sad_Vamp
lovi27 #10658 üzenetére
egyelőre 3assal vagy 4ess-el nyomom, nem is tudom....
Persze lehetne dockerezni.... de őszintén: kakáljanak sünt... mert ez a docker dolog rohadtul nem felhasználó barát, nem egyszerű, és nem hibamentes.“When the flaws of the system are exposed, it is usually the irritant who gets cast out.”
sad_Vamp
Need HALP!
"Failed to execute command 'export PATH=/bin:/sbin:/usr/bin:/usr/sbin:/usr/local/bin:/usr/local/sbin; export LANG=C.UTF-8; systemctl restart 'sharedfolders-wii.mount' 2>&1' with exit code '1': Assertion failed on job for sharedfolders-wii.mount."
nem tudok további mappákat megosztani, a fenti hibaüzenetet kapom amikor "apply"-znám.
OMV 4.1.26-1
ötletek?“When the flaws of the system are exposed, it is usually the irritant who gets cast out.”
sad_Vamp
lovi27 #10766 üzenetére
yep próbáltam más HDD-t, meg más mappát, akkor is ez:
Failed to execute command 'export PATH=/bin:/sbin:/usr/bin:/usr/sbin:/usr/local/bin:/usr/local/sbin; export LANG=C.UTF-8; systemctl restart 'sharedfolders-wii.mount' 2>&1' with exit code '1': Assertion failed on job for sharedfolders-wii.mount.“When the flaws of the system are exposed, it is usually the irritant who gets cast out.”
sad_Vamp
Itt a full report:
Error #0: OMV\ExecException: Failed to execute command 'export PATH=/bin:/sbin:/usr/bin:/usr/sbin:/usr/local/bin:/usr/local/sbin; export LANG=C.UTF-8; systemctl restart 'sharedfolders-wii.mount' 2>&1' with exit code '1': Assertion failed on job for sharedfolders-wii.mount. in /usr/share/php/openmediavault/system/process.inc:182 Stack trace: #0 /usr/share/php/openmediavault/system/systemctl.inc(86): OMV\System\Process->execute(Array, 1) #1 /usr/share/php/openmediavault/system/systemctl.inc(160): OMV\System\SystemCtl->exec('restart', NULL, false) #2 /usr/share/openmediavault/engined/module/sharedfolders.inc(66): OMV\System\SystemCtl->restart() #3 /usr/share/openmediavault/engined/rpc/config.inc(194): OMVModuleSharedfolders->startService() #4 [internal function]: OMVRpcServiceConfig->applyChanges(Array, Array) #5 /usr/share/php/openmediavault/rpc/serviceabstract.inc(123): call_user_func_array(Array, Array) #6 /usr/share/php/openmediavault/rpc/serviceabstract.inc(149): OMV\Rpc\ServiceAbstract->callMethod('applyChanges', Array, Array) #7 /usr/share/php/openmediavault/rpc/serviceabstract.inc(565): OMV\Rpc\ServiceAbstract->OMV\Rpc\{closure}('/tmp/bgstatus0E...', '/tmp/bgoutputp7...') #8 /usr/share/php/openmediavault/rpc/serviceabstract.inc(159): OMV\Rpc\ServiceAbstract->execBgProc(Object(Closure)) #9 /usr/share/openmediavault/engined/rpc/config.inc(213): OMV\Rpc\ServiceAbstract->callMethodBg('applyChanges', Array, Array) #10 [internal function]: OMVRpcServiceConfig->applyChangesBg(Array, Array) #11 /usr/share/php/openmediavault/rpc/serviceabstract.inc(123): call_user_func_array(Array, Array) #12 /usr/share/php/openmediavault/rpc/rpc.inc(86): OMV\Rpc\ServiceAbstract->callMethod('applyChangesBg', Array, Array) #13 /usr/sbin/omv-engined(537): OMV\Rpc\Rpc::call('Config', 'applyChangesBg', Array, Array, 1) #14 {main}
ezért utálom a linux-ot én ebből SEMMIT sem értek“When the flaws of the system are exposed, it is usually the irritant who gets cast out.”
sad_Vamp
lovi27 #10781 üzenetére
vlmi RRD cuccal lesz para....
Checking all RRD files. Please wait ... Cannot create socket to [localhost]:2812 -- Connection refused ERROR: Command '['monit', 'stop', 'rrdcached']' returned non-zero exit status 1hogy lehet ezt kidobni majd újra berakni?
sad_Vamp
Ajj, de bátor itt mindenki!
nekem 2-3 IT-t tanult ember sem tudott segíteni abban amit dockerrel akartam anno....
A Linus tech tips-es leírás lett volna az alap: STEAM library (2-3 gép van, ne kelljen már mindre külön lehúzni a 30+ gigákat). Bevallom volt ott 1 kis csavar, de már nem emlékszem pontosan mi lett volna az, de mindenki azt mondta az elején, "hisz ez egyszerű" a végén meg mind arra jutott "figyi nincs erre időm (értsd: fogalmam sincs róla), olvasd át a manualt (ja 65 meg 100 oldalakt) és abból majd megérted és meg tudod csinálni"
Hát "a lóf*szt mama!" ha valamihez ennyit kell művelődni az
ad1. NEM FELHASZNÁLÓ BARÁT
ad2. minden csak NEM EGYSZERŰ
ad3. mivel ennyit kell mókolni vele nagy valószínűséggel NEM is STABILAztán volt amikor a Nextcloudot akartam felrakni dockerből... követtem a híres technollájfdad-et akit itt úgy annyira ajnároztok... úgy szétb*szta a rendszert, hogy rakhattam újra! A Vége az lett, hogy a nextcloudra inkább vettem külön egy Odroid HC-t.
Amúgy szomorú megfigyelésem, hogy a linuxos "bagázs" is egyre TREHÁNYABB. Rég nem igaz, hogy a linux milyen atom stabil, meg 1x kell beállítani, aztán már megy meg stb.
Több ízben történt már meg, hogy 1 "okos" update, úgy szétcs*szte az adott rendszert hogy nyomozhattam.
És végül ami szerintem legszomorúbb a jelenlegi Linuxos világban... ezeknek a nyomozásoknak a vége az, hogy úgyse találod meg a hibát, vagy setleg találsz mondjuk 10 féle megoldást, kipróbálod mind a 10-et. -na jó nem, mert az 5-6nál már igazából besokallsz. A végeredmény pedig az, hogy sokkal gyorsabb, ha újra rakod az egészet.Most is, vicc, hogy a meglévő mappáim meg vannak gyönyörűen osztva, újat pedig NEM TUDOK hozzá adni, mert az "APPLY" gomb megnyomása után hülyét kap a rendszer (pedig pár SAJÁT file, ide-oda másolásán kívül, MC+Putty semmit nem csináltam).
A nextcloud szintén, nyomtak rá egy olyan update-ot ami elbarmolta az egész php7-es felületet, 2nap szórakozás után sem találtam rá megoldást, végül fél nap míg újra felraktam.
(külön vicces volt, hogy sok user-nek előjött kérdezték, hogy mi ez, a hivatalos support válasz az volt "egyedül csinálom a fork-ot, örüljetek, hogy ez van pofa be! rakjátok fel újra a kövi updétttel meg majd javítom")én csak ennyit szerettem volna hozzáfűzni az egész dejó a docker és mégjobb a linux témához.... kicsit mintha a win95felé közelítenénk és nem előre.
sad_Vamp
Na, mivel elfogyott a türelmem a hiba kereséssel/javítással kapcs. term. ÚJRA INSTALLÁLTAM A RENDSZERT....
ma kidobott egy csomó udpade-t, de a vége ilyen szomorkás lett:>>> *************** Error ***************
Invalid RPC response. Please check the syslog for more information.
Restarting engine daemon ...
Updating locale files ...
Updating file permissions ...
Purging internal cache ...
Exception ignored in: <function WeakValueDictionary.__init__.<locals>.remove at 0x7f60adb057b8>
Traceback (most recent call last):
File "/usr/lib/python3.5/weakref.py", line 117, in remove
TypeError: 'NoneType' object is not callable
Done ...ötletek mi a túró ez? miért van, hogy lehet javítani!?
Mert ez már rohadtul tiszta rendszer, ez már egyszerűen NEM LEHET USER ERROR!
Ennél tisztábra nem lehet megoldani, még 1 HDD sincs csatolva.... ez a weakref.py már előzőleg is kísértett.... és valószínűleg a 2812-es port volt többek közt az előző probléma okozójaMost ez ilyen lesz? ennyit tud? Rakjak ubuntut és simán osszam meg a HDD-ket?
(nem szólnák semmit ha vlmi harmat gyenge SOC-ról futtatnám a rendszert, de egy teljes értékü kabini procis PC-ről van szó. Kezdek rettentően belefáradni a nyomozásba[ Szerkesztve ]
sad_Vamp
vadkörte #10862 üzenetére
elméletben végigment.... nincs több update, ha frissítek, de ezeket irja a végén.... amint látod ott a "Done".... csak most fogalmam sincs neki álljak-e újra configurálni az egészet... ha végül megint össze fog omlani.
sad_Vamp
sad_Vamp
az előző premissionok, kiosztások, bármi.... az megmarad a file-rendszerben, vagy csak a linux/OMV tárolja?
A kérdés arra irányul kell(ene) e bármit futtatni a fileokon, mielőtt újra megpróbálok mappákat megosztani?“When the flaws of the system are exposed, it is usually the irritant who gets cast out.”
sad_Vamp
lovi27 #10890 üzenetére
dehogy sikerült.... most tette magát megint tönkre az OMV GPARTED-del...
Sima resize volt.... erre most nem találja a swapot.... (amúgy nemértem... mert régebben a swap ment előre, ez a szar meg hátra teszi..... de még csak a fizikai helye sem változott csak közé ment 1 HDD.... egyre jobban rühellem az OMV-t, nevetséges, hogy nincs a telepítőbe 1 normális particionál, nevetséges, hogy szánalmas hibákkal jön ki, nevetséges, hogy semmiből-sámli elromolhat az apply gomb.... meg satöbbi.... "kicsit" unom már....“When the flaws of the system are exposed, it is usually the irritant who gets cast out.”
sad_Vamp
Kinsiinoo #10895 üzenetére
persze....HW hiba.... azért hibás a PHP modul meg azért nem megy a monitoring és azért vannak ezek a hibák másoknak ha utána nézel ugye?
amúgy azt esetleg elismerem, hogy mondjuk az AMD-t szarul támogatja a Linux közösség.... az benne lehet a pakliban. amúgy meg a 2essel bőven jól működött minden. a 3astól kezdődtek a problémák.“When the flaws of the system are exposed, it is usually the irritant who gets cast out.”
sad_Vamp
Ha USB-re raknám a nyavalyás OMV-t akkor tényleg nem lehet USB-ről USB-re a gépben?
TDL - mondott ilyesmit a videójában.
Ki milyen USB kulcsal használja: USB2 vagy USB3?“When the flaws of the system are exposed, it is usually the irritant who gets cast out.”
sad_Vamp
Kinsiinoo #10902 üzenetére
nanana! A ryzen az újdonság... ez 1 alaplapra forraszott kabini, A4 mittoménmi (ha emlékezetem nem csal)... ITX AsRock alaplap. És igen, merem állítani, hogy minden rendben van, mert bármikor amikor más rendszert (Ubi, Mint, Ubi Server, stb) pakoltam rá ment, csak ez a nyomorult OMV hepciáskodik.... és amint már irtam:
ezek a gondok NEM CSAK NEKEM jöttek elő. Ezek nem olyan relytéjes random hibák hanem hiba ha fentebb olvastad a koléga meg is találta az 1ikre a dolgot. Arról a port dologról is több helyen olvashatsz, ez sem egyedi dolog. stb.stb.stb.
örülök hogy nektek minden flottul megy, én is ezt szeretném.... rohadtul nem élvezem, és nem szeretem, hogy folyton fórumokat kell bújnom, meg újra installálgatni, meg fene tudja aztán akkor se megy... aztán reinstall, aztán megint a Gparted cseszik el valamit (vagy én vele, bár érdekes bármely másik rendeszeren ha így csinálom megy, csak ezen a vackon nem...)
de a 3as óta nem barátok a gépemmel.... és nem tudom miért...“When the flaws of the system are exposed, it is usually the irritant who gets cast out.”
sad_Vamp
Flowtation #10919 üzenetére
hát én nem tudom, de nekem a weakref.py sosem hagyta abba.... viszont a felkinált leírás működik.
sad_Vamp
lovi27 #10921 üzenetére
értem én a célzást....az a baj hogy hülyének nézel.... a phyton változtatást pl. pont csont nélkül megcsináltam....
a Gparted meg szétcseszte a rendszert, pedig direkt nem irtam számokat, csak a csúszkát vittem odébb, bő 30GB hagyva a rendszernek... erre fel az OMV azzal indul hogy nem találja a swap file-t.... pedig a swap részhez hozzá sem volt nyúlva.... én elhiszem, hogy nem hiszed.... de attól még így volt. Pont ezért agyalok rajta, hogy leszarom, és kulcsra rakom a rendszert, és akkor cseszheti ...........
Ha az egész OMV install nem lenne 1 nagy PUTRI akkor nem kellene ilyen szarságokkal foglalkozni 10évvel ezelőtt már lehetett normálisan particionálni egy UHU-ban vagy UBUNTUBAN .... és 1szer se fordult elő, hogy letörtöltem volna olyan particiót amit nem kellett volna (sőt ez most sem történt meg!!!)... szóval ennyi.
sad_Vamp
Flowtation #10926 üzenetére
.... a gond ott van hogy a 4esről beszélek
sad_Vamp
Flowtation #10928 üzenetére
ha jól emlékszem, 2.1-el száltam fel az OMV vonatra.... 3astól kezdőtek a furaságok, most a 4esnél tetőzött.
sad_Vamp
sad_Vamp
azt tudjuk, hogy a 4.1.22-es OMVnél miért frissebb a dátum mint a 4.1.3-nál? ez megint valami különleges okosság?
sad_Vamp
nagyfejü #11000 üzenetére
Úgy néz ki felkalapáltam az OMV-t 1 USB kulcsra és most arról megy, reméljük fog is (flash memory plugin élesítve).
Kérdés a megosztással kapcsolatos: lehet úgy megosztani mappát, hogy azt csak 1 adott felhanszáló lássa? (aki tagja az users groupnak de a többi usernek nem kéne látni, viszont ezt a felhasználót sem szeretném kidobni az users-ből) ha igen mi lenne ennek a pontos mennete?[ Szerkesztve ]
sad_Vamp
lovi27 #11008 üzenetére
Nem, sajna nem.... tegnap vettem észre hogy a torrent még nincs bekapcsolva....
bekapcsoltam, transgui csatlakozott, torrent indít --> Permission denied...
oké mondom, biztos nincs jogosultság beállítva, nem is volt, kipipáltam mind2 debian-transmission-t.
... akkor sem megy...
aztán már próbálam mindent, hogy ne a root legyen a tulaj, meg stb.
akkor már a transgui sem engedett be (pedig a jelszó maradt) vagy újra permission denied...
kezdem komolyan hülyén érezni magam“When the flaws of the system are exposed, it is usually the irritant who gets cast out.”
sad_Vamp
lovi27 #11024 üzenetére
tudom hogy úgyanaz, azért se értem.
Kidobtam, majd visszaraktam a bittorrentet, beállítottam az RPC-t.... de a Transmission GUI akkor sem csatlakozik, pedig a port jó, a jelszó és a kód is jó.“When the flaws of the system are exposed, it is usually the irritant who gets cast out.”
sad_Vamp
lovi27 #11026 üzenetére
Beindult, a cím is jóvolt meg legelősször a hostnév is... aztán kövi próbálkozásnál nem, aztán megint igen
na mind1... szóval nem tudom mi lehetett a gond, esetleg az hogy legelső alkalommal később adtam hozzzá a debian-transmission-t és arra már nem reagált megfelelően... vagy nem tudom.... lényeg hogy végre megy, most már csak 1 image-t kell csinálni a kulcsról.
Aztán kipróbálom azt a részt is ami a flashmemory pluginban le van írva... ha netán sikerül "read only"-ra raknom akkor csak vissza teszem az image-t....aztán ha sikerül ez a flash kiegészítés dolog, akkor újra lementem az imaget
utána jöhet a csak én férekhozzá directory....
és ha az is megvan akkor 1 végleges mentés.... és aztán lehet évente kulcsot cserélni.BTW. most kulcsról úgy indul a cucc hogy "emergency mode" csak ctrl+D után indul el normálisan, ennek mi lehet az oka, tudja valaki?
sad_Vamp
Hosszú idő után, rendes működéssel, ez fogadott
[link]aztán kikapcs-bekapcs után, pedig ez:
[link]a rendszer USB-n volt, akkor ez most azt jelenit, hogy megdöglött az USB?
vagy még van valami lehetőség hogy működjön?
Van már valami mód hogy tovább/jobban működjön USB-ről a rendszer?
(szívesen raknám én HDD-re mint régen, de amióta ezaz új verzió van, nem tudom felparticionálni a gépemen)[ Szerkesztve ]
sad_Vamp
lovi27 #13097 üzenetére
futtatnák én, de fogalmam sincs hogy kell ha beírtam hogy FSCK akkor sem írt ki semmi okost.... próbáltam kérdőjellel is a végén úgy se lettem okosabb
írtam hogy nem HDD, hanem USBarról ment a rendszer, mert 3.x óta nem tudom felrakni a rendszert HDD-r és be particionálni mellé a maradék helyet. (mindig valami baja volt, sosem működött, ha követtem a leírást, ha nem, sok féle képp próbáltam.... ha emlékeztek morogtam is miatta eleget. [valószínű az AMD chippel nincs jóban annyira az OMV, vagy nem tudom] )
sad_Vamp
lovi27 #13103 üzenetére
Hát le felület tesztelném, de nincs most semmin linuxom azt hiszem
Win alatt pedig a ext4...aztán tesztelhetem... ha jól gondolom.
na kb fél órát nyomtam a Y gombot.... mert a -py sem a -ay nem engedete hogy menjen....
Sok cifrának tűnő hiba volt:
sok szám 0 helyet, vlmi ref számok nem ültek, dtime dolgok se tetszettek neki, találta 2140-e filet amit kijavjtott 1970-re meg csomó minden corrupt meg nem jó méret meg nem tudom....
szóval miután lefutott a fsck, újra indítottam a gépet: kernel panic.
Szóval azthiszem kijelenthetjük, hogy kinyíródott az USB.“When the flaws of the system are exposed, it is usually the irritant who gets cast out.”
sad_Vamp
tama777 #13111 üzenetére
Igen csak a particionálással van gond és míg az első pár verziónál nem volt, a 3.x-től (nem tudom pontosan) sajnos már van...
és tippem az, hogy mivel ha követtem particionálási/install útmutatót, ha nem (próbáltam alternatív utakat), akkor sem ment...
Szóval arra jutottam, hogy lehet hogy az AMD-s alaplap miatt van ez.“When the flaws of the system are exposed, it is usually the irritant who gets cast out.”
sad_Vamp
Érdemes felrakni az OMV 5-öst? Jobb mint a 4-es?
nekem 3 dolog fontos: régi SMB azzal a sima paranccsal fusson, t-or-re-nt menjen, és a DLNA.
A features-ben mintha a DLNA-t kivették volna?!“When the flaws of the system are exposed, it is usually the irritant who gets cast out.”
sad_Vamp
sztanozs #13121 üzenetére
és mennyire szopás az felrakni?
külön dedikált HDD-m van torrentnek, és szeretnék hozzáférni win alól is meg MAC alól is term. normális netdrive-ként.
mert én egyszer próbáltam ezt a dockert, de 2hét és 2 linux szaki után hagytam a francba, máig nincs megvalósítva amit szerettem volna.“When the flaws of the system are exposed, it is usually the irritant who gets cast out.”
sad_Vamp
Mi a különbség használatban/user experienceben Qbit torrent és a transmission között?
Qbit-re is van távoli elérés?
Tudtok ajánlani vlmi step-by-step tutorialt ami működik és el is magyarázza?“When the flaws of the system are exposed, it is usually the irritant who gets cast out.”
sad_Vamp
lovi27 #13158 üzenetére
én nem ezt csináltam, hanem a transmissiont próbáltam véghez vinni, csak mivel ahhoz nem volt tut. azért a technodadlife Qbittorrent tutja alapján....
mindne cuccomon transmission gui van.... nnincs kedvem mindet Qbitra cserélni ha nem muszáj
A másik, hogy nekem 1 külön HDD-m van csak a torrentnek, azt adtam meg elérési útnak, az is meg vot oszva, sőt reseteltem a permissionokat evyrbody read/writte-ra hogy ne lehessen probléma.“When the flaws of the system are exposed, it is usually the irritant who gets cast out.”
sad_Vamp
lovi27 #13162 üzenetére
Jogos! Természetesen láttam hogy írtál, valamit, hogy valami "cheat-el" vissza lehet hozni a régi klienst.... de nem akartam azt használni, mert ha netán kihúzzák az ember alól a talajt akkor úgy is meg kell tanulni a dockert
Időközben sikerült felrakni, azt viszont lehet tudni hogy mi alapján hagyja az "incomplete" mappában a befejezett letöltéseket is? Esetleg van valami kerülő dockerben arra, hogy csak úgy ki a HDD gyökérbe rakjon mindent?
MÁS:
jól látom, hogy a web SSH-t eltüntették szintén? azt vissza lehet hozni valahogy? (nincs kedvem minden gépre itthon putty-t rakni)“When the flaws of the system are exposed, it is usually the irritant who gets cast out.”
sad_Vamp
Srácok, szeretnék egy NAGY mappát frissíteni az OMV-vel lehetőleg "manuálisan" (értsd: 1 gombnyomással), vagy pl. heti rendszerességgel. Milyen plugin-t ajánlanátok erre a célra? ( a nextcloud-ot ne pls)
sad_Vamp
lovi27 #13896 üzenetére
teljesen ismeretlenek ezek számomra, azért kérdeztem, tudom hogy nem állandóan syncronizálót szeretnék mert az lassít, meg problémákat okozhat (ha törlöm a file-t, vagy átnevezem, stb. a nextcloud pls szépen bele tud néha keveredni)
sad_Vamp
Oops, egy "apróságot" azt hiszem nem írtam le
A HDD amit backup-olni szeretnék az a PC-n van, nem az OMV-ben, és azt szeretném menteni heti/havi rendszerességgel az OMV-re.... Ahogy nnéztem az Rsync beállításait nem vagyok benne biztos, hogy az tud ilyet....“When the flaws of the system are exposed, it is usually the irritant who gets cast out.”
sad_Vamp
Srácok,
létezik az, hogy mivel az AMD nem annyira jól támogatott az OMV-nél, hogy emiatt gyilkolja a rendszer lemezeket?
Most USB-ről volt régebbi laptop HDD-n a rendszer, arra értem haza, hogy valamiféle journal file system hibák vannak. Ez előtt egy USB3-as FLASH-t gyilkolt le (mondjuk ezen annyira nem csodálkozom, mert várható volt igazából), még előtt egy rendes 3.5" es használt disket. Egyik HDD sem volt szuper-öreg, vagy SMART hibás.... ezért gyanakodom valami olyasmire mint a fent leírt kérdésben van.
Van másnak is onboard AMD lappal OMV-s NAS-a? Tapasztalatok?
Vélemények?“When the flaws of the system are exposed, it is usually the irritant who gets cast out.”
sad_Vamp
A flash vadi új volt....
a többi sem ősöreg, csak használt...
de mind1.... akkor elsőkörben talán HDD-t próbálok venni.“When the flaws of the system are exposed, it is usually the irritant who gets cast out.”
Figyelem!
Megjelent a Debian 10-re épülő OMV 5 stabil kiadása.
Új telepítésre ez a verzió ajánlott.
- Bontatlan - BATTLEFIELD 1 Collectors Edition - Játékszoftver nélkül
- Windows, Office licencek a legolcsóbban, egyenesen a Microsoft-tól - 2990 Ft-tól!
- Game Pass Ultimate előfizetések 1 - 25 hónapig azonnali kézbesítéssel a LEGOLCSÓBBAN!
- Védje meg számítógépét a vírusoktól!
- 10 Darab PC Játék (Bontatlanul!) Egyben 6990Ft.-ért Foxal!!!
