, amiből valamiért kimaradt egy komponens ami a Domoticz-hoz kell Libssl.so.1.0.0
We will already start by adding the library to the list of sources file. Open it
sudo nano /etc/apt/sources.list
And add this line at the end of the filedeb http://archive.raspbian.org/raspbian/ jessie main contrib non-free rpi
Save it with CTRL + X, Y. Then run these two commands to install the library
sudo apt-get update
sudo apt-get install libssl1.0.0ezek után megy.
exTiga
Vodike
válasz layerke #3437 üzenetére
Kis szórakozás után idáig jutottam, de az utolsó 4 sor megint piros..:
2018-03-04 21:30:50.690 LUA: Lat: 47.50999832Long: 19.07999992Alt: 121.0
2018-03-04 21:30:50.691 LUA:
2018-03-04 21:30:50.691 LUA: 2018-03-04 21:30:50
2018-03-04 21:30:50.691 LUA: budapest, latitude:47.368, longitude:18.986
2018-03-04 21:30:50.691 LUA: Home altitude = 98 m
2018-03-04 21:30:50.691 LUA: number Of Day = 063
2018-03-04 21:30:50.691 LUA: 2018 is not a leap year
2018-03-04 21:30:50.691 LUA: Angular Speed = 0.98562628336756 per day
2018-03-04 21:30:50.691 LUA: Declinaison = -6.3073668147583°
2018-03-04 21:30:50.691 LUA: Universel Coordinated Time (UTC)20.5 H.dd
2018-03-04 21:30:50.691 LUA: Solar Hour 21.765733333333 H.dd
2018-03-04 21:30:50.691 LUA: Altitude of the sun = -39.948450443528°
2018-03-04 21:30:50.692 LUA: Angular hourly = -146.486°
2018-03-04 21:30:50.692 LUA: Azimuth of the sun = 314.28582914987°
2018-03-04 21:30:50.692 LUA: Duration of the sunstroke of the day = 11.08 H.dd
2018-03-04 21:30:50.692 LUA: Radiation max in atmosphere = 1382.63 W/m²
2018-03-04 21:30:50.692 LUA: Local relative pressure = 1011 hPa
2018-03-04 21:30:50.692 LUA: Absolute pressure in atmosphere = 999.2 hPa
2018-03-04 21:30:50.692 LUA: Coefficient of mitigation M = 799.38217875245 M0:790.05209991043
2018-03-04 21:30:50.692 LUA: curl "http://www.ogimet.com/cgi-bin/getsynop?block=12843&begin=201803041900"
2018-03-04 21:30:50.863 LUA: ogimet:12843,2018,03,04,19,00,AAXX 04191 12843 41656 71901 11028 21081 39938 40114 53008 70222 875// 333 87633 555 10067=
12843,2018,03,04,20,00,AAXX 04201 12843 41558 71601 11028 21081 39941 40118 52010 70322 875// 333 87630 555 10067=
2018-03-04 21:30:50.864 LUA: Station SYNOP = 12843
2018-03-04 21:30:50.864 LUA: 7 Octa
2018-03-04 21:30:50.864 LUA: Kc = 0.52369115797991
2018-03-04 21:30:50.864 LUA: Direct Radiation = 0 W/m²
2018-03-04 21:30:50.864 LUA: Scattered Radiation = 0 W/m²
2018-03-04 21:30:50.864 LUA: Total radiation = 0 W/m²
2018-03-04 21:30:50.864 LUA: Total Radiation in lux = 0 Lux
2018-03-04 21:30:50.864 LUA: and at last, Total weighted lux = 0 Lux
2018-03-04 21:30:50.865 EventSystem: Fetching url http://127.0.0.1:9999/json.htm?type=command¶m=udevice&idx=21&nvalue=0&svalue=0...
2018-03-04 21:30:50.865 EventSystem: Fetching url http://127.0.0.1:9999/json.htm?type=command¶m=udevice&idx=22&nvalue=0&svalue=314...
2018-03-04 21:30:50.865 EventSystem: Fetching url http://127.0.0.1:9999/json.htm?type=command¶m=udevice&idx=23&nvalue=0&svalue=-40...
2018-03-04 21:30:50.865 EventSystem: Fetching url http://127.0.0.1:9999/json.htm?type=command¶m=udevice&idx=24&nvalue=0&svalue=88...
2018-03-04 21:30:50.865 EventSystem: Script event triggered: octa
2018-03-04 21:30:51.071 Error: Error opening url: http://127.0.0.1:9999/json.htm?type=command¶m=udevice&idx=21&nvalue=0&svalue=0
2018-03-04 21:30:51.075 Error: Error opening url: http://127.0.0.1:9999/json.htm?type=command¶m=udevice&idx=22&nvalue=0&svalue=314
2018-03-04 21:30:51.080 Error: Error opening url: http://127.0.0.1:9999/json.htm?type=command¶m=udevice&idx=23&nvalue=0&svalue=-40
2018-03-04 21:30:51.088 Error: Error opening url: http://127.0.0.1:9999/json.htm?type=command¶m=udevice&idx=24&nvalue=0&svalue=88[ Szerkesztve ]
exTiga
Vodike
Bánatomban töröltem a domoticzban az Eventekből az octa lua scriptet és létrehoztam manuálisan a file-t itt a leírtak szerint: ~/domoticz/scripts/lua/script_time_SolarSensor.lua
terminalban, nanoval bemásoltam a scriptet, látszólag ¶m van, de a domoticz logban még mindig Error opening url: http://127.0.0.1:9999/json.htm?type=command¶m=udevice&idx=24&nvalue=0&svalue=100
pedig az adatokat szépen olvassa, minden tök jó, de ezt valamiért nem akarja. Hova ragadhatott be? Hogyan gyomláljam ki?
exTiga
Vodike
Koszonom, ki fogom probalni. Egyebkent odaig jutottam es adtam fel egyelore, hogy az eredeti layerke scripttel, annyi modositassal, hogy a @param reszt atvarialtam az altalad is emlitett modon, mukodik rendesen. Ami nem mukodik, hogy a lekert adatokat visszairja a Domoticzba. Az mindig errorra fut. Viszont, ha manualisan kimasolom es berakom a linket egy bongeszobe, akkor minden ok, jon az updated device felirat es frissiti az adatokat a Domoticzban. Mar csak azon toron magam, hogy ez automatan miert hasal el...
exTiga
Vodike
Másnál sem megy a domoticz beta update?
Updating to latest beta version...
Please Standby...
--2018-04-05 07:35:54-- http://www.domoticz.com/download.php?channel=beta&type=release&system=linux&machine=armv7l
www.domoticz.com (www.domoticz.com) feloldása… 185.27.142.198
Csatlakozás a következőhöz: www.domoticz.com (www.domoticz.com)[185.27.142.198]:80… kapcsolódva.
HTTP kérés elküldve, várakozás válaszra… 301 Moved Permanently
Hely: https://www.domoticz.com/download.php?channel=beta&type=release&system=linux&machine=armv7l [következik]
--2018-04-05 07:35:54-- https://www.domoticz.com/download.php?channel=beta&type=release&system=linux&machine=armv7l
Csatlakozás a következőhöz: www.domoticz.com (www.domoticz.com)[185.27.142.198]:443… kapcsolódva.
HIBA: „www.domoticz.com” tanúsítványa nem megbízható.
HIBA: „www.domoticz.com” tanúsítványának nincs ismert kibocsátója.
gzip: stdin: unexpected end of file
tar: Child returned status 1
tar: Error is not recoverable: exiting now
Restarting Domoticz... (please standby...)A www.domoticz.com oldalon a downloads menu sem megy nekem, a domoticzot webről sem tudom frissíteni. Remélem nem az icinga2 telepítése szól bele
exTiga
Vodike
Most, hogy belaktam egész jól a rendszerem, gondoskodnom kellene a backupról. Ki mit használ a teljes sd backupjára? Nem pont ide vágó téma, de szerintem fontos lehet. Raspbian rendszer az alap, azon fut a Domoticz.
Jó lenne kompletten az SD-t valami felhőbe rakni vagy nem is tudom. Elég a home könyvtár?
exTiga
Vodike
Sziasztok! Remélem nem probléma az off, de megköszönném, hogyha segítenétek szakdolgozatom azzal, hogy kitöltitek a kérdőívem. A téma okosotthonokhoz kapcsolódik. Köszönöm!
exTiga
Vodike
válasz layerke #4494 üzenetére
A 3 kapcsolo csak a fizikai mukodes miatt szukseges? Azert kerdezem, mert vettunk egy hazat ami mar elo van keszitve elektromos redonyre, de nem fejezte be az elozo tulaj. Magyaran minden ablaknal, kivulrol oda van vezetekezve az erosaram. Amikor kerdeztem tole, hogy mi volt a cel, akkor az rf vezerlest mondta. Na most en z-wave megoldassal szeretnem, kb ahogyan leirtad, max annyi kulonbseg, hogy qubino roller shuttert neztem ki es nem tudok fizikai kapcsolod mar odatenni. Aotec-et tervezek en is bekotni gw-nek az rpi-domoticz rendszerembe.
exTiga
Vodike
válasz layerke #4497 üzenetére
Akkor megnyugodtam. Igen en is az aeotec sajat akksis USB-s GW-jet neztem ki. Ahogy nezem a Fibaro roller shutter es a Qubino rs egy arban van, ugyhogy mindegy melyiket veszem meg. Jol ertem, hogy ebben az esetben kb a legolcsobb buta motor is eleg a megfelelo alu redonnyel? Viszont, ha egyszer eljatszom a veszelyes bindelest, utana mar remelhetoleg nem surun kell. Ugy gondoltam, hogy az rs-t a redony tokjaba rakom, kb ott tud lathatatlan lenni, no meg oda van kivezetekelve franc se tudja honnan az erosaram. Abban meg mar csak remenykedni tudok, hogy 0 is van...meg nem neztem ilyen szemmel ra, majd csak juliusban tudom tuzetesebben atnezni.
exTiga
Vodike
Nagyon köszi layerke!
exTiga
Vodike
Másnak is mostanában folyamatosan offline-ba áll a domoticz? Naponta meghal..most beizzítottam a watchguardot, hátha. Lehet visszaállok a stable-re, csak már olyan jól belaktam...
exTiga
Vodike
válasz layerke #7123 üzenetére
Mi lett a kiválasztott? Egy ismerősömnél Zipato rendszert pakoltam össze ezekkel a modulokkal: Zigbee, Z-Wave és 433. Eszközök van neki sokféle, Fibaro, Sonoff, 433-as cuccok, stb. Eléggé meggyőzött a rendszer és annyira nem drága. 50 volt a hub és 15-15 ezer a két kiegészítő modul (zigbee, 433). Z-wave-et alapból tud.
watchdog-ot izzítottam be, nem a watchguardot :-)
exTiga
Vodike
Mivel már eléggé szétbarmoltam a sok próbbálgatással a raspbianom, gondoltam újrahúzom és felteszem újra a domoticzot, viszont valamiért nem megy:
pi@szszmpi:~ $ sudo curl -L install.domoticz.com | bash
% Total % Received % Xferd Average Speed Time Time Time Current
Dload Upload Total Spent Left Speed
bash: sor: 1: szintaktikai hiba „newline” váratlan token közelében:--:-- 0
bash: sor: 1: `<!DOCTYPE html>'
100 10974 100 10974 0 0 126k 0 --:--:-- --:--:-- --:--:-- 126k
(23) Failed writing body
pi@szszmpi:~ $Mi lehet a baj? Évek óta sokszor telepítettem és mindig OK volt.
exTiga
Vodike
válasz Degeczi #7772 üzenetére
<!DOCTYPE html>
<html lang="en">
<head>
<title>Domoticz</title>
<meta charset="UTF-8">
<meta http-equiv="cache-control" content="max-age=0" />
<meta http-equiv="cache-control" content="no-cache" />
<meta http-equiv="expires" content="0" />
<meta http-equiv="expires" content="Tue, 01 Jan 1980 1:00:00 GMT" />
<meta http-equiv="pragma" content="no-cache" />
<meta name="description" content="Domoticz is a lightweight Home Automation System">
<meta name="keywords" content="Domotica, Home Automation, RFXCOM, Zwave, Hue, temperature sensors, weather sensors, open source, raspberry pi">
<link rel="shortcut icon" href="/favicon.ico" type="image/x-icon">
<link rel="icon" href="/favicon.ico" type="image/x-icon">
<link rel="stylesheet" href="css/reset.css" type="text/css" media="screen">
<link rel="stylesheet" href="css/style.css" type="text/css" media="screen">
<link rel="stylesheet" href="css/grid.css" type="text/css" media="screen">
<script src="js/jquery-1.6.3.min.js" type="text/javascript"></script>
<script src="js/cufon-yui.js" type="text/javascript"></script>
<script src="js/cufon-replace.js" type="text/javascript"></script>
<script src="js/Kozuka_Gothic_Pro_OpenType_300.font.js" type="text/javascript"></script>
<script src="js/Kozuka_Gothic_Pro_OpenType_500.font.js" type="text/javascript"></script>
<script src="js/FF-cash.js" type="text/javascript"></script>
<script type="text/javascript" src="js/jquery.easing.1.3.js"></script>
<script type="text/javascript" src="js/tms-0.3.js"></script>
<script type="text/javascript" src="js/tms_presets.js"></script>
<script src="js/jcarousellite_1.0.1.js" type="text/javascript"></script>
<script>
(function(i,s,o,g,r,a,m){i['GoogleAnalyticsObject']=r;i[r]=i[r]||function(){
(i[r].q=i[r].q||[]).push(arguments)},i[r].l=1*new Date();a=s.createElement(o),
m=s.getElementsByTagName(o)[0];a.async=1;a.src=g;m.parentNode.insertBefore(a,m)
})(window,document,'script','//www.google-analytics.com/analytics.js','ga');
ga('create', 'UA-67357724-1', 'auto');
ga('send', 'pageview');
</script>
</head>
<body>
<!--==============================header=================================-->
<header>
<div class="menu-row">
<div class="main">
<nav class="wrapper">
<ul class="menu">
<li><a class="active" href="/">Home</a></li>
<li><a href="/downloads/">Download</a></li>
<li><a href="https://www.domoticz.com/DomoticzManual.pdf">Manual</a></li>
<li><a href="https://github.com/domoticz/domoticz">Source Code</a></li>
<li><a href="https://www.domoticz.com/wiki/">Wiki</a></li>
<li><a href="https://www.domoticz.com/forum/">Forum</a></li>
<li><a href="index.html"><img src="images/uk.png"</a></li>
<li><a href="Domoticz_es.html"><img src="images/esp.png"</a></li>
<li><a> </a></li>
</ul>
</nav>
</div>
</div>
<div class="row-bot">
<div class="row-bot-bg">
<div class="main">
<div class="wrapper p6">
<h1><a>Domoticz</a></h1>
<h2>Control at your finger tips.</h2>
</div>
<div class="slider-wrapper">
<div class="slider">
<ul class="items">
<li>
<img src="images/slider-img1.jpg" alt="">
</li>
<li>
<img src="images/slider-img2.jpg" alt="">
</li>
<li>
<img src="images/slider-img3.jpg" alt="">
</li>
<li>
<img src="images/slider-img4.jpg" alt="">
</li>
<li>
<img src="images/slider-img5.jpg" alt="">
</li>
<li>
<img src="images/slider-img6.jpg" alt="">
</li>
</ul>
</div>
</div>
<div class="wrapper">
<figure class="img-indent2"><img src="images/home.png" alt=""></figure>
<div class="extra-wrap">
<strong class="text-1">Domoticz is a <a class="link-1">Home Automation System</a> that lets you monitor and configure various devices like: <a class="link-1">Lights, Switches</a>, various sensors/meters like <a class="link-1">Temperature, Rain, Wind, UV, Electra, Gas, Water</a> and much more. Notifications/Alerts can be sent to any mobile device.</a></strong>
</div>
</div>
</div>
</div>
</div>
</header>
<div class="main">
<div class="container_12">
<article class="grid_4">
<h3 class="prev-indent-bot">Free / Open Source</h3>
<h6 class="p1">Linux/Windows/Embedded Devices</h6>
<p class="img-indent-bot">This system is designed to operate in various operating systems. The user-interface is a scalable HTML5 web frontend, and is automatically adapted for Desktop and Mobile Devices.<br>Compatible with all browsers. Note for Internet explorer users: You need version 10+.</p>
</article>
<div class="indent-left">
<h3 class="p1">Some Information</h3>
<ul class="list-1">
<li>Hardware: <a href="https://www.rfxcom.com">RFXCOM Transceiver</a>, Z-Wave, P1 Smart Meter, YouLess Meter, Pulse Counters, 1-Wire, EnOcean, and a lot more....</li>
<li>Extended logging</a></li>
<li>iPhone / Android push notifications</li>
<li>Auto Learning sensors/switches</li>
<li>Manual creation of switch codes</li>
<li>Share / Use external devices</li>
<li>Designed for simplicity</li>
</ul>
</div>
</article>
<div class="indent-left2">
<h3>Donations</h3>
Donations are more than welcome and will be used to buy new hardware, devices, sensors and hosting<br>
If you like the product or encourage the development, please use the button below.
<p>
<form action="https://www.paypal.com/cgi-bin/webscr" method="post">
<input type="hidden" name="cmd" value="_s-xclick">
<input type="hidden" name="encrypted" value="-----BEGIN PKCS7-----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-----END PKCS7-----
<input type="image" src="https://www.paypalobjects.com/en_US/i/btn/btn_donateCC_LG.gif" border="0" name="submit" alt="PayPal - The safer, easier way to pay online!">
<img alt="" border="0" src="https://www.paypalobjects.com/nl_NL/i/scr/pixel.gif" width="1" height="1">
</form>
</p>
</div>
</article>
</div>
</div>
</div>
<!--==============================footer=================================-->
<footer>
<div class="main">
<div class="aligncenter">
<p class="p0">Domoticz © 2012-2018 </p>
</div>
</div>
</footer>
<script type="text/javascript"> Cufon.now(); </script>
$(window).load(function(){
$('.slider')._TMS({
duration:1000,
easing:'easeOutQuad',
preset:'diagonalExpand',
slideshow:5000
</script>
</body>
</html>
pi@szszmpi:~ $exTiga
- Veszprém és környéke adok-veszek-beszélgetek
- NVIDIA GeForce RTX 3080 / 3090 / Ti (GA102)
- Yettel topik
- GTA VI
- Megrendszabályozza a Pornhubot az EU
- Időjárás állomás - keress napi 5 dollárt!
- Részletfizetés. Bontatlan. noblechairs LEGEND székek azonnal . 24 hónap garancia . +36301300000
- Csúcsminőségű biztonsági kültéri okoskamera félár alatt
- ArenaRacer Craftsman Gamer szék
- Részletfizetés. Bontatlan. noblechairs EPIC székek azonnal . 24 / 36 hónap garancia . +36301300000
