kjany
8GB Kingston (DT100)
SiSoftware Sandra:
512B Files Test
Read Performance : 16685 operation(s)/min (1112 kB/sec, 7x)
Write Performance : 1331 operation(s)/min (89 kB/sec, 0x)
Delete Performance : 1936 operation(s)/min
File Fragments : 1.0
Combined Index : 3195 operation(s)/min32kB Files Test
Read Performance : 6489 operation(s)/min (3461 kB/sec, 23x)
Write Performance : 151 operation(s)/min (81 kB/sec, 0x)
Delete Performance : 2388 operation(s)/min
Combined Index : 472 operation(s)/min256kB Files Test
Read Performance : 2860 operation(s)/min (12203 kB/sec, 81x)
Write Performance : 523 operation(s)/min (2231 kB/sec, 14x)
Delete Performance : 2018 operation(s)/min
Combined Index : 1200 operation(s)/min2MB Files Test
Read Performance : 475 operation(s)/min (16213 kB/sec, 108x)
Write Performance : 115 operation(s)/min (3925 kB/sec, 26x)
Delete Performance : 1617 operation(s)/min
Combined Index : 254 operation(s)/min64MB Files Test
Read Performance : 15 operation(s)/min (16384 kB/sec, 109x)
Write Performance : 8 operation(s)/min (8738 kB/sec, 58x)
Delete Performance : 448 operation(s)/min
Combined Index : 13 operation(s)/minEndurance Test Status
Operating System Disk Cache Used : No
Use Overlapped I/O : No
Test File Size : 32MB
Block Size : 512 byte(s)
File Fragments : 1Endurance Benchmark Breakdown
Repeated Sector ReWrite : 76 kB/s
Sequential Sector Write : 75 kB/s
Random Sector Write : 1 kB/sDrive
Total Size : 7.4GB
Free Space : 7.4GB, 100%
Cluster Size : 4kB[ Szerkesztve ]
kjany
1GB PQI (i810)
A jelenleg forgalomban lévő legkisebb méretü pendrive !SiSoftware Sandra:
512B Files Test
Read Performance : 9770 operation(s)/min (651 kB/sec, 4x)
Write Performance : 1689 operation(s)/min (113 kB/sec, 0x)
Delete Performance : 3022 operation(s)/min
Combined Index : 3675 operation(s)/min32kB Files Test
Read Performance : 4506 operation(s)/min (2403 kB/sec, 16x)
Write Performance : 1558 operation(s)/min (831 kB/sec, 5x)
Delete Performance : 2664 operation(s)/min
Combined Index : 2753 operation(s)/min256kB Files Test
Read Performance : 2050 operation(s)/min (8747 kB/sec, 58x)
Write Performance : 416 operation(s)/min (1775 kB/sec, 11x)
Delete Performance : 837 operation(s)/min
Combined Index : 883 operation(s)/min2MB Files Test
Read Performance : 304 operation(s)/min (10377 kB/sec, 69x)
Write Performance : 42 operation(s)/min (1434 kB/sec, 9x)
Delete Performance : 664 operation(s)/min
Combined Index : 108 operation(s)/min64MB Files Test
Read Performance : 10 operation(s)/min (10923 kB/sec, 72x)
Write Performance : 3 operation(s)/min (3277 kB/sec, 21x)
Delete Performance : 43 operation(s)/min
Combined Index : 7 operation(s)/minDrive
Total Size : 962MB
Free Space : 962MB, 100%
kjany
Az előző két tesztből jól látszik, hogy a TotalCommander gyorsabbnak (néha jelentősen gyorsabbnak) méri a drivokat, mint a SisofSandra.
Vajh' miért ? -
kjany
Elég gyengécske az a 3,66 irási seb. főleg egy sokat dicsért Corsairtól.
Kiváncsi vagyok, hogy ilyen indokkal tudod -e érvényesiteni a garanciát.
Majd értesits bennünket légy szives, itt a topicban.ui: le a kalappal az 1GB A-Data előtt, ritka jó példányt fogtál ki, ha stabilan 20MB/s -el ir,
ezt a teljesitményt csak a magasabb árfekvésü driveok (pld. Kingston DT400, vagy HyperX) tudják. -
kjany
Azonnal vidd vissza gariba !!!....1-2 hónapja bejött az országba egy sz'r széria a kék szinü dt101 -ből, a jelenség az amit leirtál max 2GB irási sebesség.
Most ha otthon lennék elrettentésül tudnék linkelni teszteket, mivel én is beleszaladtam egy nagyobb mennyiségbe, ami azonnal ment is vissza a forgalmazó nagykerbe, természetesen szó nélkül cserélték. -
kjany
Na mostmár itthon a saját gépem előtt
...szóval elrettentésképpen, a kisza25 fórumtárs álltal emlitett Kingston DT101 ATTO_teszt, és TC_teszt.Ha bárki hasonlót tapasztal, és legális forrásból származik a pendriveja, azonnal vissza gariba !!!
kjany
Igen egyes kiskerek képesek minden indokot kitalálni, csakhogy meneküljenek a garancia előll , ...ezt nem értem, hiszen tőllük a nagyker szó nélkül visszaveszi.
A DT110 egy csúnyácska nagy drive (bár ez nézőpont kérdése)
Hogy mondjak valami biztatót, eladtam már legalább 20db DT110 -et, egyaránt mindegyikről pozitiv visszajelzés jött, garancia =0, ez más Kingston darabokra is igaz.
A leglasubb darab is 8-10MB/s irást tudott stabilan.
....mindig gondban vagyok ezekkel a gigabájtokkal', meg megabájtokkal'
természetesen 2MB/s -ot akartam volt irni, 2GB sebességü pendrivera egy kicsit még várni kell -
kjany
Kösz az ujabb tesztet.
Ezzel az nyert bizonyosságot, hogy sajnos a mostani DT110 széria lassan a sor végére kerül Kingstonéknál (én is hasonlókat mértem néhány napja) [L:itt%20egy%20kiss%C3%A9%20vissz%C3%A1bbvettek:][link][/L]
...NTFS -re formázás után én is tapasztaltam, hogy lassulás történik (nem értem, hogy miért) -
kjany
....tudtam, hogy valahol van nekem is olyanom
8GB Kingston DT101Y_TC_write -
kjany
kjany
válasz picur220 #271 üzenetére
Nem igaz !
A Kingston csak a RAM -okra ad élettartam garit [link]
Pendriveokra "csak" 5 év dukál [link], de ennyi pénzért már bőven kapsz 16GB -ot is [link].
Élettartam gari pld. a PQI pendriveokra vonatkozik [link].
Bár egyes kiskerek előszeretettel kurtitják meg ezeket a garanciális időket.Sorry a reklámok miatt
kjany
válasz ShadowMan05 #277 üzenetére
Igen, úgy kell tegyenek.
Ha még gari időn belül vagy, és visszaviszed, valószínüleg megkapod helyette a ma forgalomban lévő legkisebb kapacitású darabot (1GB) .
És ami igazán főnyeremény, ha mindent szabályosan intéz a kereskedő, akkor a cseredarabra is köteles adni egy újabb x évre szóló garlevelet.
kjany
...de ha jól emléXem, amikor a 128MB -os pendriveok uralkodtak, nem igazán volt módi az 5év gari, de még a 2év sem
kjany
Azonnal vissza garanciába !
Ez nem "gyengusz", hanem egyszerüen hibás.
Már valahol kitárgyaltuk itt a fórumon.
Tavaly második félévben a Kingston kiadott jópár darab hibás chipes pendriveot, elsősorban DT101, és DTMS volt köztük.
Jómagam is belefutottam egy viszonylag nagyobb tételbe, de természetesen a nagyker azonnal cserélte. -
kjany
Szerzői jogdíj a pendrive-okra
- Milyen videókártyát?
- Projektor topic
- Poco F3 - a mindenes, de nem mindenkinek
- Autós kamerák
- Crypto Trade
- Hordozható M2 SSD 2TB // Új /// Számla + 1 Év Garancia
- Crucial T500 PRO 2 TB M.2 NVME PCI-E 4.0 x4 - Új, Bontatlan, Hűtőbordás - 7400-7000 MBs - Eladó!
- Kingston A2000 500GB
- Crucial P3 500GB NVMe SSD - új, bontatlan, garanciával
- Crucial T705 PRO 4 TB M.2 NVME PCI-E 5.0 x4 - Új, Bontatlan - 14100-12600 MBs - Eladó!
